10-Segment Routing Command Reference
HomeSupportRoutersCR16000-M SeriesReference GuidesCommand ReferencesH3C CR16000-M Routers Command Reference-R838x-6W10010-Segment Routing Command Reference
07-SRv6 network slicing commands
07-SRv6 network slicing commands 184.73 KB
description
Use description to specify the description for an NSI.
No description is specified for an NSI.
NSI view
text: Specifies the description for the NSI, a case-sensitive string of 1 to 64 characters.
# Specify the description as specific-instance for NSI 1.
[Sysname] network-slice
[Sysname-network-slice] instance 1
[Sysname-network-slice-instance-1] description specific-instance
display network-slice binding-list
Use display network-slice binding-list to display the associations between NSIs and interfaces.
display network-slice binding-list [ slice-id slice-instance-id ] [ interface interface-type interface-number ]
slice-id slice-instance-id: Specifies an NSI by its ID in the range of 0 to 4294967295. If you do not specify an NSI, this command displays associated interfaces for all NSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays NSI information for all interfaces.
# Display interfaces associated with NSI 1.
<Sysname> display network-slice binding-list slice-id 1
   Slice ID  : 1
   Interface :
     Ten-GigabitEthernet3/0/1.2
     Ten-GigabitEthernet3/0/2
     Ten-GigabitEthernet3/0/3
     Ten-GigabitEthernet3/0/4.1
Slice ID
ID of the NSI.
Interface associated with the NSI.
slice-id flex-channel
display network-slice configuration
Use display network-slice configuration to display network slicing configuration.
# Display network slicing configuration.
<Sysname> display network-slice configuration
Protocol number        : 160
Statistics             : Enabled
Statistics interval(s) : 100
MaxSliceNum            : 1000
MaxInterfaceSliceNum   : 200
Protocol number
Protocol number of the IPv6 hop-by-hop extension header.
Statistics
Enabling state of network slice packet statistics:
·     Enabled
·     Disabled
Statistics interval
Intervals (in seconds) at which the device collects network slice packet statistics.
MaxSliceNum
Maximum number of NSIs that can be configured in the system.
Maximum number of network slice channels that can be configured on the interface.
display network-slice statistics
Use display network-slice statistics to display network slice packet statistics.
display network-slice statistics [ slice-id slice-instance-id ] [ interface interface-type interface-number ] [ verbose ]
slice-id slice-instance-id: Specifies an NSI by its ID in the range of 0 to 4294967295. If you do not specify an NSI, this command displays network slice packet statistics for all NSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays network slice packet statistics for all interfaces.
verbose: Displays detailed network slice packet statistics. If you do not specify this keyword, this command displays brief network slice packet statistics.
# Display brief network slice packet statistics for NSI 200.
<Sysname> display network-slice statistics slice-id 200 interface ten-gigabitethernet 3/0/1
Network slice statistics
 Interface  : Ten-GigabitEthernet3/0/1
 Slice ID   : 200
 [total]
  Pass:               42,430,945 packets,                 7,298,122,540 bytes
  Discard:            2,368,695,114 packets,              407,415,559,608 bytes
  Last 50 seconds pass rate:
                      72,498 pps,                         99,757,056 bps
  Last 50 seconds discard rate:
                      4,048,135 pps,                      5,570,233,752 bps
  Last 5 seconds pass rate:
                      7298 pps,                           99,757,056 bps
  Last 5 seconds discard rate:
                      4148,135 pps,                       5,570,233,752 bps
# Display detailed network slice packet statistics for NSI 200.
<Sysname> display network-slice statistics slice-id 200 interface ten-gigabitethernet 3/0/1 verbose
 SliceID   : 200
 [be]
  Pass:               0 packets,                          0 bytes
  Discard:            0 packets,                          0 bytes
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [af1]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [af2]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [af3]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [af4]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [ef]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [cs6]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [cs7]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
 [total]
                      0 pps,                              0 bps
                      0 pps,                              0 bps
Network slice packet statistics.
Interface with network slicing enabled.
SliceID
ID of the NSI.
service-class
Service class:
·     be
·     af1
·     af2
·     af3
·     af4
·     ef
·     cs6
·     cs7
Slot ID
Slot ID of a member interface of a Layer 3 aggregate interface. This field is displayed only when the specified interface is a Layer 3 aggregate interface.
Total
Summarized packet statistics for all service classes.
Pass
Number of packets and bytes that have passed through.
Discard
Number of packets and bytes discarded.
Last m seconds pass rate
Number of packets and bytes that have passed through per second during the last m seconds. Value m equals 10 times the collection interval. You can use the statistics interval command to set the collection interval.
Last m seconds discard rate
Number of packets and bytes discarded per second during the last m seconds. Value m equals 10 times the collection interval. You can use the statistics interval command to set the collection interval.
Last n seconds pass rate
Number of packets and bytes that have passed through per second during the last n seconds. Value n equals the collection interval. You can use the statistics interval command to set the collection interval.
Last n seconds discard rate
Number of packets and bytes discarded per second during the last n seconds. Value n equals the collection interval. You can use the statistics interval command to set the collection interval.
reset network-slice statistics
statistics interval
instance (network slice view)
Use instance to create an NSI and enter its view or enter the view of an existing NSI.
Use undo instance to delete the specified NSI.
instance slice-instance-id
undo instance slice-instance-id
No NSIs exist.
Network slice view
slice-instance-id: Specifies an NSI ID in the range of 0 to 4294967295.
The maximum number of NSIs supported by the device is 6000. You can use the display network-slice configuration command to view the maximum number of NSIs supported by the device.
If an NSI is associated with an interface through the slice-id flex-channel command, use the undo slice-id flex-channel command to cancel the association before you delete the NSI.
# Create NSI 1 and enter its view.
network-slice (system view)
Use network-slice to enable network slicing and enter network slice view.
Use undo network-slice to disable network slicing.
network-slice
undo network-slice
Network slicing is disabled.
You can configure network slicing settings in network slice view.
# Enable network slicing and enter network slice view.
network-slice (SRv6 TE policy path preference view)
Use network-slice to specify an NSI ID for an SRv6 TE policy candidate path.
Use undo network-slice to restore the default.
network-slice slice-instance-id
undo network-slice
No NSI ID is specified for an SRv6 TE policy candidate path.
You can specify an NSI ID for an SRv6 TE policy candidate path. If the path is selected, the device encapsulates an IPv6 hop-by-hop extension header that contains the NSI ID into packets forwarded through the path. The packets are called network slice packets.
If an output interface on the path contains a network slice channel that matches the NSI ID of a network slice packet, the packet is forwarded through the channel.
If no output interface on the path contains a network slice channel that matches the NSI ID of a network slice packet, the device processes the packet depending on scenarios.
·     Typically, the value for the first bit (D flag) in the Flags field of the IPv6 hop-by-hop extension header is 0. The device ignores the NSI ID in the network slice packet and forwards the packet out of the output interface as a common IPv6 packet.
·     In some special scenarios, for example, BFD/SBFD or ping/tracert scenarios in an SRv6 network, the value for the first bit (D flag) in the Flags field of the IPv6 hop-by-hop extension header can be set to 1. In this case, the device cannot ignore the NSI ID in the network slice packet. The packet is dropped.
# Specify NSI ID 10 for candidate path 20 of SRv6 TE policy a1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 20
[Sysname-srv6-te-policy-a1-path-pref20] network-slice 10
network-slice enable
Use network-slice enable to enable network slicing for an interface and enter network slice view of the interface.
Use undo network-slice enable to disable network slicing for an interface.
Network slicing is disabled for an interface.
Interface view
A Layer 3 output interface with network slicing enabled forwards packets carrying an NSI ID through a network slice channel (matching the NSI ID) on the interface.
In the current software version, only Layer 3 Ethernet interfaces, Layer 3 Ethernet subinterfaces, Layer 3 aggregate interfaces, Layer 3 aggregate subinterfaces, and FlexE interfaces support this feature.
# Enable network slicing for Ten-GigabitEthernet 3/0/1 and enter network slice view of the interface.
[Sysname] interface ten-gigabitethernet 3/0/1
[Sysname-Ten-GigabitEthernet3/0/1] network-slice enable
[Sysname-Ten-GigabitEthernet3/0/1-network-slice]
protocol-number
Use protocol-number to specify the protocol number for IPv6 hop-by-hop extension headers.
Use undo protocol-number to restore the default.
protocol-number number
The protocol number of IPv6 hop-by-hop extension headers is 0.
Network slice view
number: Specifies a number. The value takes 0 or is in the range of 160 to 252.
With SRv6 network slicing enabled, an SRv6 source node adds an IPv6 hop-by-hop extension header to a packet. The IPv6 hop-by-hop extension header contains an NSI ID. By default, the protocol number in an IPv6 hop-by-hop extension header is 0, indicating that the Next Header field of the preceding IPv6 header is 0. Upon receiving a packet, a network slicing incapable device cannot parse the IPv6 hop-by-hop extension header with protocol number 0. As a result, the packet processing becomes slow or the packet is dropped. To avoid such issues, you can use this feature to set the protocol number to a value other than 0. After that, the network slicing incapable device ignores the IPv6 hop-by-hop extension header with protocol number 0, and forwards the packet based on its IPv6 basic header. The protocol number of IPv6 hop-by-hop extension headers varies by vendor. You can edit the protocol number for interoperability between devices from different vendors.
# Specify the protocol number as 160 for IPv6 hop-by-hop extension headers.
[Sysname-network-slice] protocol-number 160
Use reset network-slice statistics to clear network slice packet statistics.
reset network-slice statistics [ slice-id slice-instance-id ] [ interface interface-type interface-number ]
slice-id slice-instance-id: Specifies an NSI by its ID in the range of 0 to 4294967295. If you do not specify an NSI, this command clears network slice packet statistics for all NSIs.
interface interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command clears network slice packet statistics for all interfaces.
# Clear network slice packet statistics for NSI 200.
<Sysname> reset network-slice statistics slice-id 200
Use slice-id flex-channel to create a network slice channel for an interface, and specify the bandwidth for the network slice channel.
Use undo slice-id flex-channel to remove a network slice channel from an interface.
slice-id slice-instance-id flex-channel flex-channel-value
undo slice-id slice-instance-id flex-channel
No network slice channels are configured on an interface.
Network slice view of the interface
slice-instance-id: Specifies an NSI by its ID associated with the network slice channel, in the range of 0 to 4294967295.
flex-channel-value: Specifies the bandwidth for the network slice channel, in the range of 1 to 4294967295, in Mbps.
After you create network slice channels on the interface, the device assigns an independent scheduling queue to each network slice channel identified by an NIS ID. Packets matching an NSI ID will be forwarded through the associated channel. The protocol number of the IPv6 hop-by-hop extension headers of packets is the protocol number specified for the NSI ID associated with the channel.
The NSI specified in this command must already exist.
You can configure multiple network slice channels on an interface.
You can execute this command on an interface for multiple times. The most recent configuration takes effect.
# Enable network slicing for Ten-GigabitEthernet 3/0/1, create a network slice channel associated with NSI 10, and set the bandwidth to 50 Mbps for the channel.
[Sysname-Ten-GigabitEthernet3/0/1-network-slice] slice-id 10 flex-channel 50
statistics enable
Use statistics enable to enable network slice packet statistics.
Use undo statistics enable to disable network slice packet statistics.
statistics enable
Network slice packet statistics is disabled.
Network slice view
With network slice packet statistics enabled, you can use the display network-slice statistics command to display statistics of packets forwarded through the specified network slice.
# Enable network slice packet statistics.
[Sysname-network-slice] statistics enable
statistics interval
Use statistics interval to set the interval for collecting network slice packet statistics.
Use undo statistics interval to restore the default.
statistics interval time
The device collects network slice packet statistics at 30-second intervals.
Network slice view
time: Specifies an interval in the range of 5 to 65535 seconds.
# Set the interval to 100 seconds for collecting network slice packet statistics.
[Sysname-network-slice] statistics interval 100
statistics enable
  • Become a Partner
  • Partner Resources
