04-DPI Command Reference
HomeSupportReference GuidesCommand ReferencesH3C SecPath Firewall Series Command Reference(V7)-6W60104-DPI Command Reference
11-APT defense commands
11-APT defense commands 87.71 KB
application
Use application to specify the application layer protocols for sandbox inspection.
Use undo application to remove application layer protocols from the sandbox inspection.
application { all | type { ftp | http | https | imap | nfs | pop3 | smb | smtp } * }
undo application { all | type { ftp | http | https | imap | nfs | pop3 | smb | smtp } * }
No application layer protocols are specified for sandbox inspection.
APT defense policy view
context-admin
all: Specifies all application layer protocols.
type: Specifies specific types of application layer protocols.
ftp: Specifies the FTP protocol.
http: Specifies the HTTP protocol.
https: Specifies the HTTPS protocol.
imap: Specifies the IMAP protocol.
nfs: Specifies the NFS protocol. Only NFSv3 is supported.
pop3: Specifies the POP3 protocol.
smb: Specifies the SMB protocol. Only SMBv1 and SMBv2 are supported.
smtp: Specifies the SMTP protocol.
This command defines packets of the specified application layer protocols to be sent to the sandbox.
Repeat this command to specify multiple application layer protocols.
# In APT defense policy policy1, configure the device to send the HTTP protocol packets to the sandbox.
[Sysname] apt policy policy1
[Sysname-apt-policy-policy1] application type http
apt apply policy
Use apt apply policy to apply an APT defense policy to a DPI application profile.
Use undo apt apply policy to remove the APT defense policy from a DPI application profile.
apt apply policy policy-name
No APT defense policy is applied to a DPI application profile.
DPI application profile view
context-admin
policy-name: Specifies an APT defense policy by its name, a case-insensitive string of 1 to 31 characters.
An APT defense policy takes effect only after it is applied to a DPI application profile.
You can apply only one APT defense policy to a DPI application profile, and the applied APT defense policy must already exist.
If you execute this command for a DPI application profile multiple times, the most recent configuration takes effect.
# Apply APT defense policy policy1 to DPI application profile profile1.
[Sysname] app-profile profile1
[Sysname-app-profile-profile1] apt apply policy policy1
apt cache size
Use apt cache size to set the APT defense cache size.
Use undo apt cache size to restore the default.
apt cache size cache-size
undo apt cache size
The APT defense cache allows a maximum of 100000 entries.
cache-size: Specifies the cache size in the range of 100000 to 200000 entries.
This command is supported only on the default context. For more information about context, see Virtual Technologies Configuration Guide.
The device caches the inspection result returned from the sandbox in the APT defense cache for matching subsequent traffic.
If you set an APT defense cache size smaller than the existing APT cache size, the system will delete the existing oldest entries.
# Set the APT defense cache size to 200000 entries.
[Sysname] apt cache size 200000
apt policy
Use apt policy to create an APT defense policy and enter its view, or enter the view of an existing APT defense policy.
Use undo apt policy to delete an APT defense policy.
apt policy policy-name
undo apt policy policy-name
An APT defense policy named default exists.
context-admin
policy-name: Specifies the APT defense policy name, a case-insensitive string of 1 to 31 characters. The new APT defense policy name cannot be default.
# Create APT defense policy policy1 and enter its view.
apt apply policy
description
Use description to configure a description for an APT defense policy.
description description-string
An APT defense policy does not have a description.
context-admin
description-string: Specifies a description, a case-insensitive string of 1 to 255 characters.
A description allows easy identification of an APT defense policy.
# Configure the description as description1 for APT defense policy policy1.
[Sysname-apt-policy-policy1] description description1
display apt cache
Use display apt cache to display APT defense cache information.
display apt cache [ slot slot-number ]
context-admin
context-operator
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, this command displays APT defense cache information on all member devices.
This command displays information in the APT defense cache. The MD5 values of files in the APT defense cache indicate the sandbox inspection results. The APT defense module caches the sandbox inspection results in the following lists:
·     Hit list—Cache the MD5 values of files that are identified as threats.
·     Non-hit list—Cache the MD5 values of files that are not threats or cannot be identified as threats.
# Display APT defense cache information.
<Sysname> display apt cache
Slot 1:
APT cache information:
Sandbox-query state : Disabled
Total cached non-hit entries : 0
Total cached hit entries : 0
Non-hit list min update interval : 0 seconds
Hit list min update interval : 0 seconds
Information in the APT defense cache.
Sandbox-query state
Status of the sandbox inspection:
·     Enabled.
·     Disabled.
Number of entries on the non-hit list.
Number of entries on the hit list.
Time elapsed since the last update on the non-hit list, in seconds.
Time elapsed since the last update on the hit list, in seconds.
display apt linkage state
Use display apt linkage state to display the connection status between the device and sandbox.
context-admin
# Display the connection status between the device and sandbox.
<Sysname> display apt linkage state
*02 28 09:19:37:651 2019 H3C APT: -Context=1; Connection to the sandbox: Connected
file max-size
Use file max-size to set the maximum file size supported in the sandbox inspection.
Use undo file max-size to restore the default.
file file-type max-size max-file-size
undo file file-type  max-size
No maximum file size is set for sandbox inspection. The system uses the default file size limit on a per-file type basis.
Sandbox view
context-admin
file-type: Specifies the supported file type name, a case-insensitive string. To obtain the supported file types, enter the question mark (?).
max-file-size: Specifies the maximum file size in KB. The maximum file size supported in the sandbox inspection varies by file type. To obtain the maximum file sizes for supported various file types, enter the question mark (?).
The files exceeding the maximum file size will not be sent to the sandbox.
# Set the maximum file size to 10240 KB for EXE files.
[Sysname] sandbox
[Sysname-sandbox] file exe max-size 10240
file-direction
Use file-direction to specify a file transfer direction for sandbox inspection.
Use undo file-direction to restore the default.
file-direction { both | download | upload }
undo file-direction
Both the uploaded and downloaded files are sent to the sandbox.
context-admin
both: Specifies both the uploaded and downloaded files.
download: Specifies the downloaded files.
upload: Specifies the uploaded files.
The device sends only the files of the specified direction to the sandbox.
If you execute this command multiple times for an APT defense policy, the most recent configuration takes effect.
# Configure the device to send uploaded files to the sandbox in APT defense policy policy1.
[Sysname-apt-policy-policy1] file-direction upload
file-type
Use file-type to specify the file type for sandbox inspection.
Use undo file-type to remove the file type from the sandbox inspection.
file-type { all | name &<1-8> }
undo file-type { all | name &<1-8> }
No file type is specified for sandbox inspection.
context-admin
all: Specifies all file types.
name &<1-8>: Specifies a space-separated list of up to eight file type names. Each name is a case-insensitive string. To obtain the supported file types, enter the question mark (?).
The device sends files of the specified types to the sandbox.
Repeat this command to specify multiple file types for sandbox inspection.
If you specify the following file types that contain multiple file formats, the configuration takes effect on all file formats:
·     BMP—BMP and DIB formats.
·     JPG—JPG, JPE, JPEG, and JFIF formats.
·     XML—MSC and XML formats.
·     RMVB—RMVB and RM formats.
·     TGZ—TGZ and TAR.GZ formats.
# Configure the device to send the doc files to the sandbox in APT defense policy policy1.
[Sysname-apt-policy-policy1] file-type doc
linkage enable
Use linkage enable to enable the linkage to the sandbox.
Use undo linkage enable to disable the linkage to the sandbox.
linkage enable
undo linkage enable
The linkage to the sandbox is disabled.
Sandbox view
context-admin
This command does not initiate a connection request to the sandbox. It only allows the linkage between the device and the sandbox. To establish a connection between the device and sandbox, execute the linkage try command.
# Enable the linkage to the sandbox.
[Sysname] sandbox
[Sysname-sandbox] linkage enable
linkage try
password
sandbox-address
username
linkage try
Use linkage try to establish a connection between the device and sandbox.
linkage try
Sandbox view
context-admin
This command takes effect only after the following conditions are met:
·     Sandbox parameters (including sandbox address, username, and password) are configured.
·     The linkage to the sandbox is enabled.
After you execute this command, the device initiates a connection request to the sandbox. After the connection is established, the device sends files to the sandbox for inspection.
# Establish a connection between the device and sandbox.
[Sysname] sandbox
[Sysname-sandbox] linkage try
linkage enable
password
sandbox-address
username
password
Use password to set the password for logging in to the sandbox.
Use undo password to restore the default.
undo password
No password is set for logging in to the sandbox.
Sandbox view
context-admin
cipher: Specifies the password in encrypted form.
simple: Specifies the password in plaintext form. For security purposes, the password specified in plaintext form will be stored in encrypted form.
string: Specifies the password. The plaintext form is a case-sensitive string of 6 to 32 characters, and the string must contain any combination of letters, digits, and special characters. The encrypted form is a case-sensitive string of 32 characters, and the string must contain letters and digits.
If you change the login password when the device is connected to the sandbox, the connection will be terminated. You need to execute the linkage try command to re-establish the connection.
# Set the password for logging in to the sandbox to 123456abc in plaintext format.
[Sysname] sandbox
[Sysname-sandbox] password simple 123456abc
sandbox-address
username
sandbox
Use sandbox to enter sandbox view.
Use undo sandbox to delete the configuration in sandbox view.
sandbox
undo sandbox
context-admin
# Enter sandbox view.
[Sysname] sandbox
[Sysname-sandbox]
sandbox-address
Use sandbox-address to specify the sandbox address.
Use undo sandbox-address to restore the default.
sandbox-address address-string
No sandbox address is specified.
Sandbox view
context-admin
address-string: Specifies the IP address or domain name of the sandbox, a case-insensitive string of 1 to 64 characters. Valid characters include letters, digits, underscores, hyphens (-), dots (.), and colons (:).
If you change the sandbox address when the device is connected to the sandbox, the connection will be terminated. You need to execute the linkage try command to re-establish the connection.
# Specify www.abc.com as the sandbox address.
[Sysname] sandbox
[Sysname-sandbox] sandbox-address www.abc.com
password
username
username
Use username to set the username for logging in to the sandbox.
Use undo username to restore the default.
username user-name
undo username
No username is set for logging in to the sandbox.
Sandbox view
context-admin
user-name: Specifies the login username, a case-insensitive string of 5 to 12 characters.
If you change the login username when the device is connected to the sandbox, the connection will be terminated. You need to execute the linkage try command to re-establish the connection.
# Set the username for logging in to the sandbox to userabc.
[Sysname] sandbox
[Sysname-sandbox] username userabc
password
sandbox-address
  • Become a Partner
  • Partner Resources
