H3C S5130S-EI Switch Series Hardware Information and Specifications-6W109
HomeSupportResource CenterSwitchesS5130S SeriesS5130S-EI SeriesTechnical DocumentsInstall & UpgradeInstallation GuidesH3C S5130S-EI Switch Series Hardware Information and Specifications-6W109
01-Hardware Information and Specifications
01-Hardware Information and Specifications 5.29 MB
1 Product models and technical specifications· 1-3
Product models· 1-3
Technical specifications· 1-5
Non-PoE switch models· 1-5
PoE switch models· 1-12
2 Chassis views· 2-21
S5130S-10P-EI 2-21
S5130S-12TP-EI 2-21
S5130S-20P-EI 2-22
S5130S-28P-EI/S5130S-28P-EI-M·· 2-23
S5130S-28TP-EI 2-23
S5130S-52P-EI/S5130S-52P-EI-M·· 2-24
S5130S-52TP-EI 2-25
S5130S-28S-EI/S5130S-28S-EI-M·· 2-25
S5130S-28S-EI-DP· 2-26
S5130S-52S-EI/S5130S-52S-EI-M·· 2-27
S5130S-28F-EI 2-27
S5130S-52F-EI 2-28
S5130S-28MP-EI 2-29
S5130S-52MP-EI 2-30
S5130S-28PS-EI 2-30
S5130S-28ST-EI 2-31
S5130S-52ST-EI 2-32
S5130S-10P-HPWR-EI 2-32
S5130S-12TP-HPWR-EI 2-33
S5130S-20P-PWR-EI 2-34
S5130S-28P-PWR-EI 2-34
S5130S-28P-HPWR-EI 2-35
S5130S-52P-PWR-EI 2-36
S5130S-16S-PWR-EI 2-37
S5130S-16S-UPWR-EI-Q·· 2-37
S5130S-28S-PWR-EI 2-38
S5130S-28S-HPWR-EI 2-39
S5130S-28S-HPWR-EI-Q·· 2-40
S5130S-28S-UPWR-EI-Q·· 2-40
S5130S-52S-PWR-EI 2-41
S5130S-28MP-HPWR-EI 2-42
S5130S-10MS-UPWR-EI 2-42
S5130S-28ST-PWR-EI 2-43
S5130S-52ST-PWR-EI 2-44
S5130S-52P-PWR-EI-AC· 2-45
S5130S-52S-PWR-EI-AC· 2-45
S5130S-28P-HPWR-EI-AC· 2-46
S5130S-28S-HPWR-EI-AC· 2-47
3 Removable components· 3-48
4 Ports and LEDs· 4-49
Ports· 4-49
Console port 4-49
Management Ethernet port 4-50
10/100/1000BASE-T autosensing Ethernet port 4-50
5G/2.5G/1000BASE-T autosensing Ethernet port 4-50
2.5G/1000/100BASE-T autosensing Ethernet port 4-51
10/5/2.5/1GBASE-T autosensing Ethernet port 4-51
SFP port 4-52
SFP+ port 4-57
Combo interface· 4-59
LEDs· 4-60
System status LED·· 4-60
Management Ethernet port LED·· 4-60
Power supply status LED·· 4-60
RPS status LED·· 4-61
Mode LED (MODE) 4-61
SFP/SFP+ port LED·· 4-61
Ethernet port LEDs· 4-61
Product models
This document is applicable to the S5130S-EI switch series. Table1-1 describes the S5130S-EI switch series models.
Table1-1 S5130S-EI switch series models
Model
Product code (PID)
S5130S-10P-EI
LS-5130S-10P-EI
LS-5130S-10P-EI-GL
LS-5130S-10P-EI-H1
S5130S-12TP-EI
LS-5130S-12TP-EI
LS-5130S-12TP-EI-GL
LS-5130S-12TP-EI-H1
S5130S-20P-EI
LS-5130S-20P-EI
LS-5130S-20P-EI-GL
LS-5130S-20P-EI-H1
S5130S-28P-EI
LS-5130S-28P-EI
LS-5130S-28P-EI-GL
LS-5130S-28P-EI-H1
LS-5130S-28P-EI-H1-GL
S5130S-28P-EI-M
LS-5130S-28P-EI-M
S5130S-28TP-EI
LS-5130S-28TP-EI
LS-5130S-28TP-EI-GL
S5130S-52P-EI
LS-5130S-52P-EI
LS-5130S-52P-EI-GL
LS-5130S-52P-EI-H1
LS-5130S-52P-EI-H1-GL
S5130S-52P-EI-M
LS-5130S-52P-EI-M
S5130S-52TP-EI
LS-5130S-52TP-EI
LS-5130S-52TP-EI-GL
S5130S-28S-EI
LS-5130S-28S-EI
LS-5130S-28S-EI-GL
LS-5130S-28S-EI-H1
LS-5130S-28S-EI-H1-GL
S5130S-28S-EI-M
LS-5130S-28S-EI-M
S5130S-28S-EI-DP
LS-5130S-28S-EI-DP
S5130S-52S-EI
LS-5130S-52S-EI
LS-5130S-52S-EI-GL
LS-5130S-52S-EI-H1
LS-5130S-52S-EI-H1-GL
S5130S-52S-EI-M
LS-5130S-52S-EI-M
S5130S-28F-EI
LS-5130S-28F-EI
LS-5130S-28F-EI-GL
S5130S-52F-EI
LS-5130S-52F-EI
LS-5130S-52F-EI-GL
S5130S-28MP-EI
LS-5130S-28MP-EI
LS-5130S-28MP-EI-GL
S5130S-52MP-EI
LS-5130S-52MP-EI
LS-5130S-52MP-EI-GL
S5130S-28PS-EI
LS-5130S-28PS-EI
LS-5130S-28PS-EI-GL
S5130S-28ST-EI
LS-5130S-28ST-EI
LS-5130S-28ST-EI-GL
S5130S-52ST-EI
LS-5130S-52ST-EI
LS-5130S-52ST-EI-GL
PoE switch models
S5130S-10P-HPWR-EI
LS-5130S-10P-HPWR-EI
LS-5130S-10P-HPWR-EI-GL
LS-5130S-10P-HPWR-EI-H1
S5130S-12TP-HPWR-EI
LS-5130S-12TP-HPWR-EI
LS-5130S-12TP-HPWR-EI-GL
LS-5130S-12TP-HPWR-EI-H1
S5130S-20P-PWR-EI
LS-5130S-20P-PWR-EI
LS-5130S-20P-PWR-EI-GL
LS-5130S-20P-PWR-EI-H1
S5130S-28P-PWR-EI
LS-5130S-28P-PWR-EI
LS-5130S-28P-PWR-EI-GL
LS-5130S-28P-PWR-EI-H1
S5130S-28P-HPWR-EI
LS-5130S-28P-HPWR-EI
LS-5130S-28P-HPWR-EI-GL
S5130S-52P-PWR-EI
LS-5130S-52P-PWR-EI
LS-5130S-52P-PWR-EI-GL
S5130S-16S-PWR-EI
LS-5130S-16S-PWR-EI
LS-5130S-16S-PWR-EI-GL
LS-5130S-16S-UPWR-EI-Q
S5130S-28S-PWR-EI
LS-5130S-28S-PWR-EI
LS-5130S-28S-PWR-EI-GL
LS-5130S-28S-PWR-EI-H1
S5130S-28S-HPWR-EI
LS-5130S-28S-HPWR-EI
LS-5130S-28S-HPWR-EI-GL
LS-5130S-28S-HPWR-EI-Q
LS-5130S-28S-UPWR-EI-Q
S5130S-52S-PWR-EI
LS-5130S-52S-PWR-EI
LS-5130S-52S-PWR-EI-GL
LS-5130S-52P-PWR-EI-AC
LS-5130S-52P-PWR-EI-AC-GL
LS-5130S-52S-PWR-EI-AC
LS-5130S-52S-PWR-EI-AC-GL
LS-5130S-28P-HPWR-EI-AC
LS-5130S-28P-HPWR-EI-AC-GL
LS-5130S-28S-HPWR-EI-AC
LS-5130S-28S-HPWR-EI-AC-GL
S5130S-28MP-HPWR-EI
LS-5130S-28MP-HPWR-EI
LS-5130S-28MP-HPWR-EI-GL
S5130S-10MS-UPWR-EI
LS-5130S-10MS-UPWR-EI
LS-5130S-10MS-UPWR-EI-GL
S5130S-28ST-PWR-EI
LS-5130S-28ST-PWR-EI
LS-5130S-28ST-PWR-EI-GL
S5130S-52ST-PWR-EI
LS-5130S-52ST-PWR-EI
LS-5130S-52ST-PWR-EI-GL
Switches of the same model but different PIDs might differ in hardware and software features. You can view the PID of a switch on the label located on its rear panel or top panel.
Table1-2 Technical specifications for non-PoE switch models (1)
Item
S5130S-10P-EI
S5130S-12TP-EI
S5130S-20P-EI
Dimensions (H × W × D)
43.6 × 266 × 161 mm (1.72 × 10.47 × 6.34 in)
43.6 × 330 × 230 mm (1.72 × 12.99 × 9.06 in)
Weight
≤ 1.5 kg (3.31 lb)
≤ 1.5 kg (3.31 lb)
≤ 2 kg (4.41 lb)
Console port
1 × serial console port
8
10 (The two highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
16
SFP port
2
4 (The two lowest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
4
Input voltage
·     Rated voltage: 100 VAC to 240 VAC @ 50 or 60 Hz
·     Max voltage: 90 VAC to 264 VAC @ 47 to 63 Hz
Minimum power consumption
7 W
8 W
9 W
Maximum power consumption
12 W
15 W
19 W
Chassis leakage current compliance
UL 62368-1/EN 62368-1/IEC 62368-1/UL 60950-1/EN 60950-1/IEC 60950-1/GB4943.1
Melting current of power supply fuse
2 A/250 V
2 A/250 V
2 A/250 V
Cooling system
Passive cooling
Passive cooling
Passive cooling
Operating temperature
–5°C to +45°C (23°F to 113°F)
Operating humidity
5% to 95%, noncondensing
Fire resistance compliance
Table1-3 Technical specifications for non-PoE switch models (2)
Item
S5130S-28P-EI
S5130S-28P-EI-M
S5130S-52P-EI
S5130S-52P-EI-M
43.6 × 440 × 160 mm (1.72 × 17.32 × 6.30 in)
43.6 × 440 × 230 mm (1.72 × 17.32 × 9.06 in)
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
24
48
SFP port
4
4
Input voltage
9 W
18 W
23 W
41 W
2 A/250 V
3.15 A/250 V
Cooling system
Passive cooling
Using fixed fan trays to draw ambient air in from the left side and right side and exhaust heated air from the power supply side.
Operating humidity
Table1-4 Technical specifications for non-PoE switch models (3)
Item
S5130S-28TP-EI
S5130S-52TP-EI
S5130S-28S-EI
S5130S-28S-EI-M
S5130S-52S-EI
S5130S-52S-EI-M
43.6 × 440 × 260 mm (1.72 × 17.32 × 10.24 in)
Weight
≤ 2 kg (4.41 lb)
≤ 3.5 kg (7.72 lb)
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
·     1 × serial console port
·     1 × micro USB console port
When both ports are connected, only the micro USB console port is available.
26 (The two highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
50 (The two highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
24
48
SFP port
N/A
N/A
SFP+ port
N/A
N/A
4
4
Input voltage
10 W
20 W
10 W
19 W
24 W
42 W
24 W
44 W
2 A/250 V
3.15 A/250 V
2 A/250 V
3.15 A/250 V
Cooling system
Passive cooling
Using fixed fan trays to draw ambient air in from the left side and right side of the chassis and exhaust heated air out from the power supply side.
·     Models with product codes LS-5130S-28S- EI-H1 and LS-5130S-28S-EI-H1-GL: Passive cooling.
·     Other models: Using fixed fan trays to draw ambient air in from the left side, right side, and port side of the chassis and exhaust heated air out from the power supply side.
Using fixed fan trays to draw ambient air in from the left side and right side and exhaust heated air out from the power supply side.
Operating humidity
Table1-5 Technical specifications for non-PoE switch models (4)
Item
S5130S-28F-EI
S5130S-52F-EI
43.6 × 440 × 360 mm (1.72 × 17.32 × 14.17 in)
Weight
≤ 6 kg (13.23 lb)
≤ 6.5 kg (14.33 lb)
Console port
8 (Each and its corresponding SFP port form a combo interface.)
2 (Each and its corresponding SFP port form a combo interface.)
SFP port
24 (The eight highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
48 (The two highest-numbered SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
SFP+ port
4
4
Power supply slot
2, at the rear panel
Input voltage
CA-70A12:
·     Max voltage: 90 VAC to 290 VAC @ 47 to 63 Hz
PSR75-12A:
·     Rated voltage:
¡     100 VAC to 240 VAC @ 50 or 60 Hz
¡     240 VDC
·     Max voltage:
¡     90 VAC to 290 VAC @ 47 to 63 Hz
¡     180 to 320 VDC
PSR150-A1:
PSR150-D1:
·     Rated voltage: –48 VDC to –60 VDC
·     Max voltage: –36 VDC to –72 VDC
DC power source for the PSR150-D1 power supply: –48 VDC power source in the equipment room or an RPS (H3C RPS800-A or RPS1600-A)
·     1 × CA-70A12: 15 W
·     2 × CA-70A12: 17 W
·     1 × PSR75-12A: 15 W
·     2 × PSR75-12A: 17 W
·     1 × PSR150-A1: 18 W
·     1 × PSR150-D1: 18 W
·     2 × PSR150-A1: 23 W
·     2 × PSR150-D1: 22 W
·     1 × CA-70A12: 26 W
·     2 × CA-70A12 29 W
·     1 × PSR75-12A: 26 W
·     2 × PSR75-12A: 29 W
·     1 × PSR150-A1: 27 W
·     1 × PSR150-D1: 27 W
·     2 × PSR150-A1: 32 W
·     2 × PSR150-D1: 33 W
·     1 × CA-70A12: 45 W
·     2 × CA-70A12: 48 W
·     1 × PSR75-12A: 45 W
·     2 × PSR75-12A: 48 W
·     1 × PSR150-A1: 48 W
·     1 × PSR150-D1: 51 W
·     2 × PSR150-A1: 55 W
·     2 × PSR150-D1: 57 W
·     1 × CA-70A12: 69 W
·     2 × CA-70A12: 72 W
·     1 × PSR75-12A: 69 W
·     2 × PSR75-12A: 72 W
·     1 × PSR150-A1: 74 W
·     1 × PSR150-D1: 84 W
·     2 × PSR150-A1: 95 W
·     2 × PSR150-D1: 95 W
·     CA-70A12: 10 A/250 V
·     PSR75-12A: 3.15 A/250 V
·     PSR150-A1: 6.3 A/250 V
·     PSR150-D1: 8 A/250 V
Cooling system
Using fixed fan trays to draw ambient air in from the left side and port side and exhaust heated air from the right side.
Operating humidity
Table1-6 Technical specifications for non-PoE switch models (5)
Item
S5130S-28MP-EI
S5130S-52MP-EI
43.6 × 440 ×160 mm (1.72 × 17.32 × 6.30 in)
Weight
≤ 2.5 kg (5.51 lb)
≤ 3.5 kg (7.72 lb)
Console port
24
48
2
SFP port
2
AC-input voltage
14 W
22 W
28 W
46 W
3.15 A/250 V
6.3 A/250 V
Cooling system
Using fixed fan trays to draw ambient air in from the left side of the chassis and exhaust heated air out from the power supply side.
Operating humidity
Table1-7 Technical specifications for non-PoE switch models (6)
Item
S5130S-28S-EI-DP
S5130S-28ST-EI
S5130S-52ST-EI
S5130S-28PS-EI
Weight
≤ 3.5 kg (7.72 lb)
≤ 2.5 kg (5.51 lb)
≤ 4 kg (8.82 lb)
≤ 4.5 kg (9.92 lb)
Console port
24
24
48
24 (The eight highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
N/A
2
2
N/A
SFP port
N/A
N/A
N/A
8 (The eight SFP ports form combo interfaces with their corresponding 10/100/1000BASE-T autosensing Ethernet ports, respectively.)
SFP+ port
4
2
2
4
Input voltage
AC power source:
DC power source (supported only by the S5130S-28PS-EI switch):
·     Rated voltage:–24 VDC to –48 VDC
·     Max voltage: –24 VDC to –48 VDC
Single AC input: 11 W
Dual AC inputs: 15 W
AC: 14 W
AC: 22 W
AC: 12 W
DC: 11 W
Single AC input: 25 W
Dual AC inputs: 26 W
AC: 36 W
AC: 53 W
AC: 31 W
DC: 26 W
2 A/250 V
2 A/250 V
2 A/250 V
2 A/250 V
Cooling system
Using fixed fan trays to draw ambient air in from the chassis left side and exhaust heated air from the chassis right side.
Operating humidity
PoE switch models
Table1-8 Technical specifications for PoE switch models (1)
Item
S5130S-10P-HPWR-EI
S5130S-12TP-HPWR-EI
S5130S-20P-PWR-EI
Weight
≤ 3 kg (6.61 lb)
≤ 3 kg (6.61 lb)
≤ 3 kg (6.61 lb)
Console port
8
16
SFP port
2
4
Input voltage
Maximum PoE power per port
30 W
30 W
The combo copper ports on an S5130S-12TP-HPWR-EI switch do not support PoE power supply.
30 W
Total PoE power
125 W
125 W
Models with product code LS-5130S-20P-PWR-EI: 170 W
Models with product code LS-5130S-20P-PWR-EI-H1: 185 W
13 W
14 W
Models with product code LS-5130S-20P-PWR-EI: 18 W
Models with product code LS-5130S-20P-PWR-EI-H1: 15 W
Maximum power consumption (including PoE power consumption)
153 W
156 W
Models with product code LS-5130S-20P-PWR-EI: 210 W
Models with product code LS-5130S-20P-PWR-EI-H1: 235 W
6.3 A/250 V
6.3 A/250 V
10 A/250 V
Cooling system
Passive cooling
Passive cooling
Using fixed fan trays to draw ambient air in from the left side and exhaust heated air from the right side.
Operating humidity
Table1-9 Technical specifications for PoE switch models (2)
Item
S5130S-28ST-PWR-EI
S5130S-52ST-PWR-EI
43.6 × 440 × 320 mm (1.72 × 17.32 × 12.60 in)
Weight
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
Console port
24
48
2
SFP+ port
2
Input voltage
30 W
Total PoE power
370 W
20 W
32 W
450 W
470 W
2 A/250 V
Cooling system
Operating humidity
Table1-10 Technical specifications for PoE switch models (2)
Item
S5130S-28P-PWR-EI
S5130S-52P-PWR-EI
S5130S-28P-HPWR-EI
43.6 × 440 × 260 mm (1.72 × 17.32 ×10.24 in)
43.6 × 440 × 400 mm (1.72 × 17.32 × 15.75 in)
Weight
≤ 4 kg (8.82 lb)
≤ 6 kg (13.23 lb)
≤ 4.5 kg (9.92 lb)
≤ 4.5 kg (9.92 lb)
≤ 6 kg (13.23 lb)
Console port
24
48
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports each form combo interfaces with its corresponding SFP port.)
28 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports each form a combo interface with its corresponding SFP port.)
48
SFP port
4
4
4 (Each and its corresponding 10/100/1000BASE-T autosensing Ethernet port form a combo interface.)
4
Input voltage
AC power source:
DC power source: H3C RPS1600-A
·     Rated voltage: –54 VDC to –57 VDC
·     Max voltage:
¡     Single DC input: –44 VDC to –60 VDC
¡     AC and DC inputs: –54 VDC to –57 VDC
30 W
The combo copper ports on the S5130S-28P-HPWR-EI and S5130S-28P-HPWR-EI-AC switches do not support PoE power output.
Total PoE power
·     Models with product code LS-5130S-28P-PWR-EI-H1: 240 W
·     Other models: 170 W
·     AC: 370 W
·     DC: 740 W
AC: 370 W
DC: 740 W
370 W
370 W
·     Models with product code LS-5130S-28P-PWR-EI-H1: 15 W
·     Other models: 19 W
·     AC: 36 W
·     DC: 26 W
AC: 23 W
DC: 16 W
15 W
36 W
·     Models with product code LS-5130S-28P-PWR-EI-H1: 295 W
·     Other models: 230 W
·     AC: 467 W
·     DC: 807 W
AC: 446 W
DC: 790 W
443 W
467 W
10 A/250 V
15 A/250 V
15 A/250 V
15 A/250 V
15 A/250 V
Cooling system
Operating humidity
Table1-11 Technical specifications for PoE switch models (3)
Item
S5130S-16S-PWR-EI
S5130S-28S-PWR-EI
S5130S-52S-PWR-EI
S5130S-28S-HPWR-EI
43.6 × 300 × 260 mm (1.72 × 11.81 × 10.24 in)
43.6 × 440 × 422 mm (1.72 × 17.32 × 16.61 in)
Weight
≤ 2.5 kg (5.51 lb)
≤ 4 kg (8.82 lb)
≤ 6 kg (13.23 lb)
≤ 4.5 kg (9.92 lb)
≤ 6 kg (13.23 lb)
≤ 6 kg (13.23 lb)
Console port
·     When both ports are connected, only the micro USB console port is available.
14
24
48
24 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports form combo interfaces with their corresponding SFP ports, respectively.)
24
48
SFP port
N/A
N/A
N/A
N/A
N/A
SFP+ port
2
4
4
4
4
4
Input voltage
AC power source:
DC power source: H3C RPS1600-A (supported only by S5130S-52S-PWR-EI and S5130S-28S-HPWR-EI switches)
·     Max voltage:
30 W
Port 13 and Port 14 do not support PoE.
Total PoE power
125 W
·     Models with product code LS-5130S-28S-PWR-EI-H1: 240 W
·     AC: 370 W
·     DC: 740 W
AC: 370 W
DC: 740 W
370 W
370 W
14 W
·     Models with product code LS-5130S-28S-PWR-EI-H1: 15 W
·     Other models: 20 W
·     AC: 37 W
·     DC: 29 W
AC: 24 W
DC: 17 W
12 W
36 W
157 W
·     Models with product code LS-5130S-28S-PWR-EI-H1: 294 W
·     Other models: 235 W
·     AC: 478 W
·     DC: 825 W
AC: 451 W
DC: 793 W
400 W
467 W
6.3 A/250 V
10 A/250 V
15 A/250 V
15 A/250 V
10 A/420 V
15 A/250 V
Cooling system
Passive cooling
Passive cooling
Operating humidity
Table1-12 Technical specifications for PoE switch models (4)
Item
S5130S-28MP-HPWR-EI
S5130S-10MS-UPWR-EI
43.6 × 440 × 420 mm (1.72 × 17.32 × 16.54 in)
Weight
≤ 3.5 kg (7.72 lb)
≤ 6 kg (13.23 lb)
≤ 5 kg (11.02 lb)
≤ 3.5 kg (7.72 lb)
≤ 4.5 kg (9.92 lb)
Console port
14
24
24
N/A
24 (The four highest-numbered 10/100/1000BASE-T autosensing Ethernet ports each form a combo interface with its corresponding SFP port.)
N/A
N/A
2
N/A
N/A
N/A
N/A
N/A
8
N/A
SFP port
N/A
N/A
2
N/A
SFP+ port
2
4
N/A
2
4
Input voltage
AC power source:
DC power source: H3C RPS1600-A (supported only by the S5130S-28MP-HPWR-EI and S5130S-10MS-UPWR-EI switches)
·     Max voltage:
90 W
Ports 1 to 8: 90 W
Ports 9 to 24: 30 W
30 W
90 W
30 W
Total PoE power
AC: 370 W
AC: 370 W
·     AC: 370 W
·     DC: 740 W
·     AC: 370 W
·     DC: 740 W
370 W
AC: 12 W
AC: 14 W
·     AC: 26 W
·     DC: 36 W
·     AC: 23 W
·     DC: 18 W
16 W
AC: 402 W
AC: 405 W
·     AC: 446 W
·     DC: 820 W
·     AC: 447 W
·     DC: 794 W
445 W
10 A/250 V
15 A/250 V
Cooling system
Passive cooling
Operating humidity
2 Chassis views
S5130S-10P-EI
Figure2-1 Front panel
(1) 10/100/1000BASE-T autosensing Ethernet port
(2) 10/100/1000BASE-T autosensing Ethernet port LED
(3) SFP port LED
(4) System status LED (SYS)
(5) Console port (CONSOLE)
(6) SFP port
Figure2-2 Rear panel
(1) Grounding screw
(2) AC-input power receptacle
S5130S-12TP-EI
Figure2-3 Front panel
(3) SFP port LED
(6) SFP port
Figure2-4 Rear panel
(1) Grounding screw
S5130S-20P-EI
Figure2-5 Front panel
(3) SFP port LED
(6) SFP port
Figure2-6 Rear panel
(1) AC-input power receptacle
(2) Grounding screw
Figure2-7 Front panel
(3) SFP port LED
(6) SFP port
Figure2-8 Rear panel
(1) Grounding screw
S5130S-28TP-EI
Figure2-9 Front panel
(2) SFP port
(3) Console port (CONSOLE)
(4) Micro USB console port
(5) 10/100/1000BASE-T autosensing Ethernet port LED
(6) System status LED (SYS)
(7) SFP port LED
Figure2-10 Rear panel
(1) Grounding screw
Figure2-11 Front panel
(4) SFP port LED
(5) System status LED (SYS)
(6) SFP port
Figure2-12 Rear panel
(1) Grounding screw
S5130S-52TP-EI
Figure2-13 Front panel
(6) SFP port LED
(7) SFP port
Figure2-14 Rear panel
(1) Grounding screw
Figure2-15 Front panel
(3) SFP+ port LED
(5) Micro USB console port
(6) Console port (CONSOLE)
(7) SFP+ port
Figure2-16 Rear panel
(1) Grounding screw
S5130S-28S-EI-DP
Figure2-17 Front panel
(2) Console port (CONSOLE)
(3) 10/100/1000BASE-T autosensing Ethernet port LED
(5) SFP+ port LED
(6) Micro USB console port
(7) SFP+ port
Figure2-18 Rear panel
(1) Grounding screw
(2) AC-input power receptacle 1
(3) AC-input power receptacle 2
The S5130S-28S-EI-DP switch has two AC-input power receptacles on the rear panel. You can use one AC power input, or two AC power inputs for 1+1 redundancy.
Figure2-19 Front panel
(5) SFP+ port LED
(7) SFP+ port
Figure2-20 Rear panel
(1) Grounding screw
S5130S-28F-EI
Figure2-21 Front panel
(1) SFP port
(2) SFP port LED
(4) 10/100/1000BASE-T autosensing Ethernet port LED
(5) Management Ethernet port
(7) Micro USB console port
(8) System status LED (SYS)
(9) Power supply 2 status LED (PWR2)
(10) Power supply 1 status LED (PWR1)
(11) SFP+ port LED
(12) Management Ethernet port status LED (ACT/LINK)
(13) SFP+ port
Figure2-22 Rear panel
(1) Grounding screw
(2) Power supply 1 (PWR1)
(3) Power supply 2 (PWR2)
The S5130S-28F-EI switch comes with power supply 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-22, two PSR150-A1 AC power supplies are installed.
S5130S-52F-EI
Figure2-23 Front panel
(1) SFP port
(2) SFP port LED
(7) System status LED (SYS)
(8) Power supply 2 status LED (PWR2)
(9) Power supply 1 status LED (PWR1)
(10) SFP+ port
(11) SFP+ port LED
Figure2-24 Rear panel
(1) Grounding screw
The S5130S-52F-EI switch comes with power supply slot 1 empty and power supply slot 2 installed with a filler panel. You can install one or two power supplies for the switch as needed. In Figure2-24, two PSR150-A1 AC power supplies are installed.
S5130S-28MP-EI
Figure2-25 Front panel
(2) 5G/2.5G/1000BASE-T autosensing Ethernet port (5GBASE-T)
(6) SFP port LED
(7) 5G/2.5G/1000BASE-T autosensing Ethernet port LED
(8) Micro USB console port
(9) SFP port
Figure2-26 Rear panel
(1) Grounding screw
S5130S-52MP-EI
Figure2-27 Front panel
(3) 5G/2.5G/1000BASE-T autosensing Ethernet port (5GBASE-T)
(4) Console port (CONSOLE)
(7) SFP port
(8) SFP port LED
(9) 5G/2.5G/1000BASE-T autosensing Ethernet port LED
Figure2-28 Rear panel
(1) Grounding screw
S5130S-28PS-EI
Figure2-29 Front panel
(3) SFP port
(4) Management Ethernet port
(7) SFP+ port
(8) SFP+ port LED
(9) Management Ethernet port status LED (ACT/LINK)
(10) SFP port LED
Figure2-30 Rear panel
(1) Grounding screw
(3) DC-input power receptacle
S5130S-28ST-EI
Figure2-31 Front panel
(2) SFP+ port
(3) 10/5/2.5/1GBASE-T autosensing Ethernet port
(6) SFP+ port LED
(7) 10/5/2.5/1GBASE-T autosensing Ethernet port LED
Figure2-32 Rear panel
(1) Grounding screw
S5130S-52ST-EI
Figure2-33 Front panel
(3) SFP+ port
(5) 10/5/2.5/1GBASE-T autosensing Ethernet port
(8) SFP+ port LED
Figure2-34 Rear panel
(2) Grounding screw
S5130S-10P-HPWR-EI
Figure2-35 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(6) Port LED mode switching button
(7) Console port (CONSOLE)
(8) SFP port
Figure2-36 Rear panel
(2) Grounding screw
S5130S-12TP-HPWR-EI
Figure2-37 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(8) SFP port
Figure2-38 Rear panel
(2) Grounding screw
S5130S-20P-PWR-EI
Figure2-39 Front panel
(3) SFP port LED
(5) Mode LED (MODE)
(8) SFP port
Figure2-40 Rear panel
(2) Grounding screw
S5130S-28P-PWR-EI
Figure2-41 Front panel
(2) Port LED mode switching button
(4) SFP port LED
(6) Mode LED (MODE)
(8) SFP port
Figure2-42 Rear panel (product code LS-5130S-28P-PWR-EI)
(1) Grounding screw
Figure2-43 Rear panel (product code LS-5130S-28P-PWR-EI-H1)
(1) Grounding screw
S5130S-28P-HPWR-EI
Figure2-44 Front panel
(3) Port LED mode switching button
(6) RPS status LED (RPS)
(7) Mode LED (MODE)
(8) SFP port LED
(9) SFP port
Figure2-45 Rear panel
(1) Grounding screw
S5130S-52P-PWR-EI
Figure2-46 Front panel
(4) Port LED mode switching button
(7) Mode LED (MODE)
(8) SFP port
(9) SFP port LED
Figure2-47 Rear panel
(1) Grounding screw
S5130S-16S-PWR-EI
Figure2-48 Front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(8) Console port (CONSOLE)
(9) SFP+ port
Figure2-49 Rear panel
(2) Grounding screw
Figure2-50 Front panel
(6) SFP+ port LED
(7) Mode LED (MODE)
(9) SFP+ port
Figure2-51 Rear panel
(2) Heat sink
(3) Grounding screw
S5130S-28S-PWR-EI
Figure2-52 Front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(9) SFP+ port
Figure2-53 Rear panel (product code LS-5130S-28S-PWR-EI)
(1) Grounding screw
Figure2-54 Rear panel (product code LS-5130S-28S-PWR-EI-H1)
(1) Grounding screw
S5130S-28S-HPWR-EI
Figure2-55 Front panel
(2) SFP port
(7) RPS status LED (RPS)
(8) Mode LED (MODE)
(9) SFP+ port LED
(10) SFP port LED
(11) Micro USB console port
(12) SFP+ port
Figure2-56 Rear panel
(1) Grounding screw
Figure2-57 Front panel
(4) SFP+ port LED
(6) Mode LED (MODE)
(9) SFP+ port
Figure2-58 Rear panel
(2) Heat sink
(3) Grounding screw
Figure2-59 Front panel
(6) Mode LED (MODE)
(7) SFP+ port LED
(9) SFP+ port
Figure2-60 Rear panel
(1) Grounding screw
(3) Heat sink
S5130S-52S-PWR-EI
Figure2-61 Front panel
(7) Mode LED (MODE)
(9) SFP+ port
(10) SFP+ port LED
Figure2-62 Rear panel
(1) Grounding screw
S5130S-28MP-HPWR-EI
Figure2-63 Front panel
(8) Mode LED (MODE)
(9) SFP port LED
(10) 5G/2.5G/1000BASE-T autosensing Ethernet port LED
(12) SFP port
Figure2-64 Rear panel
(1) Grounding screw
S5130S-10MS-UPWR-EI
Figure2-65 Front panel
(1) 2.5G/1000/100BASE-T autosensing Ethernet port
(2) SFP+ port
(5) 2.5G/1000/100BASE-T autosensing Ethernet port LED
(8) SFP+ port LED
(9) Mode LED (MODE)
(10) Micro USB console port
Figure2-66 Rear panel
(1) Grounding screw
S5130S-28ST-PWR-EI
Figure2-67 Front panel
(2) SFP+ port
(5) Port LED mode switching button
(6) 10/100/1000BASE-T autosensing Ethernet port LED
(7) SFP+ port LED
(9) Mode LED (MODE)
(10) 10/5/2.5/1GBASE-T autosensing Ethernet port LED
Figure2-68 Rear panel
(1) Grounding screw
S5130S-52ST-PWR-EI
Figure2-69 Front panel
(3) SFP+ port
(6) Mode LED (MODE)
(8) 10/5/2.5/1GBASE-T autosensing Ethernet port
(9) 10/5/2.5/1GBASE-T autosensing Ethernet port LED
(10) SFP+ port LED
Figure2-70 Rear panel
(2) Grounding screw
Figure2-71 Front panel
(6) Mode LED (MODE)
(7) SFP port LED
(8) SFP port
Figure2-72 Rear panel
(1) Grounding screw
Figure2-73 Front panel
(6) Mode LED (MODE)
(8) SFP+ port
(9) SFP+ port LED
Figure2-74 Rear panel
(1) Grounding screw
Figure2-75 Front panel
(6) Mode LED (MODE)
(7) SFP port LED
(8) SFP port
Figure2-76 Rear panel
(1) Grounding screw
Figure2-77 Front panel
(2) SFP port
(7) Mode LED (MODE)
(8) SFP+ port LED
(9) SFP port LED
(11) SFP+ port
Figure2-78 Rear panel
(1) Grounding screw
WARNING
WARNING!
·     You can replace one of the two power supplies operating in 1+1 redundancy on the S5130S-28F-EI and S5130S-52F-EI switches. To avoid device damage and bodily injury, make sure the power supply is powered off before removing it.
·     To install AC power supplies on an S5130S-28F-EI or S5130S-52F-EI switch, choose the CA-70A12 or PSR75-12A power supplies as a best practice.
The S5130S-28F-EI and S5130S-52F-EI switches each provide two power supply slots. One power supply can meet the power requirement of the switch. You can install two power supplies on the switch for 1+1 redundancy. Table3-1 describes the power supplies available for the S5130S-52F-EI switch.
Table3-1 Power supplies available for the S5130S-52F-EI switch
Power supply model
Item
Specification
Remarks
CA-70A12
Rated input voltage
100 VAC to 240 VAC @ 50 Hz or 60 Hz
H3C CA-70A12 Power Supply User Manual
Max input voltage
90 VAC to 290 VAC @ 47 Hz to 63 Hz
Max output power
75 W
PSR75-12A
Rated input voltage
AC: 100 VAC to 240 VAC @ 50 Hz or 60 Hz
DC: 240 VDC
For more information about the power supply, see H3C PSR75-12A Power Module User Manual.
Max input voltage
AC: 90 VAC to 290 VAC @ 47 Hz to 63 Hz
DC: 180 VDC to 320 VDC
Max output power
75 W
PSR150-A1
Rated input voltage
For more information about the power supplies, see H3C PSR150-A & PSR150-D Series Power Supplies User Manual.
Max input voltage
90 VAC to 264 VAC @ 47 Hz to 63 Hz
Max output power
150 W
PSR150-D1
Rated input voltage
–48 VDC to –60 VDC
Max input voltage
–36 VDC to –72 VDC
Max output power
150 W
4 Ports and LEDs
Ports
Console port
Table4-1 Console port specifications
Item
Serial console port
Connector type
RJ-45
Micro USB Type B
Compliant standard
EIA/TIA-232
USB 2.0
Transmission baud rate
9600 bps (default) to 115200 bps
Services
·     Provides connection to an ASCII terminal.
·     Provides connection to the serial port of a local PC running terminal emulation program.
·     Provides connection to the USB port of a local PC running terminal emulation program.
Available switch models
All switches
·     S5130S-28TP-EI
·     S5130S-52TP-EI
·     S5130S-16S-PWR-EI
·     S5130S-28S-EI
·     S5130S-28S-EI-M
·     S5130S-28S-EI-DP
·     S5130S-52S-EI
·     S5130S-52S-EI-M
·     S5130S-28S-PWR-EI
·     S5130S-16S-UPWR-EI-Q
·     S5130S-28S-UPWR-EI-Q
·     S5130S-28S-HPWR-EI
·     S5130S-28S-HPWR-EI-Q
·     S5130S-52S-PWR-EI
·     S5130S-52S-PWR-EI-AC
·     S5130S-28F-EI
·     S5130S-52F-EI
·      S5130S-10MS-UPWR-EI
·     S5130S-28MP-EI
·     S5130S-28MP-HPWR-EI
·     S5130S-52MP-EI
You cannot use the serial console port and micro USB console port at the same time. If you connect both ports at the same time, only the micro USB console port takes effect.
The S5130S-28F-EI and S5130S-28PS-EI switches each have one management Ethernet port. You can connect the port to a local PC for software loading and debugging or to a remote management station for remote management.
Table4-2 Management Ethernet port specifications
Item
Specification
Connector type
RJ-45
Transmission rate, duplex mode, and auto MDI/MDI-X
·     10 Mbps, half/full duplex
·     100 Mbps, half/full duplex
·     MDI/MDI-X autosensing
Max transmission distance
100 m (328.08 ft)
Transmission medium
Category-5 (or above) twisted pair cable
Compatible standards
·     IEEE 802.3i
·     IEEE 802.3u
·     IEEE 802.3ab
Functions and services
Software upgrade and network management.
Table4-3 10/100/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1000 Mbps, full duplex
100 m (328.08 ft)
Transmission medium
·     IEEE 802.3i
·     IEEE 802.3u
·     IEEE 802.3ab
The S5130S-28MP-EI, S5130S-28MP-HPWR-EI, and S5130S-52MP-EI switches provide 5G/2.5G/1000BASE-T autosensing Ethernet ports.
Table4-4 5G/2.5G/1000BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     1 Gbps, full duplex
·     2.5 Gbps, full duplex
·     5 Gbps, full duplex
·     5G mode: 100 m (328.08 ft) over Category-5e or above twisted pair
·     2.5G mode: 200 m (656.17 ft) over Category-5e or above twisted pair
·     1G mode: 200 m (656.17 ft) over Category-5e or above twisted pair
Transmission medium
Category-5e (or above) twisted pair cable
·     IEEE 802.3ab
·     IEEE 802.3an
The S5130S-10MS-UPWR-EI switch provides 2.5G/1000/100BASE-T autosensing Ethernet ports.
Table4-5 2.5G/1000/100BASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     100 Mbps, full duplex
·     100M mode: 200 m (656.17 ft) over Category-5e or above twisted pair
Transmission medium
·     IEEE 802.3ab
·     IEEE 802.3an
The S5130S-28ST-EI, S5130S-52ST-EI, S5130S-28ST-PWR-EI, and S5130S-52ST-PWR-EI switches provide 10/5/2.5/1GBASE-T autosensing Ethernet ports.
Table4-6 10/5/2.5/1GBASE-T autosensing Ethernet port specifications
Item
Specification
Connector type
RJ-45
·     10 Gbps, full duplex
·     10G mode:
¡     100 m (328.08 ft) over Category-6 shielded twisted pair or above twisted pair
¡     60 m (196.85 ft) over Category-5e twisted pair or Category-6 unshielded twisted pair
Transmission medium
Category-6 (or above) twisted pair cable
·     IEEE 802.3ab
·     IEEE 802.3an
SFP port
Some S5130S-EI switch models provide SFP ports. Table4-7 describes the SFP port support for the SFP transceiver modules and cables.
Table4-7 SFP port support for SFP transceiver modules and cables
Model
Restrictions
S5130S-28S-EI
S5130S-28ST-EI
S5130S-28S-EI-M
S5130S-28S-EI-DP
S5130S-52ST-EI
S5130S-52S-EI
S5130S-52S-EI-M
S5130S-16S-PWR-EI
S5130S-28S-PWR-EI
S5130S-28ST-PWR-EI
S5130S-52S-PWR-EI
S5130S-52ST-PWR-EI
S5130S-10MS-UPWR-EI
No SFP ports
N/A
S5130S-10P-EI
S5130S-20P-EI
S5130S-28P-EI
S5130S-28P-EI-M
S5130S-28MP-EI
S5130S-52MP-EI
S5130S-10P-HPWR-EI
S5130S-28MP-HPWR-EI
GE SFP transceiver module and cables in Table4-8
To use transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles), make sure the ambient temperature does not exceed 40°C (104°F).
S5130S-52P-EI
S5130S-52P-EI-M
S5130S-20P-PWR-EI
S5130S-28P-PWR-EI
S5130S-52P-PWR-EI
N/A
S5130S-12TP-EI
S5130S-12TP-HPWR-EI
·     SFP ports 9 and 10: GE SFP transceiver module and cables in Table4-8 and FE SFP transceiver modules in Table4-9
·     SFP ports 11 and 12: GE SFP transceiver module and cables in Table4-8
To use GE transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles), make sure the ambient temperature does not exceed 40°C (104°F).
S5130S-28TP-EI
·     SFP ports 25 and 26: GE SFP transceiver module and cables in Table4-8 and FE SFP transceiver modules in Table4-9
·     SFP ports 27 and 28: GE SFP transceiver module and cables in Table4-8
S5130S-52TP-EI
·     SFP ports 49 and 50: GE SFP transceiver module and cables in Table4-8 and FE SFP transceiver modules in Table4-9
·     SFP ports 51 and 52: GE SFP transceiver module and cables in Table4-8
N/A
S5130S-28PS-EI
S5130S-28P-HPWR-EI
S5130S-28S-HPWR-EI
GE SFP transceiver modules and cables in Table4-8 and FE SFP transceiver modules in Table4-9
N/A
S5130S-28F-EI
S5130S-52F-EI
Make sure the ambient temperature does not exceed 40°C (104°F) when the following conditions are met:
·     The switch uses one or two PSR75-12A for power supply.
·     The switch uses transceiver modules with a maximum transmission distance greater than or equal to 80 km (49.71 miles)
Table4-8 GE SFP transceiver modules and cables
GE SFP transceiver module/cable
Central wavelength
Connector
Cable specifications
Modal bandwidth (MHz*km)
Copper SFP transceiver module
SFP-GE-T
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
SFP-GE-T-D
N/A
RJ-45
Twisted pair cable
N/A
100 m (328.09 ft)
Fiber SFP transceiver module
SFP-GE-SX-MM850-A
850 nm
LC
50/125 µm multi-mode optical fiber
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
62.5/125 µm multi-mode optical fiber
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-D
850 nm
LC
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-SX-MM850-S
850
LC
Multi-mode, 50/125
500
550 m (1804.46 ft)
400
500 m (1640.42 ft)
Multi-mode, 62.5/125
200
275 m (902.23 ft)
160
220 m (721.78 ft)
SFP-GE-LX-SM1310-A
1310 nm
LC
9/125 µm single-mode optical fiber
N/A
10 km (6.21 miles)
500/400
550 m (1804.46 ft)
500
550 m (1804.46 ft)
SFP-GE-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1310-S
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1310-D
1310 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-GE-LH80-SM1550
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-GE-LH80-SM1550-D
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-GE-LH100-SM1550
1550 nm
LC
N/A
100 km (62.14 miles)
SFP-GE-LX-SM1310-BIDI
TX: 1310 nm
RX: 1490 nm
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LX-SM1490-BIDI
TX: 1490 nm
RX: 1310 nm
LC
Single-mode, 9/125
N/A
10 km (6.21 miles)
SFP-GE-LH40-SM1310-BIDI
TX: 1310 nm
RX: 1550 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH40-SM1550-BIDI
TX: 1550 nm
RX: 1310 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-GE-LH70-SM1490-BIDI
TX: 1490 nm
RX: 1550 nm
LC
Single-mode, 9/125
N/A
70 mm (2.76 in)
SFP-GE-LH70-SM1550-BIDI
TX: 1550 nm
RX: 1490 nm
LC
Single-mode, 9/125
N/A
70 mm (2.76 in)
SFP cable
SFP-STACK-Kit
N/A
N/A
SFP cable
N/A
1.5 m (4.92 ft)
IMPORTANT
IMPORTANT:
The SFP-GE-LX-SM1310-BIDI and SFP-GE-LX-SM1490-BIDI transceiver modules, the SFP-GE-LH40-SM1310-BIDI and SFP-GE-LH40-SM1550-BIDI transceiver modules, and the SFP-GE-LH70-SM1490-BIDI and SFP-GE-LH70-SM1550-BIDI transceiver modules must be used in pairs. For example, if one end uses an SFP-GE-LX-SM1310-BIDI transceiver module, the other end must use an SFP-GE-LX-SM1490-BIDI transceiver module.
Table4-9 FE SFP transceiver modules
Central wavelength
Connector
Fiber
SFP-FE-SX-MM1310-A
1310 nm
LC
·     50/125 µm, multimode
·     62.5/125 µm, multimode
2 km (1.24 miles)
SFP-FE-LX-SM1310-A
1310 nm
LC
9/125 µm, single mode
15 km (9.32 miles)
SFP-FE-LX-SM1310-D
1310 nm
LC
15 km (9.32 miles)
SFP-FE-LH40-SM1310
1310 nm
LC
40 km (24.86 miles)
SFP-FE-LH80-SM1550
1550 nm
LC
80 km (49.71 miles)
SFP-FE-LX-SM1310-BIDI
You must use these two transceiver modules in pairs.
·     TX: 1310 nm
·     RX: 1550 nm
LC
15 km (9.32 miles)
SFP-FE-LX-SM1550-BIDI
·     TX: 1550 nm
·     RX: 1310 nm
LC
·     As a best practice, use H3C SFP transceiver modules and cables for the SFP ports.
·     The H3C SFP transceiver modules and cables available for the SFP ports are subject to change over time. For the most up-to-date list of H3C SFP transceiver modules and cables available for the SFP ports, contact your H3C sales representative or technical support engineer.
·     For the specifications of the H3C SFP transceiver modules and cables, see H3C Transceiver Modules User Guide.
SFP+ port
The SFP+ ports on the switch support the following transceiver modules and cables:
·     GE SFP transceiver modules in Table4-8.
·     10-GE SFP+ transceiver modules in Table4-10.
·     10-GE SFP+ cables in Table4-11.
Table4-10 10-GE SFP+ transceiver modules available for the SFP+ ports
Central wavelength
Connector
Fiber
SFP-XG-SX-MM850-D
850 nm
LC
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-E
850 nm
LC
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-SX-MM850-S
850 nm
LC
2000
300 m (984.3 ft)
500
82 m (269.03 ft)
400
66 m (216.54 ft)
200
33 m (108.27 ft)
160
26 m (85.30 ft)
SFP-XG-LX-SM1310-D
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-E
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1310-S
1310 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1550
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1550-D
1550 nm
LC
N/A
40 km (24.86 miles)
SFP-XG-LH80-SM1550
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-XG-LH80-SM1550-D
1550 nm
LC
N/A
80 km (49.71 miles)
SFP-XG-LX-SM1270-BIDI
·     TX:1270 nm
·     RX:1330 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LX-SM1330-BIDI
·     TX:1330 nm
·     RX:1270 nm
LC
N/A
10 km (6.21 miles)
SFP-XG-LH40-SM1270-BIDI
·     TX:1270 nm
·     RX:1330 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
SFP-XG-LH40-SM1330-BIDI
·     TX:1330 nm
·     RX:1270 nm
LC
Single-mode, 9/125
N/A
40 km (24.86 miles)
IMPORTANT
IMPORTANT:
The SFP-XG-LX-SM1270-BIDI and SFP-XG-LX-SM1330-BIDI transceiver modules and the SFP-XG-LH40-SM1270-BIDI and SFP-XG-LH40-SM1330-BIDI transceiver modules must be used in pairs. For example, if one ends uses an SFP-XG-LX-SM1270-BIDI transceiver module, the other end must use an SFP-XG-LX-SM1330-BIDI transceiver module.
Table4-11 SFP+ copper cables available for the SFP+ ports
SFP+ copper cable
LSWM1STK
0.65 m (2.13 ft)
LSWM2STK
1.2 m (3.94 ft)
LSWM3STK
3 m (9.84 ft)
LSTM1STK
5 m (16.40 ft)
Table4-12 SFP+ fiber cables available for the SFP+ ports
SFP+ fiber cable
SFP-XG-D-AOC-7M
7 m (22.97 ft)
SFP-XG-D-AOC-10M
10 m (32.81 ft)
SFP-XG-D-AOC-20M
20 m (65.62 ft)
Figure4-1 10-GE SFP+ cable
(1) Connector
(2) Pull latch
·     As a best practice, use H3C SFP/SFP+ transceiver modules or SFP+ cables for the SFP+ ports.
·     The H3C SFP/SFP+ transceiver modules and SFP+ cables available for the SFP+ ports are subject to change over time. For the most up-to-date list of H3C SFP/SFP+ transceiver modules and SFP+ cables available for the SFP+ ports, contact your H3C sales representative or technical support engineer.
·     For the specifications for the H3C SFP/SFP+ transceiver modules and SFP+ cables, see H3C Transceiver Modules User Guide.
Combo interface
The S5130S-28P-HPWR-EI, S5130S-28S-HPWR-EI, S5130S-28P-HPWR-EI-AC, and S5130S-28S-HPWR-EI-AC switches each provide four combo interfaces. The S5130S-12TP-EI, S5130S-28TP-EI, S5130S-52TP-EI, S5130S-12TP-HPWR-EI, and S5130S-52F-EI switches each provide two combo interfaces. The S5130S-28F-EI and S5130S-28PS-EI switches provide eight combo interfaces. Each combo interface contains an SFP port and a 10/100/1000BASE-T autosensing Ethernet port. Only one of these two ports operates at a time.
LEDs
System status LED
The system status LED shows the operating status of the switch.
Table4-13 System status LED description
LED mark
Status
SYS
Steady yellow
Boot ROM booting stage.
Steady green
Linux kernel booting stage, or the switch has started up correctly.
Flashing green (1 Hz)
Software image loading and decompressing stage, or software booting stage.
Flashing red (3 Hz)
The switch has failed POST or the switch is faulty.
Off
The switch is powered off or has not started up correctly.
Table4-14 Management Ethernet port LED description
LED mark
Status
LINK/ACT
Steady green
A link is present on the port.
Flashing green
The port is sending or receiving data.
Off
No link is present on the port.
The S5130S-28F-EI and S5130S-52F-EI switches provide PWR1 and PWR2 LEDs on the front panel to indicate the operating status of the power supplies.
Table4-15 Power supply status LED description
LED mark
Status
PWR1/PWR2
Steady green
A power supply is installed in the power supply slot, and the power supply is outputting power correctly.
Steady yellow
A power supply is installed in the power supply slot, but the power supply is faulty or not powered on.
Off
No power supply is installed in the power supply slot.
RPS status LED
The S5130S-28P-HPWR-EI, S5130S-52P-PWR-EI, S5130S-10MS-UPWR-EI, S5130S-28S-HPWR-EI, S5130S-52S-PWR-EI, and S5130S-28MP-HPWR-EI switches support RPS input and each provide an RPS status LED on the front panel to indicate the RPS operating status.
Table4-16 RPS status LED description
LED mark
Status
RPS
Steady green
Both the RPS DC input and the AC input are normal.
Steady yellow
The RPS DC input is normal, but the AC input is disconnected or has failed.
Off
The RPS DC input has failed, or no RPS is connected.
Mode LED (MODE)
Each PoE switch provides a mode LED (MODE). The mode LED works in conjunction with the Ethernet port LEDs to indicate the operating state of the Ethernet ports and the switch.
You can use the LED mode switching button to change the indication of the mode LED.
Table4-17 Description for the mode LED
LED mark
Status
Mode LED (MODE)
Steady green
The Ethernet port LEDs are showing link state of the ports.
Flashing green
The Ethernet port LEDs are showing the PoE status of the ports.
Flashing yellow
The Ethernet port LEDs work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green, the IRF member ID of the switch is 5.
SFP/SFP+ port LED
Table4-18 SFP/SFP+ port LED description
Status
Steady green
Flashing green
Off
·     No link is present on the port.
·     The mode LED is operating in PoE mode (available only for PoE switch models)
Ethernet port LEDs
On a PoE switch, the following Ethernet port LEDs work in conjunction with the mode LED to indicate the operating state of the Ethernet ports and the switch from different aspects. Table4-19 describes the Ethernet port LEDs on a PoE switch.
·     10/100/1000BASE-T autosensing Ethernet port LEDs
·     2.5G/1000/100BASE-T autosensing Ethernet port LEDs
·     5G/2.5G/1000BASE-T autosensing Ethernet port LEDs
·     10/5/2.5/1GBASE-T autosensing Ethernet port LEDs
Table4-20 describes the Ethernet port LEDs on a non-PoE switch.
Table4-19 Ethernet port LED description for PoE switch models
Mode LED status
Ethernet port LED status
Steady green (Link/Active mode)
Steady green
Flashing green
Off
Flashing green (PoE mode)
Steady green
PoE power supply is normal.
·     The maximum PoE power provided by the port fails to meet the power requirement of the PD.
·     PoE power supply overcurrent, overvoltage, or short-circuit occurs.
·     The remaining power of the switch fails to meet the power supply requirement of the port.
Off
The port is not connected to a PD or PoE is not enabled on the port.
Flashing yellow (IRF mode)
Steady green
The Ethernet port LEDs on the switch work in conjunction to indicate the IRF member ID of the switch. For example, if the LED for port 5 is steady green and the other port LEDs are off, the IRF member ID of the switch is 5.
Table4-20 Ethernet port LED description for non-PoE switch models
LED status
Steady green
Flashing green
Off
  • Become a Partner
  • Partner Resources
