11-Load Balancing
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10011-Load Balancing
Table of Contents
Related Documents
01-HH3C-LBV2-MIB
01-HH3C-LBV2-MIB 244.95 KB
HH3C-LBV2-MIB
About this MIB
This MIB contains LB configuration, statistics, and state information, as well as notifications generated for errors occurred during configuration and operation.
MIB file name
hh3c-lbv2.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cLBv2(148)
Scalar objects
hh3cLBv2TrapEnable
Object (OID)
Access
Value range
Implementation
hh3cLBv2TrapEnable (1.3.6.1.4.1.25506.2.148.1.1)
read-write
INTEGER
enabled(1),
disabled(2)
Whether SNMP notifications is enabled for LB.
As per the MIB.
Tabular objects
hh3cLBv2GlobalStatsTable (not supported)
About this table
This table contains global LB statistics information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLBv2GlobalStatChassis, hh3cLBv2GlobalStatSlot, and hh3cLBv2GlobalStatCpuid.
Object (OID)
Access
Value range
Implementation
hh3cLBv2GlobalStatChassis(1.3.6.1.4.1.25506.2.148.1.2.1.1)
not-accessible
Unsigned32
Unsigned32 (0..255)
Chassis number.
As per the MIB.
hh3cLBv2GlobalStatSlot(1.3.6.1.4.1.25506.2.148.1.2.1.2)
not-accessible
Unsigned32
Unsigned32 (0..255)
Slot number.
As per the MIB.
hh3cLBv2GlobalStatCpuid(1.3.6.1.4.1.25506.2.148.1.2.1.3)
not-accessible
Unsigned32
Unsigned32 (0..255)
CPU number.
As per the MIB.
hh3cLBv2GlobaltatTotalConnections(1.3.6.1.4.1.25506.2.148.1.2.1.4)
read-only
Counter64
Standard MIB values.
Total number of connections.
As per the MIB.
hh3cLBv2GlobalStatActiveConnections(1.3.6.1.4.1.25506.2.148.1.2.1.5)
read-only
Gauge32
Number of active connections.
As per the MIB.
hh3cLBv2GlobalStatConnectionsRate(1.3.6.1.4.1.25506.2.148.1.2.1.6)
read-only
Gauge32
Number of connections per second.
As per the MIB.
hh3cLBv2ActionTable
About this table
This table contains LB action configuration information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLBv2ActionName.
Object (OID)
Access
Value range
Implementation
hh3cLBv2ActionName(1.3.6.1.4.1.25506.2.148.2.1.1.1)
accessible-for-notify
DisplayString
OCTET STRING (1..63)
Name of the LB action.
As per the MIB.
hh3cLBv2ActionDefaultSF(1.3.6.1.4.1.25506.2.148.2.1.1.2)
read-create
DisplayString
OCTET STRING (0..63)
Primary server farm used by the LB action.
Supports only the read operation.
hh3cLBv2ActionBackupSF(1.3.6.1.4.1.25506.2.148.2.1.1.3)
read-create
DisplayString
Backup server farm used by the LB action.
hh3cLBv2ActionInUseSF(1.3.6.1.4.1.25506.2.148.2.1.1.4)
read-only
DisplayString
Server farm currently used by the LB action.
As per the MIB.
hh3cLBv2ActionRowStatus(1.3.6.1.4.1.25506.2.148.2.1.1.5)
read-create
RowStatus
active(1)
Row status.
The value is fixed at active(1).
hh3cLBv2VSTable
About this table
This table contains virtual server configuration information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLBv2VSName.
Object (OID)
Access
Value range
Implementation
hh3cLBv2VSName(1.3.6.1.4.1.25506.2.148.3.1.1.1)
DisplayString
Virtual server name.
As per the MIB.
hh3cLBv2VSConnectionsLimit(1.3.6.1.4.1.25506.2.148.3.1.1.2)
read-create
Unsigned32
Maximum number of connections of the virtual server. 0 means not limited.
hh3cLBv2VSConnectionsRateLimit(1.3.6.1.4.1.25506.2.148.3.1.1.3)
read-create
Unsigned32
Maximum connection rate of the virtual server. 0 means not limited.
hh3cLBv2VSDefaultSF(1.3.6.1.4.1.25506.2.148.3.1.1.4)
read-create
DisplayString
Primary server farm used by the virtual server.
hh3cLBv2VSBackupSF(1.3.6.1.4.1.25506.2.148.3.1.1.5)
read-create
DisplayString
Backup server farm used by the virtual server.
hh3cLBv2VSInUseSF(1.3.6.1.4.1.25506.2.148.3.1.1.6)
read-only
DisplayString
Server farm currently used by the virtual server.
As per the MIB.
hh3cLBv2VSRowStatus(1.3.6.1.4.1.25506.2.148.3.1.1.7)
read-create
RowStatus
active(1)
Row status.
hh3cLBv2VSStatsTable (not supported)
About this table
This table contains virtual server statistics information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLBv2VSName, hh3cLBv2VSStatChassis, hh3cLBv2VSStatSlot, and hh3cLBv2VSStatCpuid.
Object (OID)
Access
Value range
Implementation
hh3cLBv2VSStatChassis(1.3.6.1.4.1.25506.2.148.3.2.1.1)
Unsigned32
Unsigned32 (0..255)
Chassis number.
As per the MIB.
hh3cLBv2VSStatSlot(1.3.6.1.4.1.25506.2.148.3.2.1.2)
Unsigned32
Unsigned32 (0..255)
Slot number.
As per the MIB.
hh3cLBv2VSStatCpuid(1.3.6.1.4.1.25506.2.148.3.2.1.3)
Unsigned32
Unsigned32 (0..255)
CPU number.
As per the MIB.
hh3cLBv2VSStatTotalConnections(1.3.6.1.4.1.25506.2.148.3.2.1.4)
read-only
Counter64
Total number of connections of the virtual server.
As per the MIB.
hh3cLBv2VSStatActiveConnections(1.3.6.1.4.1.25506.2.148.3.2.1.5)
read-only
Unsigned32
Number of active connections of the virtual server.
As per the MIB.
hh3cLBv2VSStatClientSidePKTsIn(1.3.6.1.4.1.25506.2.148.3.2.1.6)
read-only
Counter64
Number of packets that the virtual server has received from the client.
As per the MIB.
hh3cLBv2VSStatClientSidePKTsOut(1.3.6.1.4.1.25506.2.148.3.2.1.7)
read-only
Counter64
Number of packets that the virtual server has sent to the client.
As per the MIB.
hh3cLBv2VSStatDroppedPackets(1.3.6.1.4.1.25506.2.148.3.2.1.8)
read-only
Counter64
Number of packets that the virtual server has dropped.
As per the MIB.
hh3cLBv2VSStatClientSideBytesIn(1.3.6.1.4.1.25506.2.148.3.2.1.9)
read-only
Counter64
Number of bytes that the virtual server has received from the client.
As per the MIB.
The unit of this object is byte.
hh3cLBv2VSStatClientSideBytesOut(1.3.6.1.4.1.25506.2.148.3.2.1.10)
read-only
Counter64
Number of bytes that the virtual server has sent to the client.
As per the MIB.
hh3cLBv2VSStatReceivedRequests(1.3.6.1.4.1.25506.2.148.3.2.1.11)
read-only
Counter64
Number of requests that virtual server has received from the client.
As per the MIB.
hh3cLBv2VSStatSentResponses(1.3.6.1.4.1.25506.2.148.3.2.1.12)
read-only
Counter64
Number of responses that virtual server has sent to the client.
As per the MIB.
hh3cLBv2VSStatConnectionsRate(1.3.6.1.4.1.25506.2.148.3.2.1.13)
read-only
Unsigned32
Number of connections per second of the virtual server.
As per the MIB.
hh3cLBv2RSTable (not supported)
About this table
This table contains real sever configuration information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLBv2RSName.
Object (OID)
Access
Value range
Implementation
hh3cLBv2RSName(1.3.6.1.4.1.25506.2.148.4.1.1.1)
DisplayString
Real server name.
As per the MIB.
hh3cLBv2RSRowStatus(1.3.6.1.4.1.25506.2.148.4.1.1.2)
read-create
RowStatus
active(1)
Row status.
hh3cLBv2RSConnectionsLimit(1.3.6.1.4.1.25506.2.148.4.1.1.3)
read-create
Unsigned32
Maximum number of connections of the real server. 0 means not limited.
hh3cLBv2RSConnectionsRateLimit(1.3.6.1.4.1.25506.2.148.4.1.1.4)
read-create
Unsigned32
Maximum connection rate of the real server. 0 means not limited.
hh3cLBv2RSStatsTable (not supported)
About this table
This table contains real server statistics information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLBv2RSName, hh3cLBv2RSStatChassis, hh3cLBv2RSStatSlot, and hh3cLBv2RSStatCpuid.
Object (OID)
Access
Value range
Implementation
hh3cLBv2RSStatChassis(1.3.6.1.4.1.25506.2.148.4.2.1.1)
Unsigned32
Unsigned32 (0..255)
Chassis number.
As per the MIB.
hh3cLBv2RSStatSlot(1.3.6.1.4.1.25506.2.148.4.2.1.2)
Unsigned32
Unsigned32 (0..255)
Slot number.
As per the MIB.
hh3cLBv2RSStatCpuid(1.3.6.1.4.1.25506.2.148.4.2.1.3)
Unsigned32
Unsigned32 (0..255)
CPU number.
As per the MIB.
hh3cLBv2RSStatTotalConnections(1.3.6.1.4.1.25506.2.148.4.2.1.4)
read-only
Counter64
Total number of connections of the real server.
As per the MIB.
hh3cLBv2RSStatActiveConnections(1.3.6.1.4.1.25506.2.148.4.2.1.5)
read-only
Unsigned32
Number of active connections of the real server.
As per the MIB.
hh3cLBv2RSStatServerSidePKTsIn(1.3.6.1.4.1.25506.2.148.4.2.1.6)
read-only
Counter64
Number of packets that the real server has received from the device.
As per the MIB.
hh3cLBv2RSStatServerSidePKTsOut(1.3.6.1.4.1.25506.2.148.4.2.1.7)
read-only
Counter64
Number of packets that the real server has sent to the device.
As per the MIB.
hh3cLBv2RSStatDroppedPackets(1.3.6.1.4.1.25506.2.148.4.2.1.8)
read-only
Counter64
Number of packets that the real server has dropped.
As per the MIB.
hh3cLBv2RSStatServerSideBytesIn(1.3.6.1.4.1.25506.2.148.4.2.1.9)
read-only
Counter64
Number of bytes that the real server has received from the device.
As per the MIB.
hh3cLBv2RSStatServerSideBytesOut(1.3.6.1.4.1.25506.2.148.4.2.1.10)
read-only
Counter64
Number of bytes that the real server has sent to the device.
As per the MIB.
hh3cLBv2RSStatReceivedRequests(1.3.6.1.4.1.25506.2.148.4.2.1.11)
read-only
Counter64
Number of requests that the real server has received from the device.
As per the MIB.
hh3cLBv2RSStatSentResponses(1.3.6.1.4.1.25506.2.148.4.2.1.12)
read-only
Counter64
Number of responses that the real server has sent to the device.
As per the MIB.
hh3cLBv2RSStatConnectionsRate(1.3.6.1.4.1.25506.2.148.4.2.1.13)
read-only
Unsigned32
Number of connections per second of the real server.
As per the MIB.
hh3cLBv2SFTable (not supported)
About this table
This table contains server farm configuration information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is hh3cLBv2SFName.
Object (OID)
Access
Value range
Implementation
hh3cLBv2SFName(1.3.6.1.4.1.25506.2.148.5.1.1.1)
DisplayString
Server farm name
As per the MIB.
hh3cLBv2SFRowStatus(1.3.6.1.4.1.25506.2.148.5.1.1.2)
read-create
RowStatus
active(1)
Row status.
hh3cLBv2SFStatsTable (not supported)
About this table
This table contains server farm statistics information.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table indexes are hh3cLBv2SFName, hh3cLBv2SFStatChassis, hh3cLBv2SFStatSlot, and hh3cLBv2SFStatCpuid.
Object (OID)
Access
Value range
Implementation
hh3cLBv2SFStatChassis(1.3.6.1.4.1.25506.2.148.5.2.1.1)
Unsigned32
Unsigned32 (0..255)
Chassis number.
As per the MIB.
hh3cLBv2SFStatSlot(1.3.6.1.4.1.25506.2.148.5.2.1.2)
Unsigned32
Unsigned32 (0..255)
Slot number.
As per the MIB.
hh3cLBv2SFStatCpuid(1.3.6.1.4.1.25506.2.148.5.2.1.3)
Unsigned32
Unsigned32 (0..255)
CPU number.
As per the MIB.
hh3cLBv2SFStatTotalConnections(1.3.6.1.4.1.25506.2.148.5.2.1.4)
read-only
Counter64
Total number of connections of the server farm.
As per the MIB.
hh3cLBv2SFStatActiveConnections(1.3.6.1.4.1.25506.2.148.5.2.1.5)
read-only
Unsigned32
Number of active connections of the server farm.
As per the MIB.
hh3cLBv2SFStatServerSidePKTsIn(1.3.6.1.4.1.25506.2.148.5.2.1.6)
read-only
Counter64
Number of packets that the server farm has received from the device.
As per the MIB.
hh3cLBv2SFStatServerSidePKTsOut(1.3.6.1.4.1.25506.2.148.5.2.1.7)
read-only
Counter64
Number of packets that the server farm has sent to the device.
As per the MIB.
hh3cLBv2SFStatDroppedPackets(1.3.6.1.4.1.25506.2.148.5.2.1.8)
read-only
Counter64
Number of packets that the server farm has dropped.
As per the MIB.
hh3cLBv2SFStatServerSideBytesIn(1.3.6.1.4.1.25506.2.148.5.2.1.9)
read-only
Counter64
Number of bytes that the server farm has received from the device.
As per the MIB.
hh3cLBv2SFStatServerSideBytesOut(1.3.6.1.4.1.25506.2.148.5.2.1.10)
read-only
Counter64
Number of bytes that the server farm has sent to the device.
As per the MIB.
hh3cLBv2SFStatReceivedRequests(1.3.6.1.4.1.25506.2.148.5.2.1.11)
read-only
Counter64
Number of requests that the server farm has received from the device.
As per the MIB.
hh3cLBv2SFStatSentResponses(1.3.6.1.4.1.25506.2.148.5.2.1.12)
read-only
Counter64
Number of responses that the server farm has sent to the device.
As per the MIB.
Notifications
This section contains the HH3C-LBV2-MIB notifications.
hh3cLBv2VSConnOverloadTrap (not supported)
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.148.6.0.1
The number of active connections of the virtual server reaches the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.148.6.0.2 (hh3cLBv2VSConnRecoveryTrap)
ON
A notification sent when the number of active connections of the virtual server reaches the upper limit.
Status control
ON
·     CLI: Use the snmp-agent trap enable loadbalance command.
·     MIB: Set hh3cLBv2TrapEnable to enabled(1).
OFF
·     CLI: Use the undo snmp-agent trap enable loadbalance command.
·     MIB: Set hh3cLBv2TrapEnable to disabled(2).
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.148.3.1.1.1 (hh3cLBv2VSName)
Yes
DisplayString
OCTET STRING (SIZE (1..63))
1.3.6.1.4.1.25506.2.148.3.1.1.2 (hh3cLBv2VSConnectionsLimit)
No
Unsigned32
1.3.6.1.4.1.25506.2.148.3.2.1.1 (hh3cLBv2VSStatChassis)
Chassis number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.3.2.1.2 (hh3cLBv2VSStatSlot)
Slot number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.3.2.1.3 (hh3cLBv2VSStatCpuid)
CPU number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.3.2.1.5 (hh3cLBv2VSStatActiveConnections)
No
Unsigned32
Recommended action
To resolve the issue:
1.     Verify that the service access traffic is normal, or add more servers or set a larger connection limit value.
2.     If the issue persists, contact H3C Support.
hh3cLBv2VSConnRecoveryTrap (not supported)
Basic information
OID
Event
Severity
Default status
The number of active connections of the virtual server drops below the upper limit.
Recovery
ON
A notification sent when the number of active connections of the virtual server drops below the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
DisplayString
No
Unsigned32
Chassis number.
Yes
Unsigned32
0..255
Slot number.
Yes
Unsigned32
0..255
CPU number.
Yes
Unsigned32
0..255
No
Unsigned32
Recommended action
No action is required.
hh3cLBv2VSConnsRateOverloadTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.3
The connection rate of the virtual server reaches the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.148.6.0.4 (hh3cLBv2VSConnsRateRecoveryTrap)
ON
A notification sent when the connection rate of the virtual server reaches the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
DisplayString
1.3.6.1.4.1.25506.2.148.3.1.1.3 (hh3cLBv2VSConnectionsRateLimit)
No
Unsigned32
Chassis number.
Yes
Unsigned32
0..255
Slot number.
Yes
Unsigned32
0..255
CPU number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.3.2.1.13 (hh3cLBv2VSStatConnectionsRate)
Active connection rate of the virtual server.
No
Unsigned32
Recommended action
1.     Verify that the service access traffic is normal, or add more servers or set a larger connection rate limit value.
Basic information
OID
Event
Severity
Default status
The connection rate of the virtual server drops below the upper limit.
Recovery
ON
A notification sent when the connection rate of the virtual server drops below the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
DisplayString
No
Unsigned32
Chassis number.
Yes
Unsigned32
0..255
Slot number.
Yes
Unsigned32
0..255
CPU number.
Yes
Unsigned32
0..255
No
Unsigned32
Recommended action
hh3cLBv2VSActiveTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.5
The virtual server becomes available.
Recovery
ON
A notification sent when the virtual server becomes available.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
DisplayString
Recommended action
hh3cLBv2VSInactiveTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.6
The virtual server becomes unavailable.
Error
Major
1.3.6.1.4.1.25506.2.148.6.0.5 (hh3cLBv2VSActiveTrap)
ON
A notification sent when the virtual server becomes unavailable.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
DisplayString
Recommended action
hh3cLBv2RSAvailableTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.7
The real server becomes available.
Recovery
ON
A notification sent when the real server becomes available.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.148.4.1.1.1 (hh3cLBv2RSName)
Real server name.
Yes
DisplayString
Recommended action
hh3cLBv2RSUnavailableTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.8
The real server becomes unavailable.
Error
Major
1.3.6.1.4.1.25506.2.148.6.0.7 (hh3cLBv2RSAvailableTrap)
ON
A notification sent when the real server becomes unavailable.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Real server name.
Yes
DisplayString
Recommended action
1.     Verify that the server is available and the network is reachable.
hh3cLBv2SFActiveTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.9
The server farm becomes available.
Recovery
ON
A notification sent when the server farm becomes available.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.148.5.1.1.1 (hh3cLBv2SFName)
Server farm name.
Yes
DisplayString
Recommended action
hh3cLBv2SFInactiveTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.10
The server farm becomes unavailable.
Error
Major
1.3.6.1.4.1.25506.2.148.6.0.9 (hh3cLBv2SFActiveTrap)
ON
A notification sent when the server farm becomes unavailable.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Server farm name.
Yes
DisplayString
Recommended action
1.     Fix the faulty real server or add an available real server.
hh3cLBv2ActionInUseSFChangeTrap
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.11
A primary/backup switchover occurs on the server farm used by the LB action.
Informational
ON
A notification sent when a primary/backup switchover occurs on the server farm used by the LB action.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.148.2.1.1.1 (hh3cLBv2ActionName)
Yes
DisplayString
1.3.6.1.4.1.25506.2.148.2.1.1.2 (hh3cLBv2ActionDefaultSF)
No
DisplayString
OCTET STRING (SIZE (0..63))
1.3.6.1.4.1.25506.2.148.2.1.1.3 (hh3cLBv2ActionBackupSF)
No
DisplayString
1.3.6.1.4.1.25506.2.148.2.1.1.4 (hh3cLBv2ActionInUseSF)
No
DisplayString
Recommended action
hh3cLBv2VSInUseSFChangeTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.12
A primary/backup switchover occurs on the server farm used by the virtual server.
Informational
ON
A notification sent when a primary/backup switchover occurs on the server farm used by the virtual server.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Yes
DisplayString
1.3.6.1.4.1.25506.2.148.3.1.1.4 (hh3cLBv2VSDefaultSF)
No
DisplayString
1.3.6.1.4.1.25506.2.148.3.1.1.5 (hh3cLBv2VSBackupSF)
No
DisplayString
1.3.6.1.4.1.25506.2.148.3.1.1.6 (hh3cLBv2VSInUseSF)
No
DisplayString
Recommended action
hh3cLBv2RSConnOverloadTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.13
The number of active connections of the real server reaches the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.148.6.0.14 (hh3cLBv2RSConnRecoveryTrap)
ON
A notification sent when the number of active connections of the real server reaches the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Real server name.
Yes
DisplayString
1.3.6.1.4.1.25506.2.148.4.1.1.3 (hh3cLBv2RSConnectionsLimit)
No
Unsigned32
1.3.6.1.4.1.25506.2.148.4.2.1.1 (hh3cLBv2RSStatChassis)
Chassis number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.4.2.1.2 (hh3cLBv2RSStatSlot)
Slot number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.4.2.1.3 (hh3cLBv2RSStatCpuid)
CPU number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.4.2.1.5 (hh3cLBv2RSStatActiveConnections)
No
Unsigned32
Recommended action
1.     Verify that the scheduling algorithm and relevant configuration is correct, or add more servers.
Basic information
OID
Event
Severity
Default status
The number of active connections of the real server drops below the upper limit.
Recovery
ON
A notification sent when the number of active connections of the real server drops below the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Real server name.
Yes
DisplayString
No
Unsigned32
Chassis number.
Yes
Unsigned32
0..255
Slot number.
Yes
Unsigned32
0..255
CPU number.
Yes
Unsigned32
0..255
No
Unsigned32
Recommended action
hh3cLBv2RSConnsRateOverloadTrap (not supported)
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.148.6.0.15
The connection rate of the real server reaches the upper limit.
Error
Warning
1.3.6.1.4.1.25506.2.148.6.0.16 (hh3cLBv2RSConnsRateRecoveryTrap)
ON
A notification sent when the connection rate of the real server reaches the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Real server name.
Yes
DisplayString
No
Unsigned32
Chassis number.
Yes
Unsigned32
0..255
Slot number.
Yes
Unsigned32
0..255
CPU number.
Yes
Unsigned32
0..255
1.3.6.1.4.1.25506.2.148.4.2.1.13 (hh3cLBv2RSStatConnectionsRate)
Active connection rate of the real server.
No
Unsigned32
Recommended action
hh3cLBv2RSConnsRateRecoveryTrap (not supported)
Basic information
OID
Event
Severity
Default status
The connection rate of the real server drops below the upper limit.
Recovery
ON
A notification sent when the connection rate of the real server drops below the upper limit.
Status control
ON
OFF
Objects
OID (object name)
Index
Value range
Real server name.
Yes
DisplayString
No
Unsigned32
Chassis number.
Yes
Unsigned32
0..255
Slot number.
Yes
Unsigned32
0..255
CPU number.
Yes
Unsigned32
0..255
No
Unsigned32
Recommended action
