01-Text | 130.69 KB |
Deploying OpenStack by using Kolla Ansible
Preprovisioning basic SeerEngine-DC settings
Setting up the basic environment
Installing the SeerEngine-DC Neutron plug-ins
Obtaining the SeerEngine-DC Neutron plug-in installation package
Installing the SeerEngine-DC Neutron plug-ins on the OpenStack control node
Upgrading the SeerEngine-DC Neutron plug-ins
(Optional.) Configuring the metadata service for network nodes
The Inter X700 Ethernet network adapter series fails to receive LLDP messages. What should I do?
Overview
This document describes how to install SeerEngine-DC Neutron plug-ins on OpenStack deployed by using Kolla-Ansible.
Neutron is a type of OpenStack services used to manage all virtual networking infrastructures (VNIs) in an OpenStack environment. It provides virtual network services to the devices managed by OpenStack computing services. It allows tenants to create advanced virtual services, such as a firewall (FW), load balancer (LB), and virtual private network (VPN).
SeerEngine-DC Neutron plug-ins are developed for the SeerEngine-DC controller based on the OpenStack framework. The following SeerEngine-DC Neutron plug-ins are available:
· SeerEngine-DC Neutron Core plug-ins—Includes networks, subnets, routers, and ports and provides tenants with core basic network communication capabilities.
· SeerEngine-DC Neutron L3_Routing plug-in—Allows tenants to forward traffic to each other at Layer 3.
· SeerEngine-DC Neutron FWaaS plug-in—Allows tenants to create firewall services.
· SeerEngine-DC Neutron LBaaS plug-in—Allows tenants to create LB services.
· SeerEngine-DC Neutron VPNaaS plug-in—Allows tenants to create VPN services.
The SeerEngine-DC Neutron plug-ins allow deployment of the network configuration obtained from OpenStack through REST APIs on the SeerEngine-DC controller, including tenants' networks, subnets, routers, ports, FW, LB, and VPN settings.
CAUTION: To avoid service interruptions, do not modify the settings issued by the cloud platform on the controller, such as the virtual link layer network, vRouter, and vSubnet settings after the plug-ins connect to the OpenStack cloud platform. |
Preparing for installation
Hardware requirements
Table 1 shows the hardware requirements for installing the SeerEngine-DC Neutron plug-ins on a server or virtual machine.
CPU |
Memory size |
Disk space |
Single-core and multicore CPUs |
2 GB and above |
5 GB and above |
Software requirements
You can install the SeerEngine-DC Neutron plug-ins on OpenStack Pike deployed by using Kolla-Ansible.
IMPORTANT: Before you install the OpenStack plug-ins, make sure the following requirements are met: · Your system has a reliable Internet connection. · OpenStack has been deployed correctly. Verify that the /etc/hosts file on all nodes has the host name-IP address mappings, and the OpenStack Neutron extension services (Neutron-FWaas, Neutron-VPNaas, or Neutron-LBaas) have been deployed. For the deployment procedure, see the installation guide for the specific OpenStack version on the OpenStack official website. |
NOTE: For the installation of converged version of SeerEngine_DC plug-ins (SeerEngine_DC_PLUGIN-version-py2.7.egg), see H3C SeerEngine-DC OpenStack Converged Plug-Ins Installation Guide. |
Before installing the plug-ins, deploy OpenStack by using Kolla Ansible first. For the OpenStack deployment procedure, see the installation guide for the specific OpenStack version on the OpenStack official website.
This procedure preprovisions only basic SeerEngine-DC settings. For the configuration in a specific scenario, see the SeerEngine-DC configuration guide for that scenario.
Table 2 Preprovisioning basic SeerEngine-DC settings
Item |
Configuration directory |
Fabrics |
Automation > Data Center Networks > Fabrics > Fabrics |
VDS |
Automation > Data Center Networks > Common Network Settings > Virtual Distributed Switch |
IP address pool |
Automation > Data Center Networks > Resource Pools > IP Address Pools |
Add access devices and border devices to a fabric |
L4-L7 device, physical resource pool, and template |
Automation > Data Center Networks > Resource Pools > Devices > Physical Devices Automation > Data Center Networks > Resource Pools > Devices > L4-L7 Physical Resource Pools |
Border gateway |
Automation > Data Center Networks > Common Network Settings > Gateways |
Installing OpenStack plug-ins
The SeerEngine-DC Neutron plug-ins are installed on the OpenStack control node.
Before installing SeerEngine-DC Neutron plug-ins on the OpenStack control node, set up the basic environment on the node.
To set up the basic environment:
1. Update the software source list, and then download and install the Python tools.
The following uses commands on a CentOS operating system as an example.
[root@controller ~]# yum clean all
[root@controller ~]# yum makecache
[root@controller ~]# yum install –y python-pip python-setuptools
2. Install runlike.
[root@ controller ~]# pip install runlike
3. Access the neutron_server container and edit the /etc/hosts file. Add the following information to the file.
¡ IP and name mappings of all hosts in this OpenStack environment. To obtain this information, access the SeerEngine-DC controller and select Provision > Domains > Hosts.
¡ IP and name mappings of all leaf, spine, and border devices in this scenario. To obtain this information, access the SeerEngine-DC controller and select Provision > Inventory > Devices.
The SeerEngine-DC Neutron plug-ins are included in the SeerEngine-DC OpenStack package. Obtain the SeerEngine-DC OpenStack package of the required version and then save the package to the target installation directory on the server or virtual machine.
Alternatively, transfer the installation package to the target installation directory through a file transfer protocol such as FTP, TFTP, or SCP. Use the binary transfer mode to prevent the software package from being corrupted during transit.
1. Create the startup scripts for the neutron-server and h3c-agent containers.
[root@controller ~]# runlike neutron_server>docker-neutron-server.sh
[root@controller ~]# cp docker-neutron-server.sh docker-h3c-agent.sh
[root@controller ~]# sed -i 's/neutron-server/h3c-agent/g' docker-h3c-agent.sh
[root@controller ~]# sed -i 's/neutron_server/h3c_agent/g' docker-h3c-agent.sh
2. Modify the neutron.conf configuration file.
a. Use the vi editor to open the neutron.conf configuration file.
[root@controller ~]# vi /etc/kolla/neutron-server/neutron.conf
b. Configure the neutron.conf configuration file based on the operating system running in the Kolla environment.
- If a CentOS operating system runs in the Kolla environment, see H3C SeerEngine-DC Controller OpenStack Plug-Ins Installation Guide for CentOS to configure the neutron.conf configuration file.
- If a Ubuntu operating system runs in the Kolla environment, see H3C SeerEngine-DC Controller OpenStack Plug-Ins Installation Guide for Ubuntu to configure the neutron.conf configuration file.
IMPORTANT: · In the neutron_server configuration directory (/etc/kolla/neutron-server/), you can configure the service_provider parameter for a service once only. If you have configured the service_provider parameter for the firewall service in the neutron.conf configuration file, do not configure the service_provider parameter in the fwaas_driver.ini file. This rule applies also to the LBaaS and PNaaS services. · For h3c_agent to load the driver correctly, change the FWaaS driver value in the /etc/kolla/neutron-server/fwaas_driver.ini file to networking_h3c.fw.h3c_fwplugin_driver.H3CfwaasDriver. |
3. Modify the ml2_conf.ini configuration file.
a. Use the vi editor to open the ml2_conf.ini configuration file.
[root@controller ~]# vi /etc/kolla/neutron-server/ml2_conf.ini
b. Press I to switch to insert mode, and set the parameters in the ml2_conf.ini configuration file. For information about the parameters, see "ml2_conf.ini."
[ml2]
type_drivers = vxlan,vlan
tenant_network_types = vxlan,vlan
mechanism_drivers = ml2_h3c
extension_drivers = ml2_extension_h3c,qos
[ml2_type_vlan]
network_vlan_ranges = physicnet1:1000:2999,port_security
[ml2_type_vxlan]
vni_ranges = 1:500
c. Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the ml2_conf.ini file.
4. Modify the neutron.conf configuration file and add plug-ins configuration items.
b. Add the configuration items in the ml2_conf_h3c.ini file to neutron.conf based on the operating system running in the Kolla environment.
- If a CentOS operating system runs in the Kolla environment, see H3C SeerEngine-DC Controller OpenStack Plug-Ins Installation Guide for CentOS to add the configuration items.
- If a Ubuntu operating system runs in the Kolla environment, see H3C SeerEngine-DC Controller OpenStack Plug-Ins Installation Guide for Ubuntu to add the configuration items.
5. Copy the plug-ins installation package to the neutron_server container.
[root@controller ~]# docker cp SeerEngine_DC_PLUGIN-D3601_pike_2017.10-py2.7.egg neutron_server:/
6. Access the file folder on the neutron_server container where the plug-ins installation package resides and install the package.
[root@controller ~]# docker exec -it -u root neutron_server bash
(neutron-server) [root@controller ~]# easy_install SeerEngine_DC_PLUGIN-D3601_pike_2017.10-py2.7.egg
(neutron-server) [root@controller ~]# h3c-sdnplugin controller install
IMPORTANT: Before executing the h3c-sdnplugin controller install command, make sure no neutron.con file exists in the /root directory. If such a file exists, delete it or move it to another location. |
NOTE: An error might be reported when the h3c-sdnplugin controller install command is executed. Just ignore it. |
7. Create neutron-server and h3c-agent container images.
[root@controller ~]# neutron_server_image=$(docker ps --format {{.Image}} --filter name=neutron_server)
[root@controller ~]# h3c_agent_image=$(echo $neutron_server_image | sed 's/neutron-server/h3c-agent/')
[root@controller ~]# docker ps | grep $neutron_server_image
16d60524b8b3 kolla/centos-source-neutron-server:pike "dumb-init --single-? 16 months ago Up 2 weeks neutron_server
[root@controller ~]# docker commit container_uuid kolla/neutron-server-h3c (use the UUID obtained in the preceding command)
[root@controller ~]# docker rm -f neutron_server
[root@controller ~]# docker tag $neutron_server_image kolla/neutron-server-origin
[root@controller ~]# docker rmi $neutron_server_image
[root@controller ~]# docker tag kolla/neutron-server-h3c $neutron_server_image
[root@controller ~]# docker tag kolla/neutron-server-h3c $h3c_agent_image
[root@controller ~]# docker rmi kolla/neutron-server-h3c
8. Copy the neutron-server configuration to the h3c-agent directory and modify the configuration.
[root@controller ~]# cp -pR /etc/kolla/neutron-server /etc/kolla/h3c-agent
[root@controller ~]# sed -i 's/neutron-server/h3c-agent/g' /etc/kolla/h3c-agent/config.json
9. Start the neutron-server and h3c-agent containers
[root@controller ~]# source docker-neutron-server.sh
[root@controller ~]# source docker-h3c-agent.sh
10. View the startup status of the containers. If their status is Up, they have been started up correctly.
[root@controller ~]# docker ps --filter "name=neutron_server"
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
289e4e132a9b kolla/centos-source-neutron-server:pike "dumb-init --single-? 1 minutes ago Up 1 minutes neutron_server
[root@controller ~]# docker ps --filter "name=h3c_agent"
c334f7ec9857 kolla/centos-source-h3c-agent: pike "dumb-init --single-? 1 minutes ago Up 1 minutes h3c_agent
Parameters and fields
This section describes parameters in configuration files and fields included in parameters.
ml2_conf.ini
Parameter |
Required value |
type_drivers |
vxlan,vlan |
Driver type. vxlan must be specified as the first driver type. |
tenant_network_types |
vxlan,vlan |
Type of the networks to which the tenants belong. · In the host overlay scenario and network overlay with hierarchical port binding scenario, vxlan must be specified as the first network type. · In the network overlay without hierarchical port binding scenario, vlan must be specified as the first network type. For intranet, only vxlan is available. For extranet, only vlan is available. |
mechanism_drivers |
ml2_h3c |
Name of the ml2 driver. To create SR-IOV instances for VLAN networks, set this parameter to sriovnicswitch, ml2_h3c. To create hierarchy-supported instances, set this parameter to ml2_h3c,openvswitch. |
extension_drivers |
ml2_extension_h3c,qos |
Names of the ml2 extension drivers. Available names include ml2_extension_h3c, qos, and port_security. If the QoS feature is not enabled on OpenStack, you do not need to specify the value qos for this parameter. To not enable port security on OpenStack, you do not need to specify the port_security value for this parameter. |
network_vlan_ranges |
N/A |
Value range for the VLAN ID of the extranet, for example, physicnet1:1000:2999. |
vni_ranges |
N/A |
Value range for the VXLAN ID of the intranet, for example, 1:500. |
CAUTION: · Services might be interrupted during the SeerEngine-DC Neutron plug-ins upgrade procedure. Make sure you understand the impact of the upgrade before performing it on a live network. · The plug-ins settings will not be restored automatically after an upgrade in the Kolla environment. Before an upgrade, back up the settings in the /etc/kolla/neutron-server/neutron.conf and /etc/kolla/neutron-server/ml2_conf.ini configuration files. After the upgrade, modify the parameter settings according to the configuration files to ensure configuration consistency before and after the upgrade. |
Upgrade with neutron_server and h3c_agent containers removed
1. Remove the containers installed with the old version of the plug-ins and their images.
a. If no docker-neutron-server.sh scrip file exists, execute the following command. If such a file exists, skip this step.
b. Remove the containers installed with the old version of the plug-ins and their images.
[root@controller ~]# docker rm -f h3c_agent
[root@controller ~]# docker rmi $h3c_agent_image
c. Restore the default containers and images in the Kolla environment.
[root@controller ~]# docker tag kolla/neutron-server-origin $neutron_server_image
[root@controller ~]# docker rmi kolla/neutron-server-origin
IMPORTANT: Before restarting the neutron_server container, you must restore the configurations in the neutron.conf and ml2_conf.ini files and remove the plug-ins-related configuration. |
2. Install the new version of plug-ins. For the installation procedure, see "Installing the SeerEngine-DC Neutron plug-ins".
Upgrade with neutron_server and h3c_agent containers retained
To upgrade the plug-ins with neutron_server and h3c_agent containers retained, you are required to remove the old version of the plug-ins and then install the view version of the plug-ins on each of the containers.
1. Upgrade the neutron_server container.
a. Access the neutron_server container and remove the old version of the plug-ins.
(neutron-server) [root@controller ~]# h3c-sdnplugin controller uninstall
Remove service
Removed symlink /etc/systemd/system/multi-user.target.wants/h3c-agent.service.
Restore config files
Uninstallation complete.
(neutron-server) [root@controller ~]# pip uninstall seerengine-dc-plugin
Uninstalling SeerEngine-DC-PLUGIN-E3603P01-pike-2017.10:
/usr/bin/h3c-agent
/usr/bin/h3c-sdnplugin
b. Install the new version of the plug-ins, and then examine and configure the items based on the document for the new version of the plug-ins.
[root@controller ~]# docker cp SeerEngine_DC_PLUGIN-D3601_pike _2017.10-py2.7.egg neutron_server:/
(neutron-server) [root@controller ~]# easy_install SeerEngine_DC_PLUGIN-D3601_pike _2017.10-py2.7.egg
c. Exit and then restart the neutron_server container.
(neutron-server)[root@controller01 ~]# exit
[root@controller01 ~]# docker restart neutron_server
2. Upgrade the h3c_agent container.
a. Access the h3c_agent container and uninstall the old version of the plug-in.
(h3c-agent) [root@controller ~]# h3c-sdnplugin controller uninstall
Remove service
(h3c-agent) [root@controller ~]# pip uninstall seerengine-dc-plugin
/usr/bin/h3c-agent
b. Install the new version of the plug-in.
[root@controller ~]# docker cp SeerEngine_DC_PLUGIN-D3601_pike_2017.10-py2.7.egg h3c_agent:/
[root@controller ~]# docker exec -it -u root h3c_agent bash
(h3c-agent) [root@controller ~]# easy_install SeerEngine_DC_PLUGIN-D3601_pike_2017.10-py2.7.egg
(h3c-agent) [root@controller ~]# h3c-sdnplugin controller install
c. Exit and then restart the h3c_agent container.
(h3c-agent)[root@controller01 ~]# exit
[root@controller01 ~]# docker restart h3c_agent
3. Make sure the h3c-agent service is available only on one node after the upgrade if the plug-ins are installed on multiple nodes to prevent repeated issue of firewall configuration.
To stop the h3c-agent service on a node:
a. Execute the h3c_agent=$(docker ps --format {{.ID}} --filter name= h3c_agent) command to view the h3c-agent service status.
b. Execute the docker stop $h3c_agent command to disable the h3c-agent service on the node.
OpenStack supports obtaining metadata from network nodes for VMs through DHCP or L3 gateway. H3C supports only the DHCP method. To configure the metadata service for network nodes:
1. Download the OpenStack installation guide from the OpenStack official website and follow the installation guide to configure the metadata service for the network nodes.
2. Configure the network nodes to provide metadata service through DHCP.
a. Use the vi editor to open configuration file dhcp_agent.ini.
[root@network ~]# vi /etc/kolla/neutron-dhcp-agent/dhcp_agent.ini
b. Press I to switch to insert mode, and modify configuration file dhcp_agent.ini as follows:
[DEFAULT]
force_metadata = True
Set the value to True for the force_metadata parameter to force the network nodes to provide metadata service through DHCP.
c. Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the dhcp_agent.ini configuration file.
3. Restart the dhcp-agent container.
[root@network ~]# docker restart neutron_dhcp_agent
FAQ
The Python tools cannot be installed using the yum command when a proxy server is used for Internet access. What should I do?
Configure HTTP proxy by performing the following steps:
1. Make sure the server or the virtual machine can access the HTTP proxy server.
2. At the CLI of the CentOS system, use the vi editor to open the yum.conf configuration file. If the yum.conf configuration file does not exist, this step creates the file.
[root@controller ~]# vi /etc/yum.conf
3. Press I to switch to insert mode, and provide HTTP proxy information as follows:
¡ If
the server does not require authentication, enter HTTP proxy information in the following format:
proxy =
http://yourproxyaddress:proxyport
¡ If the server requires authentication,
proxy = http://yourproxyaddress:proxyport
proxy_username=username
proxy_password=password
Table 3 describes the arguments in HTTP proxy information.
Table 3 Arguments in HTTP proxy information
username |
Username for logging in to the proxy server, for example, sdn. |
password |
Password for logging in to the proxy server, for example, 123456. |
yourproxyaddress |
IP address of the proxy server, for example, 172.25.1.1. |
proxyport |
Port number of the proxy server, for example, 8080. |
proxy = http://172.25.1.1:8080
proxy_username = sdn
proxy_password = 123456
4. Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the yum.conf file.
After the plug-ins are installed successfully, what should I do if the controller fails to interconnect with the cloud platform?
Follow these steps to resolve the interconnection failure with the cloud platform:
1. Make sure you have strictly followed the procedure in this document to install and configure the plug-ins.
2. Contact the cloud platform vendor to determine whether a configuration issue exists on the cloud platform side.
3. If the issue persists, contact after-sales engineers.
Use the following procedure to resolve the issue. An enp61s0f3 Ethernet network adapter is used as an example.
1. View and record system kernel information.
[root@controller ~]# uname -r
3.10.0-957.1.3.el7.x86_64
2. View detailed information about the Ethernet network adapter and record the values for the firmware-version and bus-info fields.
[root@controller ~]# ethtool -i enp61s0f3
driver: i40e
version: 2.8.20-k
firmware-version: 3.33 0x80000f0c 1.1767.0
expansion-rom-version:
bus-info: 0000:3d:00.3
supports-statistics: yes
supports-test: yes
supports-eeprom-access: yes
supports-register-dump: yes
supports-priv-flags: yes
3. Use one of the following solutions, depending on the kernel version and network adapter firmware version:
¡ The kernel version is higher than kernel-3.10.0-957.el7 and the network adapter firmware version is 4 or higher.
# Execute the following command:
[root@controller ~]# ethtool --set-priv-flags enp61s0f3 disable-fw-lldp on
# Identify whether the value for the disable-fw-lldp field is on.
[root@controller ~]# ethtool --show-priv-flags enp61s0f3 | grep lldp
disable-fw-lldp : on
If the value is on, the network adapter then can receive LLDP messages. For this command to remain effective after a system restart, you must write this command into the user-defined startup program file.
# Open the self-defined startup program file.
[root@controller ~]# vi /etc/rc.d/rc.local
# Press I to switch to insert mode, and add this command to the file. Then press Esc to quit insert mode, and enter :wq to exit the vi editor and save the file.
# Configure the file to be executable.
[root@controller ~]# chmod 755 /etc/rc.d/rc.local
¡ The kernel version is lower than kernel-3.10.0-957.el7, or the network adapter firmware version is lower than 4.
# Execute the echo "lldp stop" > /sys/kernel/debug/i40e/bus-info/command command. Enter the recorded bus info value for the network adapter, and add a backslash (\) before each ":".
[root@controller ~]# echo "lldp stop" > /sys/kernel/debug/i40e/0000\:3d\:00.3/command
The network adapter can receive LLDP messages after this command is executed. For this command to remain effective after a system restart, you must write this command into the user-defined startup program file.
# Press I to switch to insert mode, and add this command to the file. Then Press Esc to quit insert mode, and enter :wq to exit the vi editor and save the file.
