- 09-IP Multicast Command Reference
- 01-IGMP snooping commands
- 02-Multicast routing and forwarding commands
- 03-IGMP commands
- 04-PIM commands
- 05-MSDP commands
- 06-Multicast VPN commands
- 07-MLD snooping commands
- 08-IPv6 multicast routing and forwarding commands
- 09-MLD commands
- 10-IPv6 PIM commands
00-Preface | 100.23 KB |
Preface
This command reference describes the commands for configuring multicast features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
