| 02-H3C Access Points Introduction | 70.97 KB |
New H3C Technologies Co., Ltd. http://www.h3c.com
Document version: 6W100-20220830 |
H3C 802.11ax Series Access Points
H3C 802.11ac Wave2 Series Access Points
Model |
Installation mode |
Supported modes |
Local power supply |
PoE/PSE |
Max. power consumption |
Radios |
WA6638 |
Celling mounting and wall mounting |
· FIT · Cloud · Anchor |
+54 VDC |
10GE/PoE++: 802.3bt/at/af GE/PSE: PoE_OUT,802.3af |
· 25 W (not supplying PoE power) · 37 W (supplying PoE power) |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 2.4 Gbps Radio 2: · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 2.4 Gbps Radio 3: · 2.4 GHz · 802.11b/g/n/ax · MIMO 4x4 · 1.15 Gbps |
WA6636 |
+54 VDC |
10GE/PoE++: 802.3bt/at/af GE1/PoE+: 802.3at/af GE2/PoE_OUT: PoE_OUT 802.3af |
· 40 W (supplying PoE power) · 22.5 W (not supplying PoE power) |
Radio 1 · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 4.8 Gbps Radio 2: · 5 GHz · 802.11a/n/ac/ax · MIMO 2x2 · 1.2 Gbps Radio 3: · 2.4 GHz · 802.11b/g/n/ax · MIMO 4x4 · 1.15 Gbps |
WA6630X |
Wall mounting and pole mounting |
Not supported |
10GE/PoE++: 802.3bt/at/af GE2/PSE: PoE_OUT,802.3af |
48.6 W |
Radio 1 · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 2.4 Gbps Radio 2: · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 2.4 Gbps Radio 3: · 2.4 GHz · 802.11b/g/n/ax · MIMO 2x2 · 575 Mbps |
WA6628X |
100 to 264 VAC |
GE/PoE_OUT: PoE_OUT 802.3af |
52 W |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 8x8 · 4.8 Gbps Radio 2: · 2.4 GHz · 802.11b/g/n/ax · MIMO 4x4 · 1.15 Gbps |
WA6628 |
+54 VDC |
10GE/PoE++: 802.3bt/at/af GE/PoE+: 802.3at/af |
· 25 W (not supplying power through USB port) · 28 W (supplying power through USB port) |
WA6628E-T |
Wall mounting and rack mounting |
· FIT · Cloud |
DC (+110 V)/AC (220 V) |
Not supported |
40 W |
WA6622 |
+54 VDC |
5GE/PoE+: 802.3at/af GE/PSE: PoE_OUT 802.3af |
· 19.9 W (not supplying PoE power) · 35.5 W (supplying PoE power) · 12.93 W (Not supplying PoE power and with the radios operating in 1×1 MIMO mode) |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 2.4 Gbps Radio 2: · 2.4 GHz · 802.11b/g/n/ax · MIMO 2x2 · 575 Mbps |
WA6620X |
Not supported |
31 W |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 2x2 · 1.2 Gbps Radio 2: · 2.4 GHz (default): · 5 GHz: |
WA6528i |
+54 VDC |
5GE/PoE++: 802.3bt/at/af GE/PoE_OUT: PoE_OUT 802.3af |
· 25 W (PoE_OUT/USB excluded) · 42.5 W (PoE_OUT/USB included) |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 4.8 Gbps Radio 2: · 2.4 GHz · 802.11b/g/n/ax · MIMO 4x4 · 1.15 Gbps Radio 3 (only for scanning): · 2.4 GHz: · 5 GHz: |
WA6526E |
· FIT · Cloud |
+54 VDC |
2.5GE/PoE+: 802.3at/af GE/PSE: PoE_OUT 802.3af |
· 17.6 W (not supplying power) · 35.1 W (supplying power) |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 4x4 · 4.8 Gbps Radio 2: · 2.4 GHz · 802.11b/g/n/ax · MIMO 2x2 · 575 Mbps |
WA6526 |
· FIT · Cloud |
+54 VDC |
2.5GE/PoE+: 802.3at/af |
· 17.6 W (USB excluded) · 20.1 W (USB included) |
WA6330 |
+54 VDC |
· 16.5 W (not supplying PoE power) · 32 W (supplying PoE power) · 12.93 W (Not supplying PoE power and with the radios operating in 1×1 MIMO mode) |
Radio 1: · 5 GHz · 802.11a/n/ac/ax · MIMO 2x2 · 1.2 Gbps · 5.15 GHz to 5.35 GHz Radio 2: · 2.4 GHz: · 5 GHz (default): Radio 3: · 2.4 GHz (default): · 5 GHz: |
WA6320 |
+54 VDC |
GE/PoE: 802.3af |
12.42 W |
· Radio 1: ¡ 5 GHz ¡ 802.11a/n/ac/ax ¡ MIMO 2x2 ¡ 1.2 Gbps · Radio 2: ¡ 2.4 GHz ¡ 802.11b/g/n/ax ¡ MIMO 2x2 ¡ 575 Mbps |
WA6320H |
Walljack |
+54 VDC |
Uplink/PoE In: 802.3af |
· 12.95 W without a USB device attached · 15.45 W without a USB device attached |
Model |
Installation mode |
Supported modes |
PoE/PSE |
Radios |
WA510H |
Walljack |
FIT |
+54 VDC |
12.95 W |
Radio 1: · 5 GHz · 802.11a/n/ac · MIMO 2x2 · 867 Mbps Radio 2: · 2.4 GHz · 802.11b/g/n · MIMO 2x2 · 300 Mbps |
WA530 |
· FIT · Cloud |
+54 VDC |
GE1/PoE: 802.3af GE2/PoE: 802.3af |
12.95 W |
Radio 1: · 5 GHz · 802.11a/n/ac · MIMO 2x2 · 867 Mbps Radio 2: · 2.4 GHz · 802.11b/g/n · MIMO 2x2 · 400 Mbps |
WA530X |
· FIT · FAT · Anchor |
Not supported |
GE1/PoE+: 802.3af/at |
25.5 W |
WA5330 |
+54 VDC |
GE1/PoE+: 802.3af/at GE2/IoT: used for connecting a downlink IoT access unit to the AP |
· 12.02 W (with no IoT access unit connected to it) · 24.02 W (with IoT access units connected to it) |
Radio 1: · 5 GHz · 802.11a/n/ac · MIMO 2x2 · 867 Mbps Radio 2: · 5 GHz · 802.11a/n/ac · MIMO 2x2 · 867 Mbps Radio 3: · 2.4 GHz · 802.11b/g/n · MIMO 2x2 · 400 Mbps |
WA536 |
+54 VDC |
GE1/PoE: 802.3af |
30 W |
WA538 |
+54 VDC |
GE1/PoE+: 802.3af/at GE2/PoE+: 802.3af/at |
25 W |
Radio 1: · 5 GHz · 802.11a/n/ac · MIMO 4x4 · 1733 Mbps Radio 2: · 5 GHz · 802.11a/n/ac · MIMO 2x2 · 867 Mbps Radio 3: · 2.4 GHz · 802.11b/g/n · MIMO 2x2 · 400 Mbps |
WA5530X |
Not supported |
· 22.43 W (with no access unit connected to it) · 34.43 W (with access units connected to it) |
Radio 1: · 5 GHz · 802.11a/n/ac · MIMO 2x2 · 867 Mbps Radio 2: · 5 GHz · 802.11a/n/ac · MIMO 4x4 · 1733 Mbps Radio 3: · 2.4 GHz · 802.11b/g/n · MIMO 2x2 · 400 Mbps |
WA5530i |
+48 VDC |
30 W |
WA560 |
FIT |
Not supported |
25 W |
Radio 1: · 5 GHz · 802.11a/n/ac · MIMO 4x4 · 1733 Mbps Radio 2: · 2.4 GHz · 802.11b/g/n · MIMO 4x4 · 800 Mbps |
