- 10-High Availability Command Reference
- 01-Ethernet OAM commands
- 02-CFD commands
- 03-DLDP commands
- 04-RRPP commands
- 05-ERPS commands
- 06-Smart Link commands
- 07-Monitor Link commands
- 08-VRRP commands
- 09-BFD commands
- 10-Track commands
- 11-Process placement commands
- 12-Reth interface and redundancy group commands
| 00-Preface | 100.92 KB |
Preface
This command reference describes the high availability configuration commands, including fault detection and fast failover configuration commands. With these commands, you can detect and diagnose your network, and rapidly recover your network when failures occur.
· Audience
Audience
· Network planners.
· Network administrators working with the S12500X-AF&S12500-X&S9800 switch series.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
