H3C SecPath F1000-AI-X0 Firewall Series Installation Guide-6W104
HomeSupportSecurityH3C SecPath F1000-AI FirewallInstall & UpgradeInstallation GuidesH3C SecPath F1000-AI-X0 Firewall Series Installation Guide-6W104
03-Appendix B LEDs
03-Appendix B LEDs 1.33 MB
1 Appendix B  LEDs
F1000-AI-03
Figure1-1 LEDs
(1) 10/100/1000BASE-T copper port LEDs
(2) 4G module LED
(3) System status LED
(4) Power status LED
(5) Combo interface LEDs
Table1-1 LED description
LED
Mark
Status
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
The port is receiving and sending data.
4G module LED (available only on the F100-C-A6-WL firewall)
LTE
Off
The 4G module is faulty or in airplane mode.
Flashing green (1 Hz)
The 4G module is searching for a network.
Flashing green (0.3 Hz)
The 4G module has connected to a network.
Flashing green (2.5 Hz)
The 4G module is transmitting data.
System status LED
SYS
Off
The firewall is not powered on or has failed.
Slow flashing green
The firewall is operating correctly.
Fast flashing green
The firewall is loading software.
Power status LED
PWR0, PWR1
Off
No power supply is present or the power supply has failed.
Steady green
The power supply is operating correctly.
10/100/1000BASE-T copper port LED(combo interfaces)
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
1000BASE-X fiber port LED(combo interfaces)
1000BASE-X
Off
No link is present.
Steady green
A 1000 Mbps link is present.
Flashing green
The port is receiving and sending data at 1000 Mbps.
F1000-AI-10
Figure1-2 LEDs
(2) 10/100/1000BASE-T copper port LED (combo interfaces)
(3) 1000BASE-X fiber port LED (combo interfaces)
(4) System status LED
(5) Power status LED
(6) 10GBASE-R fiber port LEDs
Table1-2 LED description
LED
Mark
Status
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
1000BASE-X
Off
No link is present.
Steady green
Flashing green
System status LED
SYS
Off
Slow flashing green
Fast flashing green
Power status LED
PWR0, PWR1
Off
Steady green
10GBASE-R
Off
No link is present.
Steady green
A 10 Gbps link is present.
Flashing green
The port is receiving and sending data at 10 Gbps.
F1000-AI-20/F1000-AI-30/F1000-AI-50
The F1000-AI-20, F1000-AI-30, and F1000-AI-50 firewalls use similar LEDs. This section uses the LEDs on the F1000-AI-20 firewall as an example.
Figure1-3 LEDs
(1) System status LED
(2) Drive status LED
(3) Power status LEDs
(4) 10/100/1000BASE-T copper port LED
(5) 1000BASE-X fiber port LED
(6) Interface module status LEDs
Table1-3 LED description
LED
Mark
Status
System status LED
SYS
Off
Slow flashing green
Fast flashing green
Drive status LED
HD0, HD1
Off
Fast flashing green
Data is being read from or written to the drive.
Steady green
The drive is present and operating correctly.
Power status LED
PWR0, PWR1
Off
Steady green
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
1000BASE-X
Off
No link is present.
Steady green
Flashing green
10GBASE-R
Off
No link is present.
Steady green
Flashing green
Interface module LED
SLOT1, SLOT2
Off
No interface module is present or the interface module has failed.
Steady green
The interface module is operating correctly.
F1000-AI-60/F1000-AI-70/F1000-AI-80/F1000-AI-90
The F1000-AI-60, F1000-AI-70, F1000-AI-80 and F1000-AI-90 firewalls use similar LEDs. This section uses the LEDs on the F1000-AI-90 firewall as an example.
Figure1-4 LEDs
(2) Ethernet fiber port LED
(4) Power status LEDs
(5) Interface module status LEDs
Table1-4 LED description
LED
Mark
Status
10/100/1000BASE-T
Off
No link is present.
Steady green
A link is present.
Flashing green
1000BASE-X
Off
No link is present.
Steady green
Flashing green
10GBASE-R
Off
No link is present.
Steady green
Flashing green
System status LED
SYS
Off
Slow flashing green
Fast flashing green
Power status LED
PWR0, PWR1
Off
Steady green
SLOT1, SLOT2, SLOT 3, SLOT 4
Off
Steady green
