| 00-Preface | 100.52 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures of the IRF and MDC technologies. The IRF technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. The MDC technology partitions a physical device or an IRF fabric into multiple logical devices. Each of the logical devices is called an MDC. Each MDC uses its own hardware and software resources, runs independently of other MDCs, and provides services for its own customer.
· Audience
Audience
· Network planners.
· Network administrators working with the S12500X-AF&S12500-X&S9800 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
