- 14-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-IPv6 static routing commands
- 04-RIP commands
- 05-RIPng commands
- 06-OSPF commands
- 07-OSPFv3 commands
- 08-IS-IS commands
- 09-BGP commands
- 10-Policy-based routing commands
- 11-IPv6 policy-based routing commands
- 12-Routing policy commands
- 13-Guard route commands
- 14-RIR commands
11-IPv6 policy-based routing commands | 127.25 KB |
apply default-output-interface
display ipv6 policy-based-route
display ipv6 policy-based-route interface
display ipv6 policy-based-route local
display ipv6 policy-based-route setup
ipv6 policy-based-route (interface view)
ipv6 policy-based-route (system view)
reset ipv6 policy-based-route statistics
apply access-vpn
Use apply access-vpn to specify the forwarding tables that can be used for the matching packets.
Use undo apply access-vpn to remove the specified forwarding tables.
apply access-vpn { public | vpn-instance vpn-instance-name&<1-4> }
undo apply access-vpn { public | vpn-instance [ vpn-instance-name&<1-4> ] }
IPv6 policy node view
context-admin
public: Specifies the forwarding table for the public network.
vpn-instance: Specifies the forwarding table for the specified MPLS L3VPN instances.
vpn-instance-name&<1-4>: Specifies a space-separated list of up to four VPN instance names. A VPN instance name is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist. Specifies a space-separated list of up to four VPN instance names. A VPN instance name is a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
Use this command only in special scenarios that require sending packets received from one network to another network, for example, from a VPN to the public network, or from one VPN to another VPN.
You can repeat this command to specify the forwarding tables for the public network and VPN instances. The device forwards the matching packets by using the first available forwarding table selected in the order in which they are specified.
If you specify the vpn-instance keyword without specifying any VPN instances when you execute the undo form of this command, all the VPN instances are removed from the IPv6 policy node.
After all the forwarding tables on the IPv6 policy node are removed, the default forwarding behavior restores.
# Specify the VPN 1 and VPN 2 forwarding tables on node 10. In this example, VPN 1 and VPN 2 already exist.
[Sysname] ipv6 policy-based-route policy1 permit node 10
[Sysname-pbr6-policy1-10] apply access-vpn vpn-instance vpn1 vpn2
# Specify the public network forwarding table on node 10.
[Sysname-pbr6-policy1-10] apply access-vpn public
apply remark-vpn
apply continue
Use apply continue to compare packets with the next policy node upon failure on the current node.
Use undo apply continue to restore the default.
apply continue
undo apply continue
IPv6 PBR does not compare packets with the next policy node upon failure on the current node.
context-admin
This command takes effect only when the mode of the node is permit.
This command applies when either of the following conditions exist:
¡ apply access-vpn
¡ apply next-hop
¡ apply output-interface
¡ apply default-next-hop
¡ apply default-output-interface
· A clause listed above is configured, but it has become invalid. Then, a routing table lookup also fails for the matching packet.
NOTE: A clause might become invalid because the specified next hop is unreachable, packets cannot be forwarded in the specified VPN instance, or the specified output interface is down. |
# Compare with the next policy node upon failure on the current node.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply continue
Use apply default-next-hop to set default next hops.
Use undo apply default-next-hop to remove default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] }&<1-4>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name | inbound-vpn ] ipv6-address&<1-4> ]
No default next hops are set.
context-admin
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN instance must already exist.
inbound-vpn: Specifies the VPN instance where the inbound interface belongs.
ipv6-address: Specifies the IPv6 address of a default next hop. If you do not specify the vpn-instance vpn-instance-name option or the inbound-vpn keyword, the default next hop belongs to the public network.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-4>: Indicates that you can specify up to four default next hops, each of which can be associated with a track entry.
You can specify multiple default next hops for backup or load sharing in one command line or by executing this command multiple times.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1:1::1:1.
[Sysname-pbr6-aa-11] apply default-next-hop 1:1::1:1 direct
apply loadshare
Use apply default-output-interface to set default output interfaces.
Use undo apply default-output-interface to remove default output interfaces.
apply default-output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply default-output-interface [ { interface-type interface-number }&<1-4> ]
No default output interfaces are set.
context-admin
&<1-4>: Indicates that you can specify up to four interfaces, each of which can be associated with a track entry.
You can specify multiple default output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The default output interface must be P2P type. Using a non-P2P default output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast interfaces such as Ethernet interfaces.
With a default output interface specified, the undo apply default-output-interface command removes the default output interface.
Without any default output interface specified, the undo apply default-output-interface command removes all default output interfaces.
# Specify GigabitEthernet 1/0/1 as the default output interface for IPv6 packets.
[Sysname-pbr6-aa-11] apply default-output-interface gigabitethernet 1/0/1
apply loadshare
apply loadshare
Use apply loadshare to enable load sharing among multiple next hops, output interfaces, default next hops, or default output interfaces.
Use undo apply loadshare to restore the default.
apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
undo apply loadshare { default-next-hop | default-output-interface | next-hop | output-interface }
Multiple next hops, output interfaces, default next hops, or default output interfaces operate in primary/backup mode.
context-admin
default-next-hop: Enables load sharing among multiple default next hops.
default-output-interface: Enables load sharing among multiple default output interfaces.
next-hop: Enables load sharing among multiple next hops.
output-interface: Enables load sharing among multiple output interfaces.
Multiple next hop, output interface, default next hop, or default output interface options operate in either primary/backup or load sharing mode.
· Primary/backup mode—One option is selected from all options in configuration order for packet forwarding, with all remaining options as backups. For example, if multiple output interfaces are configured, the first configured output interface is selected. When the selected output interface fails, the next available output interface takes over.
· Load sharing mode—Matching traffic is distributed across the available options, as follows:
¡ Multiple output interface, default next hop, or default output interface options—Load share traffic in round robin manner, starting from the first configured option. They perform per-packet load sharing for traffic that does not match any fast forwarding entry, and perform per-flow load sharing for traffic that matches a fast forwarding entry.
¡ Multiple next hops—Load share traffic in proportion to their weight. By default, all next hops have the same weight and traffic is evenly distributed among them.
# Enable load sharing among multiple next hops.
[Sysname-pbr6-aa-11] apply next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare next-hop
# Enable load sharing among multiple output interfaces.
[Sysname-pbr6-aa-11] apply output-interface gigabitethernet 1/0/1 gigabitethernet 1/0/2
[Sysname-pbr6-aa-11] apply loadshare output-interface
# Enable load sharing among multiple default next hops.
[Sysname-pbr6-aa-11] apply default-next-hop 1::1 2::2
[Sysname-pbr6-aa-11] apply loadshare default-next-hop
# Enable load sharing among multiple default output interfaces.
[Sysname-pbr6-aa-11] apply default-output-interface gigabitethernet 1/0/1 gigabitethernet 1/0/2
[Sysname-pbr6-aa-11] apply loadshare default-output-interface
apply next-hop
apply next-hop
Use apply next-hop to set next hops.
Use undo apply next-hop to remove next hops.
apply next-hop [ vpn-instance vpn-instance-name | inbound-vpn ] { ipv6-address [ direct ] [ track track-entry-number ] [ weight weight-value ] } &<1-4>
undo apply next-hop [ [ vpn-instance vpn-instance-name | inbound-vpn ] ipv6-address&<1-4> ]
No next hops are set.
context-admin
ipv6-address: Specifies the IPv6 address of a next hop. If you do not specify the vpn-instance vpn-instance-name option or the inbound-vpn keyword, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
weight weight-value: Specifies a load sharing weight for the next hop, in the range of 1 to 100. The default is 10. If you specify weights 1, 1, and 2 for three next hops, they share 1/4, 1/4, and 1/2 of the whole traffic, respectively.
&<1-4>: Indicates that you can specify up to four next hops, each of which can be associated with a track entry.
You can specify multiple next hops for backup or load sharing in one command line or by executing this command multiple times.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1::1.
apply loadshare
Use apply output-interface to set output interfaces.
Use undo apply output-interface to remove output interfaces.
apply output-interface { interface-type interface-number [ track track-entry-number ] }&<1-4>
undo apply output-interface [ { interface-type interface-number }&<1-4> ]
No output interfaces are set.
context-admin
You can specify multiple output interfaces for backup or load sharing in one command line or by executing this command multiple times.
The output interface must be P2P type. Using a non-P2P output interface can result in forwarding failures when the interface has multiple next hops. Non-P2P interfaces include broadcast interfaces such as Ethernet interfaces.
With an output interface specified, the undo apply output-interface command removes the output interface.
Without any output interface specified, the undo apply output-interface command removes all output interfaces.
# Specify GigabitEthernet 1/0/1 as the output interface for IPv6 packets.
apply loadshare
apply precedence
Use apply precedence to set a precedence for IPv6 packets.
Use undo apply precedence to restore the default.
No precedence is set for IPv6 packets.
context-admin
type: Specifies the precedence type for IPv6 packets.
value: Specifies the precedence for IPv6 packets. Eight precedence values (0 to 7) are available. Each precedence value corresponds to a precedence type, as shown in Table 1. You can set either a precedence value or a precedence type for IPv6 packets.
Table 1 IP precedences and the corresponding types
Precedence value |
Precedence type |
0 |
routine |
1 |
priority |
2 |
immediate |
3 |
flash |
4 |
flash-override |
5 |
critical |
6 |
internet |
7 |
network |
# Set the precedence to 5 (critical) for IPv6 packets.
[Sysname]ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply precedence critical
apply remark-vpn
Use apply remark-vpn to enable VPN remark action.
Use undo apply remark-vpn to restore the default.
apply remark-vpn
VPN remark action is not configured.
context-admin
VPN remark action marks the matching packets as belonging to the VPN instance to which they are forwarded based on the apply access-vpn vpn-instance command. All subsequent service modules of IPv6 PBR handle the packets as belonging to the re-marked VPN instance.
If the VPN remark action is not enabled, the forwarded matching packets are marked as belonging to the VPN instance or the public network from which they were received.
VPN remark action applies only to packets that have been successfully forwarded based on the apply access-vpn vpn-instance command.
# Forward packets that match ACL 3000 based on the forwarding table of VPN instance vpn1 and perform VPN remark action on the successfully forwarded packets.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10] if-match acl 3000
[Sysname-pbr6-aaa-10] apply access-vpn vpn-instance vpn1
[Sysname-pbr6-aaa-10] apply remark-vpn
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
context-admin
context-operator
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command displays information for all IPv6 PBR policies.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
node 1 permit:
if-match acl 2000
apply next-hop 1000::1
node 1 permit |
The match mode of Node 1 is permit. |
if-match acl |
Compares IPv6 packets with IPv6 ACL. |
apply next-hop |
Specifies a next hop for permitted IPv6 packets. |
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 interface PBR configuration and statistics for the master device.
# Display IPv6 PBR configuration and statistics on GigabitEthernet 1/0/1.
<Sysname> display ipv6 policy-based-route interface gigabitethernet 1/0/1
Policy based routing information for interface GigabitEthernet1/0/1(failed):
Policy name: aaa
node 0 deny:
Matched: 0
node 1 permit:
if-match acl 3999
Matched: 0
node 2 permit:
if-match acl 2000
apply output-interface GigabitEthernet1/0/2 track 1 (down)
apply output-interface GigabitEthernet1/0/3 track 2 (inactive)
Matched: 0
node 5 permit:
if-match acl 3101
Matched: 0
Total matched: 0
Policy based routing information for interface XXXX(failed) |
IPv6 PBR configuration and statistics on the interface. This field displays failed in brackets if none of the nodes in the policy has been successfully issued to the driver. To issue the policy, you must remove the policy from the interface and then apply it on the interface again. The failed status is available on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
node 0 deny(not support) node 2 permit(no resource) |
Match mode of the node, permit or deny. If a node fails to be issued to the driver, the command displays the cause in brackets, which include: · not support—The device does not support the match criteria configured on the node. · no resource—No sufficient resources (for example, ACLs) are available for the node. NOTE: The cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
if-match acl |
Compares IPv6 packets with the IPv6 ACL. |
apply next-hop |
apply output-interface track 1 (down) |
Specifies an output interface for permitted packets. The interface status includes the following: · down—The interface is down at network layer. · inactive—The interface is not in position. |
Matched: 0 (no statistics resource) |
Number of successful matches on the node. If the device does not have sufficient resources to count matches, this field displays no statistics resource in brackets. NOTE: The statistics collection failure cause is available only on a per-slot basis. To obtain this information, you must specify a slot number when you execute the command. · For a global interface (for example, a VLAN interface), which might have member physical interfaces on multiple slots, specify a slot that contains its member interfaces. · For a physical interface, specify its slot number. |
Total matched |
Total number of successful matches on all nodes. |
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
display ipv6 policy-based-route local [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays IPv6 local PBR configuration and statistics for the master device.
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
node 0 deny:
Matched: 0
node 1 permit:
if-match acl 3999
Matched: 0
node 2 permit:
if-match acl 2000
apply next-hop 1::1
Matched: 0
node 5 permit:
if-match acl 3101
apply next-hop 2::2
Matched: 0
Total matched: 0
Policy based routing information for local |
IPv6 local PBR configuration and statistics. |
node 0 deny/node 2 permit |
Match mode of the node, permit or deny. |
if-match acl |
Compares packets with the ACL. |
apply next-hop |
Specifies a next hop for permitted packets. |
Matched: 0 |
Number of successful matches on the node. |
Total matched |
ipv6 local policy-based-route
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
context-admin
context-operator
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy name Type Interface
pr01 Forward GigabitEthernet 1/0/1
pr02 Local N/A
Table 5 Command output
Policy name |
IPv6 PBR policy name. |
Type |
Type of the IPv6 PBR: · Forward—IPv6 interface PBR. · Local—IPv6 local PBR. |
Interface where the policy is applied. This field displays N/A for an IPv6 local PBR policy. |
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to restore the default.
undo if-match acl
No ACL match criterion is set.
context-admin
ipv6-acl-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name ipv6-acl-name: Specifies an IPv6 ACL by its name, a case-insensitive string of 1 to 63 characters starting with a letter. The ACL name cannot be all. For the command to take effect, make sure the specified IPv6 ACL is a basic or advanced ACL.
If the specified ACL does not exist or has no rules configured, no packets will match the ACL.
If the vpn-instance keyword is specified for an ACL rule, the rule applies to only VPN packets. If the vpn-instance keyword is not specified, the rule applies to only public network packets.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
if-match packet-length
Use if-match packet-length to set an IPv6 packet length match criterion.
Use undo if-match packet-length to restore the default.
if-match packet-length min-len max-len
No packet length match criterion is set.
context-admin
min-len: Specifies the minimum IPv6 packet length in the range of 1 to 65535 bytes.
max-len: Specifies the maximum IP packet length in the range of 1 to 65535 bytes. The maximum length must be no less than the minimum length.
The packet length range includes boundary values. For example, if you set the min-len and max-len arguments to 100 and 200, respectively, packets with lengths of 100 bytes and 200 bytes are also matched.
# Match packets with a length from 100 to 200 bytes.
[Sysname-pbr6-aa-11] if-match packet-length 100 200
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to restore the default.
No policy is specified for IPv6 local PBR.
context-admin
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets except the packets destined for the sender. This feature might affect local services. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to restore the default.
ipv6 policy-based-route policy-name
No IPv6 is applied to an interface.
Interface view
context-admin
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
# Apply policy aaa to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy node and enter its view, or enter the view of an existing IPv6 policy node.
Use undo ipv6 policy-based-route to delete an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy nodes exist.
context-admin
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node. A smaller number has a higher priority. The value range for the node-number argument is 0 to 65535.
To delete an IPv6 policy that has already applied to an interface, you must delete the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command deletes the specified policy node. If a match mode is specified, the command deletes all nodes configured with the match mode. If no node is specified, the command deletes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter its view.
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
context-admin
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
