| 01-Installation Guide | 4.07 MB |
Examining the installation environment
Examining the installation site
Checking power distribution or power supply environment
Installing the switch in a 19-inch rack
Attaching the mounting brackets to the switch
Mounting the switch on a workbench
Grounding the switch with a grounding strip
Grounding the switch with a grounding conductor buried in the earth ground
Grounding the switch by using the PE wire of the AC power cord
Verifying the connection after grounding the switch
Installing and removing a power supply
Connecting the AC power cord for the fixed AC power supply
Connecting the DC power cord for the fixed DC power supply
Connecting the power cord for a CA-70A12 or PSR75-12A power supply
Connecting the DC power cord for a PSR150-D1 power supply
Accessing the switch for the first time
Managing the switch from the GUI
Changing the default login password
Managing the switch from the CLI
Connecting the switch to a configuration terminal
Connecting a micro USB console cable
Planning IRF fabric size and the installation site
Identifying the master switch and planning IRF member IDs
Planning IRF topology and connections
Identifying IRF physical ports on the member switches
Configuring basic IRF settings
Connecting the IRF physical ports
Verifying the IRF fabric setup
Maintenance and troubleshooting
Input failure on an AC-powered switch
Input failure on a DC-powered switch
Input failure on a DC and AC-powered switch
Removable power supply failure
Preparing for installation
This document provides an installation guide for the following switch series:
· S5560S-SI switch series
· S5130S-SI switch series
· S5130S-LI switch series
· S5120V2-SI switch series
· S5120V2-LI switch series
· S5110V2-SI switch series
· S5000V3-EI switch series
· S5000V5-EI switch series
· S5500V3-SI switch series
· S3100V3-SI switch series
Table 1 describes the switch models that each switch series includes.
Table 1 Switch series and models
Switch series |
Model |
Product code (PID) |
S5560S-SI switch series |
Non-PoE models |
S5560S-28P-SI |
LS-5560S-28P-SI LS-5560S-28P-SI-GL |
S5560S-52P-SI |
LS-5560S-52P-SI LS-5560S-52P-SI-GL |
S5560S-28S-SI |
LS-5560S-28S-SI LS-5560S-28S-SI-GL |
S5560S-52S-SI |
LS-5560S-52S-SI LS-5560S-52S-SI-GL |
S5560S-28F-SI |
LS-5560S-28F-SI |
S5560S-28DP-SI |
LS-5560S-28DP-SI |
S5130S-SI switch series |
Non-PoE models |
S5130S-28S-SI |
LS-5130S-28S-SI |
S5130S-28S-SI-MM |
LS-5130S-28S-SI-MM |
S5130S-28S-SI-SM |
LS-5130S-28S-SI-SM |
S5130S-52S-SI |
LS-5130S-52S-SI |
S5130S-28F-SI |
LS-5130S-28F-SI |
S5130S-LI switch series |
Non-PoE models |
S5130S-28S-LI |
LS-5130S-28S-LI LS-5130S-28S-LI-GL |
S5130S-28S-LI-MM |
LS-5130S-28S-LI-MM |
S5130S-28S-LI-SM |
LS-5130S-28S-LI-SM |
S5130S-52S-LI |
LS-5130S-52S-LI LS-5130S-52S-LI-GL |
PoE models |
S5130S-28S-PWR-LI |
LS-5130S-28S-PWR-LI |
S5130S-28S-HPWR-LI |
LS-5130S-28S-HPWR-LI |
S5130S-52S-PWR-LI |
LS-5130S-52S-PWR-LI |
S5120V2-SI switch series |
Non-PoE models |
S5120V2-10P-SI |
LS-5120V2-10P-SI |
S5120V2-28P-SI |
LS-5120V2-28P-SI |
S5120V2-52P-SI |
LS-5120V2-52P-SI |
S5120V2-LI switch series |
Non-PoE models |
S5120V2-10P-LI |
LS-5120V2-10P-LI LS-5120V2-10P-LI-GL |
S5120V2-20P-LI |
LS-5120V2-20P-LI LS-5120V2-20P-LI-GL |
S5120V2-28P-LI |
LS-5120V2-28P-LI LS-5120V2-28P-LI-GL |
S5120V2-52P-LI |
LS-5120V2-52P-LI LS-5120V2-52P-LI-GL |
PoE models |
S5120V2-10P-PWR-LI |
LS-5120V2-10P-PWR-LI LS-5120V2-10P-PWR-LI-GL |
S5120V2-28P-PWR-LI |
LS-5120V2-28P-PWR-LI LS-5120V2-28P-PWR-LI-GL |
S5120V2-28P-HPWR-LI |
LS-5120V2-28P-HPWR-LI LS-5120V2-28P-HPWR-LI-GL |
S5120V2-52P-PWR-LI |
LS-5120V2-52P-PWR-LI LS-5120V2-52P-PWR-LI-GL |
S5120V2-12TP-HPWR-LI |
LS-5120V2-12TP-HPWR-LI |
S5110V2-SI switch series |
Non-PoE models |
S5110V2-28P-SI |
LS-5110V2-28P-SI |
S5110V2-52P-SI |
LS-5110V2-52P-SI |
S5000V3-EI switch series |
Non-PoE models |
S5016PV3-EI |
LS-5016PV3-EI LS-5016PV3-EI-GL |
S5024PV3-EI |
LS-5024PV3-EI LS-5024PV3-EI-GL |
S5048PV3-EI |
LS-5048PV3-EI LS-5048PV3-EI-GL |
S5024FV3-EI |
LS-5024FV3-EI LS-5024FV3-EI-GL |
PoE models |
S5024PV3-EI-PWR |
LS-5024PV3-EI-PWR LS-5024PV3-EI-PWR-GL |
S5024PV3-EI-HPWR |
LS-5024PV3-EI-HPWR LS-5024PV3-EI-HPWR-GL |
S5048PV3-EI-PWR |
LS-5048PV3-EI-PWR LS-5048PV3-EI-PWR-GL |
S5000V5-EI switch series |
Non-PoE models |
S5008PV5-EI |
LS-5008PV5-EI LS-5008PV5-EI-H1 |
S5008PV5-EI-S |
LS-5008PV5-EI-S-GL |
S5016PV5-EI |
LS-5016PV5-EI |
S5016PV5-EI-S |
LS-5016PV5-EI-S-GL |
S5024PV5-EI |
LS-5024PV5-EI LS-5024PV5-EI-GL |
S5024PV5-EI-S |
LS-5024PV5-EI-S-GL |
S5048PV5-EI |
LS-5048PV5-EI LS-5048PV5-EI-GL |
PoE models |
S5008PV5-EI-HPWR |
LS-5008PV5-EI-HPWR LS-5008PV5-EI-HPWR-H1 LS-5008PV5-EI-HPWR-GL |
S5008PV5-EI-HPWR-S |
LS-5008PV5-EI-HPWR-S-GL |
S5016PV5-EI-PWR-S |
LS-5016PV5-EI-PWR-S-GL |
S5024PV5-EI-PWR |
LS-5024PV5-EI-PWR |
S5024PV5-EI-PWR-S |
LS-5024PV5-EI-PWR-S-GL |
S5024PV5-EI-HPWR |
LS-5024PV5-EI-HPWR LS-5024PV5-EI-HPWR-GL |
S5048PV5-EI-PWR |
LS-5048PV5-EI-PWR LS-5048PV5-EI-PWR-GL |
S5500V3-SI switch series |
Non-PoE models |
S5500V3-24P-SI |
LS-5500V3-24P-SI |
S5500V3-48P-SI |
LS-5500V3-48P-SI |
S5500V3-28S-SI |
LS-5500V3-28S-SI |
S5500V3-28PS-SI |
LS-5500V3-28PS-SI |
S5500V3-54S-SI |
LS-5500V3-54S-SI |
S5500V3-54PS-SI |
LS-5500V3-54PS-SI |
S5500V3-36F-SI |
LS-5500V3-36F-SI |
S5500V3-28S-DP-SI |
LS-5500V3-28S-DP-SI |
S5500V3-54S-DP-SI |
LS-5500V3-54S-DP-SI |
S5500V3-36F-DP-SI |
LS-5500V3-36F-DP-SI |
S5500V3-54F-DP-SI |
LS-5500V3-54F-DP-SI |
S3100V3-SI switch series |
Non-PoE models |
S3100V3-10TP-SI |
LS-3100V3-10TP-SI LS-3100V3-10TP-SI-H1 |
S3100V3-18TP-SI |
LS-3100V3-18TP-SI LS-3100V3-18TP-SI-H1 |
S3100V3-28TP-SI |
LS-3100V3-28TP-SI LS-3100V3-28TP-SI-H1 |
S3100V3-52TP-SI |
LS-3100V3-52TP-SI LS-3100V3-52TP-SI-H1 |
PoE models |
S3100V3-10TP-PWR-SI |
LS-3100V3-10TP-PWR-SI LS-3100V3-10TP-PWR-SI-H1 |
S3100V3-20TP-PWR-SI |
LS-3100V3-20TP-PWR-SI LS-3100V3-20TP-PWR-SI-H1 |
S3100V3-28TP-PWR-SI |
LS-3100V3-28TP-PWR-SI LS-3100V3-28TP-PWR-SI-H1 |
NOTE: Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel. |
Safety recommendations
To avoid equipment damage or bodily injury, read the following safety recommendations before installation. Note that the recommendations do not cover every possible hazardous condition.
· Before cleaning the switch, remove all power cords from the switch. Do not clean the switch with wet cloth or liquid.
· Do not place the switch near water or in a damp environment. Prevent water or moisture from entering the switch chassis.
· Do not place the switch on an unstable case or desk. The switch might be severely damaged in case of a fall.
· Ensure good ventilation at the installation site and keep the air inlet and outlet vents of the switch free of obstruction.
· Make sure the operating voltage is as required.
· To avoid electrical shocks, do not open the chassis while the switch is operating or when the switch is just powered off.
· Always wear an ESD wrist strap when installing the switch. Make sure the strap makes good skin contact and is reliably grounded.
To ensure correct operation of your switch, make sure the installation environment meets the requirements listed in Table 2.
Table 2 Checking list for the installation environment
Item |
Requirements |
Ventilation and heat dissipation |
To ensure correct operation of your device, make sure the installation environment is adequately ventilated to prevent the switch from overheating. · Ensure a minimum clearance of 10 cm (3.94 in) around the chassis. · Do not install the device near a heat source, for example, a stove or heater. · Ensure air ventilation in the installation environment. · Do not block the ventilation holes in the device or power adapter. |
Anti-moisture |
Water or moisture might damage the circuits of the device. · Do not place the device near water or in a damp environment. · Install the switch in a clean, dry, and ventilated place where temperature is controlled in a stable range. · Make sure the installation environment is free from water leakage or condensation. If required, install a dehumidification device (such as an air conditioner with a dehumidification function or a dedicated dehumidifier). · Do not operate the device under or near the water source, such as the wash basin, laundry room, or areas with high humidity. · Do not touch the device with wet hands. |
Temperature/humidity |
For correct operation and long service life of your switch, maintain the temperature and humidity in the equipment room at acceptable ranges. · Lasting high relative humidity can cause poor insulation, electricity leakage, mechanical property change of materials, and metal corrosion. · Lasting low relative humidity can cause washer contraction and ESD and cause issues including loose mounting screws and circuit failure. · High temperature can accelerate the aging of insulation materials and significantly lower the reliability and lifespan of the switch. For the temperature and humidity requirements of the switch, see hardware information and specifications for the switch series |
Lightning protection |
Ground the switch correctly and verify the grounding. For more information, see "Grounding the switch." · If you ground the switch by using a grounding strip, make sure the grounding resistance of the grounding strip in the equipment room is less than 1W. · If you ground the switch by using a grounding conductor buried in the earth ground, make sure the grounding resistance of the grounding conductor in the ground is less than 10W. · Route the signal cables along indoor walls, bury the cables in the earth ground, or thread the cables through steel tubes. Install a signal lightning arrester with a nominal discharge current for a corresponding network interface. · Keep the signal cables far from power cords and lightning rod down conductors. · As a best practice, route power cords indoors. If an AC power cord is routed from outdoors, connect the AC power cord first to a power lightning arrester before leading it to the AC power port on the switch. Make sure the power lightning arrester has a nominal discharge current and the total length of the power cord from the power lighting arrester to the power port on the switch is less than 5 m (16.40 ft). · Ground the switch, rack, independent power supplies, and lightning arresters separately. · You must ground optical fibers with reinforcing metal stiffener from outdoors on an optical distribution frame (ODF) or fiber splice enclosure. |
Cable routing |
Do not run an Ethernet cable and power cord in parallel. · Route different types of cables separately. · Keep power cords a minimum of 5 cm (1.97 in) away from other cables. |
ESD prevention |
· Ground the switch correctly. · To avoid ESD damage to the device or components, always wear an ESD wrist strap when you install or remove the device or components. · Make sure the wrist strap has good skin contact and is reliably grounded. |
Cleanliness |
· For more information, see "Cleanliness." |
Corrosive gas prevention |
The installation site must be free from corrosive gases such as acid gases and alkaline gases. For more information, see "Corrosive gas limit." |
EMI |
· If AC power is used, use a single-phase three-wire power receptacle with protection earth (PE) to filter interference from the power grid. · Keep the device far away from radio transmitting stations, radar stations, and high-frequency devices. · Use electromagnetic shielding, for example, shielded interface cables, when necessary. |
Cleanliness
Dust buildup on the chassis might cause electrostatic adsorption and dust corrosion, resulting in poor contact of metal connectors and contact points. This might shorten the device's lifetime and even cause device failure in the worst case. Table 3 describes the switch requirement for cleanliness.
Table 3 Switch requirement for cleanliness
Substance |
Particle diameter |
Concentration limit |
Dust particles |
≥ 0.5 µm |
≤ 1.8 × 107 particles/m3 |
To maintain cleanliness in the equipment room, follow these guidelines:
· Keep the equipment room away from pollution sources. Do not smoke, eat, or drink in the equipment room.
· Use double-layer glass in windows and seal doors and windows with dust-proof rubber strips. Use screen doors and window screens for doors and windows open to the outside and make sure the external windows are air tight.
· Use dustproof materials for floors, walls, and ceilings and use wallpaper or matt paint that does not produce powders.
· Clean the equipment room regularly and clean the air filters of the rack each month.
· Wear ESD clothing and shoe covers before entering the equipment room, keep the ESD clothing and shoe covers clean, and change them frequently.
Corrosive gas limit
Corrosive gases can accelerate corrosion and aging of metal components. Make sure the corrosive gases do not exceed the concentration limits as shown in Table 4.
Table 4 Corrosive gas concentration limits
Gas |
Average concentration (mg/m3) |
Maximum concentration (mg/m3) |
SO2 |
0.3 |
1.0 |
H2S |
0.1 |
0.5 |
Cl2 |
0.1 |
0.3 |
HCI |
0.1 |
0.5 |
HF |
0.01 |
0.03 |
NH3 |
1.0 |
3.0 |
O3 |
0.05 |
0.1 |
NOX |
0.5 |
1.0 |
CAUTION: As a best practice, control the corrosive gas concentrations in the equipment room at their average values. Make sure the corrosive gas concentrations do not exceed 30 minutes per day at their maximum values. |
To control corrosive gases, use the following guidelines:
· As a best practice, do not build the equipment room in a place with a high concentration of corrosive gases.
· Make sure the equipment room is not connected to sewer, vertical shaft, or septic tank pipelines and keep it far away from these pipelines. The air inlet of the equipment room must be away from such pollution sources.
· Use environmentally friendly materials to decorate the equipment room. Avoid using organic materials that contains harmful gases, such as sulfur or chlorine-containing insulation cottons, rubber mats, sound-proof cottons, and avoid using plasterboards with high sulfur concentration.
· Place fuel (diesel or gasoline) engines separately. Do not place them in the same equipment room with the device. Make sure the exhausted air of the engines will not flow into the equipment room or towards the air inlet of the air conditioners.
· Place batteries separately. Do not place them in the same room with the device.
· Employ a professional company to monitor and control corrosive gases in the equipment room regularly.
Before you install the switch, verify that the installation site meets the installation requirements. The switch can operate correctly in an A1 or A2 installation site. Availability issues might occur if you install the switch in an A3, B1, B2, or C installation site.
Category |
Definition |
Example |
A1: indoor controlled environment |
· Indoor environments where temperature and humidity are controlled. · Completely enclosed or shielded indoor environments. |
Central equipment rooms, IDC equipment rooms, mobile cabins with air conditioners, outdoor air conditioner cabinets, and heat exchanger cabinets. |
A2: indoor partially controlled environment |
· Indoor environments where temperature and humidity are partially controlled. · Incompletely enclosed or shielded places. · Places far from pollution sources. |
Simple equipment rooms, ordinary houses, garages, corridors, and direct ventilation cabinets far from pollution sources, houses without direct exposure to sunlight or rain, railway station platforms, and stadiums. |
A3: indoor uncontrolled environment |
· Indoor environments where temperature and humidity are uncontrolled. · Incompletely enclosed or shielded places. · Places near pollution sources. |
Simple equipment rooms, ordinary houses, garages, corridors, and direct ventilation cabinets near pollution sources, houses without direct exposure to sunlight or rain, railway station platforms, stadiums, uncleaned rooms after decoration, and rooms under decoration. |
B1: outdoor general environment |
· Unshielded places where the temperature and humidity are not controlled. · Places far from pollution sources. |
Completely exposed outdoor places far from pollution sources. |
B2: harsh environment |
· Unshielded places where the temperature and humidity are not controlled. · Sea environments or outdoor land environments near pollution sources. |
Islands, ships, and completely exposed outdoor places near pollution sources. |
C: special environments |
Special application environments |
Buried, underwater, or undersea environments and manholes. |
Table 6 Pollution sources
Category |
Radius range |
Saline water areas such as oceans and saline lakes |
≤ 3.7 km (2.30 miles) |
Serious pollution sources such as metallurgic plants, coal mines, and heat and power plants |
≤ 3 km (1.86 miles) |
Medium pollution sources such as chemical factories, rubber plants, and electroplating factories |
≤ 2 km (1.24 miles) |
Light pollution sources, such as food factories, tanneries, and heating boilers |
≤ 1 km (0.62 miles) |
Table 7 Requirements for power distribution or power supply environment
Item |
Requirements |
Preparation |
The power supply must be available before you install the switch. |
Voltage |
The voltage provided to the switch must be within the operating voltage range. For the operating voltage range, see S5130S-EI Switch Series Hardware Information and Specifications. |
Power receptacle and cables |
· If the external power supply system provides an AC power outlet, use a country-specific AC power cord. Make sure the PE wire of the AC power supply is grounded reliably. · If the external power supply system provides a DC distribution box, prepare DC power cords yourself. · Do not use the power cord provided with the switch on other devices. |
Laser safety
WARNING! Disconnected optical fibers or transceiver modules might emit invisible laser light. Do not stare into beams or view directly with optical instruments when the switch is operating. |
The switch is Class 1 laser device.
Installation tools
No installation tools are provided with the switch. Prepare them yourself as required.
· Flat-blade screwdriver
· Phillips screwdriver
· ESD wrist strap
· Needle-nose pliers
· Diagonal pliers
· Crimping pliers
· Marker
CAUTION: Keep the tamper-proof seal on a mounting screw on the chassis cover intact, and if you want to open the chassis, contact H3C for permission. Otherwise, H3C shall not be liable for any consequence. |
Figure 1 Hardware installation flow
Mounting brackets
Table 8 describes the mounting brackets applicable to the switch.
Table 8 Mounting brackets applicable to the switch
Switch model |
Applicable mounting brackets |
Views |
S5560S-28P-SI S5560S-52P-SI S5560S-28S-SI S5560S-52S-SI S5130S-28S-SI S5130S-28S-SI-MM S5130S-28S-SI-SM S5130S-52S-SI S5130S-28S-LI S5130S-28S-LI-MM S5130S-28S-LI-SM S5130S-52S-LI S5130S-28S-PWR-LI S5130S-28S-HPWR-LI S5130S-52S-PWR-LI S5120V2-28P-SI S5120V2-52P-SI S5120V2-28P-LI S5120V2-52P-LI S5120V2-28P-PWR-LI S5120V2-28P-HPWR-LI S5120V2-52P-PWR-LI S5110V2-28P-SI S5110V2-52P-SI S5024PV3-EI S5048PV3-EI S5024PV3-EI-PWR S5024PV3-EI-HPWR S5048PV3-EI-PWR S5024PV5-EI S5048PV5-EI S5024PV5-EI-PWR S5024PV5-EI-HPWR S5048PV5-EI-PWR S5024FV3-EI S5500V3-24P-SI S5500V3-48P-SI S3100V3-28TP-SI S3100V3-52TP-SI S3100V3-28TP-PWR-SI |
Mounting brackets A (provided) |
See A in Figure 2. |
S5560S-28F-SI S5560S-28DP-SI S5500V3-28S-SI S5500V3-28PS-SI S5500V3-54S-SI S5500V3-54PS-SI S5500V3-36F-SI S5500V3-28S-DP-SI S5500V3-54S-DP-SI S5500V3-36F-DP-SI S5500V3-54F-DP-SI S5130S-28F-SI |
Mounting brackets B (provided) |
See B in Figure 2. |
S5120V2-20P-LI S5120V2-10P-PWR-LI S5120V2-12TP-HPWR-LI S5008PV5-EI-HPWR S5008PV5-EI-HPWR-S S5016PV3-EI S5016PV5-EI S5016PV5-EI-S S3100V3-10TP-PWR-SI S3100V3-20TP-PWR-SI S5024PV5-EI-S S5024PV5-EI-PWR-S S5016PV5-EI-PWR-S |
Mounting brackets C with product code SOHO-SWITCH-FL-02 (optional) |
See C in Figure 2. |
S5008PV5-EI S5008PV5-EI-S S5120V2-10P-SI S5120V2-10P-LI S3100V3-10TP-SI S3100V3-18TP-SI |
Mounting brackets D with product code SOHO-SWITCH-FL-01 (optional) |
See D in Figure 2. |
(1) Screw hole for attaching the bracket to the switch |
(2 ) Screw hole for attaching the bracket to the rack post |
1. Determine the installation position for the mounting brackets.
¡ The S5560S-28F-SI, S5560S-28DP-SI, S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, S5500V3-54F-DP-SI, and S5130S-28F-SI switches each provide two mounting positions on the two sides for mounting brackets: one front mounting position (near the network ports) and one rear mounting position (near the power supplies).
¡ The other switch models provide only one mounting position (near the network ports) for the mounting brackets.
2. Align one mounting bracket with the screw holes at the mounting position. Use M4 screws to attach the mounting bracket to the chassis. See Figure 3 for installing mounting bracket A, Figure 4 and Figure 5 for installing mounting bracket B, Figure 6 for installing mounting bracket C, and Figure 7 for installing mounting bracket D.
M4 screws are provided only for switches shipped with mounting brackets.
An optional mounting bracket kit contains M4 screws.
3. Repeat step 2 to attach the other mounting bracket to the chassis.
Figure 3 Attaching mounting bracket A (S5120V2-28P-HPWR-LI switch)
Figure 4 Attaching mounting bracket B (mounting position near the port side, S5560S-28F-SI switch)
Figure 6 Attaching mounting bracket C (S5120V2-20P-LI switch)
Figure 7 Attaching mounting bracket D (S5120V2-10P-LI switch)
Rack-mounting the switch
This task requires two people. To mount the switch in the rack:
1. Wear an ESD wrist strap and make sure it makes good skin contact and is reliably grounded.
2. Verify that the mounting brackets have been securely attached to the switch chassis.
3. Install cage nuts in the mounting holes in the rack posts.
No cage nuts are provided with the switch. Prepare them yourself.
4. One person holds the switch chassis and aligns the mounting brackets with the mounting holes in the rack posts, and the other person attaches the mounting brackets to the rack with M6 screws.
If the switch is not shipped with M6 screws, prepare them yourself.
5. Verify that the switch chassis is horizontal and secure.
Figure 8 Mounting the switch in a rack (S5120V2-28P-HPWR-LI switch)
Figure 9 Mounting the switch in a rack (mounting brackets installed near the port side, S5560S-28F-SI switch)
Figure 10 Mounting the switch in a rack (mounting brackets installed near the power supply side, S5560S-28F-SI switch)
Figure 11 Mounting the switch in a rack (S5120V2-10P-PWR-LI switch)
Figure 12 Mounting the switch in a rack (S5120V2-10P-LI)
IMPORTANT: · Ensure 10 cm (3.9 in) of clearance around the chassis for heat dissipation. · Do not place heavy objects on the switch. |
If a standard 19-inch rack is not available, you can place your switch on a workbench.
To mount the switch on a workbench:
1. Verify that the workbench is sturdy and reliably grounded.
2. Place the switch with bottom up, and clean the round holes in the chassis bottom with dry cloth.
3. Attach the rubber feet to the four round holes in the chassis bottom.
4. Place the switch with upside up on the workbench.
Mounting the switch on a wall
CAUTION: · Before drilling holes in a wall, make sure no electrical lines exist in the wall. · Leave a minimum clearance of 10 mm (0.39 in) around the chassis for heat dissipation. |
The S5120V2-SI, S5120V2-LI, S5000V3-EI, S5000V5-EI, and S3100V3-SI switch series support wall mounting. These switches are provided with screw anchors and screws as shown in Figure 13 for wall-mounting.
Figure 13 Screw anchor and screw
Table 9 describes the switch models that support wall mounting and installation holes distances required for wall-mounting the switch.
Table 9 Installation hole distances for switch models that support wall mounting
Switch model |
Hole distance |
S5120V2-10P-SI S5120V2-10P-LI S3100V3-10TP-SI S5024PV5-EI-S S5008PV5-EI with product code LS-5008PV5-EI-H1 S5008PV5-EI-S S5008PV5-EI-HPWR-S |
170 mm (6.69 in) |
S3100V3-18TP-SI |
172 mm (6.77 in) |
S5120V2-20P-LI S5016PV3-EI S5016PV5-EI S5016PV5-EI-S |
176 mm (6.93 in) |
S5120V2-10P-PWR-LI S5120V2-12TP-HPWR-LI S3100V3-10TP-PWR-SI S5008PV5-EI-HPWR with product code LS-5008PV5-EI-HPWR-H1 |
102 mm (4.02 in) |
S3100V3-20TP-PWR-SI S5016PV5-EI-PWR-S S5024PV5-EI-PWR-S |
116 mm (4.57 in) |
To mount the switch on a wall:
1. Mark two installation holes on the wall. Make sure the two holes are on the same horizontal line.
See Table 9 for the distance requirement between the two holes.
Figure 14 Installing the switch on a wall (1)
2. Drill two holes with a diameter of 6 mm (0.24 in) and a depth of 25 mm (0.98 in) at the marked locations. Hammer the screw anchors into the wall and use a Phillips screwdriver to fasten the screw into the screw anchor. Leave 1.5 mm (0.06 in) between the screw head and the wall for hanging the switch.
Figure 15 Installing the switch on a wall (2)
3. Align the installation holes in the switch rear with the screws on the wall and hang the switch on the screws. Make sure the port side faces down and the left and right sides are perpendicular to the ground.
Figure 16 Installing the switch on a wall (3)
WARNING! Correctly connecting the switch grounding cable is crucial to lightning protection, ESD, and EMI protection. For information about lightning protection, see H3C Network Devices Lightning Protection Guide. |
To protect against the following types of problems, use a grounding cable to connect the device to the earthing facility at the installation site:
· Bodily injury from electric shocks.
· Device and power and data line damages.
· Electrical fires, lightning strokes, electromagnetic coupling interferences, ESD damages.
You can ground the switch in one of the following ways, depending on the grounding conditions available at the installation site:
· Grounding the switch with a grounding strip
· Grounding the switch with a grounding conductor buried in the earth ground
· Grounding the switch by using the PE wire of the AC power cord
NOTE: The chassis views and power supply and grounding terminal positions in the following figures are for illustration only. |
WARNING! Connect the grounding cable to the grounding system in the equipment room. Do not connect it to a fire main or lightning rod. |
To ground the switch by using a grounding strip:
1. Attach the ring terminal end of the yellow-green grounding cable to the grounding hole in the switch.
a. Remove the grounding screw from the grounding hole in the switch.
b. Attach the grounding screw to the ring terminal of the grounding cable.
c. Use a screwdriver to fasten the grounding screw into the grounding screw hole.
Figure 17 Attaching the grounding cable to the grounding hole of the switch (S5120V2-28P-HPWR-LI switch)
(1) Grounding screw |
(2) Ring terminal |
(3) Grounding sign |
(4) Grounding hole |
(5) Grounding cable |
2. Connect the other end of the grounding cable to the grounding strip.
a. Cut the grounding cable to a length according to the distance between the switch and the grounding strip.
b. Peel 20 mm (0.79 in) of insulation sheath by using a wire stripper.
c. Use the needle-nose pliers to bend the bare wire.
d. Hook the grounding cable to the post on the grounding strip, and use the hex nut to secure the cable to the post.
Figure 18 Connecting the grounding cable to a grounding strip
(1) Grounding post |
(2) Grounding strip |
(3) Grounding cable |
(4) Hex nut |
If the installation site does not have grounding strips, but earth ground is available, hammer a 2.5 m (8.20 ft) or longer angle iron or steel tube into the earth ground to act as a grounding conductor. Make sure a minimum of 0.7 m (2.30 ft) is left between the top of the grounding conductor and the ground. In cold areas, bury the grounding conductor below the frozen soil layer. In areas with thin soil or rocky gravel, determine the depth for burying the grounding conductor based on the actual condition.
If zinc-coated steel is used, the following dimensions requirements must be met:
· Angle iron—A minimum of 50 × 50 × 5 mm (1.97 × 1.97 × 0.20 in).
· Steel tube—A minimum of 3.5 mm (0.14 in) in thickness.
· Flat steel—A minimum of 40 × 4 mm (1.57 × 0.16 in).
· Round steel—A minimum of 10 mm (0.39 in).
Weld the yellow-green grounding cable to the angel iron or steel tube and treat the joint for corrosion protection.
Figure 19 Grounding the switch by burying the grounding conductor into the earth ground
(2) Grounding cable |
(3) Earth |
(4) Joint |
(5) Grounding conductor |
(6) Chassis rear panel |
If the installation site has no grounding strips or earth ground, ground an AC-powered switch through the PE wire of the power cord. Make sure the following requirements are met:
· The power cord has a PE wire.
· The ground contact in the power outlet is securely connected to the ground in the power distribution room or on the AC transformer side.
· The power cord is securely connected to the power outlet. If the ground contact in the power outlet is not connected to the ground, report the problem and reconstruct the grounding system.
NOTE: To guarantee the grounding effect, use the grounding cable provided with the switch to connect to the grounding strip in the equipment room. |
· If you ground the switch with a grounding strip:
a. Use a multimeter to measure the resistance between the switch grounding terminal and grounding point, and make sure the resistance is less than 0.1W.
b. Use a grounding resistance tester to measure the grounding resistance of the grounding strip, and make sure the grounding resistance is less than 1W.
· If you ground the switch with a grounding conductor buried in the earth ground:
b. Use a grounding resistance tester to measure the grounding resistance of the angle iron in the ground, and make sure the grounding resistance is less than 10W. For locations with high soil resistivity, sprinkle some resistance reducer to reduce soil resistivity or replace soil around the grounding strip with soil with lower resistance.
For information about resistance measurement, see H3C Network Devices Lightning Protection Guide.
WARNING! In power redundancy mode, you can replace a power supply without powering off the switch but must follow the installation and procedures in Figure 20 and Figure 21 to avoid any bodily injury or damage to the switch. |
CAUTION: Provide a circuit breaker for each power supply and make sure the circuit breaker is off before installation. |
This section is applicable only to the switch models that use removable power supplies. For the switch models that use removable power supplies and the available power supplies, see hardware information and specifications for the switch series.
Figure 20 Installation procedure
Installing a power supply
2. Unpack the power supply and verify that the power supply model is as required.
3. Remove the filler panel (if any) from the target slot. As shown in Figure 22, use a Phillips screwdriver to loosen the screws on the filler panel and thread the screwdriver shaft through the handle to pull the filler panel out of the slot.
Figure 22 Removing the filler panel
4. Orient the power supply with the lettering on it upright. Grasp the handle of the power supply with one hand and support its bottom with the other, and slide the power supply slowly into the slot along the guide rails. See callout 1 in Figure 23.
To prevent damage to the power supply and the connector on the switch backplane, insert the power supply gently. If you encounter a hard resistance or the power supply tilts while inserting the power supply, pull out the power supply, realign it with the slot, and then insert it again.
5. Fasten the captive screws on the power supply with a Phillips screwdriver to secure the power supply in the chassis. See callout 2 in Figure 23.
If the captive screw cannot be tightly fastened, examine the installation of the power supply.
Figure 23 Installing a power supply
Removing a power supply
2. Remove the power cord from the power supply.
3. Use a Phillips screwdriver to loosen the captive screws on the power supply until they are completely disengaged from the chassis.
4. Grasp the handle of the power supply with one hand and pull the module part way out. Support the module bottom with the other hand, and pull the power supply slowly out of the slot along the guide rails.
5. Place the removed power supply on an antistatic mat or put it into its original packaging bag.
6. If you are not to install a new power supply, install a filler panel in the slot.
WARNING! · Provide a circuit breaker for each power cord. · Before connecting the power cord, make sure the circuit breaker for the power cord is turned off. |
The S5560S-28F-SI, S5560S-28DP-SI, S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, S5500V3-54F-DP-SI, and S5130S-28F-SI switches use removable power supplies.
· The S5560S-28F-SI, S5560S-28DP-SI, and S5130S-28F-SI switches support the PSR75-12A power supply.
· The S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, and S5500V3-54F-DP-SI switches each come with a CA-70A12 power supply and supports the CA-70A12, PSR75-12A, and PSR150-D1 power supplies.
The CA-70A12 and PSR75-12A power supplies support AC and 240 HVDC power input. However, when installed on an S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, or S5500V3-54F-DP-SI switch, they do not support 240 HVDC power input. The PSR-150-D1 power supply supports power input from a –48VDC power source or an external redundant power system (RPS).
Table 10 Power cord connection procedures at a glance
Switch model |
Available power source |
Connection procedure reference |
S5130S-28S-HPWR-LI S5130S-52S-PWR-LI S5120V2-28P-HPWR-LI S5120V2-52P-PWR-LI S5048PV3-EI-PWR S5024PV3-EI-HPWR S3100V3-28TP-PWR-SI with product code LS-3100V3-28TP-PWR-SI |
AC power source |
RPS (RPS1600-A) |
S5560S-28F-SI S5560S-28DP-SI S5130S-28F-SI |
· AC power source · 240 VDC high-voltage power source |
Connecting the power cord for a CA-70A12 or PSR75-12A power supply |
S5500V3-28S-DP-SI S5500V3-54S-DP-SI S5500V3-36F-DP-SI S5500V3-54F-DP-SI |
· AC power source |
· –48 VDC power source · RPS (available models: RPS800-A and RPS1600-A) |
Other switch models |
AC power source |
1. Connect the female connector of the AC power cord to the AC-input power receptacle on the switch. See Figure 24.
2. Use a cable tie to secure the power cord to the handle near the AC-input power receptacle. See Figure 25.
3. Connect the other end of the power cord to an AC power source.
Figure 24 Connecting the AC power cord for the fixed AC power supply (1)
Figure 25 Connecting the AC power cord for the fixed AC power supply (2)
CAUTION: To connect to an H3C recommended RPS, use a power cord compatible with the RPS. |
To connect the DC power cord for the fixed DC power supply:
1. Correctly orient the DC power cord connector and insert the connector into the power receptacle on the power supply.
If you orient the DC power cord connector upside down, you cannot insert the plug into the power receptacle.
2. Use a flat-head screwdriver to fasten the screws on the power cord connector, as shown in Figure 26.
3. Connect the other end of the power cord to an RPS.
Figure 26 Connecting the DC power cord for the fixed DC power supply (S5120V2-28P-HPWR-LI switch)
The power cord connection procedure is similar for the CA-70A12 and PSR75-12A power supplies. The following procedure connects the power cord for a PSR75-12A power supply.
To connect the power cord for a PSR75-12A power supply:
1. Wear an ESD wrist strap. Make sure the wrist strap makes good skin contact and is reliably grounded.
2. Install the power cord retainer clip. Insert the two ends of the clip into the holes in the brackets on the left of the power receptacle.
3. Pull the power cord retainer clip leftward, as shown in Figure 27.
4. Connect the female connector of the power cord to the power receptacle on the power supply. See callout 1 in Figure 28.
5. Pull the power cord retainer clip rightward to secure the connector to the power receptacle. See callout 2 in Figure 28.
6. Connect the other end of the power cord to an AC power source or a high-voltage DC power source.
Figure 27 Connecting the power cord for a PSR75-12A power supply (1)
Figure 28 Connecting the power cord for a PSR75-12A power supply (2)
NOTE: The power cord retainer clip in the preceding two figures is for illustration only. |
CAUTION: · To connect the power cord to a –48 VDC power source in the equipment room, use the DC power cord provided with the power supply. To ensure correct connections, identify the positive and negative marks on the power wires before connecting them. · To connect the power cord to an H3C RPS, use a power cord matching the RPS. |
To connect the DC power cord for a PSR150-D1 power supply:
2. As shown by callout 1 in Figure 29, correctly orient the DC power cord connector and insert it into the DC power-input receptacle on the power supply.
The power cord connector and power receptacle form a disorientation rejection structure. If you orient the power cord connector upside down, you cannot insert it into the power receptacle.
3. As shown by callout 2 in Figure 29, use a flat-head screwdriver to fasten the screws on the power cord connector.
4. Connect the other end of the DC power cord to a –48 VDC power source in the equipment room or an external RPS.
Figure 29 Connecting the DC power cord for a PSR150-D1 power supply
Verifying the installation
After you complete the installation, verify the following items:
· There is enough space for heat dissipation around the switch, and the rack or workbench is stable.
· The grounding cable is securely connected.
· The power source is as required by the switch.
· The power cords are correctly connected.
· If part of the network cable for a port is routed outdoors, verify that a network port lightning protector is used for the port.
· If a power line is routed from outdoors, verify that a surge protected power strip is used for the switch.
You can use the following methods to access and manage the switch for the first time:
· Managing the switch from the GUI
· Managing the switch from the CLI
Only the S5000V3-EI switch series and S5000V5-EI switch series (except the LS-5008PV5-EI and LS-5008PV5-EI-HPWR switches) support GUI management.
Accessing the GUI
The default Web login information is as follows:
· Username—admin
· Password—admin
· IP address of VLAN-interface 1—192.168.0.233/24
To access the GUI by using the default username and password:
1. Use a twisted pair cable to connect a PC to an Ethernet port on the switch.
By default, all ports on the switch belong to VLAN 1.
2. Configure an IP address in subnet 192.168.0.0/24 for the PC. Make sure the PC and the switch are reachable to each other.
The PC must use an IP address different than VLAN-interface 1.
3. Start a browser on the PC, enter http://192.168.0.233 in the address bar, and press Enter. The Web login page opens.
4. Enter the default username admin and password admin and then click Login.
NOTE: To log out, do not close the browser directly. You must click Logout at the top left corner on the Web interface. |
As a best practice for security purposes, change the default login password immediately after you log in to the GUI for the first time.
To change the default login password, click
the admin icon
at
the top left corner.
Creating user accounts
You can create user accounts other than the default account.
To create a user account, click Device > Maintenance > Administrators and create a new user account on the page that opens.
A maximum of 32 users can access the Web GUI at the same time.
You can access the S5560S-28S-SI switch, S5560S-52S-SI switch, S5560S-28F-SI switch, S5560S-28DP-SI switch, S5500V3-24P-SI switch, S5500V3-48P-SI switch, S5130S-SI switch series, and S5130S-LI switch series from the serial console port or the micro USB console port. If you connect both ports, only the micro USB console port is available. As a best practice, access the switch from the serial console port.
You can access the S5560S-28P-SI switch, S5560S-52P-SI switch, S5120V2-SI switch series, S5120V2-LI switch series, S5110V2-SI switch series, S5000V3-EI switch series, S5000V5-EI switch series, S5500V3-SI switch series (except the S5500V3-24P-SI and S5500V3-48P-SI switches), and S3100V3-SI switch series only from the serial console port.
In Figure 30, the switch is connected to a configuration terminal (PC as an example) from the serial console port.
Figure 30 Connecting the switch to a configuration terminal
As shown in Figure 30, three types of console cables can be used for connecting the switch to a configuration terminal. The switch is not provided with a serial console cable or a micro USB console cable.
Table 11 Connection methods and console cables
Connection method |
Console cable type |
Configuration terminal-side connector |
Switch-side connector |
Using the serial console port for connection |
DB9-to-RJ45 console cable |
DB-9 female connector |
RJ-45 connector |
USB-to-RJ45 console cable |
USB connector |
RJ-45 connector |
Using the micro USB console port for connection |
Micro USB console cable |
USB connector |
Micro USB connector |
The signal pinout for the RJ-45 connector of a serial console cable varies by vendor. To avoid abnormal configuration terminal display, use a serial console cable provided by H3C. For more information, see Table 12. To prepare a serial console cable yourself, make sure the signal pinout for the RJ-45 connector is the same as that shown in Table 13.
Console cable view |
Product code for the recommended H3C console cable |
04042967 |
0404A1EE |
User supplied, |
Connecting a console cable
Connecting a DB9-to-RJ45 console cable
A DB9-to-RJ45 console cable is an 8-core shielded cable, with a crimped RJ-45 connector at one end for connecting to the serial console port of the switch, and a DB-9 female connector at the other end for connecting to the serial port on the configuration terminal.
Figure 31 DB9-to-RJ45 console cable
Table 13 DB9-to-RJ45 console port signaling and pinout
RJ-45 |
Signal |
DB-9 |
Signal |
1 |
RTS |
8 |
CTS |
2 |
DTR |
6 |
DSR |
3 |
TXD |
2 |
RXD |
4 |
SG |
5 |
SG |
5 |
SG |
5 |
SG |
6 |
RXD |
3 |
TXD |
7 |
DSR |
4 |
DTR |
8 |
CTS |
7 |
RTS |
CAUTION: · Identify the mark on the console port and make sure you are connecting to the correct port. · The serial ports on PCs do not support hot swapping. To connect a PC to an operating switch, first connect the PC end. To disconnect a PC from an operating switch, first disconnect the switch end. |
To connect the console port on the switch to a configuration terminal (for example, a PC) through a DB9-to-RJ45 console cable:
1. Plug the DB-9 female connector of the DB9-to-RJ45 console cable to the serial port of the PC.
2. Connect the RJ-45 connector of the cable to the serial console port of the switch.
Connecting a USB-to-RJ45 console cable
IMPORTANT: · To use a USB-to-RJ45 console cable to connect the switch to a configuration terminal, first download and install the USB-to-RJ45 console driver on the configuration terminal and then connect the USB-to-RJ45 console cable to the configuration terminal. · If you have connected a USB-to-RJ45 console cable to the configuration terminal before driver installation, you must remove and reconnect the USB-to-RJ45 console cable to the configuration terminal. |
For information about the signal pinout for the RJ-45 connector of a USB-to-RJ45 console cable, see Table 13.
The following installs the driver on the Windows system. To install the driver on other operating systems, see the installation guide in the driver compression package named by the corresponding operating system.
To connect the switch to the configuration terminal through a USB-to-RJ45 console cable:
1. Click the following link, or copy it to the address bar on your browser and download the USB-to-RJ45 console driver.
http://www.h3c.com/en/home/USB_to_RJ45_Console/
2. View the TXT file Read me in the Windows folder to check whether the Windows system of the configuration terminal supports the driver.
3. If the Windows system supports the driver, install PL23XX-M_LogoDriver_Setup_v200_20190815.exe.
4. Click Next on the welcome page of the driver installation wizard.
Figure 32 Driver installation wizard
5. Click Finish after the drive installation is completed.
Figure 33 Finishing the driver installation
6. Connect the standard USB connector of the cable to the USB port of the configuration terminal.
7. Connect the RJ-45 connector of the cable to the console port of the switch.
To connect the switch to the configuration terminal through a micro USB console cable:
1. Connect the standard USB connector to the USB port of the PC or configuration terminal.
2. Connect the micro USB connector to the micro USB console port on the switch.
3. Click the following link, or copy it to the address bar on the browser to download the USB console driver.
http://www.h3c.com/en/home/USB_Console/
4. Select a driver program according to the operating system you use:
¡ XR21V1410_XR21B1411_Windows_Ver1840_x86_Installer.EXE—32-bit operating system.
¡ XR21V1410_XR21B1411_Windows_Ver1840_x64_Installer.EXE—64-bit operating system.
5. Click Next on the installation wizard.
Figure 34 Device Driver Installation Wizard
6. Click Continue Anyway if the following dialog box appears.
Figure 35 Software Installation
7. Click Finish.
Figure 36 Completing the device driver installation wizard
Setting terminal parameters
To configure and manage the switch through the console port, you must run a terminal emulator program, such as TeraTermPro, on your configuration terminal. You can use the emulator program to connect a network device, a Telnet site, or an SSH site. For more information about the terminal emulator programs, see the user guides for these programs.
The following are the required terminal settings:
· Bits per second—9,600.
· Data bits—8.
· Stop bits—1.
· Parity—None.
· Flow control—None.
Starting the switch
Pre-start checklist
Before powering on the switch, verify that the following conditions are met:
· The power cord is correctly connected.
· The input power voltage meets the requirement of the switch.
· The console cable is correctly connected.
· The configuration terminal (a PC, for example) has started, and its serial port settings are consistent with the console port settings on the switch.
Powering on the switch
During the startup process, you can access Boot ROM menus to perform tasks such as software upgrade and file management. The Boot ROM interface and menu options differ with software versions. For more information about Boot ROM menu options, see the software-matching release notes for the device.
After the startup completes, you can access the CLI to configure the switch.
For more information about the configuration commands and CLI, see the configuration guides and command references for the switch series.
Setting up an IRF fabric
IMPORTANT: The LS-5008PV5-EI and LS-5008PV5-EI-HPWR switches do not support IRF, so this section is not applicable to the LS-5008PV5-EI and LS-5008PV5-EI-HPWR switches. |
You can use H3C IRF technology to connect and virtualize multiple switches into a large virtual switch called an "IRF fabric" for flattened network topology, and high availability, scalability, and manageability.
For the S5500V3-EI switch series and S3100V3-SI switch series, you can only use the switches in the same group to set up an IRF fabric. For the other switch series, you can set up an IRF fabric with switches from the same switch series.
Table 14 Groups of the S5500V3-EI switch series and S3100V3-SI switch series
Group |
Switch model |
Group 1 |
S5500V3-24P-SI S5500V3-48P-SI |
Group 2 |
S5500V3-28S-SI S5500V3-28PS-SI S5500V3-54S-SI S5500V3-54PS-SI S5500V3-36F-SI S5500V3-28S-DP-SI S5500V3-54S-DP-SI S5500V3-36F-DP-SI S5500V3-54F-DP-SI |
Group 3 |
S3100V3-28TP-SI switch with product code LS-3100V3-28TP-SI-H1 S3100V3-52TP-SI switch with product code LS-3100V3-52TP-SI-H1 S3100V3-20TP-PWR-SI switch with product code LS-3100V3-20TP-PWR-SI-H1 S3100V3-18TP-SI switch with product code LS-3100V3-18TP-SI-H1 |
Group 4 |
S3100V3-28TP-SI switch with product code LS-3100V3-28TP-SI S3100V3-10TP-SI switch S3100V3-18TP-SI switch with product code LS-3100V3-18TP-SI S3100V3-52TP-SI switch with product code LS-3100V3-52TP-SI S3100V3-10TP-PWR-SI switch S3100V3-20TP-PWR-SI switch with product code LS-3100V3-20TP-PWR-SI S3100V3-28TP-PWR-SI switch |
IRF fabric setup flowchart
Figure 37 IRF fabric setup flowchart
To set up an IRF fabric:
Step |
1. Plan IRF fabric setup. |
Plan the installation site and IRF fabric setup parameters: · Planning IRF fabric size and the installation site · Identifying the master switch and planning IRF member IDs · Planning IRF topology and connections |
2. Install IRF member switches. |
See "Installing the switch in a 19-inch rack" or "Mounting the switch on a workbench." |
3. Connect grounding cables and power cords. |
See "Grounding the switch," "Installing and removing a power supply," and "Connecting the power cord." |
4. Power on the switches. |
N/A |
5. Configure basic IRF settings. |
See the IRF configuration guide or virtual technologies configuration guide for the switch series, depending on the software version. |
6. Connect the IRF physical ports. |
Connect IRF physical ports on switches. For long-distance connection, use SFP/SFP+ transceiver modules and optical fibers. For short-distance connection, use twisted-pair cables or SFP/SFP+ cables. All switches except the master switch automatically reboot, and the IRF fabric is established. |
Planning IRF fabric setup
This section describes issues that an IRF fabric setup plan must cover.
Choose switch models and identify the number of required IRF member switches, depending on the user density and upstream bandwidth requirements. The switching capacity of an IRF fabric equals the total switching capacities of all member switches.
Plan the installation site depending on your network solution, as follows:
· Place all IRF member switches in one rack for centralized high-density access.
· Distribute the IRF member switches in different racks to implement the ToR access solution for a data center.
Determine which switch you want to use as the master for managing all member switches in the IRF fabric. An IRF fabric has only one master switch. You configure and manage all member switches in the IRF fabric at the CLI of the master switch. IRF member switches automatically elect a master. You can affect the election result by assigning a high member priority to the intended master switch. For more information about master election, see the IRF configuration guide or virtual technologies configuration guide for the switch series, depending on the software version.
Prepare an IRF member ID assignment scheme. An IRF fabric uses member IDs to uniquely identify and manage its members, and you must assign each IRF member switch a unique member ID.
You can create an IRF fabric in daisy chain topology or more reliable ring topology. In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy chain topology. Instead, the IRF fabric changes to a daisy chain topology without interrupting network services.
You connect the IRF member switches through IRF ports, the logical interfaces for the connections between IRF member switches. Each IRF member switch has two IRF ports: IRF-port 1 and IRF-port 2. To use an IRF port, you must bind at least one physical port to it.
When connecting two neighboring IRF member switches, you must connect the physical ports of IRF-port 1 on one switch to the physical ports of IRF-port 2 on the other switch.
The switch can form an IRF fabric only with switches from the same switch series. For the physical ports that can be used for IRF connections on each switch model and the restrictions for using the ports, see Table 15. The IRF physical ports can set up IRF connections only when operating at their highest speeds. For example, a 10-GE port must operate at 10 Gbps. A 1-GE port must operate at 1 Gbps.
You can bind multiple ports to an IRF port for increased bandwidth and availability.
NOTE: The following figures use the SFP+ ports on S5120V2-28P-HPWR-LI switches as an example. For the ports that can be used for IRF connections, see Table 15. |
Figure 38 IRF fabric in daisy chain topology
Figure 39 IRF fabric in ring topology
Identify the IRF physical ports on the member switches according to your topology and connection scheme.
To uses physical ports on a switch in the S5500V3-SI switch series (excluding the S5500V3-24P-SI and S5500V3-48P-SI) for IRF connection, obey the following rules as a best practice:
· Use four highest numbered SFP+ ports if the switch has six SFP+ ports.
· Use two highest numbered SFP+ ports if the switch has four SFP+ ports.
With these ports as IRF physical ports, the IRF packets are placed in queues of higher forwarding priorities, ensuring smooth IRF packet forwarding in the event of large amounts of data packets and avoiding IRF splitting and other faults.
Table 15 shows the physical ports that can be used for IRF connection and the port use restrictions.
Table 15 IRF physical ports and use restrictions
Chassis |
Candidate IRF physical ports |
Use restrictions |
S5130S-28S-SI S5130S-28S-SI-MM S5130S-28S-SI-SM S5130S-28S-LI S5130S-28S-LI-MM S5130S-28S-LI-SM S5130S-28S-PWR-LI S5560S-52S-SI S5130S-52S-SI S5130S-52S-LI S5130S-52S-PWR-LI S5500V3-24P-SI S5500V3-48P-SI S5500V3-28S-SI S5500V3-54S-SI S5500V3-28S-DP-SI S5500V3-54S-DP-SI |
All the following ports on the front panel: · 10/100/1000BASE-T autosensing ports · SFP+ ports |
The physical ports bound to an IRF port must operate at the same speed. · 10/100/1000BASE-T autosensing port—1 Gbps · SFP+ port—10 Gbps For switches with 52 ports, these ports are divided into two groups: ports 1 to 24, port 51, and port 52 in one group and ports 25 to 50 in the other group. To bind multiple ports to an IRF port, make sure the ports are in the same group. Ports in one group can be bound to different IRF ports. |
S5500V3-54F-DP-SI |
All the following ports on the front panel: · SFP+ ports · SFP ports |
The physical ports bound to an IRF port must operate at the same speed. · SFP port—1 Gbps · SFP+ port—10 Gbps |
S5560S-28F-SI S5130S-28F-SI S5130S-28S-HPWR-LI S5500V3-36F-DP-SI S5500V3-28PS-SI S5500V3-54PS-SI |
All the following ports on the front panel: · 10/100/1000BASE-T autosensing ports · SFP ports · SFP+ ports |
The physical ports bound to an IRF port must operate at the same speed. · 10/100/1000BASE-T autosensing port—1 Gbps · SFP port—1 Gbps · SFP+ port—10 Gbps |
S5560S-52P-SI S5120V2-52P-SI S5120V2-52P-LI S5120V2-52P-PWR-LI S5110V2-52P-SI S5048PV3-EI S5048PV3-EI-PWR S5048PV5-EI S5048PV5-EI-PWR |
All the following ports on the front panel: · 10/100/1000BASE-T autosensing ports · SFP ports |
The physical ports bound to an IRF port must operate at the same speed. The 52 GE ports are divided into two groups: ports 1 to 24, port 51, and port 52 in one group and ports 25 to 50 in the other group. To bind multiple GE ports to an IRF port, make sure the ports are in the same group. GE ports in one group can be bound to different IRF ports. The ports must operate at 1 Gbps. |
S3100V3-52TP-SI |
The physical ports bound to an IRF port must operate at the same speed. The 20 GE ports are divided into two groups: ports 51 and 52 in one group and ports 33 to 50 in the other group. To bind multiple GE ports to an IRF port, make sure the ports are in the same group. GE ports in one group can be bound to different IRF ports. The ports must operate at 1 Gbps. |
The physical ports bound to an IRF port must operate at the same speed. The ports must operate at 1 Gbps. |
Planning the cabling scheme
Use the following cables to connect the IRF physical ports on the switches:
· 10/100/1000BASE-T autosensing Ethernet port—Category 5 or above twisted-pair cables.
· SFP port—GE SFP fiber transceiver modules and optical fibers, GE SFP copper transceiver modules and twisted-pair cables, or GE SFP cables. For the available models, see ports in hardware information and specifications for the switch series.
· SFP+ port—SFP+ transceiver modules and optical fibers or SFP+ cables. For the available models, see ports in hardware information and specifications for the switch series.
If the IRF member switches are far away from one another, use transceiver modules and optical fibers. If the IRF member switches are all in one equipment room, use twisted pair cables or SFP/SFP+ cables.
The following subsections describe several H3C recommended IRF connection schemes by using SFP cables and SFP transceiver modules and fibers. All these schemes use a ring topology.
Connecting the IRF member switches in one rack
Connect the IRF member switches (4 switches in this example) in a rack as shown in Figure 40. The switches in the ring topology (see Figure 41) are in the same order as connected in the rack.
Figure 40 Connecting the switches in one rack
Connecting the IRF member switches in a ToR solution
You can install IRF member switches in different racks side by side to deploy a top of rack (ToR) solution.
After you install the IRF member switches, power on the switches, and log in to each IRF member switch (see the fundamentals configuration guide for the switch series) to configure their member IDs, member priorities, and IRF port bindings.
Follow these guidelines when you configure the switches:
· Assign the master switch higher member priority than any other switch.
· Bind physical ports to IRF port 1 on one switch and to IRF port 2 on the other switch. You perform IRF port binding before or after connecting IRF physical ports depending on the software release.
· Execute the display irf configuration command to verify the basic IRF settings.
For more information about configuring basic IRF settings, see the IRF configuration guide or virtual technologies configuration guide for the switch series, depending on the software version.
Prepare and connects cable based on the network topology and connection methods as planned.
Wear an ESD wrist strap when you install transceiver modules and fibers. For the installation method and precautions, see H3C Transceiver Modules and Network Cables Installation Guide.
To verify the basic functionality of the IRF fabric after you finish configuring basic IRF settings and connecting IRF ports:
1. Log in to the IRF fabric through the console port of any member switch.
2. Create a Layer 3 interface, assign it an IP address, and make sure the IRF fabric and the remote network management station can reach each other.
3. Use Telnet or SNMP to access the IRF fabric from the network management station. (See the fundamentals configuration guide for the switch series.)
4. Verify that you can manage all member switches as if they were one node.
5. Display the running status of the IRF fabric by using the commands in Table 16.
Table 16 Displaying and maintaining IRF configuration and running status
Task |
Command |
Display IRF fabric information. |
display irf |
Display basic IRF settings for each member device. |
display irf configuration |
Display IRF fabric topology information. |
display irf topology |
NOTE: To avoid IP address collision and network problems, configure a minimum of one multi-active detection (MAD) mechanism to detect the presence of multiple identical IRF fabrics and handle collisions. For more information about MAD detection, see the IRF configuration guide or virtual technologies configuration guide for the switch series, depending on the software version. |
Fixed power supply failure
The following switch series uses fixed power supplies:
· S5560S-SI switch series (except the S5560S-28F-SI)
· S5130S-SI switch series (except the S5130S-28F-SI)
· S5500V3-SI switch series (except the S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, and S5500V3-54F-DP-SI)
Among these switches, the S5130S-28S-HPWR-LI, S5130S-52S-PWR-LI, S5120V2-28P-HPWR-LI, S5120V2-52P-PWR-LI, S5024PV3-EI-HPWR, S5048PV3-EI-PWR, and S3100V3-28TP-PWR-SI switches support AC power input, DC power input, and concurrent AC and DC power inputs. The other switch models support only AC power input.
To identify a power failure on the switch, examine the system status LED and the RPS status LED on the switch.
Table 17 Description for the power failure indication LEDs
LED |
Mark |
Status |
System status LED |
SYS |
Off |
The switch is powered off. |
RPS status LED (available only on the S5130S-28S-HPWR-LI, S5130S-52S-PWR-LI, S5120V2-28P-HPWR-LI, S5120V2-52P-PWR-LI, S5048PV3-EI-PWR, and S3100V3-28TP-PWR-SI with product code LS-3100V3-28TP-PWR-SI-H1 switches) |
RPS |
Steady green |
Both the DC input and the AC input are normal. |
Steady yellow |
Normal DC input, no or abnormal AC input. |
Off |
No or abnormal DC input. |
Symptom
The system status LED on an AC-powered switch is off.
Solution
To resolve the issue:
1. Verify that the AC power cord is securely connected to the switch, and the AC-input power receptacle on the switch and the connected AC power outlet are in good condition.
2. Verify that the AC power source is operating correctly.
3. Verify that the operating temperature of the switch is in the acceptable range, and the power supply has good ventilation. Over-temperature can cause the power supply to stop working and enter protection state.
4. If the issue persists, contact H3C Support.
Input failure on a DC-powered switch
Symptom
The system status LED on the DC-powered switch is off.
Solution
1. Verify that the switch is securely connected to the DC power source.
2. Verify that the DC power source is operating correctly.
Input failure on a DC and AC-powered switch
Symptom 1
The system status LED on the DC and AC-powered switch is off.
Solution
3. Verify that the switch is securely connected to the DC power source.
4. Verify that the DC power source is operating correctly.
5. Verify that the operating temperature of the switch is in the acceptable range, and the power supply has good ventilation. Over-temperature can cause the power supply to stop working and enter protection state.
6. If the issue persists, contact H3C Support.
Symptom 2
The system status LED on the DC and AC-powered switch is on but the RPS status LED is steady yellow.
Solution
3. Verify that the operating temperature of the switch is in the acceptable range.
Symptom 3
The system status LED on the DC and AC-powered switch is on but the RPS status LED is off.
Solution
Removable power supply failure
The S5560S-28F-SI, S5560S-28DP-SI, S5500V3-28S-DP-SI, S5500V3-54S-DP-SI, S5500V3-36F-DP-SI, S5500V3-54F-DP-SI, and S5130S-28F-SI switches use removable power supplies. You can determine the power supply operating status by examining the power supply LEDs PWR1 and PWR2 on the switch front panel. For descriptions about the PWR1 and PWR2 LEDs, see LEDs in hardware information and specifications for the switch series.
Symptom
A PWR LED indicates a power supply failure.
Solution
1. Verify that the power supply model is as required.
2. Verify that the power supply is installed correctly in the switch.
3. Verify that the switch is operating in the acceptable temperature range.
To replace a hot swappable power supply, see "Installing and removing a power supply."
Fan tray failure
Symptom
The system status LED on the switch indicates a fan tray failure.
Solution
When a fan tray issue occurs, contact H3C Support.
Configuration terminal issues
No display on the configuration terminal
Symptom
The configuration terminal does not have display when the switch is powered on.
Solution
1. Verify that the power system is operating correctly.
2. Verify that the switch is operating correctly.
3. Verify that the console cable has been connected correctly.
4. Verify that the following settings are configured for the terminal:
¡ Baud rate—9600.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
¡ Flow control—None.
5. Verify that the console cable is not faulty.
Garbled display on the configuration terminal
Symptom
The configuration terminal displays garbled text.
Solution
1. Verify that the following settings are configured for the terminal:
¡ Baud rate—9600.
¡ Data bits—8.
¡ Parity—None.
¡ Stop bits—1.
