01-Text | 4.15 MB |
Restrictions for using the embedded database
Obtaining IMC installation and deployment methods
Hardware requirements of the IMC platform
Hardware requirements of the EIA component
Hardware requirements of the WSM component
Embedded database installation requirements
Preparing the installation environment
Checking the installation environment
Installing and deploying the IMC platform
Selecting the installation type
Installing the IMC platform in typical mode
Installing the IMC platform in custom mode
Managing IMC by using the Intelligent Deployment Monitoring Agent
Starting the Intelligent Deployment Monitoring Agent
Installing and deploying IMC service components
Installing and deploying IMC BIMS
Installing and deploying IMC UAM
Installing and deploying IMC MVM
Installing a DHCP plug-in on an MS DHCP server
Installing a DHCP plug-in on a Linux DHCP server
Installing an LLDP Linux agent
Installing an LLDP Windows agent
Hardware, software, and browser requirements
Accessing the UAM self-service center
Accessing IMC from a mobile device
Uninstalling all IMC components at one time
Backing up and restoring the database
Backing up and restoring databases for a single IMC system
Backing up and restoring databases in stateless failover scenarios
Overview
To facilitate IMC installation and deployment, you can deploy IMC in centralized mode and use the embedded database.
This scales to small networks of less than 40 devices.
IMC components
IMC includes the IMC platform and service components.
IMC platform
The IMC platform is the base component to provide IMC services and includes the following subcomponents:
· Resource Management
· Alarm Management
· User Self Service Management
· Guest Access Management
· Intelligent Configuration Center
· Report Management
· Network Element (NE) Management
· Performance Management
· ACL Management
· Network Asset Management
· Security Control Center
· General Search Service Management
· Syslog Management
· VLAN Management
· WeChat Server
Service components
Service components are optional and purchased separately from the IMC platform. The IMC platform is the basis for implementing various services and must be installed before service component deployment.
IMC includes the following service components:
· Endpoint Intelligent Access (EIA)—Includes User Access Manager (UAM) and TACACS+ Authentication Manager (TAM).
¡ User Access Manager (UAM)—Provides policy-based Authentication, Authorization and Accounting (AAA) services. UAM software extends management to wired, wireless and remote network users. It enables the integration of network device, user, guest, and terminal management on a single unified platform.
¡ TACACS+ Authentication Manager (TAM)—Provides basic AAA functions for network devices or IT users for network device management security. TAM can assign users with different privileges, monitor login and command execution operations, and simplify user management.
· Endpoint Admission Defense (EAD) Security Policy—EAD integrates security policy management and endpoint posture assessment to identify and isolate risks at the network edge. The security policy component allows administrators to control endpoint admission based on an endpoint's identity and posture.
· MPLS VPN Manager (MVM)—Provides functions such as VPN autodiscovery, topology, monitoring, fault location, auditing, and performance evaluation, as well as VPN and service deployment. MVM also contains a traffic engineering component that helps operators monitor an entire network and deliver service quality by distributing suitable network resources as needed.
· IPsec VPN Manager (IVM)—Provides features for all aspects of IPsec VPN management, which allows administrators to construct an IPsec VPN network, effectively monitor the operation and performance of the VPN network, and quickly locate device faults for full IPsec VPN lifecycle management.
· Wireless Service Manager (WSM)—Provides unified management of wired and wireless networks, adding network management functions into existing wired network management systems. WSM software offers wireless LAN (WLAN) device configuration, topology, performance monitoring, RF heat mapping, and WLAN service reports.
· User Behavior Auditor (UBA)—Provides comprehensive log collection and audit functions supporting log formats such as NAT, flow, NetStreamV5, and DIG. UBA provides DIG logs to audit security-sensitive operations and digest information from HTTP, FTP, and SMTP packets.
· QoS Manager (QoSM)—Enhances visibility and control over QoS configurations and helps administrators focus on QoS service planning by providing a robust set of QoS device and configuration management functions. It allows administrators to organize traffic into different classes based on the configured matching criteria to provide differentiated services, committed access rate (CAR), generic traffic shaping (GTS), priority marking, queue scheduling, and congestion avoidance.
· Branch Intelligent Management System (BIMS)—Provides support for service operations, delivering high reliability, scalability, flexibility, and IP investment returns. Based on the TR-069 protocol, IMC BIMS offers resource, configuration, service, alarm, group, and privilege management. It allows the remote management of customer premise equipment (CPE) in WANs.
· Resource Automation Manager (RAM)—Provides a solution for customizing network services for users and automatically deploying network services.
· VAN Fabric Manager (VFM)—Provides an integrated solution for managing both the LANs and SANs in data centers by working with HP devices. VFM depends on VRM to obtain virtual machine (VM) migration information.
· Intelligent Analysis Reporter (iAR)—Extends the reporting capabilities within IMC to include customized reporting. iAR includes a report designer, which can save designs into report templates. Report formats include charts. Reports can be automatically generated at specified intervals and distributed to key stakeholders.
· Endpoint Mobile Office (EMO)—Provides mobile office services based on virtualization technologies and the cloud service platform. EMO allows remote access to Windows applications and desktops, provides local resources in the apps store, and manages mobile devices.
· Security Service Manager (SSM)—Contains SSM and LBM. SSM provides centralized network security management on security devices. LBM deploys configurations to LB devices to implement load balancing through virtual services, real servers, and server farms.
· Intelligent Portal Management (IPM)—Management platform that provides Wi-Fi marketing for enterprises and organizations. IPM supports site-based authentication policy customization, monitors and analyzes customer flow data, and flexibly pushes advertisements to customers. IPM meets the management and marketing requirements of portal sites, upgrades service quality, and improves customers' online experiences.
· Endpoints Profiling System (EPS)—IMC service component developed for endpoint identification and monitoring. EPS can immediately identify new or abnormal endpoints by executing periodical or one-time tasks to scan endpoints in areas of the network.
· U-Center O&M Platform—As a new-generation intelligent O&M management platform, U-Center O&M Platform provides powerful Infrastructure Operations Management (IOM), including APM and SSA.
IMC editions
The following editions of IMC are available:
· Professional
· Standard
· SNS
To deploy IMC in centralized mode and to use the embedded database, you must use the IMC SNS or Standard edition.
Table 1 Differences between IMC editions
Item |
SNS |
Standard |
Professional |
Number of nodes |
40 |
Extensible |
Extensible |
Hierarchical Network Management |
Not supported |
Lower-level NMS only |
Supported |
Distributed deployment |
Not supported |
Supported |
Supported |
Operating system |
Windows |
Windows and Linux |
Windows and Linux |
Embedded database |
Supported |
Windows and Linux |
Not supported |
Remote database |
Supported |
Supported |
Supported |
Installation and deployment
To improve server performance, IMC uses the "Install + Deploy" model.
· Install—Copies the IMC installation packages to the server and loads them to the Intelligent Deployment Monitoring Agent.
· Deploy—Decompresses the installation packages and runs deployment scripts on the server.
The IMC components are operational only after they are deployed. In centralized deployment, all IMC components are installed and deployed on the same server.
IMC automatically creates a database user for each component when the component is deployed. As a best practice, do not modify the database user configuration, including the database user password and password policy.
If the deployment or upgrade process is interrupted, IMC automatically stores logs as a compressed file in the \tmp directory of the IMC installation path. You can use the logs to quickly locate the problem or error.
The IMC Standard edition and SNS edition installation packages contain embedded database software packages. The Windows OS-specific IMC is embedded with the SQL Server 2017 Express database and the Linux OS-specific IMC is embedded with the MariaDB 10.5.12 database. To use the embedded database on these IMC editions, follow these restrictions:
· IMC must run on a Windows server on which no IMC-supported SQL server database is installed.
· The number of nodes to be managed by IMC cannot exceed 1000. If the number exceeds 1000, install a separate database.
During the database installation, IMC selects an embedded database version that is compatible with the Windows operating system version.
You can use the following methods to obtain the IMC installation and deployment procedure:
· View the video case on H3C website at http://www.h3c.com/en/Support/Resource_Center/Technical_Documents/Network_Management/Catalog/H3C_IMC/IMC/Configure/Videos/iMC_Platform_QS-5W100/.
You can also perform the following steps to view the video case:
a. Access https://www.h3c.com/en/.
b. Select Support > Technical Documents > Network Management > H3C Intelligent Management Center.
c. Click the video installation case, download the video to your computer, and decompress it.
· Read this document.
This document describes information about installing and deploying IMC on Windows Server 2012 R2. Installing and deploying IMC on Linux is the same as that on Windows.
The IMC software is included in the DVD delivered with the product.
Preparing for installation
The tables in this section use the following terminology:
· Node—IMC servers, database servers, and devices managed by IMC are called nodes.
· Collection unit—The number of collection units equals the total number of performance instances collected at 5-minute intervals. If the collection interval is greater than 5 minutes, the number of collection units decreases. If the collection interval is smaller than 5 minutes, the number of collection units increases.
For example, if performance instances listed in Table 2 are collected every 5 minutes, the total collection units are the same as the number of performance instances, which is 24. If the collection unit is twice as the 5-minute interval (10 minutes), the number of collection units is half the total number of performance instances, which is 12.
Monitored item |
Number |
Performance index |
Performance instance |
CPU |
1 |
CPU usage |
1 |
Memory |
1 |
Memory usage |
1 |
10 |
Receiving rate |
10 |
Sending rate |
10 |
Device |
1 |
Unreachability rate |
1 |
Response time |
1 |
Total |
24 |
· Java heap size—Java heap size that can be used by the IMC Web server.
To set the Java heap size for IMC on Windows, run the setmem.bat heap size script in the \client\bin directory of the IMC installation path.
Set heap size to a value in the range of 256 to 32768 for a 64-bit OS. The java heap size cannot exceed the physical memory size.
To improve I/O performance, follow these guidelines:
· When the number of the collection units is from 100 K to 200 K, install two or more disks and a RAID card with a cache of a minimum of 256 MB.
· When the number of collection units is from 200 K to 300 K, install two or more disks and a RAID card with a cache of a minimum of 512 MB.
· When the number of collection units is 300 K to 400 K, install four or more disks and a RAID card with a cache of a minimum of 1 GB.
· Install three disks in RAID 5, and four or more disks in RAID 0+1.
Optimal hardware requirements vary with scale, other management factors, and are specific to each installation. Consult H3C Support, or your local account teams for exact requirements.
If service components are added to the IMC platform, be sure to read the release notes of each component. When multiple components are deployed, the resources must be combined. Suppose the required CPU resource, memory resource, and disk resource of a component are A(num), B(num), and C(num), respectively. When multiple components are deployed, the required hardware resources are as follows:
· CPU=A0+A1+A2+A3
· Memory=B0+B1+B2+B3
· Disk=C0+C1+C2+C3
Table 3 Hardware requirements for 64-bit Windows operating system
Management scale |
System minimum requirements |
Nodes |
Collection units |
Online operators |
CPU (2.5GHz or above) |
Server memory |
Java heap size |
Disk space for installation |
Disk space for data storage |
0 to 200 |
0 to 5 K |
20 |
2 cores |
12 GB |
4 GB |
100 GB |
100 GB |
0 to 200 |
5 K to 50 K |
10 |
2 cores |
12 GB |
4 GB |
100 GB |
200 GB |
200 to 1 K |
0 to 10 K |
30 |
4 cores |
16 GB |
4 GB |
100 GB |
100 GB |
200 to 1 K |
10 K to 100 K |
10 |
4 cores |
16 GB |
4 GB |
100 GB |
200 GB |
UAM
You can deploy the portal component on multiple servers in distributed mode. When there are high requirements for portal access, as a best practice, deploy the portal component in distributed mode. When you deploy the portal component in distributed mode, as a best practice, support more users on a dedicated portal server. A dedicated portal server must have at least a configuration that is one level lower than the current configuration.
If the number of managed access users is above 5k and self-service center is needed, you must deploy self-service center in distributed mode. A dedicated self-service center must have at least a configuration that is one level lower than the current configuration.
The following deployment scheme is given based on some reasonable assumptions. More specifically:
· In the following tables, the 802.1X access method represents any access method that does not need the collaboration of UAM, except portal access.
· The CPU requirements of EIA specified here are requirements for Intel CPUs. The requirements for Kunpeng and Feiteng ARM CPUs must be twice the requirements for Intel CPUs.
Management scale |
Managed access users |
Online operators |
Access method |
Authentication method |
Online users |
Concurrent online users |
CPU (2.0GHz or above) |
Memory |
Java heap size |
Disk size for installing IMC
Disk size for running IMC
Maximum IOPS of running disks |
<=20K |
5 |
802.1X |
PAP/CHAP/EAP-MD5 |
10000 |
100 |
4-core CPU |
16G |
4G |
150GB |
100GB |
300 (as a best practice, configure a RAID controller with the cache higher than 192M) |
EAP-PEAP/TLS/TTLS |
3000 |
10 |
Portal |
PAP/CHAP |
6000 |
50 |
EAP-PEAP/TLS/TTLS |
3000 |
10 |
<=100K |
10 |
802.1X |
PAP/CHAP/EAP-MD5 |
50000 |
200 |
8-core CPU |
32G |
8G |
300GB |
150GB |
600 (as a best practice, configure a RAID controller with the cache higher than 256M) |
EAP-PEAP/TLS/TTLS |
15000 |
20 |
Portal |
PAP/CHAP |
20000 |
150 |
EAP-PEAP/TLS/TTLS |
15000 |
20 |
<=500K |
15 |
802.1X |
PAP/CHAP/EAP-MD5 |
100000 |
500 |
16-core CPU |
64G |
12G |
600GB |
300GB |
1000 (as a best practice, configure a RAID controller with the cache higher than 1G) |
EAP-PEAP/TLS/TTLS |
30000 |
50 |
Portal |
PAP/CHAP |
40000 |
300 |
EAP-PEAP/TLS/TTLS |
20000 |
40 |
Table 5 64-bit Linux
Management scale |
Online operators |
Access method |
Online users |
Memory |
Java heap size |
<=20K |
5 |
802.1X |
PAP/CHAP/EAP-MD5 |
10000 |
100 |
4-core CPU |
16G |
4G |
150GB |
100GB |
800 (as a best practice, configure a RAID controller with the cache higher than 192M) |
EAP-PEAP/TLS/TTLS |
3000 |
10 |
Portal |
PAP/CHAP |
6000 |
50 |
EAP-PEAP/TLS/TTLS |
3000 |
10 |
<=100K |
10 |
802.1X |
PAP/CHAP/EAP-MD5 |
50000 |
200 |
8-core CPU |
32G |
8G |
300GB |
150GB |
1800 (as a best practice, configure a RAID controller with the cache higher than 256M) |
EAP-PEAP/TLS/TTLS |
15000 |
20 |
Portal |
PAP/CHAP |
20000 |
150 |
EAP-PEAP/TLS/TTLS |
15000 |
20 |
<=500K |
15 |
802.1X |
PAP/CHAP/EAP-MD5 |
100000 |
500 |
16-core CPU |
64G |
12G |
600GB |
300GB |
2400 (as a best practice, configure a RAID controller with the cache higher than 1G) |
EAP-PEAP/TLS/TTLS |
30000 |
50 |
Portal |
PAP/CHAP |
40000 |
300 |
EAP-PEAP/TLS/TTLS |
20000 |
40 |
TAM
The managed devices refer to the devices added to the device list for the device authentication service.
Table 6 64-bit Windows/Linux
Management scale |
Managed devices |
Memory |
Java heap size |
<=5000 |
4-core CPU |
8G |
2G |
3GB |
160GB |
<=20K |
8-core CPU |
16G |
4G |
3GB |
320GB |
When the number of collection units is 0 to 5k, no or few performance monitors are enabled.
Management scale |
Nodes |
Collection units |
Online operators |
Memory |
Java heap size |
Fit APs: 0 to 500 |
0 to 50K |
10 |
2-core CPU |
4G |
1G |
3GB |
60GB |
Fit APs: 500 to 1000 |
16K to 90K |
10 |
4-core CPU |
8G |
4G |
3GB |
100GB |
Fit APs: 1000 to 3000 |
32K to 150K |
10 |
6-core CPU |
16G |
6G |
4GB |
200GB |
Fit APs: 3000 to 5000 |
100K to 250K |
10 |
8-core CPU |
24G |
8G |
5GB |
250GB |
Enterprise network: fit APs: 5000 to 10000 |
160K to 400K |
10 |
12-core CPU |
32G |
12G |
7GB |
300GB |
Service provider: Fit APs: 5000 to 8000 |
Management scale |
Nodes |
Collection units |
Online operators |
Memory |
Java heap size |
Fit APs: 0 to 500 |
0 to 50K |
10 |
2-core CPU |
4G |
1G |
3GB |
60GB |
16K to 90K |
10 |
4-core CPU |
8G |
4G |
3GB |
100GB |
32K to 150K |
10 |
6-core CPU |
16G |
6G |
4GB |
200GB |
100K to 250K |
10 |
8-core CPU |
24G |
8G |
5GB |
250GB |
160K to 400K |
10 |
12-core CPU |
32G |
12G |
7GB |
300GB |
Software requirements
Item |
Requirement |
Remarks |
Operating system |
Windows Server 2012 |
KB2836988 |
Windows Server 2012 R2 (64-bit) |
N/A |
Windows Server 2016 R1 (64-bit) |
N/A |
Windows Server 2019 (64-bit) |
N/A |
Database |
SQL Server 2017 Express |
Used only for the embedded database of the SNS and standard editions. |
IMC integrates the embedded database SQL Server 2017 Express for the Windows operating system.
Before installing an embedded database, go to http://www.microsoft.com/downloads to download and install .NET Framework 4.6 or .NET Framework 4.7.
NOTE: This restriction does not apply to embedded databases for the Linux operating system. |
VM requirements
As a best practice, install IMC on a physical server.
When installed on a virtual machine, IMC supports the following virtual platforms:
· VMware:
¡ VMware ESXi 5.5
¡ VMware ESXi 6.0
¡ VMware ESXi 6.5
¡ VMware ESXi 6.7
· CAS:
¡ CAS 2.0
¡ CAS 3.0
¡ CAS 5.0
· Hyper-V:
¡ Hyper-V 2008 R2
¡ Hyper-V 2012
¡ Hyper-V 2012 R2
If IMC is installed on a virtual machine, do not change the following virtual machine configuration settings:
· CPU cores
· Number, model, and MAC addresses of network adapters
· Number of disk drives
· Storage paths
· Assignment of storage
If the settings are changed, IMC might not operate correctly.
To ensure correct installation and operation of IMC, make sure no other network management products are installed on the same server as IMC.
Do not install IMC in an IPv6 environment. However, IMC allows users to manage IPv6 devices.
If IMC has been previously installed and uninstalled on the system, make sure the uninstallation is thorough. Verify that the iMC-Reserved folder is removed from the WINDOWS folder of the system disk.
For information about uninstalling IMC, see "Uninstalling IMC."
IMC provides an envcheck tool (envcheck.bat for Windows and envcheck.sh for Linux) for checking the system environment. The tool is in the install folder of the IMC installation package.
To check the installation environment:
1. Run the envcheck check tool. The installation environment check window opens. The tool will check the server port occupancy, physical memory usage, and database installation in the environment automatically.
Figure 1 Checking the installation environment
2. In the Checking installation parameters window that opens, you can edit the installation parameters as required.
Information in the Windows operating system is used as an example here.
Figure 2 Checking installation parameters
¡ Installation Position—By default, IMC is installed in the Program Files\iMC path (/opt/iMC path in Linux) on the disk with the largest free space. You can manually modify the iMC installation location and data file storage location, or click <...> to select the iMC installation location and data file storage location.
¡ Data file location—By default, data files are stored in the Program Files\imcdata path (/opt/imcdata path in Linux) on the disk with the largest free space. You can manually modify the iMC installation location and data file storage location, or click <...> to select the iMC installation location and data file storage location. The data file storage location must be empty or the installation will fail.
¡ HTTP/HTTPS port—Enter the Web service port. By default, the HTTP port is 8080 and HTTPS port is 8443. You can also self-define a port that is not occupied as the Web service port.
3. Click OK. The check result is displayed.
Figure 3 Installation environment check result
4. Click Exit and fix any failed check items according to the check results.
Checking ports and firewalls
Make sure the IMC Web service ports and database listening ports are open in the firewall. Table 10 lists the default IMC Web service ports and database listening ports.
Table 10 IMC port requirements
Server |
Usage: protocol/default port |
Direction |
Web |
HTTP: TCP/8080 HTTPS: TCP/8443 |
Browser to IMC |
Make sure the javaw.exe and java.exe programs located in the \common\jre\bin directory of the IMC installation path are not blocked by the firewall.
Use tools such as netstat -a and telnet hostname port to verify access between systems.
Setting the system time
Follow these guidelines when you set the system time:
· Do not enable seasonal time adjustments such as daylight savings time.
· Before installing IMC, verify that the system time, date, and time zone settings on the server are correct.
Do not modify the system time on the server after IMC is started. If you modify the system time, the following problems might occur:
· When jumping to a future time, the system might get so occupied in processing the sudden burst of expired data that real-time data sampling will be delayed. The delay is automatically recovered after the processing of expired data is complete.
· When you change the system time to a past time, data with overlapping time occurs, and data processing might become abnormal. After the overlapping time is past, data processing becomes normal again.
You can use the database embedded in IMC of SNS and Standard editions on Windows or Linux without installing any database or database client prior to IMC installation.
The following information describes how to install and deploy the IMC platform of the standard edition on Windows.
1. Log in to Windows as an administrator.
2. Run the install.bat script in the install directory of the IMC installation package.
The Select Country/Region, Language, and Installation Type dialog box opens, as shown in Figure 4.
Figure 4 Select Country/Region, Language, and Installation Type dialog box
3. Select the country/region, language, and installation type.
IMC supports typical and custom installations.
¡ Typical—In this mode, all platform subcomponents are automatically installed and deployed on the local host without manual intervention.
¡ Custom—In this mode, you can select desired platform subcomponents to install on the local host. After installation is complete, you must manually deploy the platform subcomponents.
4. Click OK.
When you install or upgrade IMC, follow these guidelines:
· When you install or upgrade IMC, restart the IMC server if a socket issue exists in the IMC installation environment. If no socket issue exists, you do not need to restart the IMC server.
· The installation packages of the following components are located in the tools\components directory: ACL, EUPLAT, GAM, RestPlugin, VLAN, and WeChat. Before you install and deploy the IMC platform, copy the installation packages of the components you want to install to the install\components directory.
1. In the Select Country/Region, Language, and Installation Type dialog box, select the Typical installation type, and then click OK.
The Checking installation parameters dialog box opens, as shown in Figure 5.
Figure 5 Checking installation parameters
2. Configure the installation parameters:
a. Specify the installation location and database file location, or customize the installation location and database file location as needed.
The default installation location is the \Program Files\iMC directory of the disk that has the maximum free space.
The default data file location is the \Program Files\imcdata directory of the same disk with the default installation location.
b. Configure the Web service port numbers (8080 for HTTP and 8443 for HTTPS by default).
You can also use other service port numbers that are not used by other services.
3. Click OK.
The dialog box for checking installation environments opens and displays the check results.
Fix any failed check items according to the check results.
After the checks are passed, the system installs and deploys all IMC platform subcomponents.
After IMC installation and deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 6.
Figure 6 Batch deploy succeeded
4. Click OK.
1. In the Select Country/Region, Language, and Installation Type dialog box, select the Custom installation type, and then click OK.
The Checking installation environments dialog box opens, as shown in Figure 7.
Figure 7 Checking installation environments
2. Click Continue.
After the checks are passed, the IMC installation wizard opens, as shown in Figure 8.
Figure 8 IMC installation wizard
3. Click Next.
The Agreement page opens, as shown in Figure 9.
Figure 9 Agreement page
4. Read the license agreement, select Accept, and then click Next.
The Choose Target Folder page opens, as shown in Figure 10.
Figure 10 Choose Target Folder page
5. Select the components you want to install and specify a local path as the installation location.
By default, IMC is installed in the \Program Files\iMC directory of the disk with the maximum amount of free space. This example uses the default path.
You can enter a path or click Browse to select another path.
6. Click Next.
The Deployment and Upgrade Options page opens, as shown in Figure 11.
Figure 11 Deployment and Upgrade Options page
7. Select Deploy or upgrade at once or Deploy or upgrade later. In this example, select Deploy or upgrade later.
8. Click Next.
The Installation Summary page opens, as shown in Figure 12.
Figure 12 Installation Summary page
9. Verify the installation summary, and then click Install.
After the installation is complete, the Installation Completed page opens, as shown in Figure 13.
Figure 13 Installation Completed page
10. Select Open deployment monitoring agent, and then click Finish.
The system automatically starts the Intelligent Deployment Monitoring Agent and displays the Batch deploy dialog box, as shown in Figure 14.
Figure 14 Batch deploy dialog box
11. Select the components to be deployed, and then click OK.
The Database Configuration page opens, as shown in Figure 15.
Figure 15 Database Configuration page
12. Click Cancel to exit the deployment wizard, and then click OK in the window that opens.
13. On the Deploy tab of the Intelligent Deployment Monitoring Agent window, right-click the resource management component, and then select Deploy, as shown in Figure 16.
Figure 16 Deploying the resource management component
14. In the confirmation dialog box that opens, click Yes.
The deployment wizard opens, as shown in Figure 17.
15. Click Next.
The Database Configuration page opens, as shown in Figure 18.
Figure 18 Database Configuration page
16. Click Back to return to the Deployment Wizard page, as shown in Figure 17, and then click Next to enter the Database Configuration page, as shown in Figure 19.
Figure 19 Database Configuration page
17. Select the location for saving database files.
By default, the data files are stored in the \Program Files\imcdata directory of the disk with the maximum amount of free space on Windows.
NOTE: Make sure the specified data file location is on a writable and uncompressed disk drive and does not contain any files. |
18. Click Next.
The Configure Web Service Port page opens, as shown in Figure 20.
Figure 20 Configure Web Service Port page
19. Enter the HTTP and HTTPS port numbers. This example uses the default port numbers 8080 and 8443.
If you specify other port numbers, make sure the specified ports are not used by other services.
20. Click Deploy.
21. After the resource management component deployment is complete, click Finish to close the deployment wizard.
22. On the Deploy tab of the Intelligent Deployment Monitoring Agent window, right-click the component you want to deploy, and then select Batch Deploy. In the Batch deploy window that opens, select the target components, as shown in Figure 21.
23. Click OK to start deployment.
After the deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 22.
Figure 22 Batch deploy succeeded dialog box
24. Click OK.
The Intelligent Deployment Monitoring Agent is automatically installed after the IMC platform is installed.
As the IMC management and maintenance tool, the Intelligent Deployment Monitoring Agent provides IMC operation information, as well as a variety of management options, such as:
· Starting and stopping IMC.
· Installing new components.
· Upgrading IMC components.
· Deploying and removing components.
To start the Intelligent Deployment Monitoring Agent, click Start, access the all applications page, and then select iMC > Deployment Monitoring Agent.
To start the Intelligent Deployment Monitoring Agent on Linux, run the dma.sh script in the /deploy directory of the IMC installation path.
As shown in Figure 23, the agent contains the following tabs: Monitor, Process, Deploy, and Environment. By default, the Monitor tab is displayed.
The following information describes the functionality of each tab.
Figure 23 Intelligent Deployment Monitoring Agent
Monitor tab
As shown in Figure 24, the Monitor tab displays the performance information for the IMC server, including the disk, CPU, and physical memory usage information.
This tab also provides the following options:
· Start—Click this button to start IMC. This button is available when IMC is stopped.
IMPORTANT: For correct operation, the Intelligent Management Server service must start with an account that has read/write permissions on the IMC installation folder. By default, the Intelligent Management Server service starts with the Local System account. |
· Stop—Click this button to stop IMC. This button is available when IMC is already started.
· Automatically start the services when the OS starts—Select this option to automatically start IMC when the operating system starts.
· Install—Click this button to install new components or upgrade existing components.
Figure 24 Monitor tab of the Intelligent Deployment Monitoring Agent
Process tab
As shown in Figure 25, the Process tab displays IMC process information.
Figure 25 Process tab of the Intelligent Deployment Monitoring Agent
The right-click menu of a manageable process provides the following options:
· Start Process—Select this option to start the process. This option is available when the process is stopped.
· Stop Process—Select this option to stop the process. This option is available when the process is started.
· Auto Start—Select this option to enable an automatic startup of the process when IMC is started.
· Manual Start—Select this option to require a manual startup of the process.
· Refresh Process Status—Select this option to refresh the status of the process.
Deploy tab
As shown in Figure 26, the Deploy tab displays information about all deployed components.
Figure 26 Deploy tab of the Intelligent Deployment Monitoring Agent
The right-click menu of a component provides the following options:
· Deploy—Select this option to deploy the component on the local host.
This option is available only when the selected component is in Undeployed state.
· Batch Deploy—Select this option to batch deploy components on the local host.
Components can be deployed only when they have been installed, but in Undeployed state.
· Undeploy—Select this option to undeploy the component.
This option is available only when the selected component is in Deployed state.
· Undeploy From Conductor—Select this option to delete component deployment information from the conductor server.
This option is available only when the member server where the component is deployed cannot operate correctly.
· Batch Undeploy—Select this option to undeploy multiple components.
· Upgrade—Select this option to upgrade the component.
· Batch Upgrade—Select this option to upgrade components in batches.
· Remove—Select this option to remove the component from the host.
· Show Prerequisites—Select this option to view all components that the selected component depends on. The component can be deployed only after the dependent components are deployed.
This option is unavailable if the component does not depend on any other components.
· Show Dependencies—Select this option to view all components that depend on the selected component.
This option is unavailable if no other components depend on the selected component.
Environment tab
As shown in Figure 27, the Environment tab displays the software, hardware, and database information for the current IMC server.
The tab also provides database backup and restoration options in the Database Backup and Restore area.
For more information about the Environment tab, see "Backing up and restoring the database."
Figure 27 Environment tab of the Intelligent Deployment Monitoring Agent
The following information describes how to install and deploy the service components.
Table 11 Service components and subcomponents
Component |
Subcomponent |
Endpoint Intelligent Access |
· User Access Manager: ¡ Intelligent Strategy Proxy ¡ User Access Management ¡ User Access Management Sub Server ¡ Portal Server ¡ EIP Server ¡ EIP Sub Server ¡ Policy Server ¡ Policy Proxy Server ¡ User SelfService ¡ Third-Party Page Publish Server · TACACS+ Authentication Manager |
EAD Security Policy |
· Security Policy Configuration · Desktop Asset Manager · Desktop Asset Manager Proxy Server |
MPLS VPN Manager |
· MPLS VPN Management · MPLS TE management · L2VPN Management |
IPsec VPN Manager |
IPsec VPN Manager |
Wireless Service Manager |
Wireless Intrusion Prevention System |
Wireless Location Manager |
Wireless Location Engine |
User Behavior Auditor |
· User Behavior Auditor · User Behavior Auditor Server · Network Behavior Analyzer · Network Behavior Analyzer Server |
Application Manager |
· Application Management · Application Management Service |
Server & Storage Automation |
QoS Manager |
QoS Management |
Branch Intelligent Management System |
· Branch Intelligent Management System · Auto-Configuration Server · Mobile Branch Manager |
VAN Fabric Manager |
Endpoint Mobile Office |
· Mobile Office Manager · Mobile Office MDM Proxy · Intelligent Strategy Proxy |
Security Service Manager |
· Security Service Manager · Load Balancing Manager |
All the service components can be installed in the same way, but their deployment procedure might differ. Based on the deployment procedure, the service components can be classified into several categories, as shown in Table 12.
Table 12 Service components classified by deployment procedure
Example component |
Similar components |
BIMS |
IVM, UBA, QoSM, BIMS, VFM, SSM, U-Center |
UAM |
EMO, EAD, TAM, IPM, EPS |
MVM |
N/A |
The following information describes how to install and deploy BIMS, UAM, and MVM.
IMPORTANT: U-Center must be deployed on IMC PLAT 7.3 (E0706P09). Before deploying U-Center, upgrade the platform to this version. |
Installing IMC BIMS
1. Start the Intelligent Deployment Monitoring Agent, and then click Install on the Monitor tab.
The Choose folder dialog box opens, as shown in Figure 28.
Figure 28 Choose folder dialog box
2. Click Browse, and then select the install\components folder in the BIMS installation package.
3. Click OK.
The IMC installation wizard opens, as shown in Figure 29.
Figure 29 IMC installation wizard
4. Click Next.
The Agreement page opens, as shown in Figure 30.
Figure 30 Agreement page
5. Read the license agreement and third-party license, and then select Accept.
6. Click Next.
The Choose Target Folder page opens, as shown in Figure 31.
The Installation Location field is automatically populated with the installation location of the IMC platform and cannot be modified.
Figure 31 Choose Target Folder page
7. Select the BIMS subcomponents you want to install in the component list.
8. Click Next.
The Deployment and Upgrade Options page opens, as shown in Figure 32.
Figure 32 Deployment and Upgrade Options page
9. Select Deploy or upgrade later.
10. Click Next.
The Installation Summary page opens, as shown in Figure 33.
Figure 33 Installation Summary page
11. Verify the installation information, and then click Install.
After the installation is complete, the Installation Completed page opens, as shown in Figure 34.
Figure 34 Installation Completed page
Deploying IMC BIMS
1. Select Open deployment monitoring agent, and then click Finish.
The Batch deploy dialog box opens, as shown in Figure 35.
Figure 35 Batch deploy dialog box
2. Select the BIMS subcomponents you want to deploy.
In this example, select all of the BIMS subcomponents.
3. Click OK.
The Configure Web Service Port page opens, as shown in Figure 36.
Figure 36 Configure Web Service Port page
4. Enter the HTTP and HTTPS port numbers. This example uses the default port numbers 9090 and 9443.
5. Click Deploy.
The system starts to deploy the selected BIMS subcomponents.
After the deployment is completed, the Batch deploy succeeded dialog box opens, as shown in Figure 37.
Figure 37 Batch deploy succeeded dialog box
6. Configure the Start Server now option as needed, and then click OK.
Installing IMC UAM
Install IMC UAM in the same way IMC BIMS is installed. (Details not shown.)
For information about the installation procedures, see "Installing IMC BIMS."
Deploying IMC UAM
1. On the Installation Completed page shown in Figure 38, select Open deployment monitoring agent, and then click Finish.
Figure 38 Installation Completed page
The Batch deploy dialog box opens, as shown in Figure 39.
Figure 39 Batch deploy dialog box
2. Select the UAM subcomponents you want to deploy, and then click OK.
In this example, select all of the UAM subcomponents, except for EIP Sub Server and Third-Party Page Publish Server.
The EIP Sub Server subcomponent can be deployed only on member servers in distributed deployment.
The IMC deployment wizard starts and displays the Intelligent Strategy Proxy Configuration page, as shown in Figure 40.
Figure 40 Intelligent Strategy Proxy Configuration page
3. Configure the following parameters:
¡ IPv4 Address(Client)—Enter the IP address of the Intelligent Strategy Proxy component. By default, this field is automatically populated with the IP address of the local host.
¡ IPv4 Address(Server)—Enter the IP address of the User Access Management component. By default, this field is automatically populated with the IP address of the local host.
Modify the default settings only when the local host has multiple network interface cards (NICs) and you want to associate Intelligent Strategy Proxy and User Access Management with different NICs.
4. Click Deploy.
The Configure User Access Management page opens, as shown in Figure 41.
Figure 41 Configure User Access Management page
5. Configure the following parameters:
¡ Database Password/Confirm Password—These fields are automatically populated with the database user password specified during IMC platform installation.
If the database user password is changed after IMC platform installation, enter the new password in these fields.
¡ UAM Server's IPv4 Address—This field is automatically populated with the IP address of the local host.
6. Click Deploy.
The Configure Portal Component page opens, as shown in Figure 42.
Figure 42 Configure Portal Component page
7. Use the default settings, and then click Deploy.
The Configure EIP Server page opens, as shown in Figure 43.
Figure 43 Configure EIP Server page
8. Use the default settings, and then click Deploy.
The Configure Policy Server page opens, as shown in Figure 44.
Figure 44 Configure Policy Server page
9. Use the default settings, and then click Deploy.
The Configure User SelfService page opens, as shown in Figure 45.
Figure 45 Configure User SelfService page
10. Use the default settings, and then click Deploy.
The Configure WeChat Authentication Server page opens, as shown in Figure 46.
Figure 46 Configure WeChat Authentication Server page
11. Use the default settings, and then click Deploy.
All the selected UAM subcomponents are deployed.
The Batch deploy succeeded dialog box opens, as shown in Figure 47.
Figure 47 Batch deploy succeeded dialog box
12. Configure the Start Server now option as needed, and then click OK.
Installing IMC MVM
Install IMC MVM in the same way IMC BIMS is installed. (Details not shown.)
For information about the installation procedure, see "Installing IMC BIMS."
Deploying IMC MVM
1. On the Installation Completed page shown in Figure 48, select Open deployment monitoring agent, and then click Finish.
Figure 48 Installation Completed page
The Batch deploy dialog box opens, as shown in Figure 49.
Figure 49 Batch deploy dialog box
2. Select the MVM subcomponents you want to deploy, and then click OK.
In this example, select all of the MVM subcomponents.
The Please Choose L2VPN Global Parameter Operate page opens, as shown in Figure 50.
Figure 50 Please Choose L2VPN Global Parameter Operate page
3. Configure the L2VPN parameters as needed.
VPLS can use either LDP or BGP for signaling. When BGP is selected, the VLL and PBB options become unavailable.
4. Click Deploy.
After the deployment is complete, the Batch deploy succeeded dialog box opens, as shown in Figure 51.
Figure 51 Batch deploy succeeded dialog box
5. Configure the Start Server now option as needed, and then click OK.
Installing plug-ins
Installing DHCP plug-ins
To enable IMC to obtain endpoint names from a DHCP server, install DHCP plug-ins on the DHCP server.
For IMC to obtain endpoint names from a DHCP server correctly, the following requirements must be met:
· The DHCP server must exist, and it is the only DHCP server that has the DHCP plug-in installed and is reachable from the IMC server.
· The DHCP Server service and iMC DHCP Plug service are enabled on the DHCP server.
· The DHCP server is added to IMC and its configuration is synchronized to IMC.
· The IMGAddress value in file server\imf\server\conf\imf.cfg on the DHCP server is set correctly.
By default, IMC does not obtain reserved or allocated IP addresses from the DHCP server. To enable IMC to obtain such addresses, perform the following tasks:
1. On the DHCP server, set the value of GetDHCPAllocAndReservedIpInfoFlag to 1 in file server\imf\server\conf\ dhcp_agent.cfg.
2. Restart the iMC DHCP Plug service on the DHCP server.
3. On the IMC server, synchronize the DHCP server configuration to IMC.
1. On the IMC server, edit the qvdm.conf file to enable IMC to obtain endpoint names or fully qualified domain names (FQDNs) from DHCP servers:
a. In the \server\conf\ directory of the IMC installation path, use Notepad to open the qvdm.conf file.
b. Add the following line to the file:
l2topoPCNameDhcpSwitch=1
c. Save and close the file.
d. Restart IMC in the Intelligent Deployment Monitoring Agent.
2. On the MS DHCP server, edit the imf.cfg file so that the DHCP server can communicate with IMC:
a. Transfer the plug-in installation package dhcp-plug-windows.zip from the \windows\tools\ directory of the IMC installation package on the IMC server to the MS DHCP server.
b. Decompress the installation package.
c. Use Notepad to open the imf.cfg file in the \dhcp-plug-windows\server\imf\server\conf directory.
d. Edit the imf.cfg file:
- Set the value of IMGAddress to the IP address of the IMC server.
- Set the value of IMGPort to the IMG port number, which is 8800 by default.
e. Save and close the file.
3. Run the install.bat script in the dhcp-plug-windows directory.
After the installation is complete, a new service IMC DHCP Plug is added to the system services.
4. Start the iMC DHCP Plug service:
a. Click Start, and then select Administrative Tools > Component Services.
b. On the Component Services page, select Services (Local) from the navigation tree.
c. On the Services (Local) list, right-click the IMC DHCP Plug service, and then select Start.
To uninstall the DHCP plug-in, run the uninstall.bat script in the dhcp-plug-windows directory.
IMPORTANT: Do not delete the directory where the plug-in installation package dhcp-plug-windows.zip is decompressed. If you delete the directory, you cannot uninstall the DHCP plug-in completely. |
1. On the IMC server, edit the qvdm.conf file to enable IMC to obtain endpoint names or FQDNs from DHCP servers:
a. In the \server\conf directory of the IMC installation path, use Notepad to open the qvdm.conf file.
2. On the Linux IMC server, edit the imf.cfg file so that the DHCP server can communicate with IMC.
a. Transfer the plug-in installation package dhcp-plug-linux.zip from the tools directory of the IMC installation package on the IMC server to the Linux DHCP server.
c. Use the vi editor to open the imf.cfg file in the /dhcp-plug-linux/server/imf/server/conf/ directory.
vi imf.cfg
3. Set the path of the dhcpd.leases file, which stores DHCP address allocation information:
a. Determine the path of the dhcpd.leases file. The default path is /var/lib/dhcp.
b. Use the vi editor to open the qvdm.conf file in the /dhcp-plug-linux/server/imf/server/conf/ directory, and then add the following line to the file:
DhcpPlugIpAllocPath=<file path>/dhcpd.leases
Replace file path with the path of the dhcpd.leases file.
4. Run the install.sh script in the dhcp-plug-linux directory.
After the installation is complete, the system automatically starts the dhcp-plug service and adds the service to the system services.
To manually start the dhcp-plug service, execute the service dhcp-plug start command.
To stop the dhcp-plug service, execute the service dhcp-plug stop command.
To uninstall the DHCP plug-in, run the uninstall.sh script in the dhcp-plug-linux directory of the plug-in installation package.
IMPORTANT: · Do not delete the directory to which the plug-in installation package dhcp-plug-linux.zip is decompressed. If you delete the directory, you cannot uninstall the DHCP plug-in completely. · You cannot configure the Linux DHCP server by using the Terminal Access > DHCP Configuration feature. |
Installing LLDP plug-ins
If topology calculation fails for displaying connection to servers, install an LLDP plug-in.
An LLDP plug-in contains the following packages:
· lldp-agent-redhat.zip
· lldp-agent-ubuntu.zip
· lldp-agent-windows.zip
Packages lldp-agent-redhat.zip and lldp-agent-ubuntu.zip apply to KVM servers and the lldp-agent-windows.zip package applies to Microsoft Hyper-V servers.
Before you install the LLDP plug-ins, save and decompress the packages to the target servers.
Make sure the lldp-agent-windows.zip package is saved to a non-system disk.
IMPORTANT: For DHCP plug-ins to be uninstalled completely, do not delete the folder where the decompressed installation packages are located after LLDP agent installation. |
The installation procedures for packages lldp-agent-redhat.zip and lldp-agent-ubuntu.zip are the same. The following information describes the installation procedure for the lldp-agent-redhat.zip package.
An LLDP Linux agent must be installed on 64-bit Linux, including Red Hat 5.5, Ubuntu 11.0, and their later versions.
To install and configure an LLDP Linux agent:
1. Set the executable permission to the install.sh script and run the script in the LLDP Linux agent installation path.
The LLDP Linux agent is installed.
2. Configure the LLDP Linux agent.
The configuration file lldpagent.conf is located in the conf directory of the LLDP Linux agent installation path.
The LLDP Linux agent supports both LLDP and CDP. You can enable either of them, but not both. By default, the agent support LLDP.
To enable the LLDP agent to support CDP and set the packet sending interval:
a. Open the lldpagent.conf file in the conf directory.
vi lldpagent.conf
b. Delete the pound sign (#) from the string #Agent=CDP.
c. Delete the pound sign (#) from the string #INTERVAL=300 and set the interval as needed.
The default setting is 300 seconds.
d. Save and close the file.
3. Restart the lldp-agent service.
service lldp-agent restart
LLDP Windows agent plug-ins support 32-bit and 64-bit Windows operating systems.
To install and configure an LLDP Windows agent:
1. Run the install.bat script in the LLDP Windows agent installation path.
The LLDP Windows agent is installed.
2. Configure the LLDP Windows agent.
The configuration file lldpagent.conf is located in the conf directory of the LLDP Windows agent installation path.
The LLDP Windows agent supports both LLDP and CDP. You can enable either of them, but not both. By default, the agent supports LLDP.
a. Open the lldpagent.conf file in the \Program Files\lldpAgent\ directory on the Windows system disk.
Accessing IMC
IMC is a browser-based management tool accessible from PCs. IMC of the Professional edition is also accessible from a mobile device.
Table 13 lists the hardware, software, and browser requirements for accessing IMC.
Table 13 Requirements for accessing IMC from a PC
OS |
Hardware and software |
Browser version |
Browser setting requirements |
Windows |
· Recommended resolution: 1280 pixels in width. · JRE 1.7.0_update76 or later is installed. |
· IE 10 or 11 · Firefox 50 or later · Chrome 44 or later |
· Turn off the popup blocker. · Enable Cookies. · Add IMC as a trusted site. |
Accessing IMC from a PC
Accessing IMC
1. Enter a URL in either of the following formats in the address bar of the browser:
¡ http://ip-address:port/imc
¡ https://ip-address:port/imc
In the URL strings, ip-address is the IP address of the IMC server, and port is the HTTP or HTTPS port number used by IMC. By default, IMC uses HTTP port 8080 and HTTPS port 8443.
The IMC login page opens.
2. Enter the username and password, and then click Login.
The default username for the iMC super administrator is admin. For versions earlier than iMC PLAT 7.3 (E0706), the default password is admin. For iMC PLAT 7.3 (E0706) and later versions, the default password is Pwd@12345.
IMPORTANT: · For security purposes, change the password of the IMC superuser admin immediately after the first login. · When you attempt to access IMC using HTTPS, a certificate error message might be displayed. For more information, see H3C Getting Started Guide. |
When the UAM user self-service component is deployed, access the user self-service center by entering a URL in either of the following formats in the address bar of the browser:
· http://ip-address:port
· http://ip-address:port/selfservice
In the URL, ip-address is the IP address of the IMC server where the UAM user self-service is deployed and port is the HTTP port number used by IMC.
1. Open the browser on the mobile device.
2. Enter http://ip-address:port/imc in the browser's address bar.
In the URL, ip-address is the IP address of the IMC server and port is the HTTP port number of IMC. The default HTTP port number is 8080.
3. Enter the username and the password in the Operator and Password fields.
Make sure the operator has been added to IMC. The operator account used for login must belong to an operator group that has the iMC Platform - Resource Management > Mobile Client Access operation privilege.
4. Select Mobile or PC as needed.
The PC version of IMC requires complex operations and provides all functions. The mobile version of IMC allows you to perform the following operations:
¡ View information about faulty devices and interfaces.
¡ Query devices.
¡ View device alarms.
¡ Receive real-time alarms.
¡ Test device reachability by using a ping or tracert command.
¡ View custom views and device views.
5. Click Login.
Securing IMC
As a best practice, perform the following tasks to secure IMC:
· Change the password of the IMC superuser admin immediately after the first login.
· Tie the administrative accounts to a central AAA server via LDAP or RADIUS.
· Retain one administrative account (not named admin) with a local password to recover from a loss of access to the AAA server.
· Enable the verification code feature on the IMC login page. For more information, see H3C IMC Getting Started Guide.
Displaying a user agreement
You can display a user agreement on the IMC login page to inform operators of the rights and obligations for an IMC login. To log in to IMC, operators must accept terms of the user agreement.
To display a user agreement on the IMC login page:
1. On the IMC server, enter the \client\conf directory of the IMC installation path.
2. Use Notepad to open the commonCfg.properties file.
3. Change the value of the enableTerms parameter to true.
4. Save and close the commonCfg.properties file.
5. Prepare a user agreement in HTML format named terms.html.
6. Save the terms.html file to the \client\web\apps\imc directory of the IMC installation path.
7. Display the IMC login page.
A User agreement link is displayed. Operators can click the link to view terms of the user agreement.
Figure 52 Viewing the user agreement on the login page
Upgrading IMC
The following information describes how to upgrade IMC components, using the IMC platform as an example.
Preparing for the upgrade
Before you upgrade the IMC platform, complete the following tasks:
· Obtain the upgrade packages for the IMC platform and all the deployed service components. After the IMC platform upgrade, you must upgrade all the service components.
· Back up the IMC installation directory and database files. If the upgrade fails, you can use the backup files to restore IMC.
To back up the IMC installation directory and database files:
a. Use DBMan in the Intelligent Deployment Monitoring Agent to back up the database files. For more information, see manual backup described in "Backing up and restoring the database."
b. Stop all IMC processes, and then manually copy the IMC installation directory to a specific path.
Upgrading IMC
CAUTION: · Make sure you have compatible upgrade packages for all deployed IMC components. If components do not have upgraded packages, they cannot be upgraded after the IMC platform upgrade and might become invalid. · Do not upgrade IMC by running the install\install.bat script in the IMC installation path. · If the reporting function of an upgraded service component relies on the Report Management component, upgrade the Report Management component to match the service component version. |
You can use one of the following methods to upgrade components that are installed in the tools\components directory:
· Copy files of the following components from the tools\components directory to the IMC installation directory install\components: ACL, EUPLAT, GAM, RestPlugin, VLAN, and WeChat. These components are upgraded when you upgrade the IMC platform.
· Click Install in the Monitor tab of the Intelligent Deployment Monitoring Agent and select to upgrade components in the tools\components directory.
Upgrading the IMC platform
The Choose folder dialog box opens, as shown in Figure 53.
Figure 53 Choose folder dialog box
2. Click Browse, and then select the \install\components directory in the upgrade package.
3. Click OK.
The IMC installation wizard opens, as shown in Figure 54.
Figure 54 IMC installation wizard
4. Click Next.
The Agreement page opens, as shown in Figure 55.
Figure 55 Agreement page
5. Read the license agreement, select Accept, and then click Next.
The Upgrade Common Components dialog box opens, as shown in Figure 56.
NOTE: Common components include the Intelligent Deployment Monitoring Agent and common background services. |
Figure 56 Upgrade Common Components dialog box
6. Click OK.
The system automatically upgrades common components and displays the upgrade progress, as shown in Figure 57.
Figure 57 Upgrading common components
After the common components are upgraded, the Choose Target Folder page opens, as shown in Figure 58.
The page displays the components whose upgrade packages are to be installed and the installation location.
Figure 58 Choose Target Folder page
7. Verify the information, and then click Next.
The Deployment and Upgrade Options page opens, as shown in Figure 59.
Figure 59 Deployment and Upgrade Options page
8. Select Deploy or upgrade at once, and then click Next.
The Installation Summary page opens, as shown in Figure 60.
Figure 60 Installation Summary page
After the installation is complete, the Batch upgrade dialog box opens, as shown in Figure 61.
Figure 61 Batch upgrade dialog box
10. Select the components you want to upgrade, and then click OK.
After the upgrade is complete, the Batch upgrade result dialog box shown in Figure 62 or Figure 63 opens. The dialog box content varies depending on whether auto backup and restoration settings have been configured in DBMan before the upgrade.
Figure 62 Batch upgrade result
Figure 63 Batch upgrade result
11. Click OK.
12. If the Auto Backup and Restore Settings dialog box opens, configure the auto backup and restoration settings, and then click OK.
13. To start IMC, click Start on the Monitor tab of the Intelligent Deployment Monitoring Agent.
Restoring IMC
If the IMC upgrade still fails, restore IMC to the version before the upgrade:
1. Restore the IMC database. For more information, see manual restoration described in "Backing up and restoring the database."
2. After the restoration is complete, stop IMC in the Intelligent Deployment Monitoring Agent.
3. Close the Intelligent Deployment Monitoring Agent.
4. Stop the Intelligent Management Server service in the server manager.
5. In the IMC installation directory, back up log files necessary for upgrade failure analysis, and then delete all the files in the directory.
6. Copy the backup IMC installation directory to the IMC installation path.
7. Start the Intelligent Management Server service in the server manager.
8. Start IMC in the Intelligent Deployment Monitoring Agent.
For IMC running in stateful failover mode, restore IMC only on the active server in the failover system.
Uninstalling IMC
The following information describes how to uninstall IMC on Windows Server 2012.
To reinstall IMC, complete the following tasks before reinstallation:
· If you reinstall the database after uninstalling IMC, you must manually delete the folder that stores data files of the previous IMC system. The default folder is named imcdata.
· If IMC installation or uninstallation interrupts with an error, manually delete the IMC installation directory and the iMC-Reserved folder. The iMC-Reserved folder is located in the WINDOWS directory.
Uninstalling an IMC component
Before uninstalling an IMC component, uninstall all components that depend on it.
To uninstall an IMC component:
1. Start the Intelligent Deployment Monitoring Agent.
2. On the Monitor tab, click Stop to stop the IMC service.
3. On the Deploy tab, right-click the component to be uninstalled, and then select Undeploy.
A confirmation dialog box opens.
4. Click Yes.
After the undeployment is complete, the undeployment success dialog box opens.
5. Click OK.
6. On the Deploy tab, right-click the undeployed component, and then select Remove.
7. Click Yes.
After the uninstallation is complete, the uninstallation success dialog box opens.
8. Click OK.
3. On Windows, click Start, access the all applications page, and then select iMC > Uninstall.
An uninstallation wizard dialog box opens.
4. Click Uninstall.
5. Click YES.
After the uninstallation is complete, the Uninstallation Completed dialog box opens.
6. Clear the OS reboot option, and then click OK.
7. Delete the iMC-Reserved folder in the WINDOWS folder.
8. Reboot the operating system.
Registering IMC
An unregistered IMC system has the same functions as registered IMC, except that it is a 45-day trial version from the date on which the IMC service is first started. To use the IMC software without time limitation, you must register it.
For more information about requesting and installing the IMC licenses, see H3C Intelligent Management Center Licensing Guide.
Security settings
Port settings
As a best practice, use a firewall to protect the IMC server cluster by filtering the non-service data sent to the cluster.
NOTE: · As a best practice to avoid legitimate packet fragments being filtered, do not use ACLs on switches to filter data packets destined for the IMC server cluster. · NTA/UBA typically uses probes for log collection. When a firewall is deployed between the probes and IMC, configure ACLs on the firewall to allow IP packets sent by the probes to IMC. |
Make sure the ports used by the IMC components (listed in Table 14 and Table 15) are not blocked by the firewall.
Table 14 Port numbers used by the IMC platform
Default port number |
Usage |
Location |
UDP 161 |
Port to add a device to the IMC |
Device |
UDP 22 |
Port for SSH operations |
Device |
TCP 23 |
Port for Telnet operations |
Device |
UDP 514, 515 |
Port for syslog operations |
IMC server |
UDP 162 |
Port for trap operations |
IMC server |
TCP 8080, configurable |
HTTP access to IMC |
IMC server |
TCP 8443, configurable |
HTTPS access to IMC |
IMC server |
UDP 69 |
Port for Intelligent Configuration Center to perform configuration management through TFTP |
IMC server |
TCP 20, 21 |
Port for Intelligent Configuration Center to perform configuration management through FTP |
IMC server |
TCP 2810 |
Port for data file backup and restoration by using DBMan |
IMC server |
Table 15 Port numbers used by the IMC NTA/UBA
Usage |
Location |
UDP 9020, 9021, 6343 |
Port for the IMC server to receive logs |
IMC server |
TCP 8051 |
Listening port used to monitor the command for stopping the NTA/UBA service |
IMC server |
TCP 9099 |
JMX listening port for the NTA/UBA service |
IMC server |
UDP 18801, 18802, 18803 |
Communication ports between the NTA and UBA |
IMC server |
DBMan is an automatic backup and restoration tool for the IMC platform and service component databases, and it provides a full-range system disaster backup solution. DBMan uses a standard SQL backup and restoration mechanism to process the complete databases.
DBMan supports both manual and automatic database backup and restoration. It is integrated in the Environment tab of the Intelligent Deployment Monitoring Agent, as shown in Figure 64.
The Environment tab includes the following areas:
· Running Environment—Displays the software and hardware information for the IMC server.
· Database Space Usage—Displays the database and log file usage information.
· Database Backup and Restore—Provides the following database backup and restoration options:
¡ Configure—Click this button to configure automatic database backup and restoration settings. The automatic backup and restoration function is typically used in stateless failover scenarios.
¡ Backup—Immediately backs up all IMC data files (including configuration files and database files) of the IMC server.
¡ Restore—Immediately restores the selected database files on the IMC server.
¡ Backup And Restore—Immediately backs up the database on the primary server to the backup server and performs automatic restoration. This option is applicable to stateless failover scenarios.
When you use DBMan to back up and restore IMC databases, follow these restrictions and guidelines:
· To ensure correct operation, do not back up and restore IMC databases between different operating systems.
· On the auto backup configuration page, use the Upload to Backup System option to upload selected database files to a server. Back up the files to a backup IMC server in stateless failover scenarios, or to an FTP server in a single IMC system.
· Before you select the Upload to Backup System option for an IMC database, make sure one of the following requirements is met:
¡ In stateless failover scenarios, the Conductor Server IP of Backup System is specified.
¡ In a single IMC system, the FTP server settings are configured in the dbman_ftp.conf file in the \dbman\etc directory of the IMC installation path. For example:
ftp_ip=1.1.1.1
ftp_user=admin
ftp_password=1234
· To add additional backup and restoration settings, customize settings in the dbman_addons.conf file in the \dbman\etc directory of the IMC installation path. The settings take effect immediately after the file is saved.
For example, add the following strings to the dbman_addons.conf file to specify tasks to perform before or after database restoration:
BeforeSQLScript_monitor_db_IMC_monitor = D:\1.bat
AfterSQLScript_monitor_db_IMC_monitor = D:\2.bat
Backing up and restoring databases for a single IMC system
Backing up databases
A single IMC system supports both manual and automatic backup:
· Manual backup—Immediately backs up all IMC data files.
· Automatic backup—Allows you to schedule a task to automatically back up selected data files at the specified time.
Manual backup
1. On the Environment tab, click Backup.
2. Click Yes.
The Select database backup path dialog box opens.
3. Specify a local path to save the backed up data files.
Make sure the specified path has enough space.
4. Click OK.
Automatic backup
1. On the Environment tab, click Configure.
The Auto Backup and Restore Settings dialog box opens, as shown in Figure 65.
Figure 65 Auto Backup and Restore Settings
2. Read the information in the Auto Backup and Restore Settings dialog box, select Auto Backup Mode, and then click OK.
The page for configuring auto backup settings opens, as shown in Figure 66.
Figure 66 Configuring auto backup settings
3. In the General settings area, configure the Backup File Lifetime (days) parameter:
¡ Backup File Lifetime (days)—Enter how many days a backup file can be kept. Expired files are automatically deleted. By default, the backup file lifetime is 7 days.
4. Click the Basic Configuration tab, and then configure the following parameters:
¡ Daily Backup Time (HH:mm)—Enter the time at which the automatic backup operation starts every day. By default, the daily backup time is 04:00.
¡ Conductor Server IP of Backup System—This parameter is applicable to database backup in stateless failover scenarios. To upload the database files to the conductor server of the backup system, specify the conductor server IP address in this field. Make sure automatic restoration is enabled for the backup system. To verify the component and version consistency between the primary IMC system and the backup IMC system, click Validate.
¡ Backup exported data files—Select this parameter to back up exported data files.
5. Click the Conductor Server tab, and then configure the following parameters:
¡ Backup Path—Enter or browse to the path where the backup data files are stored.
¡ Local Backup—Select the boxes in the Local Backup column for the databases you want to back up. By default, the boxes in the Local Backup column are selected for all databases. You can select or clear the boxes for all databases.
¡ Upload To Backup System—Select the boxes in the Upload To Backup System column for a database to upload the database file to the specified FTP server. By default, all boxes in the column are cleared.
6. Click the Advanced Configuration tab and configure the following parameters:
Delete local files after upload even if upload fails—Specify whether to delete local backup files after they are uploaded.
7. Click OK.
Restoring databases
A single IMC system supports only manual restoration of the databases.
Manual restoration immediately replaces the selected backup database files with the current database files to restore the databases to a specific time point.
As a best practice, restore database files for the IMC platform and service components together. If you restore only some of the database files, data loss or inconsistency might occur.
Make sure IMC has been started at least once after installation before you restore the IMC databases.
During manual database restoration, the IMC service and database service are automatically stopped and restarted.
To perform a manual restoration:
1. On the Environment tab, click Restore.
The Restoration Type dialog box opens, as shown in Figure 67.
Figure 67 Restoration Type dialog box
2. Click Locally Restore.
The Confirm dialog box opens, as shown in Figure 68.
Figure 68 Confirming the operation
3. Click Yes.
The Select the data file to be restored dialog box opens.
4. Select database files to be restored, and then click OK.
5. Click Yes.
The system starts restoring the database files.
After the restoration complete, the Message dialog box opens.
6. Click OK.
The IMC service will be automatically started.
Backing up and restoring databases in stateless failover scenarios
A typical stateless failover scenario includes a primary IMC system and a failover IMC system:
· The primary IMC system is deployed in centralized mode and uses a local database. The server in the primary IMC system is called the primary server.
· The failover IMC system is deployed in centralized or distributed mode. In centralized deployment, the server is called the backup server. In distributed deployment, the conductor server in the failover IMC system is the backup server.
For stateless failover, configure automatic backup on the primary server and configure automatic restoration on the backup server. During automatic backup and restoration, DBMan on the primary server performs the following operations:
1. Periodically or immediately backs up database files locally.
2. Uploads the backed up database files to the backup server.
3. Instructs the backup server to restore the received database files locally.
In a stateless failover scenario, you can configure automatic backup on the primary server.
Before the configuration, make sure the following settings are the same on the primary server and the backup server:
· OS
· Database type and version
· IMC version and patches
For more information about how to configure automatic backup, see "Automatic backup."
Restoring databases
In a stateless failover scenario, you can configure automatic restoration on the backup server. After receiving the backed up database files from the primary server, the backup server automatically restores the database files locally.
This example describes the automatic restoration settings for a failover IMC system that is deployed in centralized mode and uses a local database.
To configure automatic restoration on the backup server:
The Auto Backup and Restore Settings dialog box opens, as shown in Figure 69.
Figure 69 Auto Backup and Restore Settings dialog box
2. Read the information in the Auto Backup and Restore Settings dialog box, select Auto Restore Mode, and then click OK.
The page for configuring auto restoration settings opens, as shown in Figure 70.
Figure 70 Configuring auto restoration settings
3. In the Backup files location field, enter or browse to a path where the uploaded backup data files are stored.
4. In the Databases to Restore area, select databases in the Restore column to restore. By default, all databases are selected.
5. Click OK.
In a stateless failover scenario, use this option to back up the database on the primary server to the backup server and configure automatic restoration on the backup server.
To configure backup and restoration:
1. Configure automatic backup on the primary server in the same way you configure database backup in a single IMC system. For more information, see "Automatic backup."
2. Configure automatic restoration on the backup server. For more information, see "Restoring databases."
3. Click Backup and Restore on the Environment tab in the Intelligent Deployment Monitoring Agent, as shown in Figure 71.
Figure 71 Configuring backup and restoration
FAQ
After IMC installation is complete, how do I change the database file storage path?
1. Stop the IMC service by using the Intelligent Deployment Monitoring Agent.
2. Transfer the databases of IMC components to the new storage path on the database server. This example uses D:\imcdata.
3. At the CLI, access the \deploy directory of the IMC installation path and modify the database file storage path.
pwdmgr.bat –changeDataDir "D:\imcdata"
Figure 72 shows that the storage path has been successfully modified.
Figure 72 Modifying the database file storage path
4. Start the IMC service.
The time in the IMC system (such as the login time and operation log record time) is different from the time in the Linux server, and the difference might be several hours. How can I resolve this problem?
This problem occurs because the Linux OS is using a time zone different from the one that it used when IMC was installed. You can use the tzselect command to modify the time zone setting in the Linux OS.
During the component deployment process, a deployment failure error message is displayed and the system displays "Execute database script error!" The log file includes an error message that the object dbo.qv.id already exists. How can I resolve this problem?
1. Log in to the Query Analyzer of SQL Server as sa and execute the following commands:
use model
EXEC sp_droptype 'qv_id'
2. Redeploy the component that failed to be deployed.
On Linux, how can I start JavaService when Xwindows is closed?
Use service IMCdmsd start to start the JavaService.
On Windows, IMC service processes cannot be started or stopped after IMC runs for a period of time. How can I resolve this problem?
This problem is caused by insufficient virtual memory.
To resolve this problem, set the virtual memory to the system managed size:
1. On the IMC server, click Control Panel, and then click the System icon.
The System Properties dialog box opens, as shown in Figure 73.
Figure 73 System Properties dialog box
2. Click the Advanced tab, and then click Settings in the Performance area.
The Performance Options dialog box opens, as shown in Figure 74.
Figure 74 Performance Options dialog box
3. Click the Advanced tab, and then click Change in the Virtual memory area.
The Virtual Memory dialog box opens, as shown in Figure 75.
Figure 75 Virtual Memory dialog box
4. Select System managed size, and then click Set.
5. Click OK.
While I am installing .Net Framework 2.0 SP2 on a Windows server, the system displays an error message that the source file of .Net Framework 2.0 SP2 cannot be found. How can I resolve this problem?
To resolve this problem, add the source file of .Net Framework 2.0 SP2 to the Windows server:
1. Insert the Windows Server installation disk to the drive, and then locate the installation files of .Net Framework 3.5 in the disk.
In this example, the files are located in directory D:\sources\sxs, as shown in Figure 76.
Figure 76 Locating the installation files of .Net Framework 3.5
2. On the Confirm installation selections page of the Add Roles and Features Wizard shown in Figure 77, click Specify an alternate source path.
Figure 77 Confirm installation selections page
3. On the Specify an alternate source path page shown in Figure 78, enter the directory where the installation files of .Net Framework 3.5 are located in the Path field. This example uses D:\sources\sxs. Click OK.
Figure 78 Specify an alternate source path page
4. On the Confirm installation selections page, click Install to start installing .Net Framework 3.5.
After the installation is complete, click Close.
License verification fails after the Windows operating system reboots. How can I resolve this issue?
The license file contains only one MAC address if the license is requested after NIC teaming. After the operating system reboots, license verification fails because the MAC address of the NIC team has changed.
To resolve this issue, assign a static MAC address to the NIC team, as shown in Figure 79.
Figure 79 Assigning a static MAC address to the NIC team
On RHEL 8 or CentOS 8 or a later version, embedded database installation for IMC PLAT 7.3 (E0706) is interrupted. A message "mysql:error whileloading shared libraries:libtinfo.so.5:cannot open shared object file:No such file or directory" is displayed. How can I resolve this issue?
To resolve this issue, execute the following command to install the ncurses-compat-libs-6.1-7.20180224.el8.x86_64.rpm dependency before installing IMC:
rpm –ivh ncurses-compat-libs-6.1-7.20180224.el8.x86_64.rpm
Figure 80 Installing the dependency
