H3C SecPath L5030[L5060][L5080][L5000-E] Load Balancer Installation Guide-6W103
HomeSupportSecurityH3C SecPath L5000Install & UpgradeInstallation GuidesH3C SecPath L5030[L5060][L5080][L5000-E] Load Balancer Installation Guide-6W103
00-Preface
00-Preface 100.42 KB
Preface
The installation guide describes the procedure for installing H3C SecPath L5030/L5060/L5080/ L5000-E load balancer. It covers preparing for installation, installing the load balancer, logging in to the load balancer, hardware replacement, hardware management and maintenance, and troubleshooting.
·     Audience
·     Conventions
·     Documentation feedback
Audience
·     Network planners
·     Field technical support and servicing engineers
·     Network administrators working with the H3C SecPath L5030/L5060/L5080/ L5000-E load balancer
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
We appreciate your comments.
