03-Virtual Technologies
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10003-Virtual Technologies
03-HH3C-MDC-MIB
03-HH3C-MDC-MIB 93.21 KB
HH3C-MDC-MIB
About this MIB
Use this MIB to configure and manage virtual devices. You can perform the following MDC management operations:
·     Create, start, stop, and delete MDCs.
·     Allocate memory, CPU, and disk resources to MDCs.
·     Allocate physical interfaces on interface modules to MDCs.
MIB file name
hh3c-mdc.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cMDC(136)
Scalar objects
hh3cMDCMaxMDCNum
Object (OID)
Access
Value range
Implementation
hh3cMDCMaxMDCNum (1.3.6.1.4.1.25506.2.136.1.1)
read-only
Integer32
Integer32 (1..2147483647)
Maximum number of MDCs supported by the system.
Implementation varies by product.
hh3cMDCCurrentMDCNum
Object (OID)
Access
Value range
Implementation
hh3cMDCCurrentMDCNum (1.3.6.1.4.1.25506.2.136.1.2)
read-only
Integer32
Number of MDCs that have been created.
As per the MIB.
Tabular objects
hh3cMDCControlTable
About this table
Use this table to manage (including create, start, stop, or delete) an MDC and obtain settings of an MDC. The table uses MDC ID as the index. You cannot edit the name of an existing MDC.
Support for operations
For the default MDC, create, edit/modify, and read operations are supported. For non-default MDCs, only the read operation is supported.
Create
Edit/Modify
Delete
Read
Supported
Supported
Supported
Supported
Columns
The table index is hh3cMDCIndex.
Object (OID)
Access
Value range
Implementation
hh3cMDCIndex (1.3.6.1.4.1.25506.2.136.2.1.1.1.1)
accessible-for-notify
INTEGER
Index of an MDC, which corresponds to the ID of the MDC.
The index of the default MDC is 1. It cannot be edited.
When create, you must specify hh3cMDCIndex and hh3cMDCName in pairs in an SNMP request.
hh3cMDCName (1.3.6.1.4.1.25506.2.136.2.1.1.1.2)
read-create
DisplayString
OCTET STRING (1..15)
Name of the MDC.
The name of the default MDC is Admin. It cannot be edited.
The name of an existing MDC cannot be edited.
hh3cMDCAction (1.3.6.1.4.1.25506.2.136.2.1.1.1.3)
read-write
INTEGER
start(1),
stop(2)
Start or stop the MDC.
As per the MIB.
hh3cMDCStatus (1.3.6.1.4.1.25506.2.136.2.1.1.1.4)
read-only
INTEGER
inactive(1),
starting(2),
active(3),
stopping(4),
updating(5)
Status of the MDC.
As per the MIB.
hh3cMDCRowStatus (1.3.6.1.4.1.25506.2.136.2.1.1.1.5)
read-create
INTEGER
active(1),
notInService(2),
notReady(3),
createAndGo(4),
createAndWait(5),
destroy(6)
Row status.
Supports only the following values: active(1), createAndGo(4), and destroy(6).
The default MDC cannot be deleted.
hh3cMDCDISKResourceTable
About this table
Use this table to manage disk resources. You can specify a disk space percentage for an MDC and display the disk space usage.
To obtain the total amount of disk resources and the amount of available disk resources, use the hh3cFlhPartitionTable table.
·     For the default MDC, hh3cFlhPartSpace indicates the total amount of disk resources, and hh3cFlhPartSpaceFree indicates the amount of available disk resources.
·     For a non-default MDC, hh3cFlhPartSpace indicates the quota of disk resources, which is not the total amount of disk resources. hh3cMDCDiskResourceMaxLimit indicates the maximum amount of disk resources that the MDC can use. hh3cFlhPartSpaceFree indicates the amount of available disk resources, which is the same as hh3cMDCDiskResourceAvailable.
For the default MDC, both the edit/modify and read operations are supported. For non-default MDCs, only the read operation is supported.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are entPhysicalIndex, hh3cMDCIndex, and hh3cMDCDiskResourceInstance.
Object (OID)
Access
Value range
Implementation
hh3cMDCDISKResourceInstance (1.3.6.1.4.1.25506.2.136.2.2.1.1.1)
not-accessible
Integer32
Instance index of disk resources.
As per the MIB.
hh3cMDCDISKResourceInstanceName (1.3.6.1.4.1.25506.2.136.2.2.1.1.2)
read-only
OCTET STRING
OCTET STRING (1..32)
Instance name of disk resources.
As per the MIB.
hh3cMDCDISKResourceMinLimit (1.3.6.1.4.1.25506.2.136.2.2.1.1.3)
read-write
Integer32
Integer32 (0..100)
Minimum amount of disk resources that an MDC can use (minimum value for reserved disk resources).
The value of this object must be 0.
hh3cMDCDISKResourceMaxLimit (1.3.6.1.4.1.25506.2.136.2.2.1.1.4)
read-write
Integer32
Integer32 (1..100)
Maximum amount of disk resources that an MDC can use, in percentage.
As per the MIB.
Value range: 1 to 100.
hh3cMDCDISKResourceReserve
(1.3.6.1.4.1.25506.2.136.2.2.1.1.5)
read-only
Unsigned32
Standard MIB values.
Reserved amount of disk resources in the MDC, in KB.
Not supported
hh3cMDCDISKResourceQuota (1.3.6.1.4.1.25506.2.136.2.2.1.1.6)
read-only
Unsigned32
Quota of disk resources for the MDC, in KB.
As per the MIB.
hh3cMDCDISKResourceUsage (1.3.6.1.4.1.25506.2.136.2.2.1.1.7)
read-only
Unsigned32
Amount of disk resources used in the MDC, in KB.
As per the MIB.
hh3cMDCDISKResourceAvailable (1.3.6.1.4.1.25506.2.136.2.2.1.1.8)
read-only
Unsigned32
Amount of disk resources available in the MDC, in KB.
As per the MIB.
hh3CMDCMemoryResourceTable
About this table
Use this table to manage memory resources. You can specify a memory space percentage for an MDC and display the memory space usage.
The memory space percentage controls the memory that an MDC can use in the user mode. It cannot control the memory usage in the kernel because memory in the kernel is shared by all MDCs.
To obtain the total memory of the device, use the hh3cEntityExtMemSize vector of the hh3cEntityExtend object. The default MDC and non-default MDCs have the same memory size, which is the total size of the memory in the system.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table indexes are entPhysicalIndex and hh3cMDCIndex.
Object (OID)
Access
Value range
Implementation
hh3CMDCMemoryResourceMinLimit (1.3.6.1.4.1.25506.2.136.2.2.2.1.1)
read-write
Integer32
Integer32 (0..100)
Minimum amount of memory resources that an MDC can use (minimum value for reserved memory resources).
The default value must be 0.
hh3CMDCMemoryResourceMaxLimit (1.3.6.1.4.1.25506.2.136.2.2.2.1.2)
read-write
Integer32
Integer32 (0..100)
Minimum amount of memory resources that the MDC can use, in percentage.
As per the MIB.
hh3CMDCMemoryResourceReserve
(1.3.6.1.4.1.25506.2.136.2.2.2.1.3)
read-only
Unsigned32
Reserved memory resources in the MDC, in KB.
Not supported
hh3CMDCMemoryResourceQuota (1.3.6.1.4.1.25506.2.136.2.2.2.1.4)
read-only
Unsigned32
Quota of memory resources, in KB.
As per the MIB.
hh3CMDCMemoryResourceUsage (1.3.6.1.4.1.25506.2.136.2.2.2.1.5)
read-only
Unsigned32
Amount of used memory resources used in the MDC, in KB.
As per the MIB.
hh3CMDCMemoryResourceAvailable (1.3.6.1.4.1.25506.2.136.2.2.2.1.6)
read-only
Unsigned32
Amount of memory resources in the MDC, in KB.
As per the MIB.
hh3cMDCCPUResourceTable
About this table
Use this table to manage CPU resources. You can specify a CPU weight for an MDC and display the CPU usage.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cMDCCPUResourceLimit (1.3.6.1.4.1.25506.2.136.2.2.3.1.1)
read-write
Integer32
Integer32 (1..10)
CPU weight.
Default: 10.
hh3cMDCCPUResourceUsage (1.3.6.1.4.1.25506.2.136.2.2.3.1.2)
read-only
Integer32
Integer32 (0..100)
CPU usage.
As per the MIB.
hh3cMDCLocationTable
About this table
Use this table to assign physical interfaces on an interface module to an MDC.
This table is applicable only to distributed devices.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
Object (OID)
Access
Value range
Implementation
hh3cMDCLocationStatus (1.3.6.1.4.1.25506.2.136.2.3.1.1.1)
read-write
TruthValue
true(1),
false(2)
Whether to assign an interface module to an MDC.
As per the MIB.
hh3cMDCGroupIfTable
About this table
This table contains relation between interfaces and groups, which is used with hh3cMDCAllocateTable to realize interface allocation
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Supported
Columns
The table index is entPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cMDCGroupIdentity (1.3.6.1.4.1.25506.2.136.2.4.1.1.2)
read-only
Integer32
Interface group ID, which is comprised of the following bits:
·     Bits 0 through 7 represent the ID of the group.
·     Bits 8 through 31 represent the index of an interface module.
As per the MIB.
About this table
Use this table to assign interfaces to an MDC. You can assign interfaces to a non-default MDC from the default MDC, and assign interfaces back to the default MDC from a non-default MDC.
Edit or modify operation is supported only on the default MDC. Non-default MDCs support only the read operation.
Create
Edit/Modify
Delete
Read
Not supported
Supported
Not supported
Supported
Columns
The table index is hh3cMDCAllocateGroupIndex.
Object (OID)
Access
Value range
Implementation
hh3cMDCAllocateGroupIndex (1.3.6.1.4.1.25506.2.136.2.4.2.1.1)
not-accessible
Integer32
As per the MIB.
hh3cMDCAllocateGroupDescription (1.3.6.1.4.1.25506.2.136.2.4.2.1.2)
read-only
DisplayString
OCTET STRING (1..255)
List of interfaces in the interface group.
As per the MIB.
hh3cMDCAllocateMDCId (1.3.6.1.4.1.25506.2.136.2.4.2.1.3)
read-write
Integer32
Index of the MDC to which the interfaces are assigned.
As per the MIB.
Notifications
This section contains HH3C-MDC-MIB notifications.
hh3cMDCStateChangeToActive
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.136.3.0.1
Activation of an MDC.
Informational
N/A
N/A
ON
This notification is generated when the status of an MDC changes from inactive to active.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.136.2.1.1.1.1 (hh3cMDCIndex)
MDC ID.
Y
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.136.2.1.1.1.2 (hh3cMDCName)
MDC name.
N
DisplayString
OCTET STRING (SIZE (1..15))
Recommended action
No action is required.
hh3cMDCStateChangeToInactive
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.136.3.0.2
Deactivation of an MDC.
Informational
N/A
N/A
ON
This notification is generated when the status of an MDC changes from active to inactive.
Status control
Objects
OID (object name)
Index
Value range
MDC ID.
Y
Integer32
1..2147483647
MDC name.
N
DisplayString
Recommended action
