03-Virtual Technologies
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10003-Virtual Technologies
05-HH3C-STACK-MIB
05-HH3C-STACK-MIB 154.96 KB
HH3C-STACK-MIB
About this MIB
Use this MIB to obtain IRF information and manage IRF fabrics.
MIB file name
hh3c-stack.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cStack(91)
Scalar objects
hh3cStackMaxMember
Object (OID)
Access
Value range
Implementation
hh3cStackMaxMember (1.3.6.1.4.1.25506.2.91.1.1)
read-only
Integer32
Standard MIB values.
Maximum number of member devices that an IRF fabric can contain.
As per the MIB.
hh3cStackMemberNum
Object (OID)
Access
Value range
Implementation
hh3cStackMemberNum (1.3.6.1.4.1.25506.2.91.1.2)
read-only
Integer32
Number of member devices that an IRF fabric contains.
As per the MIB.
hh3cStackMaxConfigPriority
Object (OID)
Access
Value range
Implementation
hh3cStackMaxConfigPriority (1.3.6.1.4.1.25506.2.91.1.3)
read-only
Integer32
The maximum priority value that can be assigned to a member device in an IRF fabric.
The member priority can affect master election.
As per the MIB.
hh3cStackAutoUpdate
Object (OID)
Access
Value range
Implementation
hh3cStackAutoUpdate (1.3.6.1.4.1.25506.2.91.1.4)
read-write
IINTEGER
IINTEGER{
disabled(1),
enabled(2)
Whether an IRF fabric supports software auto-update.
When you add a device to the IRF fabric, software auto-update compares the startup software images of the device with the current software images of the IRF master. If the two sets of images are different, the device automatically performs the following operations:
1.     Downloads the current software images of the master.
2.     Sets the downloaded images as its main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new device with the software images running on the IRF fabric for the device to join the IRF fabric if software auto-update is disabled.
As per the MIB.
hh3cStackMacPersistence
Object (OID)
Access
Value range
Implementation
hh3cStackMacPersistence (1.3.6.1.4.1.25506.2.91.1.5)
read-write
INTEGER
INTEGER            {
notPersist(1),
persistForSixMin(2),
persistForever(3)
Status of the IRF bridge MAC persistence feature.
As per the MIB.
hh3cStackLinkDelayInterval
Object (OID)
Access
Value range
Implementation
hh3cStackLinkDelayInterval (1.3.6.1.4.1.25506.2.91.1.6)
read-write
Integer32
SIZE((0.. 10000))
IRF link status change report delay, in the range of 1 to 10000 milliseconds.
If the value is set to 0, link status change events of IRF ports are reported without any delay.
As per the MIB.
hh3cStackTopology
Object (OID)
Access
Value range
Implementation
hh3cStackTopology (1.3.6.1.4.1.25506.2.91.1.7)
read-only
INTEGER
INTEGER            {
chainConn(1),
ringConn(2)
Topology type of an IRF fabric.
As per the MIB.
hh3cStackDomainId
Object (OID)
Access
Value range
Implementation
hh3cStackDomainId (1.3.6.1.4.1.25506.2.91.1.8)
read-write
Unsigned32
SIZE((0..4294967295))
Domain ID of an IRF fabric.
As per the MIB.
hh3cStackPortConfigActivate
Object (OID)
Access
Value range
Implementation
hh3cStackPortConfigActivate (1.3.6.1.4.1.25506.2.91.1.9)
read-write
INTEGER
INTEGER
none(1),
set(2)
Whether to activate IRF port configuration.
As per the MIB.
Tabular objects
hh3cStackDeviceConfigTable
About this table
This table contains parameters about each IRF member device in an IRF fabric.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is entPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cStackMemberID (1.3.6.1.4.1.25506.2.91.2.1.1)
read-only
Integer32
IRF member ID of a member device.
The member ID must be unique in the IRF fabric.
As per the MIB.
hh3cStackConfigMemberID (1.3.6.1.4.1.25506.2.91.2.1.2)
read-write
Integer32
IRF member ID that will take effect at the next startup.
As per the MIB.
hh3cStackPriority (1.3.6.1.4.1.25506.2.91.2.1.3)
read-write
Integer32
IRF priority of the member device.
The priority can affect master election.
As per the MIB.
hh3cStackPortNum (1.3.6.1.4.1.25506.2.91.2.1.4)
read-only
Integer32
Number of IRF ports enabled on the member device.
As per the MIB.
hh3cStackPortMaxNum (1.3.6.1.4.1.25506.2.91.2.1.5)
read-only
Integer32
Maximum number of IRF ports supported by the member device.
As per the MIB.
hh3cStackBoardConfigTable
About this table
This table contains role information about each board in an IRF fabric. For modular devices, a board refers to an MPU. For fix-port devices or expandable fixed-port devices, a board refers to an IRF member device.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cStackBoardRole (1.3.6.1.4.1.25506.2.91.3.1.1)
read-only
INTEGER
INTEGER
slave(1),
master(2),
loading(3),
other(4)
IRF role of a board.
As per the MIB.
hh3cStackBoardBelongtoMember (1.3.6.1.4.1.25506.2.91.3.1.2)
read-only
Integer32
IRF member ID of the member device where the board resides.
As per the MIB.
hh3cStackPortInfoTable
About this table
This table contains IRF port information about each member device in an IRF fabric.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table indexes are hh3cStackmemberID and hh3cStackPortIndex.
Object (OID)
Access
Value range
Implementation
hh3cStackPortIndex (1.3.6.1.4.1.25506.2.91.4.1.1)
not-accessible
Integer32
Logical index of an IRF port on a member device.
As per the MIB.
hh3cStackPortEnable (1.3.6.1.4.1.25506.2.91.4.1.2)
read-only
INTEGER
INTEGER
disabled(1),
enabled(2)
Whether the IRF port has been enabled.
If IRF physical interfaces have been bound to the IRF port, the IRF port is enabled.
If no IRF physical interface has been bound to the IRF port, the IRF port is disabled.
As per the MIB.
hh3cStackPortStatus (1.3.6.1.4.1.25506.2.91.4.1.3)
read-only
INTEGER
INTEGER            {
up(1),
down(2),
silent(3),
disabled(4)
Link status of the IRF port.
As per the MIB.
hh3cStackNeighbor (1.3.6.1.4.1.25506.2.91.4.1.4)
read-only
Integer32
IRF member ID of the member device connected to the IRF port.
As per the MIB.
hh3cStackPortForwardingPath(1.3.6.1.4.1.25506.2.91.4.1.5)
read-only
OCTET STRING
Forwarding path information for traffic from the IRF port to other member devices in the IRF fabric.
The return value is a string of comma-separated IRF member IDs and the string ends with \0.
As per the MIB.
hh3cStackPhyPortInfoTable
About this table
This table contains information about IRF physical interfaces.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cStackBelongtoPort (1.3.6.1.4.1.25506.2.91.5.1.1)
read-write
Integer32
Logical index of an IRF port to which an IRF physical interface is bound.
As per the MIB.
Notifications
hh3cStackPortLinkStatusChange
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.91.6.0.1
The link status of an IRF port changed.
Informational
N/A
N/A
ON
This notification is generated when the link status of an IRF port changes.
Status control
This notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.91.2.1.1 (hh3cStackMemberID)
IRF member ID.
Yes
Integer32
1.3.6.1.4.1.25506.2.91.4.1.1 (hh3cStackPortIndex)
IRF port index.
Yes
Integer32
1.3.6.1.4.1.25506.2.91.4.1.3 (hh3cStackPortStatus)
No
INTEGER
up(1)
down(2)
silent(3)
disabled(4)
Recommended action
If the IRF port is up, no action is required.
If the IRF port is not up, perform the following tasks to resolve the issue:
1.     Check the operating status of the IRF fabric.
¡     If the IRF fabric is being established, verify that the IRF port is up after the IRF fabric is established.
¡     If the IRF fabric has been established, check the link for connectivity issues and resolve the issues.
2.     If the issue persists, contact H3C Support.
hh3cStackTopologyChange
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.2
The topology type of an IRF fabric changed.
Informational
N/A
N/A
ON
This notification is generated when the topology type of an IRF fabric changes.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.91.1.7 (hh3cStackTopology)
No
INTEGER
chainConn(1)
ringConn(2)
This table does not contain indexes. For information about the index or indexes of a MIB object instance in an SNMP variable binding, see the section for that MIB object.
Recommended action
No action is required in the following situations:
·     The topology is changed by the administrator.
·     The topology changes when the IRF fabric is being established.
·     The topology changes from a daisy chain topology to a ring topology.
If the topology changes from ring to daisy chain in other situations, take the following measures to resolve the issue:
1.     Check the running status of each member device and the link status and resolve any faulty issues.
hh3cStackMadBfdChangeNormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.3
The state of BFD MAD changed to normal.
Informational
N/A
N/A
ON
This notification is generated when the state of BFD MAD changes to normal.
Status control
Objects
OID (object name)
Index
Value range
 1.3.6.1.2.1.2.2.1.1 (ifIndex)
Index of the BFD MAD-enabled interface.
No
InterfaceIndex
Integer32 (1..2147483647)
 1.3.6.1.2.1.2.2.1.2 ( ifDescr)
BFD MAD interface name
No
OCTET STRING
OCTET STRING (0..255)
Recommended action
No action is required.
hh3cStackMadBfdChangeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.4
The state of BFD MAD changed to failure.
Informational
N/A
ON
This notification is generated when the state of BFD MAD changes to failure.
Status control
Objects
OID (object name)
Index
Value range
No
InterfaceIndex
 1.3.6.1.2.1.2.2.1.2 (ifDescr)
BFD MAD interface name.
No
OCTET STRING
Recommended action
Verify that the interface is up and the configuration is correct.
hh3cStackMadLacpChangeNormal
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.5
The state of LACP MAD changed to normal.
Informational
N/A
N/A
ON
This notification is generated when the state of LACP MAD changes to normal.
Status control
Objects
OID (object name)
Index
Value range
Index of the LACP MAD-enabled interface.
No
InterfaceIndex
LACP MAD interface name.
No
OCTET STRING
Recommended action
hh3cStackMadLacpChangeFailure
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.6
The state of LACP MAD changed to failure.
Informational
N/A
ON
This notification is generated when the state of LACP MAD changes to failure.
Status control
Objects
OID (object name)
Index
Value range
No
InterfaceIndex
No
OCTET STRING
Recommended action
hh3cStackPhysicalIntfLinkUp
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.7
An IRF physical interface came up.
Informational
N/A
N/A
ON
This notification is generated when an IRF physical interface comes up.
Status control
Objects
OID (object name)
Index
Value range
(hh3cStackMemberID)
IRF member ID.
Yes
Integer32
IRF port index.
Yes
Integer32
1.3.6.1.4.1.25506.2.91.6.1.1
(hh3cStackPhysicalIntfName)
IRF physical interface name.
No
OCTET STRING
OCTET STRING (1..255)
Recommended action
hh3cStackPhysicalIntfLinkDown
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.91.6.0.8
An IRF physical interface went down.
Informational
N/A
ON
This notification is generated when an IRF physical interface goes down.
Status control
Objects
OID (object name)
Index
Value range
(hh3cStackMemberID)
IRF member ID.
Yes
Integer32
IRF port index.
Yes
Integer32
No
OCTET STRING
Recommended action
Check the IRF physical interface status and handle the issue accordingly.
