- 11-NMM Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PoE commands
- 06-SNMP commands
- 07-RMON commands
- 08-Event MIB commands
- 09-NETCONF commands
- 10-SmartMC commands
- 11-EPA commands
- 12-ONVIF commands
- 13-CWMP commands
- 14-EAA commands
- 15-Process monitoring and maintenance commands
- 16-Sampler commands
- 17-Mirroring commands
- 18-NetStream commands
- 19-IPv6 NetStream commands
- 20-sFlow commands
- 21-Information center commands
- 22-Packet capture commands
- 23-VCF fabric commands
- 24-Cloud connection commands
- 25-EPS agent commands
- 26-eMDI commands
- 27-SQA commands
| 05-PoE commands | 142.82 KB |
display poe pse interface power
poe legacy enable (interface view)
poe legacy enable (system view)
PoE commands
Only the PoE models support the PoE feature.
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to restore the default.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] apply poe-profile name forIPphone
apply poe-profile interface
display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the PoE profile application from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface gigabitethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs GigabitEthernet 1/0/2 to GigabitEthernet 1/0/6.
[Sysname] apply poe-profile index 1 interface gigabitethernet 1/0/2 to gigabitethernet 1/0/6
apply poe-profile
display poe-profile interface
display poe device
Use display poe device to display general PSE information.
display poe device [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays general PSE information about all PSEs in the IRF fabric.
# Display general PSE information.
<Sysname> display poe device
Slot 1:
PSE ID Slot No. SSlot No. PortNum MaxPower(W) State Model
4 1 0 24 450.0 Off LSP8POED
Slot |
IRF member device ID. |
PSE ID |
ID of the PSE. |
Slot No. |
Slot number of the PSE. |
SSlot No. |
Sub-slot number of the PSE. |
PortNum |
Number of PIs on the PSE. |
MaxPower(W) |
Maximum power of the PSE. |
State |
PSE status: · On—The PSE is supplying power. · Off—The PSE is not supplying power. · Faulty—The PSE has failed. |
Model |
PSE model. |
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet 1/0/1.
<Sysname> display poe interface gigabitethernet 1/0/1
PoE Status : Enabled
Power Priority : Low
Oper : Off
IEEE Class : 0
Detection Status : Searching
Power Mode : Signal
Current Power : 0 mW
Average Power : 0 mW
Peak Power : 0 mW
Max Power : 30000 mW
Electric Current : 0 mA
Voltage : 56.3 V
PD Description :
Legacy PD Detection : Enabled
PoE force power Status : Disabled
PoE Status |
PoE status: · Enabled. · Disabled. |
Power Priority |
Power supply priority: · Critical (highest). · High. · Low. |
Oper |
Operating status: · Off—PoE is disabled. · On—Power is being supplied to the PI correctly. · Power-lack—Remaining guaranteed power is insufficient for a critical PI. · Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power. · Power-itself—The PD is using another power supply. · Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power. |
IEEE Class |
PD power class by which the PI supplies power to the PD. If the PI does not support supplying power to the PD, this field displays a hyphen (-). |
Detection Status |
Power detection status: · Disabled—The PoE function is disabled. · Searching—The PI is searching for the PD. · Delivering power—The PI is supplying power to the PD. · Fault—A fault occurred during the test. · Test—The PI is supplying power forcibly to the PD. · Other fault—A fault has caused the PSE to enter the idle status. · PD disconnected—The PD is disconnected. |
Power Mode |
Power transmission mode: Signal—Power is transmitted over the signal pairs of a twisted pair cable. |
Current Power |
Current power, including PD consumption power and transmission loss. |
Average Power |
Average power. |
Peak Power |
Peak power. |
Max Power |
Maximum power. |
Electric Current |
Current. |
Voltage |
Voltage. |
PD Description |
Type and location description for the PD connected to the PI. |
Legacy PD Detection |
Whether non-standard PD detection is enabled: · Enabled. · Disabled. |
PoE force power Status |
Whether forced power supply is enabled: · Enabled. · Disabled. |
# Display power supplying information for all PIs.
Interface PoE Priority CurPower Oper IEEE Detection
(W) Class Status
GE1/0/1 Disabled Low 0.0 Off 0 Disabled
GE1/0/2 Disabled Low 0.0 Off 0 Disabled
GE1/0/3 Disabled Low 0.0 Off 0 Disabled
GE1/0/4 Disabled Low 0.0 Off 0 Disabled
GE1/0/5 Disabled Low 0.0 Off 0 Disabled
GE1/0/6 Enabled Low 0.0 Off 0 Searching
GE1/0/7 Disabled Low 0.0 Off 0 Disabled
GE1/0/8 Disabled Low 0.0 Off 0 Disabled
GE1/0/9 Disabled Low 0.0 Off 0 Disabled
GE1/0/10 Disabled Low 0.0 Off 0 Disabled
GE1/0/11 Enabled Low 0.0 Off 0 Disabled
GE1/0/12 Disabled Low 0.0 Off 0 Disabled
GE1/0/13 Disabled Low 0.0 Off 0 Disabled
GE1/0/14 Disabled Low 0.0 Off 0 Disabled
GE1/0/15 Disabled Low 0.0 Off 0 Disabled
GE1/0/16 Disabled Low 0.0 Off 0 Disabled
GE1/0/17 Disabled Low 0.0 Off 0 Disabled
GE1/0/18 Disabled Low 0.0 Off 0 Disabled
GE1/0/19 Disabled Low 0.0 Off 0 Disabled
GE1/0/20 Disabled Low 0.0 Off 0 Disabled
GE1/0/21 Disabled Low 0.0 Off 0 Disabled
GE1/0/22 Disabled Low 0.0 Off 0 Disabled
GE1/0/23 Disabled Low 0.0 Off 0 Disabled
GE1/0/24 Disabled Low 0.0 Off 0 Disabled
--- On State Ports: 0; Used: 0.0(W); Remaining: 450.0(W) ---
Interface name. |
PoE |
Priority |
Power priority: · Critical (highest). · High. · Low. |
CurPower |
Current power. |
Oper |
IEEE Class |
Detection Status |
Power detection status: · Disabled—PoE function is disabled. · Searching—The PI is searching for the PD. · Delivering Power—The PI is supplying power for the PD. · Fault—A fault occurred during the test. · Test—The PI is undergoing a test. · Other fault—A fault has caused the PSE to enter the idle status. · PD disconnected—The PD is disconnected. |
On State Ports |
Number of PIs that are supplying power. |
Used |
Power consumed by the current PI. |
Remaining |
Total remaining power of all PSEs configured with a maximum power. This field displays 0 if no PSE is configured with a maximum power (all PSEs participate in dynamic power allocation). |
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/1.
<Sysname> display poe interface power gigabitethernet 1/0/1
Interface Current Peak Max PD Description
(W) (W) (W)
GE1/0/1 15.0 15.3 30.0 Access Point on Room 509 for Peter
# Display power information for all PIs.
(W) (W) (W)
GE1/0/1 0.0 0.0 30.0
GE1/0/2 0.0 0.0 30.0
GE1/0/3 0.0 0.0 30.0
GE1/0/4 0.0 0.0 30.0
GE1/0/5 0.0 0.0 30.0
GE1/0/6 0.0 0.0 30.0
GE1/0/7 0.0 0.0 30.0
GE1/0/8 0.0 0.0 30.0
GE1/0/9 0.0 0.0 30.0
GE1/0/10 0.0 0.0 30.0
GE1/0/11 0.0 0.0 30.0
GE1/0/12 0.0 0.0 30.0
GE1/0/13 0.0 0.0 30.0
GE1/0/14 0.0 0.0 30.0
GE1/0/15 0.0 0.0 30.0
GE1/0/16 0.0 0.0 30.0
GE1/0/17 0.0 0.0 30.0
GE1/0/18 0.0 0.0 30.0
GE1/0/19 0.0 0.0 30.0
GE1/0/20 0.0 0.0 30.0
GE1/0/21 0.0 0.0 30.0
GE1/0/22 0.0 0.0 30.0
GE1/0/23 0.0 0.0 30.0
GE1/0/24 0.0 0.0 30.0
Interface name. |
CurPower |
Current power. |
PeakPower |
Peak power. |
MaxPower |
Maximum power. |
PD Description |
Type and location description for the PD connected to a PI. |
Ports On |
Used |
Power consumed by all PIs. |
Remaining |
display poe pse
Use display poe pse to display detailed PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID. If you do not specify a PSE, this command displays detailed PSE information about all PSEs.
# Display detailed PSE information.
<Sysname> display poe pse
PSE ID : 4
Slot No. : 1
SSlot No. : 0
PSE Model : LSP8POED
PSE Status : Enabled
PSE Fast Power Supply : Enabled
Current Power : 0.0 W
Average Power : 0.0 W
Peak Power : 0.0 W
Max Power : 450.0 W
Remaining Guaranteed Power : 450.0 W
PSE CPLD Version : -
PSE Software Version : 172
PSE Hardware Version : 0
Legacy PD Detection : Disabled
Power Utilization Threshold : 80
PD Power Policy : Disabled
PD Disconnect-Detection Mode : DC
PD High Inrush : Disabled
Table 5 Command output
PSE ID |
ID of the PSE. |
Slot No. |
SSlot No. |
Sublsot number of the PSE. |
PSE Status |
PoE status of the PSE: · Enabled. · Disabled. |
PSE Fast Power Supply |
Wether PSE fast power supply is enabled: · Enabled. · Disabled. |
Power Priority |
Power priority of the PSE. |
Current Power |
Current power of the PSE. |
Average Power |
Average power of the PSE. |
Peak Power |
Peak power of the PSE. |
Max Power |
Maximum power configured for the PSE. |
Remaining Guaranteed Power |
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE. |
PSE CPLD Version |
PSE CPLD version number. |
PSE Software Version |
PSE software version number. |
PSE Hardware Version |
PSE hardware version number. |
Nonstandard PD detection status: · Enabled. · Disabled. |
Power Utilization Threshold |
PSE power alarm threshold. |
PD Power Policy |
PD power management policy mode. |
PD Disconnect-Detection Mode |
PD disconnection detection mode. |
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID. To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 4.
<Sysname> display poe pse 4 interface
(W) Class Status
Table 6 Command output
Interface name. |
PoE |
Priority |
Priority: · Critical (highest). · High. · Low. |
CurPower |
Current power. |
Oper |
IEEE Class |
Detection Status |
Power detection status: · Disabled—PoE function is disabled. · Searching—The PI is searching for the PD. · Delivering Power—The PI is supplying power to the PD. · Fault—A fault occurred during the test. · Test—The PI is undergoing a test. · Other Fault—A fault has caused the PSE to enter the idle status. · PD Disconnected—The PD is disconnected. |
On State Ports |
Used |
Power consumed by PIs on the PSE. |
Remaining |
Remaining power of the PSE. This field displays 0 for a PSE that participates in dynamic power allocation. |
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID. To display PSE ID and slot mappings, use the display poe device command.
# Display power information for PIs on PSE 4.
<Sysname> display poe pse 4 interface power
(W) (W) (W)
Table 7 Command output
Interface name. |
Current |
Current power. |
Peak |
Peak power. |
Max |
Maximum power. |
PD Description |
Type and location description for the PD connected with a PI. |
Ports On |
Used |
Remaining |
display poe-profile
Use display poe-profile to display information about the PoE profile.
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
PoE Profile Index ApplyNum Interfaces Configuration
forIPphone 1 4 GE1/0/1 poe enable
GE1/0/2 poe priority critical
GE1/0/3
GE1/0/4
forAP 2 2 GE1/0/5 poe enable
GE1/0/6 poe max-power 14000
--- Total PoE profiles: 2, total ports: 6 ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
forIPphone 1 6 GE1/0/1 poe enable
GE1/0/3
GE1/0/4
GE1/0/5
GE1/0/6
--- Total ports: 6 ---
PoE Profile |
Name of the PoE profile. |
Index |
Index number of the PoE profile. |
ApplyNum |
Number of PIs to which the PoE profile is applied. |
Interfaces |
Interface name of the PI to which the PoE configuration is applied. |
Configuration |
Configurations of the PoE profile. |
Total PoE profiles |
Number of PoE profiles. |
Total ports |
Number of PIs to which all PoE profiles are applied. |
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on GigabitEthernet 1/0/1.
<Sysname> display poe-profile interface gigabitethernet 1/0/1
PoEProfile Index ApplyNum Interface Effective configuration
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 8.
poe ai enable
Use poe ai enable to enable AI-driven PoE.
Use undo ai poe enable to disable AI-driven PoE.
poe ai enable
undo poe ai enable
AI-driven PoE is disabled.
With AI-driven PoE enabled, the device automatically recovers a PI when it fails. If more than one PI fails simultaneously, the device recovers the PIs one by one in ascending order of PI number.
AI-driven PoE automatically adjusts the power supply parameters to fit the power needs. If you disable AI-driven PoE, the system reverts the parameters to the settings before the adjustment.
AI-driven PoE takes effect only on PSEs that run firmware V147 or later.
· PSEs with firmware earlier than V147—You must use the poe update command to upgrade the PSE firmware and then enable AI-driven PoE on it.
· PSEs with firmware V147 or later—You do not need to re-enable AI-driven PoE after upgrading the firmware if you have enabled the feature before the upgrade.
# Enable AI-driven PoE.
[Sysname] poe ai enable
poe update
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-GigabitEthernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
poe-profile
poe fast-on enable
Use poe fast-on enable to enable fast PoE for a PSE.
Use undo poe fast-on enable to disable fast PoE for the PSE.
poe fast-on enable pse pse-id
undo poe fast-on enable pse pse-id
Fast PoE is disabled on a PSE. PIs on the PSE supply power to PDs only after the PSE has started up.
Fast PoE enables a PI on a PSE to supply power to PDs immediately after the PSE is powered on.
You must re-configure this command if you modified other PoE settings after configuring this command.
# Enable fast PoE for PSE 4.
[Sysname] poe fast-on enable pse 4
display poe pse
Use poe legacy enable to enable nonstandard PD detection for a PI.
Use undo poe legacy enable to disable nonstandard PD detection for a PI.
poe legacy enable
Nonstandard PD detection is disabled for a PI.
Interface view
The device supports PSE-based and PI-based nonstandard PD detection. If you enable nonstandard PD detection both in system view and interface view, the configuration in system view takes effect.
As a best practice for disabling nonstandard PD detection for all PIs successfully in one operation, disable this feature in both system view and interface view.
# Enable nonstandard PD detection for a PI.
[Sysname-GigabitEthernet1/0/1] poe legacy enable
Use poe legacy enable to enable the PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 4 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 4
display poe pse
poe max-power
Use poe max-power to set the maximum PI power.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum PI power is 30000 W.
PI view
PoE profile view
max-power: Sets the maximum PI power in milliwatts. The value range is 1000 to 30000.
# Set the maximum PI power to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/1] poe max-power 12000
# Set the maximum PI power to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe max-power (system view)
Use poe max-power to set the maximum PSE power.
poe pse pse-id max-power max-power
undo poe pse pse-id max-power
The maximum PSE power depends on the installed PoE power supply.
max-power: Sets the maximum PSE power in watts. The value range and increment vary by device model.
To avoid the PSE power overload situation, make sure the total power of all PSEs is less than the maximum PoE power.
The maximum power of the PSE must be greater than or equal to the total maximum power of all its critical PIs on the PSE to guarantee these PIs power.
# Set the maximum power of PSE 4 to 150 watts.
[Sysname] poe pse 4 max-power 150
poe max-power (interface view)
poe priority pse
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is configured for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname-GigabitEthernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is disabled, the PSE does not supply power to new PDs when PSE power overload occurs.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to PDs based on the priority of their PIs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe power-delay
Use poe power-delay to enable PoE delay.
Use undo poe power-delay to disable PoE delay.
poe power-delay time
PoE delay is disabled.
time: Specifies the delay time in the range of 1 to 3600, in seconds.
By default, the device executes the poe enable command and supplies power to an interface immediately when any one of the following conditions is met:
· The poe enable command is configured.
· The device reboots with the poe enable command in the configuration file.
· The interface comes up and the PoE module resumes PoE power supply to the interface.
The poe power-delay creates a PoE delay timer after the poe enable command is executed and allows the PoE module to supply power to the PI only after the timer expires.
The undo poe enable command is executed immediately upon configuration and is not affected by the poe power-delay command.
# Enable PoE delay and set the delay time to 30 seconds.
[Sysname] poe power-delay 30
poe enable
poe priority (interface view)
Use poe priority to set the power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power supply priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-GigabitEthernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
poe reset enable
Use poe reset enable to enable PI power cycling upon a system warm reboot.
Use undo poe pse-policy priority to disable PI power cycling upon a system warm reboot.
poe reset enable
undo poe reset enable
PI power cycling upon a system warm reboot is disabled.
During the system warm reboot process (upon execution of the reboot command), the PIs continue supplying power to the PDs but data connections between the PDs and the device are interrupted. After the system reboots, PDs might not re-initiate data connections with the device. Power cycling PIs upon a system warm reboot allows the PDs to re-establish data connections with the device.
# Enable PI power cycling upon a system warm reboot.
[Sysname] poe reset enable
poe track-shutdown
Use poe track-shutdown to disable PoE on shutdown interfaces.
Use undo poe track-shutdown to restore the default.
poe track-shutdown
PoE is not disabled on shutdown interfaces.
By default, the device continues supplying power to an interface after the interface is shut down by the shutdown command or by an upper layer module such as monitor link. As a result, the PD connected to the shutdown interface operates continuously but fails to access the network.
This command disables the PoE module from supplying power to an interface after the interface is shut down. After the interface comes up, the PoE module resumes power supply to the interface.
The command does not power off an interface that has been shut down but is supplying power to a PD.
# Disable PoE on shutdown interfaces.
[Sysname] poe track-shutdown
poe enable
poe update
Use poe update to upgrade the PSE firmware when the device is operating.
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-insensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, all PSEs are upgraded.
You can upgrade the PSE firmware in service in either of the following modes:
· Refresh mode—Updates the PSE firmware without deleting it. You can use the refresh mode in most cases.
· Full mode—Deletes the current PSE firmware and reloads a new one. Use the full mode if the PSE firmware is damaged and you cannot execute any PoE commands.
# Upgrade the firmware of PSE 4 in service.
[Sysname] poe update refresh POE-168.bin pse 4
This command will refresh the PSE firmware. Continue? [Y/N]:y
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for the PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of the PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power usage crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 4 to 90%.
[Sysname] poe utilization-threshold 90 pse 4
poe-profile
Use poe-profile to create a PoE profile and enter its view, or enter the view of an existing PoE profile.
Use undo poe-profile to delete a PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profiles exist.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
To configure PIs in batches, use the PoE profile.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
apply poe-profile
poe enable
poe priority
