00-Preface | 100.77 KB |
Preface
This command reference describes the commands for configuring ACL and QoS features, including ACL, traffic classification, traffic policing, traffic shaping, QoS policy, congestion management, congestion avoidance, priority mapping, MPLS QoS, and Frame Relay QoS.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
