03-Virtual Technologies
HomeSupportReference GuidesMIB CompanionH3C Security Products MIB Reference(Comware 7)-6W10003-Virtual Technologies
04-HH3C-PEX-MIB
04-HH3C-PEX-MIB 110.00 KB
HH3C-PEX-MIB
About this MIB
Use the HH3C-PEX-MIB module to obtain information about port extenders (PEX) and management PEXs.
MIB file name
hh3c-pex.mib
Root object
iso(1).org(3).dod(6).internet(1).private(4).enterprises(1).hh3c(25506).hh3cCommon(2).hh3cPex(129)
Scalar objects
hh3cPexSpecInfo
Object (OID)
Access
Value range
Implementation
hh3cPexPortMinId (1.3.6.1.4.1.25506.2.129.1.1)
read-only
Integer32
Standard MIB values.
The lowest PEX port number.
As per the MIB.
hh3cPexPortMaxId (1.3.6.1.4.1.25506.2.129.1.2)
read-only
Integer32
The highest PEX port number.
As per the MIB.
hh3cPexMinAssociateId (1.3.6.1.4.1.25506.2.129.1.3)
read-only
Integer32
The lowest virtual chassis ID or virtual slot number for PEXs.
As per the MIB.
hh3cPexMaxAssociateId (1.3.6.1.4.1.25506.2.129.1.4)
read-only
Integer32
The highest virtual chassis ID or virtual slot number for PEXs.
As per the MIB.
hh3cPexMaxPortPerPexPort (1.3.6.1.4.1.25506.2.129.1.5)
read-only
Integer32
The maximum number of physical interfaces that can be assigned to the PEX port for connectivity to a PEX.
As per the MIB.
hh3cPexEntPhysicalIndexBind (1.3.6.1.4.1.25506.2.129.4.1)
accessible-for-notify
Integer32
Entity index.
As per the MIB.
Tabular objects
hh3cPexPortTable
About this table
This table contains PEX information.
Support for operations
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is hh3cPexPortId.
Object (OID)
Access
Value range
Implementation
hh3cPexPortId (1.3.6.1.4.1.25506.2.129.2.1.1.1)
Integer32
PEX port number.
As per the MIB.
hh3cPexPortAssociateId (1.3.6.1.4.1.25506.2.129.2.1.1.2)
read-create
Integer32
The virtual chassis ID or virtual slot number assigned to the PEX.
As per the MIB.
hh3cPexPortEntPhysicalIndex (1.3.6.1.4.1.25506.2.129.2.1.1.3)
read-only
Integer32
Entity index of the PEX.
As per the MIB.
hh3cPexPortDescr (1.3.6.1.4.1.25506.2.129.2.1.1.4)
read-create
DisplayString
(SIZE(1..80))
PEX port description.
As per the MIB.
hh3cPexPortStatus (1.3.6.1.4.1.25506.2.129.2.1.1.5)
read-only
INTEGER
INTEGER
offline(1),            loading(2),            online(3)
PEX state.
As per the MIB.
hh3cPexPortRowStatus (1.3.6.1.4.1.25506.2.129.2.1.1.6)
read-create
RowStatus
RowStatus
active(1),
createAndGo(4),
destroy(6)
Row status.
As per the MIB.
hh3cPexPhyPortTable
About this table
This table contains information about the interfaces connected to PEXs.
Create
Edit/Modify
Delete
Read
Not supported
Not supported
Not supported
Not supported
Columns
The table index is entPhysicalIndex.
Object (OID)
Access
Value range
Implementation
hh3cPexPhyPortStatus (1.3.6.1.4.1.25506.2.129.2.2.1.1)
read-only
INTEGER
INTEGER                 {
unknown(1),          down(2),     blocked(3),         forwarding(4)
The state of a physical interface that connects the parent fabric to a PEX.
As per the MIB.
hh3cPexPhyPortBelongToPexPort (1.3.6.1.4.1.25506.2.129.2.2.1.2)
read-write
Integer32
The PEX port to which the physical interface belongs.
As per the MIB.
hh3cPexPhyPortNeighborEntIndex (1.3.6.1.4.1.25506.2.129.2.2.1.3)
read-only
Integer32
Entity index of a physical interface that connects the PEX to the parent fabric. It is identical to entPhysicalIndex in ENTITY-MIB.
As per the MIB.
Notifications
hh3cPexPortOnline
Basic information
OID
Event
Severity
Recovery notification
Default status
1.3.6.1.4.1.25506.2.129.3.0.1
PEX came online.
Recovery
ON
This notification occurs when a PEX comes online.
Status control
The notification cannot be disabled.
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.129.2.1.1.1 (hh3cPexPortId)
PEX port number.
Yes
Integer32
1..2147483647
1.3.6.1.4.1.25506.2.129.2.1.1.4 (hh3cPexPortDescr)
No
DisplayString
OCTET STRING (SIZE (0..79))
Recommended action
No action is required.
hh3cPexPortOffline
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.129.3.0.2
PEX went offline.
Error
Major
ON
This notification is generated when a PEX goes online.
Status control
Objects
OID (object name)
Index
Value range
PEX port number.
Yes
Integer32
1..2147483647
No
DisplayString
Recommended action
To resolve the issue:
1.     Examine the startup status of the PEX, and then take either of the following actions:
¡     If the PEX is starting up, wait for it to complete the startup process and then verify its online status.
¡     If the PEX is not starting up, examine the links between the PE and the parent fabric for link issues.
2.     If the issue persists, contact H3C Support.
hh3cPexPhyPortForwarding
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.129.3.0.3
PEX physical interface changed to the forwarding state.
ON
This notification is generated when the state of a PEX physical interface changes from blocked to forwarding.
Status control
Objects
OID (object name)
Index
Value range
1.3.6.1.4.1.25506.2.129.4.1 (hh3cPexEntPhysicalIndexBind)
Entity index.
Yes
Integer32
1.3.6.1.2.1.47.1.1.1.1.2 (entPhysicalDescr)
Interface description.
No
SnmpAdminString
OCTET STRING (SIZE (0..255))
Recommended action
hh3cPexPhyPortBlocked
Basic information
OID
Event
Severity
Default status
1.3.6.1.4.1.25506.2.129.3.0.4
PEX physical interface changed to the blocked state.
Error
Major
ON
This notification is generated when the state of a PEX physical interface changes from forwarding to blocked.
Status control
Objects
OID (object name)
Index
Value range
Entity index.
Yes
Integer32
No
SnmpAdminString
Recommended action
To resolve this issue:
¡     If the device is starting up, no action is required.
¡     If the device is not starting up, go to the next step.
2.     Examine PEX cabling to verify that:
¡     The PEX's all PEX physical interfaces are connected to the physical interfaces assigned to the same PEX port on the parent fabric.
¡     The PEX port contains only physical links to the same PEX.
3.     Make sure the links between the parent fabric and the PEX are stable.
4.     If the issue persists, contact H3C Support.
