| 00-Preface | 100.42 KB |
Preface
This document describes the installation procedure for the H3C SecPath F10X0 firewalls. It covers preparing for installation, installing the firewall, accessing the firewall, hardware replacement, hardware management and maintenance, and troubleshooting.
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with H3C SecPath F10X0 firewalls
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Documentation feedback
We appreciate your comments.
