01-EVPN commands | 180.75 KB |
address-family evpn (public instance view)
address-family evpn (VPN instance view)
address-family ipv4 (public instance view)
display evpn route arp suppression
route-distinguisher (EVPN instance view)
route-distinguisher (public instance view)
EVPN commands
The following compatibility matrix shows the support of hardware platforms for EVPN:
Hardware |
EVPN compatibility |
MSR810, MSR810-W, MSR810-W-DB, MSR810-LM, MSR810-W-LM, MSR810-10-PoE, MSR810-LM-HK, MSR810-W-LM-HK, MSR810-LMS-EA |
Yes |
MSR810-LMS, MSR810-LUS |
No |
MSR2600-6-X1, MSR2600-10-X1 |
Yes |
MSR 2630 |
Yes |
MSR3600-28, MSR3600-51 |
Yes |
No |
Yes |
MSR3610-I-DP, MSR3610-IE-DP |
Yes |
MSR3610-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC |
Yes |
Yes |
MSR3610-G, MSR3620-G |
Yes |
Use address-family evpn to enter public instance EVPN view.
Use undo address-family evpn to delete all settings in public instance EVPN view.
address-family evpn
Public instance view
You can configure EVPN settings such as route targets in public instance EVPN view.
# Enter public instance EVPN view.
[Sysname] ip public-instance
[Sysname-public-instance] address-family evpn
[Sysname-public-instance-evpn]
Use address-family evpn to enter VPN instance EVPN view.
Use undo address-family evpn to delete all settings in VPN instance EVPN view.
address-family evpn
VPN instance view
You can configure EVPN settings such as route targets and routing policies in VPN instance EVPN view.
# Enter EVPN view of VPN instance tenant.
[Sysname] ip vpn-instance tenant
[Sysname-vpn-instance-tenant] address-family evpn
[Sysname-vpn-evpn-tenant]
Use address-family ipv4 to enter public instance IPv4 address family view.
Use undo address-family ipv4 to delete all settings in public instance IPv4 address family view.
address-family ipv4
# Enter public instance IPv4 address family view.
[Sysname-public-instance] address-family ipv4
[Sysname-public-instance-ipv4]
address-family l2vpn evpn
Use address-family l2vpn evpn to create the BGP EVPN address family and enter its view, or enter the view of the existing BGP EVPN address family.
Use undo address-family l2vpn evpn to delete the BGP EVPN address family and all settings in BGP EVPN address family view.
The BGP EVPN address family does not exist.
BGP instance view
Configuration made in BGP EVPN address family view takes effect only on routes and peers of the BGP EVPN address family that are on the public network.
# Create the BGP EVPN address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family l2vpn evpn
[Sysname-bgp-default-evpn]
advertise l2vpn evpn
Use advertise l2vpn evpn to enable BGP EVPN route advertisement to the local site.
Use undo advertise l2vpn evpn to disable BGP EVPN route advertisement to the local site.
BGP EVPN route advertisement to the local site is enabled.
BGP-VPN IPv4 unicast address family view
This command enables the device to advertise private BGP EVPN routes to the local site after the device adds the routes to the routing table of a VPN instance.
# Enable BGP EVPN route advertisement to the local site for VPN instance vpn1.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] address-family ipv4
[Sysname-bgp-default-ipv4-vpn1] advertise l2vpn evpn
arp mac-learning disable
Use arp mac-learning disable to disable an EVPN instance from learning MAC addresses from ARP information.
Use undo arp mac-learning disable to restore the default.
An EVPN instance learns MAC addresses from ARP information.
EVPN instance view
The MAC information and ARP information advertised by a remote VTEP overlap. To avoid duplication, use this command to disable the learning of MAC addresses from ARP information. EVPN will learn remote MAC addresses only from the MAC information advertised from remote sites.
# Disable an EVPN instance from learning MAC addresses from ARP information.
[Sysname] vsi aaa
[Sysname-vsi-aaa] evpn encapsulation vxlan
[Sysname-vsi-aaa-evpn-vxlan] arp mac-learning disable
dci enable
Use dci enable to enable DCI on an interface.
Use undo dci enable to disable DCI on an interface.
dci enable
undo dci enable
DCI is disabled on an interface.
Interface view
For EDs to automatically establish VXLAN-DCI tunnels, you must enable DCI on the Layer 3 interfaces that interconnect the EDs.
# Enable DCI on GigabitEthernet 1/0/1
[Sysname-GigabitEthernet1/0/1] dci enable
display bgp l2vpn evpn
Use display bgp l2vpn evpn to display BGP EVPN routes.
display bgp [ instance instance-name ] l2vpn evpn [ peer ipv4-address { advertised-routes | received-routes } [ statistics ] | route-distinguisher route-distinguisher [ route-type { auto-discovery | es | imet | ip-prefix | mac-ip } ] [ evpn-route route-length [ advertise-info ] ] | route-type { auto-discovery | es | imet | ip-prefix | mac-ip } | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays BGP EVPN routes for the default BGP instance.
peer ipv4-address: Specifies a peer by its IPv4 address.
advertised-routes: Specifies the routes advertised to the specified peer.
received-routes: Specifies the routes received from the specified peer.
statistics: Displays BGP EVPN route statistics.
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. The RD can use one of the following formats:
· 16-bit AS number:32-bit user-defined number. For example, 101:3.
· 32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number. For example, 65536:1. The AS number must be equal to or greater than 65536.
route-type: Specifies a route type.
auto-discovery: Specifies Ethernet auto-discovery routes.
es: Specifies Ethernet segment (ES) routes.
imet: Specifies inclusive multicast Ethernet tag (IMET) routes.
ip-prefix: Specifies IP prefix advertisement routes.
mac-ip: Specifies MAC/IP advertisement routes.
evpn-route: Specifies a BGP EVPN route, a case-insensitive string of 1 to 512 characters.
route-length: Specifies the route length in bits, in the range of 0 to 65535.
advertise-info: Displays advertisement information for BGP EVPN routes.
If you do not specify any parameter, this command displays brief information about all BGP EVPN routes.
# Display brief information about all BGP EVPN routes.
<Sysname> display bgp l2vpn evpn
BGP local router ID is 8.8.8.8
Total number of routes from all PEs: 3
Route distinguisher: 1:1
Total number of routes: 2
* >i [2][0][48][7010-0000-0001][0][0.0.0.0]/104
7.7.7.7 0 100 0 i
Route distinguisher of public instance: 1:15
Total number of routes: 1
* >e [2][0][48][0011-0022-0033][32][11.22.33.55]/136
30.30.1.2 0 0 100i
Status codes |
Route status codes: · * - valid—Valid route. · > - best—Optimal route. · d - dampened—Dampened route. · h - history—History route. · i - internal—Internal route. · e - external—External route. · s - suppressed—Suppressed route. · S - Stale—Stale route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. The origin of routes advertised by using the network command is IGP. · e – EGP—Learned through EGP. · ? – incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Network |
BGP EVPN route/route length. BGP EVPN routes are as follows: · [1][ESI][EthernetTagID] ¡ 1—Ethernet auto-discovery route. ¡ ESI—Ethernet segment identifier (ESI). ¡ EthernetTagID—Ethernet tag ID. · [2][EthernetTagID][MACLength][MAC][IPAddressLength][IPAddress] ¡ 2—MAC/IP advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ MACLength—MAC address length. ¡ MAC—MAC address. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address. · [3][EthernetTagID][IPAddressLength][IPAddress] ¡ 3—IMET route. ¡ EthernetTagID—Ethernet tag ID. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [4][ESI][IPAddressLength][IPAddress] ¡ 4—ES route. ¡ ESI—ESI. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. · [5][EthernetTagID][IPAddressLength][IPAddress] ¡ 5—IP prefix advertisement route. ¡ EthernetTagID—Ethernet tag ID. ¡ IPAddressLength—IP address length. ¡ IPAddress—IP address of the originating router. |
NextHop |
Next hop IP address. |
MED |
Multi-Exit Discriminator (MED) attribute. |
LocPrf |
Local precedence. |
PrefVal |
Preferred value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route. |
# Display detailed information about BGP EVPN route [1][00:00:00:00:00:00:00:00:00:00][5]/120 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [1][00:00:00:00:00:00:00:00:00:00][5] 120
BGP local router ID: 172.16.250.133
Local AS number: 100
Route distinguisher: 1.1.1.1:100
Paths: 1 available, 1 best
BGP routing table information of [1][00:00:00:00:00:00:00:00:00:00][5]/120:
Rely nexthop : 10.1.1.2
Original nexthop: 10.1.1.2
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN >, <ESI Label: Flag 0,
Label 1>
AS-path : 200
Origin : igp
State : valid, external, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
VPN-Peer UserID : N/A
DSCP : N/A
EVPN route type : Ethernet auto-discovery route
ESI : 00:00:00:00:00:00:00:00:00:00
Ethernet tag ID : 5
MPLS label : 10
Paths |
Number of routes: · available—Number of valid routes. · best—Number of optimal routes. |
From |
IP address of the BGP peer that advertised the route. |
Rely Nexthop |
Next hop after route recursion. If no next hop is found, this field displays not resolved. |
Original nexthop |
Original next hop of the route. If the route was obtained from a BGP update message, the original next hop is the next hop IP address in the message. |
OutLabel |
Outgoing label of the route. |
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ESI Label. |
AS-path |
AS_PATH attribute of the route. This attribute records the ASs the route has passed and avoids routing loops. |
Origin |
Origin of the route: · igp—Originated in the AS. The origin of routes advertised by using the network command is IGP. · egp—Learned through EGP. · incomplete—Unknown origin. The origin of routes redistributed from IGP protocols is incomplete. |
Attribute value |
Attributes of the route: · MED—MED value for the destination network. · localpref—Local preference value. · pref-val—Preferred value. · pre—Route preference value. |
State |
Current state of the route: · valid. · internal. · external. · local. · synchronize. · best. |
IP precedence |
IP precedence in the range of 0 to 7. N/A indicates that the IP precedence is invalid. |
QoS local ID |
QoS local ID in the range of 1 to 4095. N/A indicates that the QoS local ID is invalid. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the traffic index is invalid. |
VPN-Peer UserID |
VPN peer ID in the range of 1 to 134217727. N/A indicates that the route does not support this field. |
DSCP |
DSCP value in the range of 0 to 63. N/A indicates that the route does not support this field. |
MPLS label |
MPLS label. The current software version does not support this field. |
# Display detailed information about BGP EVPN route [2][5][48][0001-0203-0405][32][4.5.5.5]/136 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [2][5][48][0001-0203-0405][32][5.5.5.5] 136
BGP routing table information of [2][5][48][0001-0203-0405][32][5.5.5.5]/136:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <RT: 1:3>, <RT: 1:4>, <RT: 1:5>, <RT: 1:6>, <RT: 1:7
>, <Encapsulation Type: VXLAN>, <Router's Mac: 0006-0708-0910
>, <MAC Mobility: Flag 0, SeqNum 2>, <Default GateWay>
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EVPN route type : MAC/IP advertisement route
Ethernet tag ID : 5
MAC address : 0001-0203-0405
IP address : 5.5.5.5/32
MPLS label1 : 10
MPLS label2 : 0
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. · MAC Mobility—MAC mobility. ¡ Flag—Indicates whether the MAC address can move. A value of 1 indicates that the MAC address cannot move, and a value of 0 indicates that the MAC address can move. ¡ SeqNum—Identifies the most recent move of the MAC address. · Default GateWay—Route for the default gateway. |
MPLS label1 |
VXLAN ID used for Layer 2 forwarding. |
MPLS label2 |
L3 VXLAN ID used for Layer 3 forwarding. |
# Display detailed information about BGP EVPN route [3][0][32][5.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [3][0][32][4.5.5.5] 80
BGP routing table information of [3][0][32][4.5.5.5]/80:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>
PMSI tunnel : Flag 0, TunnelType 6, Label 10, EndPointAddress 10.1.1.2
AS-path : 200
Origin : igp
Attribute value : MED 0,pref-val 0
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EVPN route type : Inclusive multicast Ethernet tag route
Ethernet tag ID : 0
Origin address : 5.5.5.5/32
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. |
PMSI tunnel |
P-Multicast Service Interface (PMSI) tunnel information: · Flag—Flags. This field is fixed at 0 in the current software version. · TunnelType—Tunnel type. This field is fixed at 6 in the current software version, which represents a head-end replication tunnel. · Label—VXLAN ID. · EndPointAddress—Tunnel destination address. |
Origin address |
# Display detailed information about BGP EVPN route [4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5]/128 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5] 128
BGP routing table information of [4][00:00:00:00:00:00:00:00:00:00][32][4.5.5.5]/128:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <ES-Import RT: 1:1>
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EVPN route type : Ethernet segment route
Origin address : 4.5.5.5/32
Table 5 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · ES-Import RT. |
Origin address |
# Display detailed information about BGP EVPN route [5][10][32][4.5.5.5]/80 with RD 1.1.1.1:100.
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [5][10][32][4.5.5.5] 80
BGP routing table information of [5][10][32][4.5.5.5]/80:
OutLabel : NULL
Ext-Community : <RT: 1:2>, <Encapsulation Type: VXLAN>, <Router's Mac:
0006-0708-0910>
AS-path : 200
Origin : igp
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
DSCP : N/A
EVPN route type : IP prefix advertisement route
Ethernet tag ID : 10
IP address : 4.5.5.5/32
Gateway address : 0.0.0.0
MPLS Label : 1
Table 6 Command output
Ext-Community |
Extended community attributes: · RT. · Encapsulation Type. · Router's Mac. |
IP address |
IP address and prefix length. |
MPLS Label |
<Sysname> display bgp l2vpn evpn route-distinguisher 1.1.1.1:100 [4][00:00:00:00:00:00:00:00:00:00] [32][4.5.5.5] 128 advertise-info
Paths: 1 best
10.2.1.2
Table 7 Command output
Paths |
Advertised to peers (1 in total) |
Peers to whom the route has been advertised and the number of the peers. |
display evpn auto-discovery
Use display evpn auto-discovery to display information about peers that are automatically discovered through BGP.
display evpn auto-discovery { imet [ peer ip-address] [ vsi vsi-name ] | macip-prefix [ nexthop next-hop ] [ count ] }
imet: Specifies peers discovered through IMET routes.
peer ip-address: Specifies a peer by its IP address. If you do not specify this option, the command displays information about all automatically discovered peers.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays peer information for all VSIs.
macip-prefix: Specifies peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
nexthop next-hop: Specifies a next hop. If you do not specify this option, the command displays peer information for all next hops.
count: Displays the number of peers. If you do not specify this keyword, the command displays detailed peer information.
# Display information about peers discovered through IMET routes.
<Sysname> display evpn auto-discovery imet
Total number of automatically discovered peers: 2
VSI name: vpna
RD PE_address Tunnel_address Tunnel mode VXLAN ID
1:10 2.2.2.2 2.2.2.2 VXLAN 10
2:100 3.3.3.3 3.3.3.3 VXLAN 10
Table 8 Command output
PE_address |
Identifier of the remote VTEP on the VSI. |
Tunnel_address |
Tunnel destination IP address. |
Tunnel mode |
Tunnel mode: · VXLAN. · VXLAN-DCI. |
# Display information about peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix
Destination IP Source IP L3VNI Tunnel mode Outgoing interface
1.1.1.1 3.3.3.3 200 VXLAN Vsi-interface3
2.2.2.2 3.3.3.3 200 VXLAN Vsi-interface3
# Display the total number of peers discovered through MAC/IP advertisement routes and IP prefix advertisement routes.
<Sysname> display evpn auto-discovery macip-prefix count
Total number of entries: 2
Table 9 Command output
Destination IP |
Source IP |
Tunnel source IP address. |
L3VNI |
Tunnel mode |
Outgoing interface |
VSI interface associated with the L3 VXLAN ID. |
Use display evpn route arp to display EVPN ARP entries.
display evpn route arp [ local | remote ] [ public-instance | vpn-instance vpn-instance-name ] [ count ]
local: Specifies local ARP entries.
remote: Specifies remote ARP entries.
public-instance: Specifies the public instance.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters.
count: Displays the number of ARP entries. If you do not specify this keyword, the command displays detailed information about ARP entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP entries.
If you do not specify the public-instance keyword or the vpn-instance vpn-instance-name option, this command displays EVPN ARP entries for the public instance and all VPN instances.
# Display all EVPN ARP entries.
<Sysname> display evpn route arp
Flags: D - Dynamic B - BGP G - Gateway L - Local active M - Mapping
VPN instance:vpn1 Interface:Vsi-interface1
IP address MAC address Router MAC VSI index Flags
10.1.1.1 0003-0003-0003 a0ce-7e40-0400 0 GL
10.1.1.11 0001-0001-0001 a0ce-7e40-0400 0 DL
10.1.1.12 0001-0001-0011 a0ce-7e41-0401 0 B
10.1.1.13 0001-0001-0021 a0ce-7e42-0402 0 B
Public instance Interface:Vsi-interface2
11.1.1.1 0033-0033-0033 a0ce-7e40-0400 0 GL
11.1.1.11 0011-0011-0011 a0ce-7e40-0400 0 DL
# Display the total number of EVPN ARP entries.
<Sysname> display evpn route arp count
Total number of entries: 6
Table 10 Command output
VSI interface. |
Flags |
ARP entry type: · D—Dynamically learned entry. · B—Entry learned from BGP EVPN routes. · G—Entry for the gateway. · L—Local entry. · M—Entry from a remote VXLAN that is mapped to a local VXLAN. |
Use display evpn route arp suppression to display EVPN ARP flood suppression entries.
display evpn route arp suppression [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local ARP flood suppression entries.
remote: Specifies remote ARP flood suppression entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays ARP flood suppression entries for all VSIs.
count: Displays the number of ARP flood suppression entries. If you do not specify this keyword, the command displays detailed information about ARP flood suppression entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN ARP flood suppression entries.
# Display all EVPN ARP flood suppression entries.
<Sysname> display evpn route arp suppression
VSI name: vpna
IP address MAC address Flags
10.1.1.12 0002-0002-0002 B
# Display the total number of ARP flood suppression entries.
<Sysname> display evpn route arp suppression count
Total number of entries: 1
Table 11 Command output
Flags |
ARP flood suppression entry type: · D—Dynamically learned entry. · B—Entry learned from BGP EVPN routes. · G—Entry for the gateway. · L—Local entry. · M—Entry from a remote VXLAN that is mapped to a local VXLAN. |
display evpn route mac
Use display evpn route mac to display EVPN MAC address entries.
display evpn route mac [ local | remote ] [ vsi vsi-name ] [ count ]
local: Specifies local MAC address entries.
remote: Specifies remote MAC address entries.
vsi vsi-name: Specifies a VSI by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays MAC address entries for all VSIs.
count: Displays the number of MAC address entries. If you do not specify this keyword, the command displays detailed information about MAC address entries.
If you do not specify the local or remote keyword, this command displays both local and remote EVPN MAC address entries.
# Display all EVPN MAC address entries.
<Sysname> display evpn route mac
VSI name: bbb
MAC address Link ID/Name Flags Next hop
0000-0000-000a 1 DL -
0000-0000-0009 Tunnel1 B 2.2.2.2
# Display the total number of EVPN MAC address entries.
<Sysname> display evpn route mac count
Table 12 Command output
Link ID/Name |
For a local MAC address, this field displays the AC's link ID on the VSI. For a remote MAC address, this field displays the tunnel interface name. |
Flags |
MAC address entry type: · D—Dynamically learned entry. · B—Entry learned from BGP EVPN routes. · G—Entry for the gateway. · L—Local entry. · M—Entry from a remote VXLAN that is mapped to a local VXLAN. |
Next hop |
IP address of the remote VTEP. If the MAC address entry is a local entry, a hyphen (-) is displayed. |
display evpn routing-table
Use display evpn routing-table to display the EVPN routing table for a VPN instance.
display evpn routing-table { public-instance | vpn-instance vpn-instance-name } [ count ]
count: Displays the number of entries in the routing table. If you do not specify this keyword, the command displays detailed information about the routing table.
# Display the EVPN IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1
VPN instance name: vpn1 Local L3VNI: 7
IP address Nexthop Outgoing interface NibID
10.1.1.11 1.1.1.1 Vsi-interface3 0x18000000
10.1.1.12 2.2.2.2 Vsi-interface3 0x18000001
# Display the EVPN IPv4 routing table for the public instance.
<Sysname> display evpn routing-table public-instance
Public instance Local L3VNI: 3900
# Display the number of EVPN route entries in the IPv4 routing table for VPN instance vpn1.
<Sysname> display evpn routing-table vpn-instance vpn1 count
Table 13 Command output
Local L3VNI |
L3 VXLAN ID associated with the VPN instance or the public instance. |
NibID |
Next hop ID. |
evpn encapsulation
Use evpn encapsulation to create an EVPN instance and enter its view, or enter the view of an existing EVPN instance.
Use undo evpn encapsulation to restore the default.
No EVPN instance exists.
VSI view
vxlan: Specifies VXLAN encapsulation.
Before you can configure EVPN settings, you must create an EVPN instance.
# Create an EVPN instance and enter its view.
[Sysname] vsi aaa
export route-policy
Use export route-policy to apply an export routing policy to EVPN on a VPN instance.
Use undo export route-policy to restore the default.
No export routing policy is applied to EVPN on a VPN instance.
route-policy: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
You can specify an export routing policy to filter advertised routes or modify their route attributes for EVPN.
EVPN can use an export routing policy specified in VPN instance view or in VPN instance EVPN view. Export routing policy configuration in EVPN view takes precedence over that in VPN instance view.
# Apply export routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-instance-vpn1] address-family evpn
[Sysname-vpn-evpn-vpn1] export route-policy poly-1
route-policy (Layer 3—IP Routing Command Reference)
import route-policy
Use import route-policy to apply an import routing policy to EVPN on a VPN instance.
Use undo import route-policy to restore the default.
No import routing policy is applied to EVPN on a VPN instance. The VPN instance accepts a route when the export route targets of the route match local import route targets.
You can specify an import routing policy to filter received routes or modify their route attributes for EVPN.
EVPN can use an import routing policy specified in VPN instance view or in VPN instance EVPN view. Import routing policy configuration in EVPN view takes precedence over that in VPN instance view.
# Apply import routing policy poly-1 to EVPN on VPN instance vpn1.
[Sysname-vpn-evpn-vpn1] import route-policy poly-1
ip public-instance
Use ip public-instance to create the public instance and enter its view, or enter the view of the existing public instance.
Use undo ip public-instance to delete the public instance.
ip public-instance
The public instance does not exist.
A distributed EVPN gateway uses the public instance to perform Layer 3 forwarding for the public network and to enable communication between private and public networks. The public instance is similar to a VPN instance. A distributed EVPN gateway processes traffic of the public instance in the same way it does for a VPN instance.
# Create the public instance and enter its view.
l3-vni
Use l3-vni to configure an L3 VXLAN ID for a VSI interface or for the public instance.
Use undo l3-vni to remove the L3 VXLAN ID for a VSI interface or for the public instance.
l3-vni vxlan-id
undo l3-vni
No L3 VXLAN ID is configured for a VSI interface or for the public instance.
VSI interface view
vxlan-id: Specifies a VXLAN ID in the range of 0 to 16777215.
On distributed EVPN gateways, you must configure L3 VXLAN IDs for the gateways to differentiate traffic of different VPN instances.
To forward Layer 3 traffic of a VPN instance, you must assign an L3 VXLAN ID to the VSI interface of the VPN instance. To forward Layer 3 traffic of the public network, you must assign the same L3 VXLAN ID to the public instance and the VSI interface of the public instance.
To modify the L3 VXLAN ID for the public instance, you must first delete the original L3 VXLAN ID.
# Configure the L3 VXLAN ID as 1000 for VSI-interface 100.
[Sysname] interface vsi-interface 100
[Sysname-Vsi-interface100] l3-vni 1000
mac-advertising disable
Use mac-advertising disable to disable MAC address advertisement and withdraw advertised MAC addresses.
Use undo mac-advertising disable to restore the default.
MAC address advertisement is enabled.
EVPN instance view
The MAC information and ARP information advertised by the VTEP overlap. To avoid duplication, use this command to disable MAC address advertisement and withdraw the MAC addresses advertised to remote VTEPs.
# Disable MAC address advertisement and withdraw advertised MAC addresses for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] mac-advertising disable
mapping vni
Use mapping vni to map a local VXLAN to a remote VXLAN.
Use undo mapping vni to restore the default.
mapping vni vxlan-id
undo mapping vni
A local VXLAN is not mapped to any remote VXLAN.
EVPN instance view
vxlan-id: Specifies a remote VXLAN ID in the range of 0 to 16777215.
The VXLAN mapping feature provides Layer 2 connectivity for a tenant subnet that uses different VXLAN IDs in multiple data centers.
VXLAN mapping includes the following types:
· Non-intermediate VXLAN mapping—When two data centers use different VXLAN IDs for a subnet, map the local VXLAN to the remote VXLAN on the ED of one data center. For example, for VXLAN 10 of data center 1 to communicate with VXLAN 20 of data center 2, map VXLAN 10 to VXLAN 20 on the ED of data center 1.
· Intermediate VXLAN mapping—When multiple data centers use different VXLAN IDs for a subnet, map the VXLANs to an intermediate VXLAN on all EDs. For example, data center 1 uses VXLAN 10, data center 2 uses VXLAN 20, and data center 3 uses VXLAN 30. To provide connectivity for the VXLANs, map them to intermediate VXLAN 500 on EDs of the data centers. You must use intermediate VXLAN mapping if more than two data centers use different VXLAN IDs. The intermediate VXLAN can be used only for VXLAN mapping, and it cannot be used for common VXLAN services.
You must create mapped remote VXLANs on the device, create an EVPN instance for each remote VXLAN, and configure RD and route target settings for the EVPN instances.
A mapped remote VXLAN ID cannot be the reserved VXLAN ID specified by using the reserved vxlan command.
# Map local VXLAN 100 to remote VXLAN 200.
[Sysname] vsi aaa
[Sysname-vsi-aaa] vxlan 100
[Sysname-vsi-aaa-vxlan-100] quit
[Sysname-vsi-aaa-evpn-vxlan] mapping vni 200
reserved vxlan (VXLAN Command Reference)
peer next-hop-invariable
Use peer next-hop-invariable to configure the device to not change the next hop of routes advertised to an EBGP peer or peer group.
Use undo peer next-hop-invariable to configure the device to use its address as the next hop of routes advertised to an EBGP peer or peer group.
undo peer { group-name | ipv4-address [ mask-length ] } next-hop-invariable
The device uses its address as the next hop of routes advertised to EBGP peers or peer groups.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters.
mask-length: Specifies a mask length in the range of 0 to 32. To specify a subnet, you must specify both the ipv4-address and mask-length arguments.
This command is exclusive with the peer next-hop-local command.
The next hop in BGP EVPN routes is the IP address of the originating VTEP. By default, the device replaces the next hop of IBGP routes with its address when advertising the routes to an EBGP peer. If the device is a transport network device, it will modify the next hop of BGP EVPN routes. For VTEPs to learn one another's IP address, you must configure the device to not change the next hop of routes advertised to EBGP peers.
# Configure the device to not change the next hop of routes advertised to EBGP peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 next-hop-invariable
peer next-hop-local (Layer 3—IP Routing Command Reference)
peer router-mac-local
Use peer router-mac-local to enable route router MAC replacement for a peer or peer group.
Use undo peer router-mac-local to cancel route router MAC replacement configuration for a peer or peer group.
peer { group-name | ipv4-address [ mask-length ] } router-mac-local
undo peer { group-name | ipv4-address [ mask-length ] } router-mac-local
The device does not modify the router MAC address of routes before advertising the routes.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The peer group must exist.
ipv4-address: Specifies a peer by its IPv4 address. The peer must exist.
This command enables an ED to use its router MAC address to replace the router MAC address of routes received from and advertised to a peer or peer group in the local data center. The router MAC replacement process is as follows:
· For routes received from the peer or peer group, the ED performs router MAC replacement and advertises the routes to remote EDs.
· For routes received from a remote data center, the ED performs router MAC replacement and advertises the routes to the peer or peer group.
# In BGP EVPN address family view, enable route router MAC replacement for peer 1.1.1.1.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] peer 1.1.1.1 router-mac-local
policy vpn-target
Use policy vpn-target to enable route target filtering for BGP EVPN routes.
Use undo policy vpn-target to disable route target filtering for BGP EVPN routes.
policy vpn-target
Route target filtering is enabled for BGP EVPN routes.
When route target filtering is enabled for BGP EVPN routes, the EVPN routing table accepts only BGP EVPN routes of which the export route targets match the local import route targets. If the device must save all BGP EVPN routes, use the undo policy vpn-target command to disable route target filtering for BGP EVPN routes.
# Disable route target filtering for BGP EVPN routes.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] undo policy vpn-target
Use route-distinguisher to configure an RD for an EVPN instance.
Use undo route-distinguisher to restore the default.
route-distinguisher { route-distinguisher | auto }
No RD is configured for an EVPN instance.
EVPN instance view
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD cannot be all zeros and can use one of the following formats:
auto: Automatically generates an RD in the N:VXLAN ID format. The initial value of N is 1. If N:VXLAN ID is already in use, the system increases the value of N by 1 until the RD is available.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses the RD to differentiate BGP EVPN routes of different EVPN instances.
# Configure 22:1 as the RD of an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] route-distinguisher 22:1
Use route-distinguisher to configure an RD for the public instance.
No RD is configured for the public instance.
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. The RD can use one of the following formats:
To modify the RD of the public instance, first execute the undo route-distinguisher command to remove the original RD.
# Configure 22:1 as the RD of the public instance.
[Sysname-public-instance] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy.
Use undo rr-filter to restore the default.
undo rr-filter
An RR does not filter reflected BGP EVPN routes.
ext-comm-list-number: Specifies an extended community attribute list by its number in the range of 1 to 65535.
This command enables an RR to reflect only received BGP EVPN routes that match the attributes in the specified extended community attribute list.
If a cluster contains multiple RRs, you can configure different reflection policies on the RRs for load sharing among the RRs.
For more information about the extended community attribute list, see Layer 3—IP Routing Configuration Guide.
# Configure a reflection policy for the device to reflect BGP EVPN routes that match extended community attribute list 10.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] rr-filter 10
ip extcommunity-list (Layer 3—IP Routing Command Reference)
vpn-route cross multipath
Use vpn-route cross multipath to enable ECMP VPN route redistribution.
Use undo vpn-route cross multipath to disable ECMP VPN route redistribution.
ECMP VPN route redistribution is disabled. If multiple routes have the same prefix and RD, BGP only imports the optimal route into the EVPN routing table.
ECMP VPN route redistribution enables BGP to import all routes that have the same prefix and RD into the EVPN routing table.
# Enable ECMP VPN route redistribution.
[Sysname] bgp 100
[Sysname-bgp-default-evpn] vpn-route cross multipath
vpn-target
Use vpn-target to configure route targets for EVPN.
Use undo vpn-target to delete route targets for EVPN.
In EVPN instance view:
vpn-target { vpn-target&<1-8> | auto } [ both | export-extcommunity | import-extcommunity ]
undo vpn-target { vpn-target&<1-8> | auto | all } [ both | export-extcommunity | import-extcommunity ]
In VPN instance EVPN view, public instance IPv4 address family view, or public instance EVPN view:
EVPN does not have route targets.
EVPN instance view
Public instance EVPN view
Public instance IPv4 address family view
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets. Each route target is a string of 3 to 21 characters in one of the following formats:
auto: Automatically generates a route target in the format of BGP AS number:VXLAN ID.
both: Uses the specified route targets as both import and export targets. If you do not specify the both, export-extcommunity, or import-extcommunity keyword, the both keyword applies.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Specifies all route targets.
EVPN uses MP-BGP to advertise BGP EVPN routes for automatic VTEP discovery, MAC reachability information advertisement, and host route advertisement. MP-BGP uses route targets to control the advertisement and acceptance of BGP EVPN routes.
A VTEP sets the export targets for BGP EVPN routes before advertising the routes to remote VTEPs. The VTEP checks the export targets of BGP EVPN routes from remote VTEPs and imports only BGP EVPN routes of which the export targets match the local import targets.
If you execute this command multiple times, all configured route targets take effect.
# Configure import route targets 10:1, 100:1, and 1000:1 for an EVPN instance.
[Sysname] vsi aaa
[Sysname-vsi-aaa-evpn-vxlan] vpn-target 10:1 100:1 1000:1 import-extcommunity
