H3C SecPath LB Products Configuration Examples(V7)-6W600
HomeSupportConfigure & DeployConfiguration ExamplesH3C SecPath LB Products Configuration Examples(V7)-6W600
02-Application Load Balancing Configuration Examples
Copyright © 2022 New H3C Technologies Co., Ltd. All rights reserved.
Introduction· 1
Prerequisites· 1
Application load balancing features· 1
Layer 4 application load balancing configuration examples· 2
Example: Configuring SNAT-based application load balancing· 2
Network configuration· 2
Analysis· 2
Software versions used· 3
Restrictions and guidelines· 3
Procedures· 3
Verifying the configuration· 12
Configuration files· 12
Example: Configuring SNAT-based application load balancing (with VSIP on the same network as client IP) 13
Network configuration· 13
Analysis· 14
Software versions used· 14
Restrictions and guidelines· 14
Procedures· 14
Verifying the configuration· 23
Configuration files· 23
Example: Configuring source address-based application load balancing· 24
Network configuration· 24
Analysis· 25
Software versions used· 25
Restrictions and guidelines· 25
Procedures· 25
Verifying the configuration· 36
Configuration files· 37
Example: Configuring triangle transmission· 39
Network configuration· 39
Analysis· 39
Software versions used· 40
Restrictions and guidelines· 40
Procedures· 40
Verifying the configuration· 47
Configuration files· 47
Example: Configuring priority scheduling-based application load balancing· 48
Network configuration· 48
Analysis· 48
Software versions used· 49
Restrictions and guidelines· 49
Procedures· 49
Verifying the configuration· 56
Configuration files· 57
Example: Configuring Layer 4 application load balancing for high availability· 57
Network configuration· 57
Analysis· 58
Software versions used· 59
Restrictions and guidelines· 59
Procedures· 60
Verifying the configuration· 72
Configuration files on the active device· 75
Configuration files on the standby device· 76
Load balancing scheduling algorithm configuration examples· 78
Example: Configuring hash algorithm and stickiness based on source address· 78
Network configuration· 78
Analysis· 79
Software versions used· 79
Restrictions and guidelines· 79
Procedures· 79
Verifying the configuration· 87
Configuration files· 88
Example: Configuring least connection scheduling algorithm and source address-based stickiness· 89
Network configuration· 89
Analysis· 89
Software versions used· 90
Restrictions and guidelines· 90
Procedures· 90
Verifying the configuration· 99
Configuration files· 102
Layer 7 application load balancing configuration examples· 103
Example: Configuring URL-based Layer 7 load balancing· 103
Network configuration· 103
Analysis· 103
Software versions used· 104
Restrictions and guidelines· 104
Procedures· 104
Verifying the configuration· 121
Configuration files· 124
Example: Configuring host-based Layer 7 load balancing· 126
Network configuration· 126
Analysis· 127
Software versions used· 127
Restrictions and guidelines· 127
Procedures· 128
Verifying the configuration· 139
Configuration files· 140
Example: Configuring priority scheduling-based application load balancing· 141
Network configuration· 141
Analysis· 142
Software versions used· 142
Restrictions and guidelines· 143
Procedures· 143
Verifying the configuration· 149
Configuration files· 150
Example: Configuring client source address insertion· 151
Network configuration· 151
Analysis· 152
Software versions used· 152
Restrictions and guidelines· 152
Procedures· 153
Verifying the configuration· 169
Configuration files· 171
Example: Configuring NAT66 client source address insertion· 172
Network configuration· 172
Analysis· 173
Software versions used· 173
Restrictions and guidelines· 173
Procedures· 174
Verifying the configuration· 191
Configuration files· 192
Example: Configuring URL-based HTTP redirection· 193
Network configuration· 193
Analysis· 194
Software versions used· 194
Restrictions and guidelines· 194
Procedures· 195
Verifying the configuration· 210
Configuration files· 211
Example: Configuring content rewrite for HTTP redirection· 213
Network configuration· 213
Analysis· 214
Software versions used· 214
Restrictions and guidelines· 215
Procedures· 215
Verifying the configuration· 228
Configuration files· 231
Example: Configuring HTTP header insertion, rewriting, and deletion· 233
Network configuration· 233
Analysis· 233
Software versions used· 233
Restrictions and guidelines· 234
Procedures· 234
Verifying the configuration· 246
Configuration files· 250
Example: Configuring HTTP cookie insert, rewrite, and get sticky methods· 252
Network configuration· 252
Analysis· 252
Software versions used· 253
Restrictions and guidelines· 253
Procedures· 253
Verifying the configuration· 269
Configuration files· 276
Example: Configuring SSL offloading· 277
Network configuration· 277
Analysis· 278
Software versions used· 278
Restrictions and guidelines· 278
Procedures· 279
Verifying the configuration· 287
Configuration files· 288
Example: Configuring SSL client certificate transparent transmission· 289
Network configuration· 289
Analysis· 290
Software versions used· 290
Restrictions and guidelines· 290
Procedures· 291
Verifying the configuration· 303
Configuration files· 304
Example: Configuring bidirectional SSL authentication· 306
Network configuration· 306
Analysis· 306
Software versions used· 306
Restrictions and guidelines· 307
Procedures· 307
Verifying the configuration· 318
Configuration files· 319
Example: Configuring dual certificates for an SSL server policy· 320
Network configuration· 320
Analysis· 321
Software versions used· 321
Restrictions and guidelines· 321
Procedures· 322
Verifying the configuration· 331
Configuration files· 332
Example: Configuring SNI-based certificate selection from SSL server policies· 334
Network configuration· 334
Analysis· 334
Software versions used· 335
Restrictions and guidelines· 335
Procedures· 335
Verifying the configuration· 344
Configuration files· 350
Example: Configuring connection reuse· 354
Network configuration· 354
Analysis· 354
Software versions used· 354
Restrictions and guidelines· 355
Procedures· 355
Verifying the configuration· 365
Configuration files· 367
Example: Configuring HTTP compression· 368
Network configuration· 368
Analysis· 369
Software versions used· 369
Procedures· 369
Verifying the configuration· 376
Configuration files· 377
Example: Configuring a Web cache policy· 378
Network configuration· 378
Analysis· 379
Software versions used· 379
Restrictions and guidelines· 379
Procedures· 379
Verifying the configuration· 387
Configuration files· 391
Example: Configuring WebSocket 392
Network configuration· 392
Analysis· 393
Software versions used· 393
Restrictions and guidelines· 393
Procedures· 393
Verifying the configuration· 399
Configuration files· 402
Example: Configuring RADIUS load balancing for home broadband AAA authentication· 403
Network configuration· 403
Analysis· 404
Software versions used· 404
Restrictions and guidelines· 404
Procedures· 405
Verifying the configuration· 412
Configuration files· 413
Example: Configuring SIP load balancing· 414
Network configuration· 414
Analysis· 415
Software versions used· 415
Restrictions and guidelines· 415
Procedures· 415
Verifying the configuration· 421
Configuration files· 428
Example: Configuring MySQL load balancing· 429
Network configuration· 429
Analysis· 429
Software versions used· 430
Restrictions and guidelines· 430
Procedures· 430
Verifying the configuration· 444
Configuration files· 444
Example: Configuring load balancing for Oracle database servers· 446
Network configuration· 446
Analysis· 446
Software versions used· 446
Restrictions and guidelines· 447
Procedures· 447
Verifying the configuration· 455
Configuration files· 456
Example: Configuring TCP options· 457
Network configuration· 457
Analysis· 457
Software versions used· 458
Restrictions and guidelines· 458
Procedures· 458
Verifying the configuration· 469
Configuration files· 471
NAT64 load balancing configuration examples· 472
Example: Configuring NAT64 load balancing (Layer 7) 472
Network configuration· 472
Analysis· 473
Software versions used· 473
Restrictions and guidelines· 473
Procedures· 474
Verifying the configuration· 485
Configuration files· 486
Example: Configuring NAT64 load balancing (Layer 4-to-Layer 7) 487
Network configuration· 487
Analysis· 488
Software versions used· 488
Restrictions and guidelines· 488
Procedures· 488
Verifying the configuration· 500
Configuration files· 501
Example: Configuring NAT64 load balancing for AFT (IPv4-to-IPv6) 502
Network configuration· 502
Analysis· 503
Software versions used· 503
Restrictions and guidelines· 503
Procedures· 503
Verifying the configuration· 513
Configuration files· 515
Example: Configuring NAT64 load balancing for AFT (IPv6-to-IPv4) 516
Network configuration· 516
Analysis· 517
Software versions used· 517
Restrictions and guidelines· 517
Procedures· 518
Verifying the configuration· 527
Configuration files· 529
Connection limit configuration example· 530
Network configuration· 530
Analysis· 531
Software versions used· 531
Restrictions and guidelines· 531
Procedures· 532
Verifying the configuration· 543
Configuration files· 555
IPS/AV/WAF-based deep packet inspection configuration example· 556
Network configuration· 556
Analysis· 557
Software versions used· 557
Restrictions and guidelines· 557
Procedures· 558
Verifying the configuration· 572
Configuration files· 576
Introduction
The following information provides application load balancing configuration examples.
The following information applies to Comware 7-based LB devices. Procedures and information in the examples might be slightly different depending on the software or hardware version of the device.
The following information is provided based on the assumption that you have basic knowledge of load balancing (LB).
The types of virtual servers supported by application load balancing include IP, TCP, UDP, RADIUS, HTTP, MySQL, SIP-TCP, and SIP-UDP. The virtual server types supported by Layer 4 application load balancing include IP, TCP, and UDP. The virtual server types supported by Layer 7 application load balancing include HTTP and RADIUS.
·     Layer 4 application load balancing—Flow-based load balancing. It distributes packets of the same flow to the same server. Layer 4 application load balancing cannot distribute Layer 7 HTTP services based on contents.
·     Layer 7 application load balancing—Content-based load balancing. It distributes packets one by one based on the packet content, and connects to the specified server according to the specified policy, achieving application load balancing in a wider service scope.
As shown in Figure 1, an external host is connected to the internal servers through an LB device. Server A, Server B, and Server C are internal servers that can provide FTP services. Configure application load balancing to enable the host to access FTP services and monitor reachability of the servers through health monitoring.
Figure 1 Network diagram
Analysis
To implement SNAT–based application load balancing, complete the following configuration on the LB device:
·     Configure server farm, real server, and virtual service settings.
·     Configure SNAT address pool settings and make sure the real servers each have a route to the SNAT address pool.
This configuration example was created and verified on Alpha 1160P16 of L1000-AK315.
When you configure SNAT-based application load balancing, follow these restrictions and guidelines:
·     In the inbound direction, configure Layer 2 transparent transmission for the switch to make sure the host has a route to reach the LB device. In the outbound direction, configure Layer 3 routing for the switch to make sure the LB device has a route to reach the server. Configure next hops for routes on the switch.
·     In this example, the SNAT address pool uses the same network segment as the output interface. You need to enable ARP for the SNAT address pool.
Procedures
Perform the following configuration on the LB device.
Assigning IP addresses to interfaces
Details not shown.
Creating a health monitoring template
1.     Navigate to the LB > Global Configuration > Health Monitoring page.
2.     Click Create to create an NQA template named t1. Specify the template type as TCP and destination port number as 80.
Figure 2 Creating a health monitoring template
3.     Click OK.
Creating an SNAT address pool
1.     Navigate to the LB > Global Configuration > SNAT Pools page.
2.     Click Create to create an SNAT pool named snat1. Specify start IP address 192.168.1.11 and end IP address 192.168.1.14, and configure the interfaces for sending gratuitous ARP or ND packets.
Figure 3 Creating an SNAT address pool
3.     Click OK.
Figure 4 SNAT address pool information
4.     Click OK.
Creating a sever farm
1.     Navigate to the LB > Application Load Balancing > Server Farms page.
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address, probe method as t1, and SNAT address pool as snat1.
Figure 5 Creating a server farm
3.     Click OK.
Configuring real servers
2.     Edit the settings for server farm sf1. Create real server rs1 as the server farm member, and specify its IP address as 192.168.1.1.
Figure 6 Adding a server farm member
Figure 7 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way real server rs1 is created. Specify the IP address for real servers rs2 and rs3 as 192.168.1.2 and 192.168.1.3, respectively.
Figure 8 Server farm information
Configuring a virtual server
1.     Navigate to the LB > Application Load Balancing > Virtual Servers page.
2.     Click Create to create a virtual server named vs. Specify the type as TCP, IP address as 61.159.4.100, default server farm as sf1, and enable the virtual server feature.
Figure 9 Creating a virtual server
3.     Click OK.
Sending an FTP request
Send an FTP request from the host to the FTP server at 61.159.4.100. If the operation succeeds, you can view virtual server and real server statistics on the LB device.
Figure 10 Virtual server statistics
Figure 11 Real server statistics
Configuration files
nqa template tcp t1
destination port 80
server-farm sf1
predictor hash address source
snat-pool snat1
probe t1
success-criteria at-least 1
real-server rs1 port 0
real-server rs2 port 0
real-server rs3 port 0
real-server rs1
ip address 192.168.1.1
real-server rs2
ip address 192.168.1.2
real-server rs3
ip address 192.168.1.3
loadbalance snat-pool snat1
ip range start 192.168.1.11 end 192.168.1.14
arp-nd interface Route-Aggregation1.20
virtual-server vs type tcp
virtual ip address 61.159.4.100
 default server-farm sf1
connection-sync enable
sticky-sync enable global
 service enable
As shown in Figure 12, an external host is connected to the internal servers through an LB device. Server A, Server B, and Server C are internal servers that can provide FTP services. Configure application load balancing to enable the host to access FTP services and monitor reachability of the servers through health monitoring.
Figure 12 Network diagram
Analysis
·     In this example, make sure the virtual server IP is in the same network segment as the outbound interface address of the client, and the IP address advertisement feature is enabled on the virtual server.
Procedures
Details not shown.
Figure 13 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create an SNAT pool named snat1. Specify the start IP address as 192.168.1.11, and the end IP address as 192.168.1.14. Specify the interface for sending gratuitous ARP or ND packets.
Figure 14 Creating an SNAT pool
3.     Click OK.
Figure 15 SNAT pool information
4.     Click OK.
Figure 16 Creating a server farm
3.     Click OK.
Figure 17 Adding a real server
Figure 18 Creating a real server
3.     Click OK.
Figure 19 Server farm information
2.     Click Create to create a virtual server named vs. Specify the type as TCP, virtual server IP address as 10.0.0.8, and default server farm as sf1. Enable the IP address advertisement and virtual server features.
Figure 20 Creating a virtual server
3.     Click OK.
Sent an FTP request from the host to the FTP server with IP address 10.0.0.8. After the access is successful, you can view the virtual server and real server statistics on the LB device.
Figure 21 Virtual server statistics
Figure 22 Real server statistics
Configuration files
nqa template tcp t1
destination port 80
server-farm sf1
snat-pool snat1
probe t1
real-server rs1
real-server rs2
real-server rs3
virtual ip address 10.0.0.8
route-advertisement enable
arp-nd interface Route-Aggregation1.10
 service enable
As shown in the Figure 23, the LB device connects the user and three servers Server A, Server B and Server C that can provide FTP services. Configure application load balancing to enable these servers to jointly provide FTP services and monitor reachability of the servers through health monitoring.
Figure 23 Network diagram
Analysis
To implement source address-based application load balancing, complete the following configuration on the LB device:
·     Configure LB policy settings.
When you configure source address-based application load balancing, follow these restrictions and guidelines:
·     Make sure the routes from the host to the LB device, from the LB device to the server, and from the server to the LB device are available, and the server gateway is deployed on the LB device.
·     Configure Layer 2 transparent transmission for both inbound and outbound directions on the switch, with the gateway on the LB device.
Procedures
Details not shown.
Figure 24 Creating a health monitoring template
3.     Click OK.
Creating server farms
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as t1.
Figure 25 Creating a server farm
3.     Click OK.
4.     Create server farms sf2 and sf3 in the same way sf1 is created.
Figure 26 Server farm information
Figure 27 Adding a real server
Figure 28 Creating a real server
3.     Click OK.
Figure 29 Real server information
4.     Click OK.
5.     Create real server rs2 in the same way rs1 is created:
a.     Navigate to the LB > Application Load Balancing > Server Farms page.
b.     Edit server farm sf2 to add a real server.
c.     Create real server rs2 as shown in the figure above, and configure its IPv4 address as 192.168.1.2.
6.     Create real server rs3 in the same way rs1 is created:
b.     Edit server farm sf3 to add a real server.
c.     Create real server rs3 as shown in the figure above, and configure its IPv4 address as 192.168.1.3.
Configuring LB classes
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Class page.
2.     Click Create to create a class named lc1, and set the type to Generic and the match type to Match any. In the Create Match Rule dialog box, set the rule ID to 1, the type to Source IPv4 address, the IPv4 address to 10.0.4.0, and the mask length to 26. Then click OK.
Figure 30 Creating a class
3.     Click OK.
Figure 31 Class information
4.     Click OK.
5.     Create lc2 in the same way lc1 is created. Specify IPv4 address 10.0.4.64 and mask length 26 in the match rule of lc2.
Configuring LB actions
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Action page.
2.     Click Create to create an action named la1, specify the type as Generic, and the primary server farm as sf1.
Figure 32 Creating an action
3.     Click OK.
4.     Create la2 and la3 in the same way la1 is created. The primary server farm of la2 is sf2, and the primary server farm of la3 is sf3.
Configuring an LB policy
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Load Balancing Policy page.
2.     Click Create to create a policy named lp1, specify the type as Generic, and specify the default action as la3.
3.     Click Create to create a rule. Specify the class as lc1, and the action as la1, and then click OK.
4.     Click Create to create another rule. Specify the class as lc2, and the action as la2, and then click OK. .
Figure 33 Creating policy lp1
5.     Click OK.
Figure 34 Policy lp1 configuration information
6.     Click OK.
Creating virtual server vs
2.     Click Create to create a virtual server named vs. Specify the type as TCP, the IPv4 address as 61.159.4.100/32, the load balancing policy as lp1, and enable the virtual server feature.
Figure 35 Creating a virtual server
3.     Click OK.
Sending FTP requests
Send three FTP requests from the host with source addresses 10.0.4.1, 10.0.4.65, and 10.0.4.129, respectively. After accessing the FTP server through the virtual server with IP address 61.159.4.100 successfully, you can view the virtual server and real server statistics. The FTP requests from source addresses 10.0.4.64/26 and 10.0.4.64/26 are assigned to rs1 and rs2, respectively. The FTP requests from other source addresses are assigned to rs3.
Figure 36 Viewing virtual server statistics
An FTP request sourced from 10.0.4.1 matches policy lc1 and is sent to rs1. You can view the real server statistics of only rs1.
Figure 37 Viewing real server statistics
An FTP request sourced from 10.0.4.65 matches policy lc2 and is sent to rs2. You can view the real server statistics of only rs2.
Figure 38 Viewing real server statistics
An FTP request sourced from 10.0.4.129 matches policy lc3 and is sent to rs3. You can view the real server statistics of only rs3.
Figure 39 Viewing real server statistics
Configuration files
nqa template tcp t1
destination port 80
server-farm sf1
probe t1
server-farm sf2
probe t1
server-farm sf3
probe t1
real-server rs1
real-server rs2
real-server rs3
loadbalance class lc1 type generic match-any
 match 1 source ip address 10.0.4.0 26
loadbalance class lc2 type generic match-any
  match 1 source ip address 10.0.4.64 26
loadbalance action la1 type generic
 server-farm sf1
loadbalance action la2 type generic
 server-farm sf2
loadbalance action la3 type generic
 server-farm sf3
loadbalance policy lp1 type generic
 class lc1 action la1
 class lc2 action la2
 default-class action la3
 lb-policy lp1
 service enable
As shown in the Figure 40, the three servers Server A, Server B and Server C can provide FTP services.
The network requirements are as follows:
·     User requests accessing the virtual server address are forwarded through the LB device to the real servers.
·     Response packets are forwarded through the switch directly to reduce workload on the LB device.
To implement these requirements, configure application load balancing as follows:
·     Specify the source IP address of response packets for the servers as the IP address of the virtual server.
·     Enable the three servers to jointly provide FTP services by considering their hardware performance.
·     Monitor the state of the servers through health monitoring.
Figure 40 Network diagram
Analysis
To implement triangle transmission, complete the following configuration on the LB device:
·     To forward server response packets directly through the switch, specify the source address of the response packets as the IP address of the virtual server. Therefore, in addition to physical interface addresses, you need to configure loopback interfaces for the real servers and specify the loopback interface address as the virtual server IP address 61.159.4.100.
When you configure triangle transmission, follow these restrictions and guidelines:
·     Make sure the switch has Layer 3 routing capabilities in the inbound direction, and the inbound gateway is on the switch. The direct routes from the host to the switch and from the switch to the LB device are available. The route from the host to the LB device is available, with the switch as the next hop. Make sure the switch has Layer 3 routing capabilities in the outbound direction. The routes from the LB device to the server and from the server to the host are available, both with the switch as the next hop.
·     The request packets are forwarded through the LB device, but the response packets are not forwarded through the LB device. Make sure the route from the server back to the host is available.
·     Disable the DNAT feature in the server farm.
Procedures
Details not shown.
Figure 41 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as t1, and disable the NAT feature.
Figure 42 Creating a server farm
3.     Click OK.
Figure 43 Adding a real server
Figure 44 Creating a real server
3.     Click OK.
Figure 45 Server farm information
2.     Click Create to create a virtual server named vs, specify the type as TCP, virtual server IP address as 61.159.4.100/32, and default server farm as sf1, and enable the virtual server feature.
Figure 46 Creating a virtual server
3.     Click OK.
Send an FTP request from the host to the FTP server with IP address 61.159.4.100. After the access is successful, you can view the virtual server and real server statistics on the LB device.
Figure 47 Virtual server statistics
Figure 48 Real server statistics
Configuration files
nqa template tcp t1
destination port 80
server-farm sf1
transparent enable
 probe t1
real-server rs1
real-server rs2
real-server rs3
 service enable
As shown in the Figure 49, the external user accesses the internal server through the LB device. Three servers Server A, Server B and Server C can provide FTP services. The LB device distributes user requests based on the server priorities and the number of real servers allowed to be scheduled in the server farm to achieve load balancing.
Figure 49 Network diagram
Analysis
To implement priority scheduling-based application load balancing, complete the following configuration on the LB device:
·     To distribute traffic to only the server with the highest priority, set the number of real servers available for scheduling in the server farm to 1, and set the priorities for the real servers to 4, 8, and 1, respectively.
·     To distribute traffic to two servers, set the number of real servers available for scheduling in the server farm to 2, and set the priorities for the real servers to 4, 8, and 1, respectively.
When you configure priority scheduling-based application load balancing, follow these restrictions and guidelines:
·     Makes sure the routes from the host to the LB device, from the LB device to the server, and from the server to the LB device are available, with the LB device as the gateway.
·     Configure Layer 2 transparent transmission in both the inbound and outbound directions of the switch, with the LB device as the gateway.
·     Configure the number of real servers available for scheduling in the server farm, and set different priorities for the real servers.
Procedures
Details not shown.
Figure 50 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as t1. Select the Limit real servers to participate in scheduling option, and set both minimum number and maximum number to 1.
Figure 51 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1. Add real server rs1, and specify its IP address as 192.168.1.1 and priority as 4.
Figure 52 Adding a real server
Figure 53 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Set the priority of rs2 to 8, and the IPv4 address to 192.168.1.2. Set the priority of rs3 to 1, and the IPv4 address to 192.168.1.3.
Figure 54 Server farm information
Figure 55 Creating a virtual server
3.     Click OK.
When number of servers available for scheduling is set to 1, send an FTP request from the host to the FTP server with IP address 61.159.4.100. After the access is successful, you can view the virtual server and real server statistics on the LB device. Real server rs2 with the highest priority is selected, and only real server rs2 has traffic statistics.
Figure 56 Virtual server statistics
Figure 57 Real server statistics
When number of servers available for scheduling is set to 2, send an FTP request from the host to the FTP server with IP address 61.159.4.100. After the access is successful, you can view the virtual server and real server statistics on the LB device. The traffic is distributed to rs1 and rs2 with higher priorities.
Figure 58 Virtual server statistics
Figure 59 Real server statistics
Configuration files
nqa template tcp t1
destination port 80
server-farm sf1
selected-server min 1 max 1
 probe t1
 priority 8
 priority 1
real-server rs1
real-server rs2
real-server rs3
 service enable
To improve service stability, configure two LB devices in a network deployed with HA group and VRRP, with Device A as the master and Device B as the backup. When Device A or the associated links fail, Device B takes over to ensure service continuity (the service traffic is not automatically switched back by default).
Figure 60 Network diagram
Analysis
To implement service switchover when one of the two LB devices fails, complete the following configuration:
·     Configure and issue interface addresses and VRRP settings to both LB devices, configure VRRP group settings on the associated interfaces, and configure the virtual IP address of the VRRP group.
·     Configure and issue HA group settings on both LB devices, and set up the HA control and data channels on the directly connected interfaces as aggregate interfaces between the two devices. Specify the primary and secondary devices for the HA group, specify the control channel and data channel, and enable the automatic backup and hot backup of configuration.
·     Configure and issue basic configurations that dot not require backup, such as routing and health monitoring, on the two devices.
This configuration example was created and verified on Feature 1160P16 of L1050.
When you configure Layer 4 application load balancing for high availability, follow these restrictions and guidelines:
·     When deleting and modifying the LB service configuration that can be backed up, perform the operation on the primary device of the HA group and synchronize the configuration to the secondary device. Do not modify or delete configuration on the secondary device to prevent configuration inconsistency on the two devices. The existing load balancing configuration on the primary device will be backed up in batches after automatic configuration synchronization is enabled. You can also manually synchronize the configuration to the secondary device. For routing and probe method settings that do not require backup but must be consistent on both devices, configure and issue the settings to the devices separately.
·     You must configure the NQA probe method template, interface IP address, routing and other related settings manually on both the primary and secondary devices and saved them as basic configuration. For files such as ISP files for load balancing, certificate files related to SSL offloading, and script files for custom monitoring, import, issue, and save them on the devices separately.
·     In the current software version, configuration synchronization is supported by the following service modules:
¡     Resources—VPN instance, ACL (except the acl copy command), object group, time range, security zone, session management, APR, and AAA.
¡     DPI related modules—Application layer detection engine, IPS, URL filtering, data filtering, file filtering, antivirus, data analysis center, and WAF.
¡     Policies—Security policy, ASPF, attack detection and prevention (except the blacklist ip command), connection limit, NAT, AFT, load balancing, bandwidth management, application audit and management, shared access management, and proxy policy.
¡     Logs—Fast log output (except the customlog host source command), and flow log (except the userlog flow export source-ip command).
¡     VPN—SSL VPN.
¡     Other types—VLAN and information center (except the info-center loghost source command).
·     As a best practice, use static aggregation the for data and control channels of the HA group.
·     Save the basic configuration and service configuration after they are completed.
·     In the HA group and VRRP collaborated network, when the master device fails, the traffic is automatically switched to the peer device for processing. By default, when the original active device recovers, traffic is not switched back. To address this issue, enable preemption and set the switchover delay to ensure that the service can be switched back smoothly. A switchover delay timer of 0 means that service cannot be switched back.
·     The SNAT address pool configuration for load balancing is based on address splitting. When the address in the SNAT address pool is on the same network segment as the IP address of the interface where the device connects to the server, specify the interface that sends gratuitous ARP or ND packets for the SNAT address pool. You must specify the interface on the device connecting to the server. When they are not on the same network segment, you do not need to specify an interface for sending gratuitous ARP or ND packets for the SNAT address pool.
·     When the virtual server IP address is on the same network as the IP address of the interface where the device connects to the client, you must specify the interface that sends gratuitous ARP or ND packets for the virtual server. Make sure the interface belongs to the device connecting to the client. When they are not on the same network segment, you do not need to specify an interface for sending gratuitous ARP or ND packets for the virtual server.
·     Bind the virtual server to the VRRP group for load balancing. If both IPv4 and IPv6 addresses exist, bind each of them to the VRRP group.
Procedures
Details not shown.
Configuring HA group settings on the active device
1.     Navigate to the System > HA > HA page.
2.     Click Configure. On the HA group configuration page, enable HA group, specify the operating mode as Active/standby, and specify the device role as Active. Specify the local address as 1.1.1.1, and the peer IP address as 1.1.1.2. Specify the data channel as RAGG1, enable configuration consistency check, and set the time interval to 12 hours.
Figure 61 Configuring HA group settings
3.     Click OK.
Configuring VRRP settings on the active device
1.     Navigate to the System > HA > VRRP page.
2.     Click Create. Specify the interface where the VRRP group resides as the Layer 3 aggregation subinterface 2.1 and the VRID as 1, select Associate and add to active group, and set the virtual IP address to 10.1.1.1/32.
Figure 62 Configuring VRRP group settings
3.     Click OK.
4.     Create Layer 3 aggregate subinterface 2.2 where the VRRP group resides in the same way Layer 3 aggregate subinterface 2.1 is created.
Navigate to the System > HA > VRRP page to add a VRRP backup. Specify the interface where the VRRP group resides as the Layer 3 aggregation subinterface 2.2 and the VRID as 1, select Associate and add to VRRP active group, and set the virtual IP address to 192.168.1.254/32.
Configuring HA group settings on the standby device
2.     Click Configure. On the HA group configuration page, enable HA group, specify the operating mode as Active/standby, and specify the device role as Standby. Specify the local address as 1.1.1.2, and the peer IP address as 1.1.1.1. Specify the data channel as RAGG1, enable configuration consistency check, and set the time interval to 12 hours.
Figure 63 Configuring HA group settings
3.     Click OK.
Configuring VRRP settings on the standby device
2.     Click Create. Specify the interface where the VRRP group resides as the Layer 3 aggregation subinterface 2.1 and the VRID as 1, select Associate and add to standby group, and set the virtual IP address to 10.1.1.1/32.
Figure 64 Configuring VRRP backup group
3.     Click OK.
Navigate to the System > HA > VRRP page to add a VRRP backup. Specify the interface where the VRRP group resides as the Layer 3 aggregation subinterface 2.2 and the VRID as 1, select Associate and add to VRRP standby group, and set the virtual IP address to 192.168.1.254/32.
Configuring a health monitoring template
2.     Click Create to create a health monitoring template named icmp. Specify the type as ICMP, probe interval as 3000 ms, and the number of successful consecutive probes as 1. The NQA health monitoring template does not require backup, so you need to configure it on both devices.
Figure 65 Adding a health monitoring template
3.     Click OK.
Configuring an SNAT pool
1.     Navigate to the LB > Global Configuration > SNAT Pool page.
2.     Click Create to create an SNAT pool snat, configure the address range from 192.168.1.101 to 192.168.1.112, and configure the interface for sending gratuitous ARP or ND packets.
Figure 66 Adding an SNAT pool
Configuring a server farm
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as icmp.
Figure 67 Adding the server farm
3.     Click OK.
2.     Edit server farm sf. Add a new real server named rs1, and specify the real server IP address as 192.168.1.101.
Figure 68 Adding a real server
Figure 69 Adding a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Configure their IPv4 addresses as 192.168.1.102 and 192.168.1.103.
Figure 70 Real server list
2.     Click Create to add a virtual server named vs. Specify the type as TCP, VSIP as 61.159.4.100, and server farm as sf. Bind the virtual server to VRRP group 1, specify the VRRP group associated interface as Layer 3 aggregation subinterface 2.1, and enable the virtual server feature.
Figure 71 Creating a virtual server
3.     Click OK.
Viewing the HA group state
1.     On the active device, navigate to the System > HA > HA page.
2.     View the HA group information. After the HA group is successfully set up, on the active device, the operating mode is Active/standby, the device role is Active, and the device status is Active. The keepalive link status is normal, and the VRRP virtual IP address status is normal, which is Master.
Figure 72 HA group information on the active device
3.     On the standby device, navigate to the System > HA > HA page.
4.     After the HA group is successfully set up, on the standby device, the operating mode is Active/standby, the device role is Standby, and the device status is Backup. The keepalive link status is normal, and the VRRP virtual IP address status is normal, which is Backup.
Figure 73 HA group information on the standby device
1.     Send an FTP request from the host to the device with address 61.159.4.100. After the access is successful, navigate to the Monitor > Application Loading Balancing > Virtual Servers > Real-time Statistics page on the device.
When the active device is working correctly, the virtual server statistics on the active device include new requests and concurrent requests, and the statistics on the standby device include only the concurrent requests.
Figure 74 Virtual server statistics on the active device
Figure 75 Virtual server statistics on the standby device
Simulating a fault on the active device
1.     When the active device fails, on the active device, navigate to the System > HA > HA page.
2.     After the HA group is successfully set up, on the active device, the operating mode is Active/standby, the device role is the Active, the device status is Backup. The keepalive link status is normal and the VRRP virtual IP address status is abnormal, which is Initialize.
Figure 76 HA group information on the active device
4.     After the HA group is successfully set up, on the standby device, the operating mode is Active/standby, the device role is Standby, and the device status is Active. The keepalive link status is normal, and the VRRP virtual IP address status is abnormal, which is Master.
Figure 77 HA on the standby device
5.     Send an FTP request from the host to the device with IP address 61.159.4.100. After the access is successful, navigate to the Monitor > Application Loading Balancing > Virtual Servers > Real-time Statistics page on the device.
6.     When the active device fails, the virtual server statistics on the active device include the number of active connections only, and the statistics on the standby device include both the number of active connections and the number of new connections.
Figure 78 Virtual server statistics on the active device
Figure 79 Virtual server statistics on the standby device
nqa template icmp icmp
 frequency 3000
 reaction trigger probe-pass 1
interface Route-Aggregation2.1
 ip address 10.1.1.253 255.255.255.0
 vrrp vrid 1 virtual-ip 10.1.1.1 active
 vlan-type dot1q vid 201
interface Route-Aggregation2.2
 vrrp vrid 1 virtual-ip 192.168.1.254 active
 vlan-type dot1q vid 202
remote-backup group
 data-channel interface Route-Aggregation1
 configuration sync-check interval 12
 local-ip 1.1.1.1
 remote-ip 1.1.1.2
 device-role primary
 ip range start 192.168.1.101 end 192.168.1.112
 arp-nd interface Route-Aggregation2.2
server-farm sf
 probe icmp
real-server rs1
real-server rs2
 ip address 192.168.1.4
real-server rs3
 ip address 192.168.1.5
 vrrp vrid 1 interface Route-Aggregation2.1
 service enable
 frequency 3000
 vrrp vrid 1 virtual-ip 10.1.1.1 standby
 vrrp vrid 1 virtual-ip 192.168.1.254 standby
remote-backup group
 local-ip 1.1.1.2
 remote-ip 1.1.1.1
 device-role secondary
server-farm sf
 probe icmp
real-server rs1
real-server rs2
real-server rs3
 service enable
As shown in the Figure 80, user requests accessing the virtual server address are forwarded through the LB device to the real servers providing HTTP services. The user requests will be load-shared among the three servers. Configure the source address hash algorithm on the LB device to distribute requests of the same user to one server. When one of the real servers fails the health check, user requests on other servers are still assigned to the same servers by source address. To ensure service continuity, use the source address-based hash algorithm together with the source address-based stickiness.
Figure 80 Network diagram
Analysis
To implement Layer 7 application load balancing based on the source address hashing and source address stickiness, complete the following configuration on the LB device:
·     Configure server farm, real server, and virtual server settings on the LB device.
·     Create a sticky group and set the sticky method to source address.
·     Configure Layer 2 transparent transmission in the inbound direction of the switch, with the LB device as the gateway. Make sure a route is available from the host to the LB device. Configure Layer 2 transparent transmission in the outbound direction of the switch, with the LB device as the gateway. Make sure a route is available from the LB device to the server and from the server to the LB device.
When you configure hash algorithm and stickiness based on source address for load balancing, follow these restrictions and guidelines:
·     Make sure the routes from the host to the LB device, from the LB device to the server, and from the server to the LB device are available, with the LB device as the gateway.
·     Configure the source address/port-based stickiness.
Procedures
Details not shown.
Figure 81 Creating a health monitoring template
3.     Click OK.
Figure 82 Creating a server farm
3.     Click OK.
Figure 83 Adding a real server
Figure 84 Creating a real server
3.     Click OK.
Figure 85 Server farm information
Configuring a sticky group
1.     Navigate to the LB > Global Configuration > Sticky Groups page.
2.     Click Create to create a sticky group named sg-add. Specify the type as Address and port and address/port stickiness method as Source address.
Figure 86 Creating a sticky group
3.     Click OK.
2.     Click Create to create a virtual server named vs. Specify the type as TCP, virtual server IP address as 61.159.4.100, and server farm as sf1. Specify sticky group sg-add with the source address/port sticky method, and enable the virtual server feature.
Figure 87 Creating a virtual server
3.     Click OK.
Disabling real servers rs2 and rs3 and view statistics
For the virtual server, specify the source address–based sticky group of the server farm as sg-add. First, disable real servers rs2 and rs3.
Figure 88 Viewing the status of server farm sf1
Send an HTTP request from the client with a source address and multiple ports to the server, and view the real server statistics. Only rs1 has traffic.
Figure 89 Viewing real server statistics
Enabling real servers rs2 and rs3 and view statistics
Enable real servers rs2 and rs3, and view load balancing information of the real servers.
Figure 90 Viewing the status of server farm sf1
Because the virtual server is configured with the source address stickiness, when the real server fails and then succeeds in the probe check, the requests with the same source address and different ports are still distributed to the same real server. In the real server statistics, only rs1 has traffic.
Figure 91 Viewing real server statistics
Configuration files
nqa template tcp t1
destination port 80
sticky-group sg-add type address-port
ip source
server-farm sf1
probe t1
real-server rs1
real-server rs2
real-server rs3
default server-farm sf1 sticky sg-add
service enable
As shown in the Figure 92, user requests accessing the virtual server address are forwarded through the LB device to the real servers providing HTTP services. The user requests will be load-shared among the three servers. Configure the least connection algorithm and source address stickiness on the LB device to distribute requests of the same user to one server even when traffic is not evenly distributed. Configure the slow online feature to avoid distributing all new traffic to a server that fails and then succeeds in the health check, preventing repeated up and down issues of the server.
Figure 92 Network diagram
Analysis
To implement Layer 7 application load balancing based on the least connection algorithm, source address stickiness, and slow online, complete the following configuration on the LB device:
·     Configure the slow online feature on the server farm. You must use the least connection algorithm together with the slow online feature. If not, when the server fails and then succeeds in the health check, all new requests will be distributed to the server. The server might go down again.
·     Create a sticky group with the source address/port sticky method.
When you configure load balancing based on the least connection algorithm, source address stickiness, and slow online, follow these restrictions and guidelines:
·     Enable the slow online feature for the server farm.
Procedures
Details not shown.
Figure 93 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create a server farm named sf1, specify the scheduling algorithm as Weighted least connection (member) and probe method as t1, and enable the slow online feature.
Figure 94 Creating a server farm
3.     Click OK.
Figure 95 Adding a real server
Figure 96 Creating a real server
3.     Click OK.
Figure 97 Server farm information
2.     Click Create to create a sticky group named sg-add. Specify the type as Address and port and sticky method as Source address.
Figure 98 Creating a sticky group
3.     Click OK.
2.     Click Create to create a virtual server named vs. Specify the type as TCP, virtual server IP address as 61.159.4.100, and server farm as sf1. Specify sticky group sg-add of the address/port type, and enable the virtual server feature.
Figure 99 Creating a virtual server
3.     Click OK.
1.     Verify and view the server farm information. Configure the delay timer of the three real servers rs1, rs2 and rs3 on the server side as 100 ms, 200 ms, and 300 ms, respectively. Because the server farm is configured with a weighted least connection algorithm, the traffic volumes on the real servers are in the sequence of rs1 > rs2 > rs3.
Figure 100 Real server statistics
2.     Send an access request from the client. According to the real server traffic statistics, the traffic is distributed to rs3.
Figure 101 Real server statistics
Send an access request from the client again. According to the real server traffic statistics, the traffic is still distributed to rs3.
Figure 102 Real server statistics
3.     Configure the slow online feature for the server farm. The health monitoring of real servers rs1 and rs2 is successful. Disable real server rs3. The traffic is evenly distributed to real servers rs1 and rs2.
Figure 103 Status of server farm sf1
Send an HTTP request from the client to the server. According to the statistics of the real servers, servers rs1 and rs2 share the traffic evenly.
Figure 104 Real server statistics
4.     Enable real server rs3, and view the load balancing information of the real servers.
Figure 105 Status of server farm sf1
Because the server farm is configured with the slow online feature, when the probe method on server rs3 is successful, all new traffic will not be allocated to rs3. The three real servers will share new traffic. View traffic statistics on rs3. After the probe method on the server rs3 is successful, the traffic volume slowly increases.
Figure 106 Real server statistics
Click Refresh.
Figure 107 Real server statistics
5.     Disable the slow online feature of the server farm. Health monitoring of real servers rs1 and rs2 is successful. Disable real server rs3. The traffic is evenly distributed to real servers rs1 and rs2.
Figure 108 Status of server farm sf1
Send an HTTP request from the client to the server to view the statistics of the real servers. Servers rs1 and rs2 share the traffic evenly.
Figure 109 Real server statistics
6.     Enable real server rs3, and view load balancing information of the real servers.
Figure 110 Status of server farm sf1
The server farm is configured with the least connection algorithm and the slow online feature. When health monitoring on server rs3 is successful, all new traffic will be allocated to rs3. View the traffic statistics on rs3. After health monitoring on server rs3 is successful, the traffic volume quickly increases.
Figure 111 Viewing real server statistics
Click Refresh.
Figure 112 Real server statistics
Configuration files
nqa template tcp t1
destination port 80
server-farm sf1
predictor least-connection member
probe t1
slow-online standby-time 15 ramp-up-time 30
real-server rs1
real-server rs2
real-server rs3
 ip source
 service enable
As shown in the Figure 113, the host accesses six servers through the LB device, and all the six servers Server A, Server B, Server C, Server D, Server E, and Server F can provide HTTP services. The traffic from the host will be load-shared among the six servers according to the URLs accessed by the host. The requests containing sports, government, and news in the URLs are distributed to Server A and Server D, the requests containing finance, technology, and shopping in the URLs are distributed to Server B and Server E, and requests containing other URLs are distributed to Server C and Server F.
Figure 113 Network diagram
Analysis
To implement URL-based Layer 7 application load balancing, complete the following configuration on the LB device:
·     Configure LB policy, class, and action settings. Configure rules for matching URLs in the class, so that the LB device can distribute requests containing sports, government, and news in the URLs to Server A and Server D, requests containing finance, technology, and shopping in the URLs to Server B and Server E, and requests containing other URLs to Server C and Server F.
When you configure URL-based Layer 7 application load balancing, follow these restrictions and guidelines:
·     If an HTTP packet has multiple requests, configure load balancing on a per request basis.
Procedures
Details not shown.
2.     Click Create to create a template named t1, specify the type as HTTP, and set the expected status code to 200.
Figure 114 Creating a health monitoring template
3.     Click OK.
Figure 115 Creating a server farm
3.     Click OK.
Figure 116 Server farm information
Figure 117 Adding a real server
Figure 118 Creating a real server
3.     Click OK.
Figure 119 Real server information
4.     Click OK.
5.     Create the other five real servers in the same way rs1 is created:
a.     Navigate to the LB > Application Load Balancing > Server Farms page. Edit server farm sf1, and add a real server. Create real server rs11 as shown in the figure above, and configure its IPv4 address as 192.168.1.11.
b.     Navigate to the LB > Application Load Balancing > Server Farms page. Edit server farm sf2, and add real servers. Create real servers rs2 and rs12 as shown in the figure above, and configure their IPv4 addresses as 192.168.1.2 and 192.168.1.12, respectively.
c.     Navigate to the LB > Application Load Balancing > Server Farms page. Edit server farm sf3, and add real servers. Create real servers rs3 and rs13 as shown in the figure above, and respectively configure their IPv4 addresses as 192.168.1.3 and 192.168.1.13, respectively..
1.     Create a sticky group of HTTP-Cookie type. Configure the sticky method as Cookie insertion, and configure the cookie name as cookie1. (Cookie insertion inserts the Set-cookie field in HTTP response packets sent by the server for stickiness processing).
2.     Navigate to the LB > Global Configuration > Sticky Groups page.
3.     Click Create to create a sticky group named sg1, set the type to http-cookie, the sticky method to Cookie insertion, and the cookie name to cookie1.
Figure 120 Creating a sticky group
4.     Click OK.
2.     Click Create to create a class named lc1. Set the type to HTTP and the match type to Match any:
¡     Add a rule with ID 1, specify the type as URL, and the URL content as sports, and then click OK.
¡     Add a rule with ID 2, specify the type as URL, and the URL content as news, and then click OK.
¡     Add a rule with ID 3, specify the type as URL, and the URL content as government, and then click OK.
Figure 121 Creating class lc1
3.     Click OK.
4.     Click OK.
5.     Click OK.
Figure 122 Class information
6.     Create lc2 in the same way lc1 is created, and configure the parameters.
Figure 123 Class lc2 information
2.     Click Create to create an action named la1, specify the type as HTTP, the primary server farm as sf1, and the sticky group as sg1.
Figure 124 Creating an action
3.     Click OK.
4.     Create LB actions la2 and la3 in the same way la1 is created. Specify the primary server farm for la2 as sf2, and primary server farm for la3 as sf3, as shown in Figure 125 and Figure 126.
Figure 125 Configuring LB action la2
Figure 126 Configuring LB action la3
2.     Click Create to create a policy named lp1, specify the type as HTTP, specify the default action as la3, and click Create in the rule. In the Create Rule dialog box, specify class lc1 and action la1, and click OK. Then, click Create again, specify class lc2 and action la2, and click OK.
Figure 127 Creating an LB policy
3.     Click OK.
Figure 128 Policy lp1 configuration information
4.     Click OK.
Configuring a parameter profile
1.     Navigate to the LB > Application Load Balancing > Parameter Profiles page.
2.     Click Create to create a parameter profile named pp1, specify the type as HTTP, and enable the per-packet load balancing.
Figure 129 Creating a parameter profile
3.     Click OK.
2.     Click Create to create a virtual server named vs. Specify the type as HTTP and the virtual IP address as 61.159.4.100. Specify LB policy lp1 and parameter profile pp1, and enable the virtual server feature.
Figure 130 Creating a virtual server
3.     Click OK.
Initiate seven request packets containing aaa, sports, news, government, finance, technology, and shopping in the URLs from the host to the HTTP server. The access is successful, and you can view the virtual server and real server statistics on the LB device, and from the captured packets on the host. The response packets sent back by the server have a set-cookie field in the header.
The virtual server has statistics.
Figure 131 Virtual server statistics
Host requests containing sports, news, and government in the URLs match LB class lc1. Real server rs1 has traffic statistics.
Figure 132 Real server statistics
Hosts requests containing finance, technology, and shopping in the URLs match LB class lc2. Real server rs12 has traffic statistics at this time.
Figure 133 Real server statistics
Host requests containing aaa in the URLs fail to match LB classes lc1 and lc2, and are forwarded through lc3 (default setting). Real server rs13 has traffic statistics at this time.
Figure 134 Real server statistics
Initiate host requests containing aaa, sports, news, government, finance, technology, and shopping in the URLs. The statistics are as follows:
Figure 135 Virtual server statistics
Figure 136 Server farm statistics
Figure 137 Real server statistics
Initiates host requests containing sports, news, and government in the URLs to verify that cookie insertion stickiness is effective. Captures packets to verify that the set-cookie field in the header of the response packets returned by the server is cookie1=2.5.b092d037.0.
Figure 138 Captured packet information
According to the real server statistics, only rs1 is matched.
Figure 139 Real server statistics
Initiate a host request with the cookie value Cookie1=2.5.b092d037.0 again. Verify that the stickiness has taken effect. Only rs1 has statistics.
Figure 140 Real server statistics
Configuration files
nqa template http t1
 expect status 200
server-farm sf1
probe t1
real-server rs11 port 0
server-farm sf2
probe t1
real-server rs12 port 0
server-farm sf3
probe t1
real-server rs13 port 0
real-server rs1
real-server rs11
ip address 192.168.1.11
real-server rs2
real-server rs12
ip address 192.168.1.12
real-server rs3
real-server rs13
ip address 192.168.1.13
loadbalance class lc1 type http match-any
 match 1 url sports
 match 2 url news
 match 3 url government
loadbalance class lc2 type http match-any
 match 1 url finance
 match 2 url technology
 match 3 url shopping
loadbalance action la1 type http
 server-farm sf1 sticky sg1
loadbalance action la2 type http
 server-farm sf2 sticky sg1
loadbalance action la3 type http
 server-farm sf3 sticky sg1
loadbalance policy lp1 type http
sticky-group sg1 type http-cookie
 cookie insert name cookie1
parameter-profile pp1 type http
 rebalance per-request
virtual-server vs type http
parameter http pp1
lb-policy lp1
service enable
As shown in the Figure 141, the DNS server resolves the virtual server address for the domain name in the DNS request sent from the host. The host then initiates access requests to the virtual server address to accesses three servers through the LB device. All three servers can provide HTTP services. The access requests will be load-shared among the three servers according to the LB policy.
Figure 141 Network diagram
Analysis
To implement host-based Layer 7 application load balancing, complete the following configuration on the LB device:
·     Configure LB policy, class and action settings. Configure rules to match the host in the class, so that the LB device can distribute requests with domain name www.aaa.com to Server A, requests with domain name www.bbb.com to Server B, and requests with domain name www.ccc.com to Server C.
·     The DNS server resolves domain names, and return the resolved IP addresses to the host.
·     The virtual server address is the IP address resolved by the DNS server, so that the host can initiate a request to the virtual server.
When you configure host-based Layer 7 application load balancing, follow these restrictions and guidelines:
·     A route is available between the host and DNS server.
·     Make sure the IP address resolved by the DNS server from the DNS request is the same as the virtual server IP address on the LB device.
Procedures
Details not shown.
Figure 142 Creating a health monitoring template
3.     Click OK.
Figure 143 Creating a server farm
3.     Click OK.
Figure 144 Server farm information
Figure 145 Adding a real server
Figure 146 Creating a real server
3.     Click OK.
Figure 147 Real server information
4.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Classes page.
2.     Click Create to create a class named lc1, and set the type to HTTP and the match type to Match all.
3.     In the Create Match Rule dialog box, specify the rule ID as 1, the type as HTTP Header, the header name as host, and the header value as www.aaa.com.
Figure 148 Creating a class
4.     Click OK.
Figure 149 Class information
5.     Create lc2 and lc3 respectively in the same way lc1 is created. Specify the header value as www.bbb.com for lc2 and www.ccc.com for lc3.
2.     Click Create to create an LB action named la1, specify the type as HTTP, and set the primary server farm to sf1.
Figure 150 Creating an action
3.     Click OK.
2.     Click Create to create a policy named lp1, specify the type as HTTP, and click Create to create a rule.
3.     In the Create Rule dialog box, set the class to lc1 and the action to la1, and click OK.
4.     Click Create again. Specify the class as lc2 and the action as la2, and click OK.
5.     Click Create again. Specify the class as lc3 and the action as la2, and click OK.
Figure 151 Creating a policy
Figure 152 Policy information
6.     Click OK.
2.     Click Create to create a virtual server named vs. Specify the type as HTTP and virtual IP address as 61.159.4.100, specify LB policy lp1, and enable the virtual server feature.
Figure 153 Creating a virtual server
3.     Click OK.
When the host initiates a request to visit www.aaa.com, rs1 has statistics. When the host initiates a request to visit www.bbb.com, rs2 has statistics. When the host initiates a request to visit www.ccc.com, rs3 has statistics. View the virtual server and real server statistics:
Figure 154 Virtual server statistics
The host request to visit www.aaa.com matches LB class lc1, and rs1 has traffic statistics.
Figure 155 Real server statistics
The host request to visit www.bbb.com matches LB class lc2, and rs2 has traffic statistics.
Figure 156 Viewing real server statistics
The host request to visit www.ccc.com matches LB class lc3, and rs3 has traffic statistics.
Figure 157 Viewing real server statistics
Configuration files
 expect status 200
server-farm sf1
probe t1
server-farm sf2
probe t1
server-farm sf3
probe t1
 match 1 header host value www.aaa.com
 match 1 header host value www.bbb.com
loadbalance class lc3 type http
 match 1 header host value www.ccc.com
 server-farm sf1
 server-farm sf2
 server-farm sf3
 class lc3 action la3
real-server rs1
real-server rs2
real-server rs3
lb-policy lp1
service enable
As shown in the Figure 158, the host accesses three servers through the LB device. Three servers Server A, Server B and Server C can provide HTTP services. The LB device distributes user requests based on the server priorities and the number of real servers allowed to be scheduled in the server farm to achieve load balancing.
Figure 158 Network diagram
Analysis
To implement priority scheduling-based Layer 7 application load balancing, complete the following configuration on the LB device:
When you configure priority scheduling-based Layer 7 application load balancing, follow these restrictions and guidelines:
Procedures
Details not shown.
Figure 159 Creating a health monitoring template
3.     Click OK.
Figure 160 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and add a real server with name rs1 and IP address 192.168.1.1. Specify the priority as 4 and the server farm as sf1.
Figure 161 Adding a real server
Figure 162 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Specify the priority of rs2 as 8 and the IPv4 address as 192.168.1.2. Specify the priority of rs3 as 1 and the IPv4 address as 192.168.1.3.
Figure 163 Server farm information
2.     Click Create to create a virtual server named vs, specify the type as HTTP, virtual server IP address as 61.159.4.100, default server farm as sf1, and enable the virtual server feature.
Figure 164 Creating a virtual server
3.     Click OK.
When number of servers available for scheduling is set to 1, send an FTP request from the host to the FTP server with IP address 61.159.4.100. After the access is successful, you can view the virtual server and real server statistics on the LB device. Real server rs2 with the highest priority is selected, and statistics for only real server rs2 is displayed.
Figure 165 Virtual server statistics
Figure 166 Real server statistics
Figure 167 Virtual server statistics
Figure 168 Real server statistics
Configuration files
 expect status 200
server-farm sf1
 probe t1
  priority 8
  priority 1
real-server rs1
real-server rs2
real-server rs3
 service enable
Example: Configuring client source address insertion
The SNAT service is deployed for SLB. Enable the LB device to insert specific values in the client requests for the server to perform data statistics based on the client address.
As shown in the Figure 169, the internal host can access three servers through the LB device. The three servers Server A, Server B, and Server C in the public network can all provide HTTP services. The host requests to the server will be load-shared among the three servers. Configure the LB device to perform SNAT on the host requests, and transparently transmit the client address with the URL keyword government in the access requests to the real server C for further processing. Other access requests are load-shared between real servers A and B.
Figure 169 Network diagram
Analysis
To enable the LB device to transparently transmit the client source address of a specific user, complete the following configuration on the LB device:
·     Configure SNAT to shield the internal network address of the client.
·     Create an LB policy. In the LB action, enable X-Forwarded-For field insertion to carry the client source address upon receiving access requests containing keyword government in the URL. The LB device will directly load-share other requests.
·     Create an HTTP parameter profile, enable per-request load balancing to insert a source address into each client request.
When you configure client source address insertion, follow these restrictions and guidelines:
·     Make sure a route is available from the host to the LB device.
·     Specify the real server addresses on the LB device as the actual server addresses.
·     When the IP addresses in the SNAT address pool are in the same network segment as the outbound interface, specify the interface in the address pool for sending gratuitous ARP packets.
·     The header content in an HTTP packet is a string of 1 to 255 characters. You can also specify the following replacement strings:
¡     %is—Source IP address or source IPv6 address.
¡     %ps—Source port number.
¡     %id—Destination IP address or destination IPv6 address.
¡     %pd—Destination port number.
Procedures
Details not shown.
Figure 170 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create an SNAT pool named snat1. Set both the start and end IP addresses to public network address 192.168.1.254. Specify the interface for sending gratuitous ARP or ND packets.
Figure 171 Creating an SNAT pool
3.     Click OK.
Figure 172 SNAT pool information
4.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Server Farms page. Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address, probe method as t1, and SNAT address pool as snat1.
Figure 173 Creating server farm sf1
2.     Click OK.
3.     Navigate to the LB > Application Load Balancing > Server Farms page to create a server farm named sf2. Specify the scheduling algorithm as Round robin, probe method as t1, SNAT address pool as snat1, and then click OK.
Figure 174 Creating server farm sf2
2.     Edit server farm sf1, and add a real server. Create a real server named rs1, specify the real server IP address as 192.168.1.1, and click OK.
Figure 175 Adding a real server
Figure 176 Creating a real server
3.     Click OK.
4.     Create real server rs2 in the same way rs1 is created:
b.     Edit server farm sf1 to add a real server.
5.     Create real server rs3 in the same way rs1 is created:
c.     Create real server rs3 as shown in the figure above, and configure its IPv4 address as 192.168.1.2.
Figure 177 Server farm information
Creating an LB class
2.     Create an LB class of the HTTP type named lc1 to match access requests containing keyword government in the URL.
Figure 178 Creating an LB class
3.     Click OK.
Figure 179 Class information
Creating an LB action
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Actions page.
2.     Create an LB action of the HTTP type named la1 to forward matching traffic to server farm sf2, and enable X-Forwarded-For field insertion.
Figure 180 Creating an LB action
3.     Navigate to the LB > Application Load Balancing > Advanced Policies > Actions page to create an LB action of the HTTP type named la2 to forward matching traffic to server farm sf1.
Figure 181 Creating an LB action
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > LB Policies page.
2.     Create an LB policy of the HTTP type named lp1, and specify the default action as la2. In the Create Rule dialog box, specify LB class lc1 and LB action la1.
Figure 182 Creating a policy
3.     Click OK.
Figure 183 Policy information
2.     Click Create to create an HTTP parameter profile named pp1, and enable Load balance each request.
Figure 184 Creating a parameter profile
Figure 185 Creating a virtual server
The host initiates a request without keyword government in the URL to access the HTTP server through http://61.159.4.100. The access is successful. The request is assigned to real servers rs1 and rs2 of server farm sf1. View the both virtual server and real server statistics.
Figure 186 Virtual server statistics
Figure 187 Real server statistics
The host initiates a request that contains keyword government in the URL to access the HTTP server through http://61.159.4.100. The access is successful. You can see that the request containing keyword government in the URL is assigned to rs3. The packet capture information on the server shows that the request header contains the x-forwarded-for field whose value is the client address. View the virtual server and real server statistics as well as the packet capture information.
Figure 188 Virtual server statistics
Figure 189 Real server statistics
A large number of hosts access the HTTP server through http://61.159.4.100. The accesses are successful. From the packet capture information on the server, you can see the requests containing keyword government in the URL. The request header contains the x-forwarded-for field whose value is the client address.
Configuration files
 expect status 200
 ip range start 192.168.1.254 end 192.168.1.254
server-farm sf1
snat-pool snat1
 probe t1
server-farm sf2
 snat-pool snat1
 probe t1
 match 1 url government
 server-farm sf2
 header insert request name X-Forwarded-For value %is
 server-farm sf1
 default-class action la2
real-server rs1
real-server rs2
real-server rs3
 header modify per-request
parameter http pp1
 lb-policy lp1
 service enable
Example: Configuring NAT66 client source address insertion
As shown in the Figure 190, the internal user Host can access three servers through the LB device. The three servers Server A, Server B, and Server C in the public network can all provide HTTP services. The host requests to the server will be load-shared among the three servers. Configure the LB device to perform SNAT on the host requests, and transparently transmit the client address with the URL keyword government in the access requests to the real server C for further processing. Other access requests are load-shared between real servers A and B.
Figure 190 Network diagram
Analysis
Software versions used
This configuration example was created and verified on Alpha 1160P16 of L1000-AK315.
When you configure NAT66 client source address insertion, follow these restrictions and guidelines:
¡     %sps—Source port number on the server end.
¡     %spd—Destination port number on the server end.
¡     %sis—Source IP address on the server end.
¡     %sid—Destination IP address on the server end.
Procedures
Details not shown.
Figure 191 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create an SNAT pool named snat1. Set both the start and end addresses to public network address of 7::6. Specify the interface for sending gratuitous ARP or ND packets.
Figure 192 Creating an SNAT pool
3.     Click OK.
Figure 193 SNAT pool information
4.     Click OK.
Figure 194 Creating server farm sf1
3.     Click OK.
4.     Navigate to the LB > Application Load Balancing > Server Farms page to create a server farm named sf2. Specify the scheduling algorithm as Round robin, probe method as t1, SNAT address pool as snat1, and then click OK.
Figure 195 Creating server farm sf2
2.     Edit server farm sf1, and add a real server. Create a real server named rs1, specify its IP address as 7::2, and then click OK.
Figure 196 Adding a real server
Figure 197 Creating a real server
3.     Click OK.
4.     Create a real server named rs2 for server farm sf1 as shown in the figure above and configure its IPv6 address as 7::3.
5.     Create a real server named rs3 for server farm sf2 as shown in the figure above and configure its IPv6 address as 7::4.
Figure 198 Server farm information
Figure 199 Creating a class
3.     Click OK.
Figure 200 Class information
Figure 201 Creating an LB action
Figure 202 Creating an LB action
Figure 203 Creating a policy
3.     Click OK.
Figure 204 Policy information
Figure 205 Creating a parameter profile
2.     Click Create to create a virtual server named vs. Specify the type as HTTP and virtual IP address as 200::1. Specify LB policy lp1 and parameter profile pp1, and enable the virtual server feature.
Figure 206 Creating a virtual server
A large number of hosts access the HTTP server through http://200::1. The accesses are successful. From the packet capture information on the server, you can see the requests containing keyword government in the URL. The request header contains the x-forwarded-for field whose value is the client address.
Configuration files
 expect status 200
 ipv6 range start 7::6 end 7::6
server-farm sf1
 snat-pool snat1
 probe t1
 real-server rs1 port 80
 real-server rs2 port 80
server-farm sf2
 snat-pool snat1
 probe t1
 real-server rs3 port 80
 server-farm sf2
 header insert request name x-forwarded-for value %is
 server-farm sf1
loadbalance policy lp type http
real-server rs1
 ipv6 address 7::2
real-server rs2
 ipv6 address 7::3
real-server rs3
 ipv6 address 7::4
 virtual ipv6 address 200::1
parameter http pp1
 lb-policy lp1
 service enable
Example: Configuring URL-based HTTP redirection
A host accesses three servers Server A, Server B, and Server C through the LB device. Configured with the HTTP and HTTPS protocols, the servers in the public network can all provide HTTP services. The host requests to the server will be load-shared among the three servers.
Configure HTTP redirection actions based on URLs in host requests to redirect an HTTP request to an HTTPS request or redirect an HTTPS request to an HTTP request. For example:
·     When a request contains HTTP URL http://61.159.4.100/login/index.html, the LB device redirects it to HTTPs URL https://61.159.4.100/login/index.html.
·     When a request contains HTTPS URL https://61.159.4.100/map/index.html, the LB device redirects it to HTTP URL http://61.159.4.100/map/index.html.
Figure 207 Network diagram
Analysis
To implement URL-based HTTP redirection, complete the following configuration on the LB device:
·     Configure server farm, real server, and LB policy settings.
·     Import the CA and local certificates to the LB device, and create an SSL policy on the LB device.
·     Configure virtual server settings and apply LB policies to the virtual server.
·     Configure LB actions to redirect an HTTP request to an HTTPS request or redirect an HTTPS request to an HTTP request according to the requested URLs.
This configuration example was created and verified on Feature 1160P16 of L1070.
When you configure the URL-based policy redirection function, follow these restrictions and guidelines:
·     Make sure the real server associated with the HTTPS virtual server uses port number 80.
·     After configuring the virtual server, you need to enable the virtual server feature.
·     After creating an SSL server policy, use relevant commands to manually enable the SSL server to send the complete certificate chain during SSL negotiation.
Procedures
Perform the following configuration on the LB device.
Assigning IP addresses to interfaces
Details not shown.
1.     Navigate to the LB > Global Configuration > Health Monitoring page.
Figure 208 Creating a health monitoring template
3.     Click OK.
Figure 209 Creating a server farm
3.     Click OK.
Configuring real servers
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1, the IP address as 192.168.1.1, and the port number as 80.
Figure 210 Adding a real server
Figure 211 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Configure IPv4 addresses as 192.168.1.2 and 192.168.1.3 and port number as 80 for real servers rs2 and rs3, respectively.
Figure 212 Server farm information
2.     Create a class named lc-http. In the Create Match Rule dialog box, set the rule ID to 1, the type to URL, and the URL to /login.
Figure 213 Creating a class named lc-http
3.     Create a class named lc-https. In the Create Match Rule dialog box, set the rule ID to 1, the type to URL, and the URL to /map.
Figure 214 Creating a class named lc-https
2.     Create an action named http-https, specify the type as HTTP redirection, and specify the redirection URL as https://%h%p.
Figure 215 Creating an action
3.     Navigate to the LB > Application Load Balancing > Advanced Policies > Actions page.
4.     Create an action named https-http, specify the type as HTTP redirection, and specify the redirection URL as http://%h%p.
Figure 216 Creating an action
2.     Create an LB policy named lp1, and specify the type as HTTP. In the Create Rule dialog box, specify class lc-http and action http-https.
Figure 217 Creating LB policy lp1
3.     Navigate to the LB > Application Load Balancing > Advanced Policies > LB Policies page.
4.     Create an LB policy named lp1, and specify the type as HTTP. In the Create Rule dialog box, specify class lc-https and action https-http.
Figure 218 Creating LB policy lp2
Creating a PKI domain and disabling CRL checking
1.     Navigate to the Objects > KPI > Certificates page.
2.     Click Create to create a PKI domain named ca, and disable CRL checking.
Figure 219 Creating a PKI domain
3.     Click OK.
Importing the CA certificate and local certificate
1.     Select the created PKI domain ca, and click Import Certificate.
Figure 220 Importing a certificate
2.     Specify the certificate type as CA certificate, and click Select file to select the CA certificate file.
Figure 221 Importing a CA certificate
3.     Click OK and then click Yes to confirm the fingerprint information.
Figure 222 Certificate fingerprint information
4.     Specify the certificate type as Local certificate, click Select file to select the local certificate file, and enter the certificate password.
Figure 223 Importing a local certificate
5.     Click OK.
Creating an SSL server policy and specifying PKI domain ca
1.     Navigate to the Objects > SSL > Server Policies page.
2.     Click Create to create an SSL server policy named SSL, and specify the PKI domain as ca.
Figure 224 Creating an SSL server policy
3.     Click OK.
4.     Execute the following commands to manually enable the SSL server to send a complete certificate chain during SSL negotiation (the configuration is not supported on the Web interface):
[Sysname] ssl server-policy ssl
[Sysname-ssl-server-policy-ssl] certificate-chain-sending enable
Configuring a virtual server
1.     Navigate to the LB > Application Load Balancing > Virtual Servers page.
2.     Create a virtual server named vs1. Specify the type as HTTP, IPv4 address as 61.159.4.100, default server farm as sf1, and port number as 80. Specify LB policy lp1, enable the virtual server feature, and then click OK.
Figure 225 Creating virtual server vs1
3.     Click OK.
4.     Navigate to the LB > Application Load Balancing > Virtual Servers page to create a virtual server named vs2. Specify the type as HTTPS, IPv4 address as 61.159.4.100, default server farm as sf1, and port number as 443. Specify SSL server policy ssl, specify LB policy lp2, and enable the virtual server feature.
Figure 226 Creating virtual server vs2
5.     Click OK.
Redirecting http://x.x.x.x/login in the request to https://x.x.x.x/login
If you enter http://61.159.4.100/login/index.html, the URL will be redirected to https://61.159.4.100/login/index.html.
Figure 227 Captured packets on the host
Redirecting https://x.x.x.x/map/index.html in the request to http://x.x.x.x/map.html
If you enter https://61.159.4.100/map/index.html, the URL will be redirected to http://61.159.4.100/login/index.html.
Figure 228 Captured packets on the host
Configuration files
 expect status 200
pki domain ca
 public-key rsa general name ca
 undo crl check enable
 pki-domain ca
 ciphersuite dhe_rsa_aes_256_cbc_sha rsa_aes_256_cbc_sha dhe_rsa_aes_128_cbc_sha
 rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha256 rsa_aes_256_cbc_sha256 dhe_rsa_aes_1
28_cbc_sha256 dhe_rsa_aes_256_cbc_sha256 ecdhe_rsa_aes_128_cbc_sha256 ecdhe_rsa_
aes_256_cbc_sha384 ecdhe_rsa_aes_128_gcm_sha256
 ciphersuite ecdhe_rsa_aes_256_gcm_sha384 ecdhe_ecdsa_aes_128_cbc_sha256 ecdhe_e
cdsa_aes_256_cbc_sha384 ecdhe_ecdsa_aes_128_gcm_sha256 ecdhe_ecdsa_aes_256_gcm_s
ha384 tls_aes_128_gcm_sha256 tls_aes_256_gcm_sha384 tls_chacha20_poly1305_sha256
 tls_aes_128_ccm_sha256 tls_aes_128_ccm_8_sha256
 version ssl3.0 disable
 version tls1.0 disable
server-farm sf1
 predictor hash address source
 probe t1
 success-criteria at-least 1
loadbalance class lc-http type http match-any
 match 1 url /login
loadbalance class lc-https type http match-any
 match 1 url /map
loadbalance action http-https type http
 redirect relocation https://%h%p
loadbalance action https-http type http
 redirect relocation http://%h%p
 class lc-http action http-https
loadbalance policy lp2 type http
 class lc-https action https-http
real-server rs1
real-server rs2
 ip address 192.168.1.2
real-server rs3
 ip address 192.168.1.3
virtual-server vs1 type http
 virtual ip address 61.159.4.100
 lb-policy lp1
 sticky-sync enable global
 service enable
virtual-server vs2 type http
 port 443
 lb-policy lp2
 ssl-server-policy ssl
 service enable
Example: Configuring content rewrite for HTTP redirection
A host accesses four servers through the LB device. The four servers can provide HTTP services. One group of servers provide HTTP services via port 8080, and the other group provide HTTP services via port 80. Configure the LB device to rewrite the URL in the Location header of HTTP response packets according to different user requests. The LB devices load-shares host traffic among the four servers, and provides port 80 to the user.
Configure the redirection feature for the real servers to implement the following requirements:
·     When the URL in the request is /test1, the redirection URL is server IP + server port.
·     When the URL in the request is /test2, the redirection URL is virtual server IP + server port.
·     When the URL in the request is /test3, the redirection URL is domain name + server port.
·     The LB device replaces the Location header value in the response packets with virtual server IP + virtual server port and sends them to the user.
Figure 229 Network diagram
Analysis
For user requests containing URL test1, the three real servers respond with the redirection URL http://RS_IP:8080/. For user requests containing URL test2, the three real servers respond with the redirection URL http://VIP :8080/. For user requests containing URL test3, the three real servers respond with the redirection URL http://HOST:8080/. The LB device replaces the Location header value in the response packets with http://VIP/. When the user initiate a request with this URL, the real servers can respond with an OK packet correctly.
This configuration example does not illustrate how to configure the redirection feature for real servers.
To modify the Location header in the response packets sent from real servers, complete the following configuration on the LB device:
·     Configure server farm and real server settings.
·     Configure an LB policy to match URLs containing test1, test2, or test3 and URLs that do not carry these strings. Configure LB actions to replace the Location header content in the response packets sent from real servers.
·     Configure a virtual server and apply the LB policy to the virtual server.
When you configure the content rewrite for HTTP redirection, follow these restrictions and guidelines:
·     Make sure the port number used by the real server is 8080.
Procedures
In this example, two real servers can respond with redirection or 200 OK packets. You can enable the feature on one real server as needed.
Details not shown.
Creating an HTTP NQA template
Figure 230 Creating a health monitoring template named t1
3.     Click OK.
Configuring server farms
Figure 231 Creating a server farm
3.     Click OK.
4.     Create server farm sf2 in the same way sf1 is created. Use server farm sf2 to distribute reinitiated client requests according to the redirection content.
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1, IP address as 192.168.1.1, and port number as 8080.
Figure 232 Adding a real server
Figure 233 Creating a real server
3.     Click OK.
b.     Edit server farm sf2 to add a real server.
c.     Create real server rs2 as shown in the figure above. Configure its IPv4 address as 192.168.1.2 and port number as 8080.
5.     Create real servers rs11 and rs12 in the same way rs1 is created:
c.     Create real servers rs11 and rs12 as shown in the figure above. Configure their IPv4 addresses as 192.168.1.11 and 192.168.1.12 and port number as 80.
Figure 234 Server farm information
Configuring an LB class
2.     Create a class named lc1, and specify the type as HTTP and the match type as Match any.
3.     Click Create to create match rules 1, 2, and 3 to match URL content test1, test2, and test3, respectively.
Figure 235 Creating a class
Figure 236 Parameters of class lc1
Configuring an LB action
2.     Create an LB action named la1. Specify the type as HTTP, and the primary server farm as sf1.
3.     Click Create for Header rewrite. Specify the header name as Location, the header value as .*:8080(.*), and the replacement string as http://61.159.4.100%1. (Value %1 means leave the (.*) content unchanged in the URL.)
Figure 237 Creating an action
4.     Navigate to the LB > Application Load Balancing > Advanced Policies > Actions page.
5.     Create an LB action named la2, and specify the type as HTTP, and the primary server farm as sf2.
Figure 238 Creating an action
Configuring an LB policy
2.     Create an LB policy named lp1, and specify the type as HTTP and the default action as la2. In the Create Rule dialog box, specify class lc1 and action la1.
User requests containing test1, test2, or test3 in the URLs will match LB class lc1 in LB policy lp1. According to LB action la1, the LB device will send the requests to server farm sf1. The Location header content in the returned redirection packet will be replaced with to http://VIP/.
For other requests that do not match LB class lc1, the LB device sends them to server farm sf2 according to LB action la2.
Figure 239 Creating a policy
Creating an HTTP LB parameter profile
2.     Create a parameter profile named pp1, specify the type as HTTP, and enable per-packet load balancing.
Figure 240 Creating a parameter profile
2.     Create a virtual server named vs. Specify the type as HTTP, IP address as 61.159.4.100, and port number as 80. Specify LB policy lp1 and parameter profile pp1, enable the virtual server feature, and then click OK.
Figure 241 Creating a virtual server
If the client sends a request with URL http://61.159.4.100/test1.html, the following situations will occur:
·     The real server responds with a redirection packet with a modified URL of http://192.168.1.1:8080/.
·     The LB device replaces the URL returned to the client with http://60.159.4.100/.
·     The client uses this URL to access the virtual server successfully.
If the client sends a request with URL http://61.159.4.100/test2.html, the following situations will occur:
·     The real server responds with a redirection packet with a modified URL of http://61.159.4.100:8080/.
If the client sends a request with URL http://61.159.4.100/test3.html, the following situations will occur:
·     The real server responds with a redirection packet with a modified URL of http://www.hello.com:8080/.
·     The LB device replaces the URL returned to the client with http://61.159.4.100/.
Configuration files
 expect status 200
server-farm sf1
 probe t1
 real-server rs1 port 8080
 real-server rs2 port 8080
server-farm sf2
 probe t1
 real-server rs11 port 80
 real-server rs12 port 80
 match 1 url test1
 match 2 url test2
 match 3 url test3
 server-farm sf1
 header rewrite response name Location value .*:8080(.*) replace http://61.159.4
.100%1
 server-farm sf2
 class lc1 action la1
real-server rs1
real-server rs11
real-server rs12
real-server rs2
 parameter http pp1
 lb-policy lp1
 service enable
Example: Configuring HTTP header insertion, rewriting, and deletion
As shown in the Figure 242, a host accesses three servers through the LB device. All these three servers Server A, Server B, and Server C can provide HTTP services. By configuring HTTP-type LB actions on the LB device, you can insert, rewrite, and delete HTTP headers.
Figure 242 Network diagram
Analysis
To insert, rewrite, and delete HTTP headers, complete the following configuration on the LB device:
·     Configure server farm, real server, virtual server, and LB policy settings.
·     Enable the LB device to insert, rewrite, and delete HTTP headers.
When you configure HTTP header insertion, rewriting, and deletion, follow these restrictions and guidelines:
·     Make sure a route is available between the host and the LB device.
·     Make sure a route is available between the server and the LB device.
·     Specify a server farm for the LB actions.
Procedures
Details not shown.
Figure 243 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as t1.
Figure 244 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and create a real server. Specify the real server name as rs1 and the IP address as 192.168.1.1.
Figure 245 Adding a real server
Figure 246 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Configure their IPv4 addresses as 192.168.1.2 and 192.168.1.3, respectively.
Figure 247 Server farm information
2.     Create an LB class named lc1, and specify the type as HTTP and the match type as Match any. In the Create Match Rule dialog box, set the rule ID to 1, the type to URL, and the URL to test.
Figure 248 Creating a class
2.     Create an LB action named la1, and specify the type as HTTP and the primary server farm as sf1.
3.     In the Create Header Deletion dialog box, specify the direction as Response and the header name as Content-Type.
4.     In the Create Header Insertion dialog box, specify the direction as Both and the header name as header-insert-name, and the header value is 21.
5.     In the Create Header Rewrite dialog box, specify the direction as request, the header name as host, the header value as 61.159.4.100, and the replacement string as host.com.
Figure 249 Creating an action
6.     Click OK.
2.     Create an LB policy named lp1, and specify the type as HTTP. In the Create Rule dialog box, specify class lc1 and action la1.
User requests containing test in the URL will match LB class lc1 in policy lp1. The LB device will send the requests to server farm sf1 and process the HTTP headers as configured in LB action la1.
Figure 250 Creating an LB policy
2.     Create a virtual server named vs. Specify the type as HTTP, IP address as 61.159.4.100, default server farm as sf1, and port number as 80. Specify LB policy lp1, enable the virtual server feature, and click OK.
Figure 251 Creating a virtual server
View the packets captured on the client and server ends.
Header insertion
View request packets on the client.
Figure 252 Request packets for header insertion on the client
View request packets on the server.
Figure 253 Request packets for header insertion on the server
View response packets on the server.
Figure 254 Response packets for header insertion on the server
View response packets on the client.
Figure 255 Response packets for header insertion on the client
Header rewrite
Figure 256 Request packets for header rewrite on the client
Figure 257 Request packets for header rewrite on the server
Header deletion
Compared with the packet captured on the server, the header content content-type is deleted from the HTTP response packet captured on the client.
Figure 258 Response packets for header deletion on the server
Figure 259 Response packets for header deletion on the client
Configuration files
 expect status 200
server-farm sf1
 probe t1
 real-server rs1 port 0
 real-server rs2 port 0
 real-server rs3 port 0
 match 1 url test
 server-farm sf1
 header delete response name Content-Type
 header insert both name header-insert-name value 21
 header rewrite request name Host value 61.159.4.100 replace host.com
real-server rs1
real-server rs2
real-server rs3
 lb-policy lp1
 service enable
Example: Configuring HTTP cookie insert, rewrite, and get sticky methods
The host accesses three servers through the LB device. The servers can provide HTTP services. You can configure the cookie insert, cookie rewrite, and cookie get sticky methods to perform operations on HTTP response packets sent by the server.
·     The cookie insert sticky method inserts the Set-Cookie field to the HTTP response packets sent by the server.
·     The cookie rewrite sticky method rewrites the Set-Cookie field in the HTTP response packets sent by the server.
·     The cookie get sticky method gets the Set-Cookie field in the HTTP response packets sent by the server.
Figure 260 Network diagram
Analysis
To insert, rewrite, and get HTTP cookies, complete the following configuration on the LB device:
·     Configure server farm, real server, virtual server, and sticky group settings.
·     The LB device can insert, rewrite, and get HTTP cookies, and can distribute services to a specific server based on sticky entries.
When you configure the HTTP cookie insert, rewrite, and get sticky methods, follow these restrictions and guidelines:
·     Specify sticky groups for the virtual server.
Procedures
Details not shown.
Figure 261 Creating a health monitoring template
3.     Click OK.
Figure 262 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1 and the IP address as 192.168.1.1.
Figure 263 Adding a real server
Figure 264 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Configure their IPv4 addresses as 192.168.1.2 and 192.168.1, respectively.
Figure 265 Server farm information
2.     Click Create to create a sticky group named cookie_insert, set the type to HTTP-Cookie, the cookie stickiness to Cookie insertion, and the cookie name to X-LB.
Figure 266 Creating a sticky group cookie_insert
3.     Click OK.
4.     Navigate to the LB > Global Configuration > Sticky Groups page.
5.     Click Create to create a sticky group named cookie_rewrite, set the type to HTTP-Cookie, the cookie stickiness to Cookie rewrite, and the cookie name to cookie_rewrite.
Figure 267 Creating a sticky group cookie_rewrite
6.     Click OK.
7.     Navigate to the LB > Global Configuration > Sticky Groups page.
8.     Click Create to create a sticky group named cookie_get, and set the type to HTTP-Cookie, the cookie stickiness to Cookie get, and the cookie name to cookie_get.
Figure 268 Creating a sticky group cookie_get
9.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Class page.
2.     Click Create to create a class named lc1, and specify the type as HTTP. In the Create Match Rule dialog box, set the rule ID to 1, the type to URL, and the URL to test1.
Figure 269 Creating class lc1
3.     Click OK.
4.     Navigate to the LB > Application Load Balancing > Advanced Policies > Class page.
5.     Click Create to create a class named lc2, and specify the type as HTTP. In the Create Match Rule dialog box, set the rule ID to 1, the type to URL, and the URL to test2.
Figure 270 Creating a class lc2
6.     Click OK.
Configuring LB actions
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Action page.
2.     Click Create to create an action named la1 Specify the type as HTTP, the primary server farm as sf1, and the sticky group as cookie_insert.
Figure 271 Creating action la1
3.     Click OK.
4.     Navigate to the LB > Application Load Balancing > Advanced Policies > Action page.
5.     Click Create to create an action named la2. Specify the type as HTTP, the primary server farm as sf1, and the sticky group as cookie_rewrite.
Figure 272 Creating action la2
6.     Click OK.
7.     Navigate to the LB > Application Load Balancing > Advanced Policies > Action page.
8.     Click Create to create an action named la3. Specify the type as HTTP, the primary server farm as sf1, and the sticky group as cookie_get.
Figure 273 Creating action la2
9.     Click OK.
2.     Create an LB policy named lp1, specify the type as HTTP, and specify the default action as la3.
3.     Click Create. In the Create Rule dialog box, specify class lc1 and action la1.
4.     Click Create. In the Create Rule dialog box, specify class lc2 and action la2.
User requests containing test1 in the URL will match LB class lc1 in LB policy lp1. The LB device will send the requests to server farm sf1, and process the HTTP header based on LB action la1.
Figure 274 Creating an LB policy
5.     Click OK.
Figure 275 LB policy information
2.     Create a virtual server named vs1. Specify the type as HTTP, IPv4 address as 61.159.4.100, default server farm as sf1, and port number as 80. Enable the virtual server feature, and then click OK.
Figure 276 Creating virtual server vs1
3.     Click OK.
Viewing sticky entries
<Sysname>display sticky virtual-server
Slot 1:
  Virtual server name: vs1
  Server-farm name: sf1
  Class: lc1
  Sticky group name: cookie_insert
  Sticky type: HTTP cookie
  Sticky method: Cookie Insert
  Sticky Key: 2.8.b092d037.0
  Real server addr: 192.168.1.1:0
  Cookie name: X-LB
  Cookie domain:
  Cookie path: /
  HttpOnly: Disabled
  Secure: Disabled
  Timeout: 86400
  Class: lc1
  Sticky Key: 2.e.c55bd498.0
  Real server addr: 192.168.1.2:0
  Cookie name: X-LB
  Cookie domain:
  Cookie path: /
  HttpOnly: Disabled
  Secure: Disabled
  Timeout: 86400
  Class: lc1
  Sticky Key: 2.11.7707dba7.0
  Real server addr: 192.168.1.3:0
  Cookie name: X-LB
  Cookie domain:
  Cookie path: /
  HttpOnly: Disabled
  Secure: Disabled
  Timeout: 86400
  Class: lc2
  Sticky group name: cookie_rewrite
  Sticky method: Cookie Rewrite
  Sticky Key: 2.7.19ba92e3.0
  Cookie name: X-LB
  HttpOnly: Disabled
  Secure: Disabled
  Timeout: 86400
  Class: lc2
  Sticky Key: 2.d.8013df67.0
  Cookie name: X-LB
  HttpOnly: Disabled
  Secure: Disabled
  Timeout: 86400
  Class: lc2
  Sticky Key: 2.10.8af0cfe3.0
  Cookie name: X-LB
  HttpOnly: Disabled
  Secure: Disabled
  Timeout: 86400
You can clear real server and virtual server statistics before sending traffic for verification.
1.     Navigate to the Monitor > Application Load Balancing > Virtual Servers > Real-time Statistics page.
2.     Click Clear.
Figure 277 Clearing virtual server statistics
3.     Navigate to the Monitor > Application Load Balancing > Real Servers > Real-time Statistics page.
4.     Click Clear.
Figure 278 Clearing real server statistics
Verifying cookie insertion
1.     Initiate a request with URL http://61.149.4.100/test1, and capture packets on the host. The LB device inserts Set-Cookie: X-LB=2.8.b092d037.0 to the HTTP response packet.
2.     On the server, capture HTTP response packets.
Figure 279 HTTP response packets captured on the server
3.     On the host, capture HTTP response packets.
Figure 280 HTTP response packets captured on the host
4.     When the traffic is injected for the first time, the LB device returns a cookie value (Set-Cookie: X-LB=2.8.b092d037.0) associated with rs1. View load balancing information on the real servers. Only rs1 has statistics.
5.     Navigate to the Monitor > Application Load Balancing > Real Servers > Real-time Statistics page. View the traffic statistics. (Details not shown.)
6.     The second request carries the inserted Cookie value (2.8.b092d037.0), inject traffic to verify that stickiness takes effect, and all requests are assigned to the same real server rs1.
7.     Navigate to the Monitor > Application Load Balancing > Real Servers > Real-time Statistics page. View the traffic statistics. (Details not shown.)
Verifying cookie rewrite
1.     Initiate a request with URL http://61.149.4.100/test2, and capture packets on the host. The LB device rewrites the cookie from 2.8.b092d037.0 to 2.7.19ba92e3.0 in the HTTP response packet.
Figure 281 HTTP response packets captured on the server
Figure 282 HTTP response packets captured on the host
4.     When the traffic is injected for the first time, the cookie value (Set-Cookie: X-LB=2.8.b092d037.0) carried by the server is rewritten by the LB device to 2.7.19ba92e3.0 associated with rs1. View load balancing information on the real servers. Only rs1 has statistics.
6.     The second request carries the rewritten Cookie value (2.7.19ba92e3.0), inject traffic to verify that stickiness takes effect, and all requests are assigned to the same real server rs1.
Verifying cookie get
1.     Initiate a request with URL http://61.149.4.100/test3, and capture packets on the host and server ends to verify that the packets carry the cookie field (cookie-get=6.6.b092d037.0).
You can see that no change occurs in the cookie. (Details not shown.)
When the traffic is injected for the first time, the request is allocated to real server rs1.
Figure 283 HTTP response packet captured on the server
Figure 284 HTTP response packet captured on the host
2.     Carry the cookie value in the request. Verify that stickiness takes effect, and all requests are assigned to the same real server.
When the traffic is injected for the first time, the request is allocated to real server rs1. Only rs1 has statistics.
3.     Navigate to the Monitor > Application Load Balancing > Real Servers > Real-time Statistics page. View the traffic statistics. (Details not shown.)
4.     The second request carries the inserted cookie value (2.8.b092d037.0), inject traffic to verify that stickiness takes effect, and all requests are assigned to the same real server rs1.
Configuration files
 expect status 200
sticky-group cookie_get type http-cookie
 cookie get name cookie-get
 check all-packet
sticky-group cookie_insert type http-cookie
 cookie insert
 check all-packet
sticky-group cookie_rewrite type http-cookie
 cookie rewrite
 check all-packet
server-farm sf1
 match 1 url test1
 match 1 url test2
 server-farm sf1 sticky cookie_insert
 server-farm sf1 sticky cookie_rewrite
 server-farm sf1 sticky cookie_get
 class lc2 action la2
 default-class action la3
real-server rs1
real-server rs2
real-server rs3
 lb-policy lp1
 service enable
Example: Configuring SSL offloading
SSL offloading enables the LB device to provide SSL encryption and decryption services for the Web server on the internal network, and provide secure access (SSL encryption) to the Web server externally. The internal Web server only needs to process services without performing SSL encryption and decryption, improving the processing capacity of the server.
The LB device encrypts and decrypts the HTTPS access request from the host to three servers Server A, Server B, and Server C in the public network that can all provide HTTP services. The host traffic will be load-shared among the three servers.
Figure 285 Network diagram
Analysis
To implement SSL offloading, complete the following configuration on the LB device:
·     Import the CA and local certificates to the LB device, and create an SSL server policy on the LB device.
·     Configure server farm, real server, and virtual server settings.
·     The client can access the HTTP server successfully through HTTPS.
When you configure the SSL offloading function, follow these restrictions and guidelines:
·     You must first apply for the correct certificate, and then upload the certificate to the LB device through FTP or TFTP.
·     Configure the port number of the virtual server as 443, and the port number of the real server as 80.
·     When the SSL server policy is modified, you must disable and enable the virtual server again to make the configuration effective.
Procedures
Details not shown.
Figure 286 Creating a PKI domain
3.     Click OK.
Importing the CA certificate and local certificate into the PKI domain
Figure 287 Importing a certificate
2.     Specify the certificate type as CA certificate, click Select file, and select the CA certificate file.
Figure 288 Importing a CA certificate
Figure 289 Certificate fingerprint information
4.     Specify the certificate type as Local certificate, click Select file, select the local certificate file, and enter the password for certificate.
Figure 290 Importing a local certificate
5.     Click OK.
2.     Click Create to create an SSL server policy named ssl, and specify the PKI domain as ca.
Figure 291 Creating an SSL server policy
3.     Click OK.
[Sysname]ssl server-policy ssl
[Sysname-ssl-server-policy-ssl]certificate-chain-sending enable
Figure 292 Creating a health monitoring template
3.     Click OK.
Configuring a server farm
Figure 293 Creating a server farm
3.     Click OK.
Configuring the real server
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1, IP address as 192.168.1.1, and port number as 80.
Figure 294 Adding a real server
Figure 295 Creating a real server
3.     Click OK.
c.     Create real server rs2 as shown in the figure above. Configure its IPv4 address as 192.168.1.2 and port number as 80.
c.     Create real server rs3 as shown in the figure above. Configure its IPv4 address as 192.168.1.3 and port number as 80.
Figure 296 Server farm information
2.     Click Create to create a virtual server named vs. Specify the type as HTTPS, virtual IP address as 61.159.4.100, default server farm as sf1, and port number as 443. Specify SSL policy ssl, and enable the virtual server feature.
Figure 297 Creating a virtual server
3.     Click OK.
The host accesses the HTTP server through https://61.159.4.100 successfully. The packets exchanged between the client and the device are in encrypted form. View captured packet information on the client.
The packets exchanged between the device and the server are in plaintext form. View captured packet information on the server.
Configuration files
 expect status 200
pki domain ca
 public-key rsa general name ca length 2048
 pki-domain ca
 undo version gm-tls1.1 disable
server-farm sf1
 probe t1
real-server rs1
real-server rs2
real-server rs3
 port 443
 default server-farm sf1
 service enable
Example: Configuring SSL client certificate transparent transmission
The LB device encrypts and decrypts the HTTPS access request from the host to three servers Server A, Server B, and Server C that can all provide HTTP services. The host traffic will be load-shared among the three servers. Enable SSL client verification for the LB device to insert common certificate fields in client requests, so that the server can determine whether the received access comes from a trusted client.
Figure 298 Network diagram
Analysis
To implement the SSL client certificate transparent transmission function, complete the following configuration on the LB device:
·     Import the CA certificate and local certificate to the LB device, and create an SSL server policy on the LB device.
·     Configure the LB action and insert the common fields of the certificate.
·     The common certificate field content to be inserted is a string of 1 to 255 characters. You can also specify the following values:
¡     %{x509v}—Certificate version.
¡     %{x509snum}—Certificate serial number.
¡     %{x509sigalgo}—Certificate signature algorithm.
¡     %{x509issuer}—Certificate issuer.
When you configure SSL client certificate transparent transmission, follow these restrictions and guidelines:
·     Enable client verification for the SSL server policy, and import the correct CA certificate and local certificate to the client.
Procedures
Details not shown.
Figure 299 Creating a PKI domain
3.     Click OK.
Figure 300 Importing a certificate
Figure 301 Importing a CA certificate
Figure 302 Certificate fingerprint information
Figure 303 Importing a local certificate
5.     Click OK.
2.     Click Create to create an SSL server policy named ssl, specify the PKI domain as ca, and enable client authentication.
Figure 304 Creating an SSL server policy
3.     Click OK.
Figure 305 Creating a health monitoring template
3.     Click OK.
Figure 306 Creating a server farm
3.     Click OK.
Figure 307 Adding a real server
Figure 308 Creating a real server
3.     Click OK.
Figure 309 Server farm information
2.     Click Create to create an LB action. Specify the type as HTTP and the primary server farm as sf1.
3.     Click Create for Header insertion. In the Create Header Insertion dialog box, specify the direction as Request, and set the header name to http-certification-insert and the value to %{x509v} (certificate version).
Figure 310 Creating LB action la1
4.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Load Balancing Policy page.
2.     Click Create to create an LB policy named lp, and specify the type as HTTP and the default action as la1.
Figure 311 Creating an LB policy
3.     Click OK.
2.     Click Create to create a virtual server named vs. Specify the type as HTTPS, virtual IP address as 61.159.4.100, and port number as 443. Specify SSL server policy ssl and LB policy lp, and enable the virtual server feature.
Figure 312 Creating a virtual server
3.     Click OK.
Without a correct certificate imported to the host
From the packet captured on the host, you can see that the device requests a certificate (Certificate Request) from the host, but the host without a correct certificate imported cannot send the certificate. As a result, the SSL handshake fails and the host fails to accesses the HTTP server through https://61.159.4.100.
Figure 313 Packets captured on the host
With a correct certificate imported to the host
You can see from the packet captured on the host that the device requests a certificate (Certificate Request) from the host, and the host responds with the correct certificate. As a result, the SSL handshake is successful, and the host accesses the HTTP server through https://61.159.4.100 successfully.
Figure 314 Packets captured on the host
Viewing captured packet information on the server
The HTTP request packet is inserted with the field http-certification-insert and the value of the certificate version.
Figure 315 Packets captured on the server
Configuration files
 expect status 200
pki domain ca
 pki-domain ca
 ciphersuite dhe_rsa_aes_256_cbc_sha rsa_aes_256_cbc_sha dhe_rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha rsa_aes_128_cbc_sha256 rsa_aes_
256_cbc_sha256 dhe_rsa_aes_128_cbc_sha256 dhe_rsa_aes_256_cbc_sha256 ecdhe_rsa_aes_128_cbc_sha256 ecdhe_rsa_aes_256_cbc_sha384 ecdhe
 ciphersuite ecdhe_rsa_aes_256_gcm_sha384 ecdhe_ecdsa_aes_128_cbc_sha256 ecdhe_ecdsa_aes_256_cbc_sha384 ecdhe_ecdsa_aes_128_gcm_sha2
56 ecdhe_ecdsa_aes_256_gcm_sha384 tls_aes_128_gcm_sha256 tls_aes_256_gcm_sha384 tls_chacha20_poly1305_sha256 tls_aes_128_ccm_sha256
 client-verify enable
server-farm sf1
 probe t1
 server-farm sf1
 header insert request name http-certification-insert value %{x509v}
 default-class action la1
real-server rs1
real-server rs2
real-server rs3
 port 443
 lb-policy lp
 service enable
Example: Configuring bidirectional SSL authentication
The LB device provides bidirectional SSL authentication services for users and the internal HTTPS servers. It requires identity authentication for both the server and the host. Only permitted clients are allowed to access the server.
The LB device encrypts and decrypts the HTTPS access request from the host to three servers Server A, Server B, and Server C that can all provide HTTPS services. The host traffic will be load-shared among the three servers.
Figure 316 Network diagram
Analysis
To implement bidirectional SSL authentication, complete the following configuration on the LB device:
·     Import the CA certificate and local certificate to the LB device.
·     Create an SSL server policy and an SSL client policy on the LB device.
When you configure bidirectional SSL authentication, follow these restrictions and guidelines:
·     Configure the port number of the virtual server as 443, and the port number of the real server as 443.
·     Import the same local certificate as the LB device to the server.
·     When the SSL server policy or SSL client policy is modified, you must disable and enable the virtual server again to make the configuration effective.
Procedures
Details not shown.
Figure 317 Creating a PKI domain
3.     Click OK.
Figure 318 Importing a certificate
Figure 319 Importing a CA certificate
Figure 320 Certificate fingerprint information
Figure 321 Importing a local certificate
5.     Click OK.
2.     Click Create to create an SSL server policy named ssl_server, and specify the PKI domain as ca.
Figure 322 Creating an SSL server policy
3.     Click OK.
[Sysname]ssl server-policy ssl_server
Creating an SSL client policy
1.     Navigate to the Objects > SSL > Client Policies page.
2.     Click Create to create an SSL server policy named ssl_client, and specify the PKI domain as ca.
Figure 323 Creating an SSL client policy
2.     Click Create to create a template named t1, and specify the type as HTTPS, the SSL client policy as ssl_client, and the expected status code as 200.
Figure 324 Creating a health monitoring template
3.     Click OK.
Figure 325 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1, IP address as 192.168.1.1, and port number as 443.
Figure 326 Adding a real server
Figure 327 Creating a real server
3.     Click OK.
a.     Navigate to the LB > Application Load Balancing > Server Farms page.
c.     Create real server rs2 as shown in the figure above. Configure its IPv4 address as 192.168.1.2 and port number as 443.
c.     Create real server rs3 as shown in the figure above. Configure its IPv4 address as 192.168.1.3 and port number as 443.
Figure 328 Server farm information
2.     Click Create to create a virtual server named vs. Specify the type as HTTPS, virtual IP address as 61.159.4.100, default server farm as sf1, and port number as 443. Specify SSL server policy ssl_server and SSL client policy ssl_client, and enable the virtual server feature.
Figure 329 Creating a virtual server
3.     Click OK.
The host accesses the HTTP server through https://61.159.4.100 successfully. The packets exchanged between the host and the device are in encrypted form. View captured packet information on the host.
Figure 330 Packets captured on the host
The packets exchanged between the device and the server are in encrypted form. View captured packet information on the server.
Figure 331 Packets captured on the server
Configuration files
nqa template https t1
 expect status 200
 ssl-client-policy ssl_client
pki domain ca
 pki-domain ca
ssl client-policy ssl_client
 pki-domain ca
server-farm sf1
 probe t1
 real-server rs1 port 443
 real-server rs2 port 443
 real-server rs3 port 443
real-server rs1
real-server rs2
real-server rs3
 port 443
 ssl-server-policy ssl_server
 service enable
Example: Configuring dual certificates for an SSL server policy
Configure both RSA and ECC certificates for the LB device. The host can establish an SSL connection with the same virtual server on the LB device for transmitting encrypted data by using the RSA or ECC encryption algorithm.
Figure 332 Network diagram
Analysis
To configure dual certificates for an SSL server policy, complete the following configuration on the LB device:
·     Import the CA and local certificates (RSA certificate and ECC certificate) to the LB device, create an SSL server policy on the LB device, and specify PKI domains associated with the two certificates.
·     The HTTPS requests from the client can be encrypted by using the RSA and ECC algorithms to access the virtual server successfully.
When you configure dual certificates for an SSL server policy, follow these restrictions and guidelines:
Procedures
Details not shown.
2.     Click Create to create a PKI domain named ca_rsa, and disable CRL checking.
Figure 333 Creating a PKI domain
3.     Click OK.
4.     Create PKI domain ca_ecc in the same way PKI domain ca_rsa is created.
Importing the CA and local certificates to the PKI domains
1.     Select the created PKI domain ca_rsa, and click Import Certificate.
Figure 334 Importing a certificate
Figure 335 Importing a CA certificate
Figure 336 Certificate fingerprint information
4.     Specify the certificate type as Local certificate, click Select file, select the local certificate file, import the RSA certificate, and enter the password for certificate.
Figure 337 Importing a local certificate
5.     Click OK.
6.     Import the CA and local certificates to PKI domain ca_ecc in the same way. Select the created PKI domain ca_ecc, and import the CA certificate and the local certificate (ECC certificate), respectively.
2.     Click Create to create an SSL server policy named ssl, and specify the PKI domain as ca_rsa.
3.     Click the plus sign next to the PKI domain field to specify PKI domain ca_ecc.
Figure 338 Creating an SSL server policy
Figure 339 Selecting the second PKI domain
4.     Click OK.
5.     Execute the following commands to manually enable the SSL server to send a complete certificate chain during SSL negotiation (the configuration is not supported on the Web interface):
2.     Click Create to create a template named t1, specify the type as HTTP, and set the expected status code to 200.
Figure 340 Creating a health monitoring template
3.     Click OK.
Figure 341 Creating a server farm
3.     Click OK.
Figure 342 Adding a real server
Figure 343 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Configure the IPv4 addresses as 192.168.1.2 and 192.168.1.3 and port number as 80 for real servers rs2 and rs3, respectively.
Figure 344 Server farm information
1.     Navigate to the Policies > LB > Server Load Balancing > Virtual Servers page.
Figure 345 Creating a virtual server
3.     Click OK.
The host uses the RSA encryption algorithm to access the virtual server through https://61.159.4.100 successfully. View captured packet information on the host. The server hello packet shows that the negotiated algorithm is the RSA encryption algorithm.
Figure 346 Packets captured on the host
The host uses the ECC encryption algorithm to access the virtual server through https://61.159.4.100 successfully. View captured packet information on the host. The server hello packet shows that the negotiated algorithm is the ECC encryption algorithm.
Figure 347 Packets captured on the host
Configuration files
nqa template http t1
 expect status 200
pki domain ca_ecc
 public-key ecdsa name ca-ecc secp256r1
pki domain ca_rsa
 public-key rsa general name ca-rsa length 2048
 pki-domain ca_rsa ca_ecc
server-farm sf1
 probe t1
real-server rs1
 ip address 192.168.1.1
real-server rs2
real-server rs3
virtual-server vs type http
 port 443
 service enable
Example: Configuring SNI-based certificate selection from SSL server policies
Enable the LB device to use SSL server policies to match SNIs in user requests, so that the server can return the user with the certificates associated with the matching SSL server policies. The LB device will insert domain names into SSL handshake packets, enabling the server to return the domain name-associated certificates to the client.
Figure 348 Network diagram
Analysis
To configure SNI-based certificate selection from SSL server policies, complete the following configuration on the LB device:
·     Import CA and local certificates to the LB device, create a default SSL server policy on the LB device, and configure SSL server policies to match specific SNIs.
·     The host can send HTTPS requests carrying different SNIs to the virtual server successfully and can obtain the associated certificates.
When you configure SNI-based certificate selection from SSL server policies, follow these restrictions and guidelines:
·     You must first apply for the correct certificates, and then upload the certificates to the LB device through FTP or TFTP. Import the certificate for the SSL server policy corresponding to each SNI.
·     In the same view, you cannot configure multiple identical SSL server policies.
·     In the same view, you cannot configure multiple SSL server policies with the same SNI.
·     Configure the default SSL server policy to match user requests without carrying a SNI.
·     After creating an SSL server policy, use relevant commands to manually configure SNIs and the SSL server policies.
Procedures
Details not shown.
Creating PKI domains and disabling CRL checking
2.     Click Create to create a PKI domain named ca_default, and disable CRL checking.
Figure 349 Creating a PKI domain
3.     Click OK.
4.     Create PKI domains ca_aaa and ca_bbb in the same way PKI domain ca_default is created.
Importing CA and local certificates into PKI domains
1.     Select the created PKI domain ca_default, and click Import Certificate.
Figure 350 Importing a certificate
Figure 351 Importing a CA certificate
Figure 352 Certificate fingerprint information
Figure 353 Importing a local certificate
5.     Click OK.
6.     Import the CA and local certificates to PKI domains ca_aaa and ca_bbb in the same way.
Creating SSL server policies
2.     Click Create to create an SSL server policy named ssl_default, and specify the PKI domain as ca_default.
Figure 354 Creating an SSL server policy
3.     Click OK.
4.     Create SSL server policies ssl_aaa and ssl_bbb in the same way SSL server policy ssl_default is created.
[Sysname] ssl server-policy ssl_default
[Sysname-ssl-server-policy-ssl_default] certificate-chain-sending enable
[Sysname-ssl-server-policy-ssl_default] quit
[Sysname] ssl server-policy ssl_aaa
[Sysname-ssl-server-policy-ssl_aaa] certificate-chain-sending enable
[Sysname-ssl-server-policy-ssl_aaa] quit
[Sysname] ssl server-policy ssl_bbb
[Sysname-ssl-server-policy-ssl_bbb] certificate-chain-sending enable
[Sysname-ssl-server-policy-ssl_bbb] quit
Figure 355 Creating a health monitoring template
3.     Click OK.
Figure 356 Creating a server farm
3.     Click OK.
Figure 357 Adding a real server
Figure 358 Creating a real server
3.     Click OK.
Figure 359 Server farm information
Figure 360 Creating a virtual server
3.     Click OK.
Configuring SNIs
Use the following commands to manually configure SNIs for the virtual server:
[Sysname]virtual-server vs
[Sysname-vs-http-vs]ssl-server-policy ssl_aaa sni www.aaa.com
[Sysname-vs-http-vs]ssl-server-policy ssl_bbb sni www.bbb.com
Sending a request without carrying an SNI
The host accesses the virtual server through https://61.159.4.100 (without carrying the SNI information) successfully. Capture packets on the host to verify the following information:
·     The client Hello packet has no SNI information.
·     The server Hello packet shows that the certificate of the default SSL server policy ssl_default is used.
·     The subjectPublicKey in the server Hello packet is consistent with the public key of the local key pair ca_default (configured on the Objects > Public Key Management > Local Key Pairs page), which means that the certificate corresponding to SSL server policy ssl_default is used.
Figure 361 Packets captured on the host (client Hello)
Figure 362 Packets captured on the host (server Hello)
Figure 363 Packets captured on the host (subjectPublicKey)
Figure 364 Device public key
Sending a request carrying SNI https://www.aaa.com
The host accesses the virtual server through https://www.aaa.com (SNI information) successfully. Capture packets on the host to verify the following information:
·     The client Hello packet has SNI information www.aaa.com.
·     The server Hello packet shows that the certificate of SSL server policy ssl_aaa is used.
·     The subjectPublicKey in the server Hello packet is consistent with the public key of the local key pair ca_aaa (configured on the Objects > Public Key Management > Local Key Pairs page), which means that the certificate corresponding to SSL server policy ssl_aaa is used.
Figure 365 Packets captured on the host (client Hello)
Figure 366 Packets captured on the host (server Hello)
Figure 367 Packets captured on the host (subjectPublicKey)
Figure 368 Device public key
Sending a request carrying SNI https://www.bbb.com
·     The client Hello packet has SNI information www.bbb.com.
·     The server Hello packet shows that the certificate of SSL server policy ssl_bbb is used.
·     The subjectPublicKey in the server Hello packet is consistent with the public key of the local key pair ca_bbb (configured on the Objects > Public Key Management > Local Key Pairs page), which means that the certificate corresponding to SSL server policy ssl_bbb is used.
Figure 369 Packets captured on the host (client Hello)
Figure 370 Packets captured on the host (server Hello)
Figure 371 Packets captured on the host (subjectPublicKey)
Figure 372 Device public key
Configuration files
 expect status 200
pki domain ca_aaa
 public-key rsa general name ca-aaa
pki domain ca_bbb
 public-key rsa general name ca-bbb length 2048
pki domain ca_default
 public-key ecdsa name ca-default secp256r1
 pki-domain ca_aaa
 pki-domain ca_bbb
 pki-domain ca_default
server-farm sf1
 probe t1
real-server rs1
real-server rs2
real-server rs3
 port 443
 ssl-server-policy ssl_default
 service enable
Example: Configuring connection reuse
The connection reuse feature stores the server connections that are not transmitting data into the cache pool, and reuses the connections for client HTTP requests. This feature ensures server performance and the delay caused by establishing new TCP connections with the server. In addition, it minimizes the number of concurrent connections on the back-end server to save server resources.
The host accesses three servers through the LB device. These three servers Server A, Server B, and Server C can provide HTTP services. The host traffic will be load-shared among these servers. Enable the connection reuse feature to establish a connection that does not age for a long time between the LB device and the server. Multiple clients can reuse the same TCP connection with the server.
Figure 373 Network diagram
Analysis
To configure HTTP connection reuse, complete the following configuration on the LB device:
·     Create a parameter profile of HTTP type and enable connection reuse.
·     Specify the parameter profile for the HTTP virtual server.
·     Reuse a TCP connection when a large number of hosts access the server through multiple connections.
When you configure HTTP connection reuse, follow these restrictions and guidelines:
·     Make sure a route is available from the host to the LB device.
·     Configure an SNAT pool for a server farm.
·     Specify the real server addresses on the LB device as the actual server addresses.
Procedures
Details not shown.
Figure 374 Creating a health monitoring template
3.     Click OK.
Creating parameter profiles
1.     Navigate to the LB > Application Load Balancing > Parameter Profiles page.
2.     Create a parameter profile named pp1, specify the type as HTTP, and enable connection reuse.
Figure 375 Creating an HTTP parameter profile
3.     Click OK.
4.     Create a parameter profile named pp2, specify the type as OneConnect, and specify the idle timeout time as 3 seconds.
Figure 376 Creating a OneConnect parameter profile
5.     Click OK.
Configuring an SNAT pool
1.     Navigate to the LB > Public Configuration > SNAT Pool page.
2.     Click Create to create an SNAT pool named snat1. Create an address range with start IP address 192.168.1.210 and end IP address 192.168.1.220. Select RAGG1.20 as the interface for sending gratuitous ARP or ND packets.
Figure 377 Creating an SNAT pool
Figure 378 SNAT pool information
3.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Server Farms page.
2.     Create a server farm named sf1. Specify the scheduling algorithm as Round robin, probe method as t1, and SNAT pool as snat1.
Figure 379 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1 and IP address as 192.168.1.1.
Figure 380 Adding a real server
Figure 381 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way rs1 is created. Configure the IPv4 addresses for real servers rs2 and rs3 as 192.168.1.2 and 192.168.3, respectively.
Figure 382 Server farm information
2.     Create a virtual server named vs, specify the type as HTTP, configure the virtual server IP as 61.159.4.100 and default server farm as sf1, enable the virtual server feature, and specify parameter profile pp1 of HTTP type and parameter profile pp2 of OneConnect type.
Figure 383 Creating a virtual server
3.     Click OK.
Verifying the configuration when connection reuse is disabled
When connection reuse is disabled, a large number of hosts can access the HTTP server through http:// 61.159.4.100 successfully. On the LB device, you can see that the connection establishment rates are equal in the virtual server statistics and real server statistics.
1.     Navigate to the Monitor > Application Load Balancing > Virtual Servers > Real-time Statistics page. View the traffic statistics.
Figure 384 Virtual server statistics
2.     Navigate to the Monitor > Application Load Balancing > Real Servers > Real-time Statistics page. View the traffic statistics.
Figure 385 Real server statistics
3.     Click Details to view the detailed virtual server and real server statistics. You can see that the total number of connections in the virtual server statistics is equal to that in the real server statistics. (Details not shown.)
4.     Check the packet captured on the server. One request corresponds to one TCP connection.
Figure 386 Packets captured on the server
Verifying the configuration when connection reuse is enabled
When connection reuse is enabled, a large number of hosts can access the HTTP server through http:// 61.159.4.100 successfully. On the LB device, you can see that the connection establishment rate in the virtual server statistics is far greater than that in the real server statistics.
Figure 387 Virtual server statistics
Figure 388 Real server statistics
3.     Click Detail to view the detailed virtual server and real server statistics. You can see that the total number of connections in the virtual server statistics is far greater than that in the real server statistics. (Details not shown.)
4.     Capture packets on the server. You can see that eleven requests share one TCP connection.
Figure 389 Packets captured on the server
Configuration files
 expect status 200
parameter-profile pp1 type http
 server-connection reuse
parameter-profile pp2 type oneconnect
 max-reuse 10
 idle-time 3
loadbalance snat-pool snat1
 ip range start 192.168.1.210 end 192.168.1.220
 arp-nd interface Route-Aggregation1.20
server-farm sf1
 snat-pool snat1
 probe t1
real-server rs1
real-server rs2
real-server rs3
 parameter http pp1
 parameter oneconnect pp2
 service enable
Example: Configuring HTTP compression
The LB device compresses the response packets from the server, and the host needs to carry Accept-Encoding information. As shown in the Figure 390, the host can access three servers through the LB device. These three servers Server A, Server B, and Server C in the public network can all provide HTTP services. Enable the server to reply with large packets, and configure a parameter profile with compression parameters for the LB device to compress large packets returned from the server to the host.
Figure 390 Network diagram
Analysis
To implement HTTP compression, complete the following configuration on the LB device:
·     Configure a parameter profile with compression parameters.
·     Enable the LB device to compress the large file replied by the server.
Software versions used
Procedures
Details not shown.
Figure 391 Creating a health monitoring template
3.     Click OK.
Figure 392 Creating a server farm
3.     Click OK.
Figure 393 Adding a real server
Figure 394 Creating a real server
3.     Click OK.
Figure 395 Server farm information
Configuring a parameter profile
2.     Click Create to create a parameter profile named pp1. Specify the type as HTTP compression, the compression level as 9, and the preferred compression algorithm as deflate.
Figure 396 Creating parameter profile information
3.     Click OK.
2.     Click Create to create a virtual server named vs1, specify the type as HTTP, specify parameter profile pp1, specify server farm sf1, and enable the virtual server feature.
Figure 397 Creating a virtual server
3.     Click OK.
The host accesses the server through the browser that supports Accept-Encoding: gzip and deflate by default. Enable the server to reply with a large file of 2512000 bytes. Capture packets on the client. You can see that the compressed length is marked in a red circle for the packet returned by the LB device to the client with a status code of 200 OK.
Figure 398 Packets captured on the host
Figure 399 Packets captured on the server
Configuration files
 expect status 200
parameter-profile pp1 type http-compression
 compression level 9
 prefer-method deflate
server-farm sf1
probe t1
real-server rs1
real-server rs2
real-server rs3
 parameter http-compression pp1
 service enable
Example: Configuring a Web cache policy
A Web cache policy allows you to cache frequently accessed webpages locally in files. If a user accesses the same URI before the cached file expires, the device responds with the file instead of sending the request to the server. By using a Web cache policy, you can alleviate the pressure on the server, reduce the transmission costs, and reduce the response time for users.
Other functional modules (for example, an LB virtual server) can use a Web cache policy to cache frequently accessed webpages.
Network caching can address the demands of service quality and high-speed and stable networks.
Deploy a cache device between the server and the client to save the content frequently accessed or downloaded by the user that is larger than 1 KB. When a user accesses or downloads the same content again, the device responds with the content saved in the cache without having to connect to the associated website This can improve the access or download speed and save network bandwidth.
Figure 400 Network diagram
Analysis
To implement the Web cache feature, complete the following configuration on the LB device:
·     Configure a Web cache policy.
·     Specify the cache policy for the virtual server.
When you configure a Web cache policy, follow these restrictions and guidelines:
·     The device can cache only the requested files that are larger than 1 KB
Procedures
Details not shown.
Creating a cache policy
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Cache Policy page.
2.     Click Create to create a Web cache policy named cache, specify the type as HTTP, and configure relevant parameters as follows.
Figure 401 Creating a Web cache policy
3.     Click OK.
Figure 402 Creating a health monitoring template
3.     Click OK.
Figure 403 Creating a server farm
3.     Click OK.
Figure 404 Adding a real server
Figure 405 Creating a real server
3.     Click OK.
Figure 406 Server farm information
2.     Click Create to create a virtual server named cache, specify the type as HTTP, set the IP address to 61.159.4.100, specify the server farm as sf1, enable the virtual server feature, and specify cache policy cache.
Figure 407 Creating a virtual server
3.     Click OK.
Initiating a client request for the first time
1.     Initiate a client request with URL http://61.159.4.100/download. The access is successful.
2.     Navigate to the Monitor > Application Load Balancing > Virtual Servers > Real-time Statistics page.
Figure 408 Viewing virtual server statistics
Figure 409 Viewing real server statistics
4.     Navigate to the LB > Application Load Balancing > Advanced Policies > Cache Policy page. View the number of requests matching the Web cache policy.
Figure 410 Viewing Web cache policy statistics
Initiate the client request again
1.     Initiate the request http://61.159.4.100/download again. The access is successful.
Figure 411 Viewing virtual server statistics
Figure 412 Viewing real server statistics
Figure 413 Viewing Web cache policy statistics
Configuration files
 expect status 200
server-farm sf1
 probe t1
real-server rs1
real-server rs2
real-server rs3
virtual-server cache type http
 lb-cache-policy cache
 service enable
cache-policy cache type http
 match 1 uri /download
Example: Configuring WebSocket
WebSocket is a network technology for full-duplex communication between a client and a server, and is an application layer protocol. It is based on the TCP and uses the handshake channel of HTTP. Specifically, the client negotiates an upgrade protocol with the WebSocket server through an HTTP request. After the protocol upgrade is completed, subsequent data are exchanged based on the WebSocket protocol.
The host can access three servers through the LB device. All the three servers Server A, Server B, and Server C can all provide HTTP services. The host traffic to the server will be load-shared among the three servers.
The client initiates a protocol upgrade request in the standard HTTP packet format, and only supports the GET method. The protocol version is 1.1. The server responds to the protocol upgrade and returns a status code of 101 to indicate protocol switchover.
Figure 414 Network diagram
Analysis
To configure WebSocket, complete the following configuration on the LB device:
·     Configure the same basic settings as other Layer 7 load balancing configuration examples.
·     This example uses the client-side websocket.html and the server-side server.py application programs to simulate the test. The actual test result might vary by application scenario.
This configuration example was created and verified on Feature 1160P16 of L1070.
Make sure the server supports running Python programs and can call the server.py program.
Procedures
Perform the following configuration on the LB device.
Assigning IP addresses to interfaces
Details not shown.
Creating a TCP NQA template
1.     Navigate to the LB > Global Configuration > Health Monitoring page.
2.     Click Create to create a template named t1, specify the type as HTTP, and set the destination port number to 8000.
Figure 415 Creating a health monitoring template
3.     Click OK.
Figure 416 Creating a server farm
3.     Click OK.
Configuring real servers
2.     Edit server farm sf1, and create a real server. Specify the real server name as rs1, IP address as 192.168.1.1, and port number as 8000.
Figure 417 Adding a real server
Figure 418 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way real server rs1 is created. Configure the IPv4 addresses as 192.168.1.2 and 192.168.1.3 and the port number as 8000 for real servers rs2 and rs3, respectively.
Figure 419 Server farm information
2.     Create a virtual server named vs, specify the type as HTTP, and set the IPv4 address to 61.159.4.100 and the port number to 8000. Specify server farm sf1, and enable the virtual server feature.
3.     Click OK.
Figure 420 Creating a virtual server
Running the server.py file on the server
Figure 421 Running the server.py file
Opening the websocket.html file on the host
Open the websocket.html file on the host, establish a connection with the virtual service address 61.159.4.100 (port number 8000), and send the WebSocket information. You can see that the connection is established successfully and the information is sent successfully.
Figure 422 Sending the WebSocket information
Viewing captured packet information on the host
View captured packet information on the host. You can see that the sent HTTP request packet carries the field Connection: Upgrade.
Figure 423 Packets captured on the host
View captured packet information on the server. You can see that the server responds to the protocol upgrade request, and returns a status code of 101, indicating that the protocol is switched to WebSocket.
Figure 424 Packets captured on the server
Configuration files
nqa template tcp t1
 destination port 8000
server-farm sf1
 probe t1
 real-server rs1 port 8000
 real-server rs2 port 8000
 real-server rs3 port 8000
real-server rs1
real-server rs2
real-server rs3
 port 8000
 service enable
Example: Configuring RADIUS load balancing for home broadband AAA authentication
As shown in the Figure 425, the LB device is connected to a cluster of RADIUS servers. The host provides RADIUS services for external users through NAS via the three RADIUS servers. The IP addresses of the RADIUS servers are 192.168.1.1 through 192.168.1.3.
If a user initiates an authentication request to the NAS device, the LB device will distribute the request packets to different RADIUS server for load balancing.
When a small number of NAS devices exist, enable UDP per-packet load balancing to distribute requests to the RADIUS servers more evenly. Configure the RADIUS sticky method distribute authentication packets with the same username to the same authentication server. Configure ICMP and UDP NQA templates for service health check to ensure high availability.
Figure 425 Network diagram
Analysis
To implement RADIUS load sharing for home broadband AAA authentication, complete the following configuration:
·     Configure routes between the RADIUS server, NAS client, and LB device.
·     Configure UDP per-packet load balancing to load-share services.
·     Configure health monitoring of the ICMP type and health monitoring for UDP ports 1812 and 1813 to ensure service reliability.
·     Configure a sticky group to distribute authentication packets with the same username to the same authentication server.
This configuration example was created and verified on Alpha 1160P16 of L1000-AK315.
In this example, configure the aging timer for RADIUS sticky entries as 3600 seconds. Adjust the value as needed.
Procedures
Details not shown.
Creating health monitoring templates
2.     Click Create to create a template named t1, and specify the type as ICMP.
Figure 426 Creating a health monitoring template
3.     Click OK.
4.     Create NQA templates t2 and t3, specify the type as UDP, configure the payload fill string, and enable port detection (the settings are not supported on the Web interface in D060SP).
[Sysname]nqa template udp t2
[Sysname-nqatplt-udp-t2]data-fill "default send string" raw
[Sysname-nqatplt-udp-t2]destination port 1812
[Sysname-nqatplt-udp-t2]port-detect enable
[Sysname-nqatplt-udp-t2]reaction trigger probe-pass 1
[Sysname-nqatplt-udp-t2]quit
[Sysname]nqa template udp t3
[Sysname-nqatplt-udp-t3]data-fill "default send string" raw
[Sysname-nqatplt-udp-t3]destination port 1813
[Sysname-nqatplt-udp-t3]port-detect enable
[Sysname-nqatplt-udp-t3]reaction trigger probe-pass 1
2.     Click Create to create a server farm named sf, specify the scheduling algorithm as Round robin, specify the probe templates t1, t2, and t3, and specify the success criteria as All.
Figure 427 Creating a server farm
3.     Click OK.
2.     Edit server farm sf, and add a real server. Specify the real server name as rs1 and IP address as 192.168.1.1.
Figure 428 Adding a real server
Figure 429 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way real server rs1 is created. Specify the IP address for real servers rs2 and rs3 as 192.168.1.2 and 192.168.1.3, respectively.
Figure 430 Server farm information
Configuring a sticky group
1.     Navigate to the LB > Global Configuration > Sticky Groups page.
2.     Click Create to create a sticky group named radius.
3.     Set the type to RADIUS, sticky method to user-name, and aging time to 3600s.
Figure 431 Creating a sticky group
4.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Virtual Servers page.
3.     Specify the type as RADIUS, set the VSIP address to 61.159.4.100, specify server farm sf and sticky group radius, enable UDP per-packet load balancing, and enable the virtual server feature.
Figure 432 Creating a virtual server
4.     Click OK.
The user on the NAS client sends a RADIUS authentication request to the LB device. The LB device load-balances the request among RADIUS servers for processing, and generates sticky entries at the same time.
View the sticky entries, the real server to which the username is assigned:
Slot 1:
  Sticky type: RADIUS
  Sticky method: Attribute ID
  Sticky Key: 8b69353fe93eb925a6b8e98d63a4bd60
  Text: admin123
  Virtual server addr: 61.159.4.100:1812
  Client addr: 10.0.0.2
  Timeout: 3600 sec
  Expiration time: 3512 sec
Initiate RADIUS traffic, and the traffic are load-shared among real servers.
Figure 433 Real server statistics
Configuration files
nqa template icmp t1
nqa template udp t2
 port-detect enable
nqa template udp t3
 port-detect enable
real-server rs1
success-criteria at-least 1
real-server rs2
 ip address 192.168.1.2
real-server rs3
 ip address 192.168.1.3
server-farm sf
 probe t2
 probe t3
 probe t1
sticky-group radius type radius
 radius-attribute user-name
virtual-server vs type radius
 virtual ip address 61.159.4.100
 default server-farm sf sticky radius
 udp per-packet
 connection-sync enable
 sticky-sync enable
 service enable
Example: Configuring SIP load balancing
As shown in the Figure 434, the LB device is connected to a cluster of SIP servers that provide SIP services for external users. The IP addresses of the three SIP servers are 192.168.1.1 through 192.168.1.3. The LB device will distribute the SIP request packets sent by the host evenly among the SIP servers. If a small number of SIP clients exist, you can enable traffic to be load-balanced more evenly by distributing SIP requests with the same Call-ID to the same server.
Figure 434 Network diagram
Analysis
To implement SIP load balancing, complete the following configuration on the LB device:
·     Configure a SIP sticky group and a SIP health monitoring template.
·     Create a server farm, add real servers to it, and specify a SIP health monitoring template.
·     Configure a SIP virtual server, and specify a server farm and a SIP sticky group.
When you configure SIP load balancing, follow these restrictions and guidelines:
·     Use a SIP NQA template for health monitoring.
·     Enable UDP per-packet load balancing for the SIP-UDP virtual server.
Procedures
Details not shown.
Creating a SIP NQA template
Use the following command to configure a SIP NQA template (not supported on the Web interface):
[Sysname]nqa template sip t1
1.     Navigate to the Policies > LB > Server Load Balancing > Server Farm page.
2.     Click Create to create a server farm named sf_sip. Specify the scheduling algorithm as Hash source IP address and probe method as sip.
Figure 435 Creating a server farm
3.     Click OK.
2.     Edit server farm sf_sip, and create a real server. Specify the real server name as rs1 and the IP address as 192.168.1.1.
Figure 436 Adding a real server
Figure 437 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way real server rs1 is created. Configure the IPv4 addresses as 192.168.1.2 and 192.168.1.3 for real servers rs2 and rs3, respectively.
Figure 438 Server farm information
1.     Navigate to the Policies > LB > Public Configuration > Sticky Group page.
2.     Click Create to create a sticky group named sip, and specify the type as SIP and the SIP sticky method as Call-ID.
Figure 439 Creating a sticky group sip
3.     Click OK.
Configuring a virtual server
2.     Create a virtual server named vs, specify the type as SIP-UDP, and set the IPv4 address to 61.159.4.100 and the port number to 5060.
3.     Enable UDP per-packet load balancing, specify server farm sf_sip and sticky method sip, and enable the virtual server feature.
4.     Click OK.
Figure 440 Creating a virtual server
5.     Click OK.
1.     Clear real server statistics for accurate verification result, and then inject traffic for verification.
3.     Click Clear to clear statistics of all real servers.
Figure 441 Clearing server farm statistics
4.     Click Details to view the detailed statistics of each real server.
Figure 442 Viewing the detailed statistics of the real server
Sending SIP-UDP requests from a large number of users with different Call-IDs to the virtual server
The host initiates SIP-UDP requests to the virtual server with multiple addresses, and the access is successful. The server farm member statistics on the LB device shows that the requests are evenly distributed among the three servers. The packet information shows that the SIP session is successfully established and the RTP media stream is sent.
Figure 443 Statistics result of real server rs1
Figure 444 Statistics result of real server rs2
Figure 445 Statistics result of real server rs3
Figure 446 Packet information on the server
Sending SIP-UDP requests from a small number of users with different Call-IDs to the virtual server
Clear the server farm member statistics. The host initiates SIP-UDP requests to the virtual server with few addresses, and the access is successful. The server farm member statistics on the LB device shows that the requests are evenly distributed among the three servers. The packet information shows that the SIP session is successfully established and the RTP media stream is sent.
Figure 447 Real server statistics
Figure 448 Real server statistics with UDP per-packet load balancing disabled
Sending SIP-UDP requests with the same Call-ID to the virtual server
Clear the server farm member statistics. The host initiates SIP-UDP requests with the same Call_ID to the virtual server vs, and the access is successful. The server farm member statistics on the LB device shows that the requests are distributed to one server. The packet information shows that the packets with different source addresses but the same Call-ID are assigned to the same real server.
Figure 449 Virtual server statistics
Figure 450 Real server statistics
Figure 451 Packets with the same Call-ID assigned to the same server
Configuration files
server-farm sf_sip
 predictor hash address source
probe sip
nqa template sip sip
real-server rs1
real-server rs2
real-server rs3
sticky-group sip type sip
 header call-id
virtual-server vs type sip-udp
 default server-farm sf_sip sticky sip
 udp per-packet
 sticky-sync enable
 service enable
Example: Configuring MySQL load balancing
For faster MySQL database responses, you can use database load balancing to share user requests among different devices, and reduce the pressure on a single database. In addition, database read requests can be sent to the read server, and database write requests can be sent to the write server.
As shown in the Figure 452, the host can access MySQL servers through the LB device. Server A and Server B process read requests, and Server C processes write requests. Both read and write requests can be distributed to the associated servers without service interruption, and subsequent requests can reuse the previous connections to reduce the pressure on the servers.
Figure 452 Network diagram
Analysis
To implement MySQL load balancing, complete the following configuration on the LB device:
·     Configure the read server farm, write server farm, read real server, and write real server settings. Add read and write real servers to the read and write server farms, respectively.
·     Configure the virtual server of MySQL type, enable the read/write splitting function, and specify the read and write server farms, respectively. The username and password of the database must be consistent with those in the actual MySQL server. The version number of the database is less than or equal to that of the actual server. As a best practice, use the same version number.
·     Configure a parameter profile of the MySQL type, enable connection reuse, and specify it for the MySQL virtual server.
·     Configure SNAT settings.
·     The read and write requests matching the virtual server will be distributed to the associated real servers in the read and write server farms. Specify the MySQL parameter profile for the virtual server to distribute the read and write requests to the read and write server farms without interrupting server connections.
When you configure MySQL load balancing, follow these restrictions and guidelines:
·     On the MySQL type virtual server, the username and password of the database must be consistent with those in the actual MySQL server. The version number of the database must be less than or equal to that of the real server. As a best practice, use the same version number.
·     Enable connection reuse for the MySQL parameter profile, and specify the parameter profile for the MySQL virtual server.
Procedures
Details not shown.
2.     Click Create to create a template named t1, specify the type as TCP, and set the destination port number to 3306.
Figure 453 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create an SNAT pool named snat1. Create an address range with start IP address 1.1.1.11 and end IP address1.1.1.20.
Figure 454 Creating an SNAT pool
Figure 455 SNAT pool information
3.     Click OK.
Creating server farms
2.     Click Create to create a read server farm named sf_read and write server farm sf_write. Specify the scheduling algorithm as Hash source IP address and probe method as t1.
Figure 456 Creating read server farm sf_read
3.     Click OK.
Figure 457 Creating write server farm sf_write
4.     Click OK.
Figure 458 Adding a real server
Figure 459 Creating a real server
3.     Click OK.
Figure 460 Server farm information
Adding real servers to server farms
2.     Edit server farm sf_read, and click Add to add a real server. Specify the real server name as rs1 and IP address as 192.168.1.1.
Figure 461 Adding a real server
Figure 462 Creating a real server
3.     Click OK.
4.     Add real servers rs2 and rs3 in the same way rs1 is added. Add real server rs2 to server farm sf_read, and configure the real server IPv4 address as 192.168.1.2. Add real server rs3 to server farm sf_write, and configure the real server IPv4 address as 192.168.1.3.
Figure 463 Server farm sf_read information
Figure 464 Server farm sf_write information
Creating a MySQL parameter profile
2.     Click Create to create a parameter profile named vs, specify the type as MySQL, and enable connection reuse.
Figure 465 Creating a parameter profile
2.     Click Create to create a virtual server vs, specify the type as MySQL, set the IP address to 61.159.4.100/32 and the port number to 3306, and enable read/write splitting. Specify read server farm sf_read and write server farm sf_write. Configure the username and password (root/123456) and the version number (5.1) of MySQL, specify MySQL parameter profile mysql, and enable the virtual server feature.
Figure 466 Creating a virtual server
Figure 467 Creating a user
3.     Click OK.
The host initiates a MySQL request to the virtual server with IP address 61.159.4.100. After the access is successful, you can view virtual server and real server statistics on the LB device. By capturing packets on the real server, you can see that the source address of the service packets processed by the LB device is an IP address in the SNAT pool, instead of the client address.
Figure 468 Analysis of packets captured on the client
A connection is established for the read and write requests.
Figure 469 Analysis of packets captured on the real server
The read request is sent to a read real server, and the write request is sent to a write real server. The existing connection is not interrupted when the read and write requests are sent to the real servers.
Configuration files
nqa template tcp t1
 destination port 3306
parameter-profile mysql type mysql
 ip range start 1.1.1.11 end 1.1.1.20
server-farm sf_read
 snat-pool snat1
 probe t1
 real-server rs1 port 0
 real-server rs2 port 0
server-farm sf_write
 snat-pool snat1
 probe t1
 real-server rs3 port 0
real-server rs1
real-server rs2
real-server rs3
virtual-server vs type mysql
 parameter mysql mysql
 sticky-sync enable global
 version 5.1
 username root password cipher U1FMAPD7zhCOQGelh2yW3A==
 readwrite-separation read-server-farm sf_read write-server-farm sf_write
 service enable
Example: Configuring load balancing for Oracle database servers
As shown in the Figure 470, the host accesses the Oracle database servers through the LB device. Three servers Server A, Server B and Server C can provide Oracle database services. Configure application load balancing to enable these servers to jointly provide Oracle database services and monitor reachability of the servers through health monitoring.
Figure 470 Network diagram
Analysis
To implement load balancing for Oracle database servers, complete the following configuration on the LB device:
·     Configure server farm and real server settings.
·     Create a TCP virtual server, and enable the Layer 7 operation mode.
·     User requests to the Oracle database that match the virtual server will be load-shared among the real servers through the load balancing method of the server farm. You need to configure the port number monitored by the virtual server as the Oracle server port number.
When you configure load balancing for Oracle database servers, follow these restrictions and guidelines:
·     Configure the port number of the virtual server as the Oracle service port number.
·     Enable the Layer 7 operation mode for the TCP virtual server.
Procedures
Details not shown.
2.     Click Create to create a template named t1, specify the type as TCP, and set the destination port number to 1521.
Figure 471 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create an SNAT pool named snat1. Create an address range with start IP address 1.1.1.11 and end IP address 1.1.1.20.
Figure 472 Creating an SNAT pool
Figure 473 SNAT pool information
3.     Click OK.
Figure 474 Creating a server farm
3.     Click OK.
Figure 475 Adding a real server
Figure 476 Creating a real server
3.     Click OK.
Figure 477 Server farm information
2.     Click Create to create a virtual server named vs. Specify the type as TCP, IPv4 address as 61.159.4.100/32, and port number as 1521. Enable the Layer 7 operation mode, and enable the virtual server feature.
Figure 478 Creating a virtual server
3.     Click OK.
The host initiates an Oracle request to the virtual server with IP address 61.159.4.100. After the access is successful, you can view the virtual server and real server statistics on the LB device. By capturing packets on the real server, you can see that the source address of the service packets processed by the LB device is an IP address in the SNAT pool, instead of the client address.
Figure 479 Analysis of packets captured on the client
Figure 480 Analysis of packets captured on the real server
Configuration files
nqa template tcp t1
 destination port 1521
server-farm sf1
 snat-pool snat1
 probe t1
real-server rs1
real-server rs2
real-server rs3
virtual-server vs type tcp
 port 1521
 application-mode enable
 service enable  #
Example: Configuring TCP options
The backend server might fail to obtain the client IP address upon an IP address change, or discard a packet with invalid timestamp. To address the issue, you can insert the client IP address into a TCP option, or remove the specified TCP option (such as timestamp option) from TCP packet headers.
As shown in the Figure 481, the host can access three web servers through the LB device. These three servers Server A, Server B, and Server C in the public network can all provide HTTP services. Configure application load balancing to implement the following requirements:
·     Specify an SNAT pool to translate the source address of user request packets.
·     Insert the client IP address into TCP Option 28 of TCP packets sent to the server
·     Remove TCP Option 8 (timestamp option) from the headers of TCP packets sent by the LB device to the server.
Figure 481 Network diagram
Analysis
To insert client IP address to a TCP option or remove a TCP option, complete the following configuration on the LB device:
·     Configure an SNAT address pool and specify it for the server farm.
·     Configure a TCP parameter profile to insert client IP address to TCP option 28 and remove TCP option 8 (timestamp).
·     Configure a TCP virtual server, enable the Layer 7 operation mode, and specify the TCP parameter profile for this virtual server.
·     Enable the LB device to translate the source address in the HTTP request packet matching the virtual server into an IP address in the SNAT pool before sending the packet to the server. At the same time, the LB device inserts the client IP address into TCP Option 28 of the TCP packet, and removes TCP Option 8 from the TCP packet.
When you insert client IP address to a TCP option or remove a TCP option, follow these restrictions and guidelines:
·     Specify a non-zero port number for the TCP virtual server, and enable the Layer 7 operation mode.
·     The Layer 7 HTTP virtual services are supported at the same time.
Procedures
Details not shown.
2.     Click Create to create an NQA template named t1. Specify the template type as TCP and destination port number as 80.
Figure 482 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create an SNAT pool named snat1. Create an address range with start IP address 192.168.1.201 and end IP address 192.168.1.210. Select RAGG1.20 as the interface for sending gratuitous ARP or ND packets.
Figure 483 Creating an SNAT pool
Figure 484 SNAT pool information
3.     Click OK.
Figure 485 Creating a server farm
3.     Click OK.
Figure 486 Adding a real server
Figure 487 Creating a real server
3.     Click OK.
Figure 488 Server farm information
2.     Click Create to create a parameter profile named tcp_option, and specify the type as TCP.
3.     Specify TCP option 28 to insert the client IP address into the TCP option, and specify TCP option 8 (timestamp option) to be removed from TCP packet headers.
Figure 489 Creating a parameter profile
4.     Click OK.
Figure 490 Parameter profile information
2.     Click Create to create a virtual server named vs. Specify the type as TCP, IPv4 address as 61.159.4.100/32, and port number as 80. Enable the Layer 7 operation mode, and enable the virtual server feature.
Figure 491 Creating a virtual server
3.     Click OK.
Viewing packet information with the parameter profile specified for the virtual server
The host initiates an HTTP request to the virtual server with IP address 61.159.4.100. After the access is successful, view the packets captured on the server.
The client IP address is inserted into TCP Option 28, and TCP Option 8 (timestamp option) is removed from the TCP packet.
Figure 492 TCP packet with client IP address inserted and timestamp option deleted
Viewing packet information without specifying a parameter profile for the virtual server
The host initiates an HTTP request to the virtual server with IP address 61.159.4.100. After the access is successful, view the packets captured on the server. You can see that the packet contains a timestamp.
Figure 493 Packets captured on the server when no parameter profile is specified for the virtual server
Configuration files
nqa template tcp t1
 destination port 80
parameter-profile tcp_option type tcp
 tcp option remove 8
 tcp option insert 28 src-addr
 ip range start 192.168.1.201 end 192.168.1.210
server-farm sf1
 snat-pool snat1
 probe t1
real-server rs1
real-server rs2
real-server rs3
 port 80
 parameter tcp tcp_option client-side
 parameter tcp tcp_option server-side
 service enable
NAT64 load balancing configuration examples
Example: Configuring NAT64 load balancing (Layer 7)
As shown in the Figure 494, configure IPv4 and IPv6 SNAT address pools on the LB device to implement the following requirements:
·     The host with an IPv4 address can initiate a request destined to the virtual server IPv4 address to access the server with an IPv6 address. In addition, you can view the NAT46 session log on the LB device.
·     The host with an IPv6 address can initiate a request destined to the virtual server IPv6 address to access the server with an IPv4 address. In addition, you can view the NAT64 session log on the LB device.
Figure 494 Network diagram
Analysis
To implement Layer 7 NAT64 load balancing, complete the following configuration on the LB device:
·     Configure the SNAT address pools to implement NAT64 and NAT46, respectively.
·     Enable LB NAT logging for the LB device.
When you configure Layer 7 NAT64 load balancing, follow these restrictions and guidelines:
·     Associate the SNAT address pools with the IPv4 and IPv6 virtual servers, respectively.
·     NAT64 supports only the virtual services of HTTP type.
·     You need to use relevant commands to configure LB NAT logging that is not supported on the Web interface.
Procedures
Details not shown.
2.     Click Create to create a template named t1 and specify the type as HTTP.
Figure 495 Creating a health monitoring template
3.     Click OK.
Configuring SNAT address pools
1.     Navigate to the LB > Global Configuration > SNAT Pool page.
2.     Click Create to create an IPv4 SNAT pool named snat1.
Figure 496 Creating an IPv4 SNAT address pool
3.     Click OK.
4.     Create IPv6 address pool snat2 in the same way snat1 is created.
Figure 497 Creating an IPv6 SNAT address pool
2.     Click Create to create server farms named sf1 and sf2. Specify SNAT address pools snat1 and snat2 for server farms sf1 and sf2, respectively. Specify the scheduling algorithm as Hash source IP address and probe method as t1.
Figure 498 Creating a server farm
3.     Click OK.
Figure 499 Creating server farm sf2
4.     Click OK.
Configuring the real server
2.     Edit server farm sf1, and click Add to create a real server. Specify the real server name as rs1 and IP address as 7.0.0.2.
Figure 500 Adding an IPv4 real server
Figure 501 Creating a real server
3.     Click OK.
4.     Create real server rs2 in the same way real server rs1 is created. Configure the IPv4 address for real server rs2 as 7.0.0.3.
Figure 502 Server farm information
5.     Click OK.
6.     Navigate to the LB > Application Load Balancing > Server Farms page.
7.     Edit server farm sf2, and click Add to create a real server. Specify the real server name as rs11 and the IPv6 address as 7::2.
Figure 503 Adding an IPv6 real server
Figure 504 Creating a real server
8.     Click OK.
9.     Create real server rs12 in the same way rs11 is created. Configure the IPv6 address for real server rs12 as 7::3.
Figure 505 Server farm information
10.     Click OK.
Configuring virtual servers
2.     Click Create to create virtual servers named vs1 and vs2, specify their IP addresses as 200::1 and 61.159.4.100, and specify server farms sf1 and sf2 for them, respectively. Specify the type as HTTP, and enable the virtual server feature.
Figure 506 Creating virtual server vs1
3.     Click OK.
Figure 507 Creating virtual server vs1
4.     Click OK.
Enabling LB NAT logging
Execute the following commands to enable LB NAT logging for the LB device (the configuration is not supported on the Web interface):
[Sysname] loadbalance log enable nat
[Sysname] userlog flow syslog
Accessing an IPv4 server from an IPv6 address
The host with an IPv6 address can successfully access the IPv4 HTTP server through http://200::1.
To view virtual server and real server statistics, NAT64 logs, and session information:
1.     Navigate to the Monitor > Application Load Balancing page to view virtual server and real server statistics on the LB device. (Details not shown.)
2.     Navigate to the Monitor > Device Logs > System Logs page to view NAT64 logs.
Figure 508 NAT64 logs
3.     Navigate to the Monitor > Sessions Monitoring > Proxy Session page to view proxy session information.
Figure 509 Proxy session information
Accessing an IPv6 server from an IPv4 address
The host with an IPv4 address can successfully access the IPv6 HTTP server through http://61.159.4.100.
Figure 510 NAT64 logs
Figure 511 Proxy session information
Configuration files
 expect status 200
 ip range start 7.0.0.101 end 7.0.0.110
loadbalance snat-pool snat2
 ipv6 range start 7::101 end 7::10A
server-farm sf1
 snat-pool snat1
 probe t1
server-farm sf2
 snat-pool snat2
 probe t1
 real-server rs11 port 0
 real-server rs12 port 0
real-server rs1
 ip address 7.0.0.2
real-server rs11
 ipv6 address 7::2
real-server rs12
 ipv6 address 7::3
real-server rs2
 ip address 7.0.0.3
virtual-server vs1 type http
 virtual ipv6 address 200::1
 default server-farm sf1
 service enable
virtual-server vs2 type http
 default server-farm sf2
 service enable
userlog flow syslog
Example: Configuring NAT64 load balancing (Layer 4-to-Layer 7)
As shown in Figure 512, enable the LB device to distribute requests from IPv4 address 10.0.0.2 to the HTTP servers with IPv6 addresses 7::2 and 7::3, and distribute requests from IPv6 address 300::2 to the HTTP servers with IPv4 addresses 7.0.0.2 and 7.0.0.3.
Figure 512 Network diagram
Analysis
To implement Layer 4-to-Layer 7 NAT64 load balancing, enable the Layer 7 operation mode for TCP virtual servers on the LB device.
When you configure Layer 4-to-Layer 7 NAT64 load balancing, follow these restrictions and guidelines:
·     Specify SNAT pools for server farms.
·     Enable the Layer 7 operation mode for the TCP virtual servers.
·     Specify a non-zero port number for the TCP virtual servers.
·     This configuration example does not apply to multi-channel protocols, such as FTP.
Procedures
Details not shown.
Figure 513 Creating a health monitoring template
3.     Click OK.
Configuring SNAT pools
Figure 514 Creating an IPv4 SNAT pool
3.     Click OK.
4.     Create SNAT pool snat2 in the same way snat1 is created.
Figure 515 Creating an IPv6 SNAT pool
2.     Click Create to create server farms named sf1 and sf2. Specify SNAT pools snat1 and snat2 for server farms sf1 and sf2, respectively. Specify the scheduling algorithm as Hash source IP address and probe method as t1.
Figure 516 Creating a server farm
3.     Click OK.
Figure 517 Creating server farm sf2
4.     Click OK.
Figure 518 Adding an IPv4 real server
Figure 519 Creating a real server
3.     Click OK.
Figure 520 Server farm information
5.     Click OK.
Figure 521 Adding an IPv6 real server
Figure 522 Creating a real server
8.     Click OK.
Figure 523 Server farm information
10.     Click OK.
2.     Click Create to create virtual servers named vs1 and vs2, specify their IP addresses as 200::1 and 61.159.4.100, and specify server farms sf1 and sf2 for them, respectively. Specify the type as TCP, set the port number to 80, enable the Layer 7 operation mode, and enable the virtual server feature.
Figure 524 Creating virtual server vs1
3.     Click OK.
Figure 525 Creating virtual server vs2
4.     Click OK.
Verify that the host can access the HTTP server through http://61.159.4.100 and http://200::1 successfully, and you can view the virtual server and real server statistics.
Figure 526 LB session information
Configuration files
nqa template icmp icmp
loadbalance snat-pool snat_v6
 ipv6 range start 7::1 end 7::1
loadbalance snat-pool snat_v4
 ip range start 7.0.0.1 end 7.0.0.1
server-farm sf1
snat-pool   snat_v4
 probe icmp
server-farm sf2
 snat-pool   snat_v6
 probe icmp
real-server rs1
 ip address 7.0.0.2
real-server rs11
 ipv6 address 7::2
real-server rs12
 ipv6 address 7::3
real-server rs2
 ip address 7.0.0.3
virtual-server vs_v6 type tcp
 port 80
 service enable
virtual-server vs_v4 type tcp
port 80
 service enable
Example: Configuring NAT64 load balancing for AFT (IPv4-to-IPv6)
As shown in Figure 527, enable the LB device to distribute user requests from IPv4 address 10.0.0.0/24 in a company to the FTP servers with IPv6 addresses 7::2 and 7::3 on the internet.
Figure 527 Network diagram
Analysis
To implement NAT64, complete the following configuration on the LB device:
·     Configure an IPv6-to-IPv4 source address static translation policy to translate the specified destination IPv4 address into an IPv6 address.
·     Configure a NAT64 prefix to translate the matching source IPv4 addresses into IPv6 addresses.
·     Configure an IPv4-to-IPv6 source address dynamic translation policy to translate the source IP addresses matching the NAT64 prefix into IPv6 addresses.
When you configure NAT64 load balancing for AFT (IPv4-to-IPv6), follow these restrictions and guidelines:
·     Enable AFT for associated interfaces.
·     A translation policy can take effect only after you specify a NAT64 prefix or general prefix for it.
·     Enable IP address advertisement for the virtual server.
·     Configure a specific IP address for the virtual server, instead of a network address.
·     Configuration of both LB and AFT is supported only at Layer 4.
Procedures
Details not shown.
Enabling AFT
1.     Navigate to the Network > AFT page.
2.     Select interfaces and enable AFT for them.
Figure 528 Enabling AFT for the interfaces
Figure 529 AFT enabled for the interfaces
Configuring AFT prefix and policy settings
1.     Navigate to the Objects > ACL > IPv4 ACL page.
2.     Click Create to create basic ACL 2000.
Figure 530 Creating an ACL
3.     Click OK to add a rule that permits user requests sourced from network 10.0.0.0/24 to access the Internet.
Figure 531 Adding a rule
4.     Click OK to add another rule that denies user requests sourced from any other IP addresses.
Figure 532 Adding another rule
5.     Click Cancel to complete the configuration.
Figure 533 Completing ACL configuration
Figure 534 ACL rule information
6.     Navigate to the Network > ACL > NAT64 Prefixes page.
7.     Click Create to create NAT64 prefix 2018::, and specify the prefix length as 96.
This prefix will be used in the IPv4-to-IPv6 source address dynamic translation policy to translate matching source IP addresses into IPv6 addresses.
Figure 535 Creating a NAT64 prefix
8.     Click OK.
9.     Execute the following command on the LB device to configure an IPv4-to-IPv6 source address dynamic translation policy to translate source addresses matching ACL 2000 into IPv6 addresses based on the NAT64 prefix. (The configuration is not available on the Web interface.)
[Sysname] aft v4tov6 source acl number 2000 prefix-nat64 2018:: 96
10.     Navigate to the Network > AFT > AFT Policies page.
11.     Click Create to create an IPv6-to-IPv4 source address static translation policy. Specify the translation method as v6tov4, the IPv4 address as 61.232.0.2, and the IPv6 address as 200::1.
Figure 536 IPv6-to-IPv4 source address static translation policy
12.     Click OK.
Configuring a health monitoring template
2.     Click Create to create a template named tcp, and specify the type as TCP.
Figure 537 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create a server farm named sf2. Specify the scheduling algorithm as Hash source IP address and probe method as tcp.
Figure 538 Creating server farm sf2
3.     Click OK.
2.     Edit server farm sf2, and click Add to create a real server. Specify the real server name as rs11 and the IPv6 address as 7::2.
Figure 539 Adding an IPv6 real server
Figure 540 Creating a real server
3.     Click OK.
4.     Create real server rs12 in the same way rs11 is created. Configure the IPv6 address for real server rs12 as 7::3.
Figure 541 Server farm information
5.     Click OK.
2.     Click Create to create a virtual server named vs_v6. Specify the type as TCP and virtual server IP address as 200::1. Specify server farm sf2, enable IP address advertisement, and enable the virtual server feature.
Figure 542 Creating virtual server vs1
Execute the ftp 61.232.0.2 command to verify that the host can access the FTP server successfully. You can view the AFT session statistics on the LB device.
Figure 543 Successful service access
Display AFT session information. You can see that an IPv4 session and an IPv6 session have been created, corresponding to the packets before and after the translation, respectively.
<Sysname>display  aft session ipv4 verbose
Slot 1:
Initiator:
  Source      IP/port: 10.0.0.22/62853
  Destination IP/port: 61.232.0.2/21
  DS-Lite tunnel peer: -
  Protocol: TCP(6)
  Inbound interface: Route-Aggregation1.10
Responder:
  Source      IP/port: 61.232.0.2/21
  Destination IP/port: 10.0.0.22/62853
  Protocol: TCP(6)
  Inbound interface: Route-Aggregation1.20
State: TCP_ESTABLISHED
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2021-09-28 20:52:37  TTL: 3583s
Initiator->Responder:            0 packets          0 bytes
Responder->Initiator:            0 packets          0 bytes
Total sessions found: 1
<Sysname>display  aft session ipv6 verbose
Slot 1:
Initiator:
  Source      IP/port: 2018::A00:16/62853
  Destination IP/port: 200::1/21
  Protocol: TCP(6)
Responder:
  Source      IP/port: 7::2/21
  Destination IP/port: 2018::A00:16/62853
  Protocol: TCP(6)
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2021-09-28 20:52:37  TTL: 3579s
<Sysname>
Configuration files
nqa template tcp tcp
 destination port 21
interface Route-Aggregation1.10
 ip address 10.0.0.1 255.255.255.0
 aft enable
 vlan-type dot1q vid 10
 aft enable
 vlan-type dot1q 20
 ipv6 address 7::1/64
acl basic 2000
 rule 0 permit source 10.0.0.0 0.0.0.255
 rule 5 deny
 aft prefix-nat64 2018:: 96
 aft v6tov4 source 200::1 61.232.0.2
server-farm sf2
 probe tcp
real-server rs11
 ipv6 address 7::2
real-server rs12
 ipv6 address 7::3
 route-advertisement enable
 service enable
Example: Configuring NAT64 load balancing for AFT (IPv6-to-IPv4)
As shown in Figure 544, the Internet has been upgraded to IPv6, but the internal network of the company is still an IPv4 network. The company wants to provide FTP services for users on the Internet, and uses IPv6 address 300::2 to access the Internet.
Figure 544 Network diagram
Analysis
·     Configure an IPv4-to-IPv6 source address static translation policy to map an IPv6 address to the FTP server address in the IPv4 network. The hosts on the Internet can access the FTP server through this IPv6 address. When the LB device receives a packet destined to the IPv6 address, it translates the destination address in the packet to the specified IPv4 address.
·     Configure an IPv6-to-IPv4 source address dynamic translation policy to translate the source addresses of IPv6 packets from the Internet into IPv4 addresses 7.0.0.200 and 7.0.0.201.
When you configure NAT64 load balancing for AFT (IPv6-to-IPv4), follow these restrictions and guidelines:
Procedures
Details not shown.
Enabling AFT
Figure 545 Enabling AFT for the interfaces
Figure 546 AFT enabled for the interfaces
1.     Navigate to the Objects > ACL > IPv6 ACL page.
Figure 547 Creating an ACL
3.     Click OK to add a rule that permits user requests sourced from network 300:: 64.
Figure 548 Adding a rule
4.     Click OK to add another rule that denies user requests sourced from any other IPv6 addresses.
Figure 549 Adding another rule
Figure 550 Completing ACL configuration
Figure 551 ACL rule information
This prefix will be used to translate matching destination IPv6 addresses into an IPv4 addresses.
Figure 552 Creating a NAT64 prefix
8.     Click OK.
9.     Navigate to the Objects > Object Groups > AFT Address Groups page, and click Create to create an AFT address group. Specify the start IP address as 7.0.0.200 and the end IP address as 7.0.0.203.
Figure 553 Configuring an AFT address group
10.     Click OK.
Figure 554 AFT address group information
11.     Navigate to the Network > AFT > AFT Policies page.
12.     Click Create to create an IPv4-to-IPv6 source address dynamic translation policy to translate source addresses matching ACL 2000 into IPv4 addresses based on the NAT64 prefix. Specify translation method NAT64 prefix, ACL 2000 for packet matching, and AFT address group 0.
Figure 555 Creating an AFT policy
13.     Click OK.
1.     Navigate to the Objects > Health Monitoring page.
Figure 556 Creating a health monitoring template
3.     Click OK.
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as tcp.
Figure 557 Creating server farm sf1
3.     Click OK.
Figure 558 Adding a real server
Figure 559 Creating a real server
3.     Click OK.
Figure 560 Server farm information
5.     Click OK.
2.     Click Create to create a virtual server named vs_v4. Specify the type as TCP and virtual server IP address as 61.159.4.100. Specify server farm sf1, enable IP address advertisement, and enable the virtual server feature.
Figure 561 Creating virtual server vs_v4
3.     Click OK.
Execute the ftp ipv6 2018::61.159.4.100 command to verify that the host can access the FTP server successfully. You can view the virtual server, real server, and AFT session statistics on the LB device.
Figure 562 Successful service access
Display AFT session information. You can see that an IPv6 session and an IPv4 session have been created, corresponding to the packets before and after the translation, respectively.
Slot 1:
Initiator:
  Source      IP/port: 300::2/63966
  Destination IP/port: 2018::3D9F:464/21
  Protocol: TCP(6)
Responder:
  Source      IP/port: 2018::3D9F:464/21
  Destination IP/port: 300::2/63966
  Protocol: TCP(6)
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2021-09-29 15:03:55  TTL: 3596s
<Sysname>
Slot 1:
Initiator:
  Source      IP/port: 7.0.0.203/63966
  Destination IP/port: 61.159.4.100/21
  Protocol: TCP(6)
Responder:
  Source      IP/port: 7.0.0.2/21
  Destination IP/port: 7.0.0.203/63966
  Protocol: TCP(6)
Application: FTP
Rule ID: -/-/-
Rule name:
Start time: 2021-09-29 15:03:55  TTL: 3592s
Configuration files
 destination port 21
 aft enable
 ipv6 address 300::1/64
 ip address 7.0.0.1 255.255.255.0
 aft enable
 vlan-type dot1q vid 20
acl ipv6 basic 2000
 rule 0 permit source 300::/64
 rule 5 deny
aft address-group 0
 address 7.0.0.200 7.0.0.203
 aft v6tov4 source acl ipv6 number 2000 address-group 0 no-pat
server-farm sf1
 probe tcp
real-server rs1
 ip address 7.0.0.2
real-server rs2
 ip address 7.0.0.3
 service enable
Connection limit configuration example
As shown in the Figure 563, a host accesses three servers through the LB device. The three servers Server A, Server B, and Server C in the public network can all provide HTTP services. The host traffic will be load-shared among the three servers. To avoid network congestion and resource overconsumption, the LB device must meet the following requirements:
·     Allow a maximum of 200 connections to be established to Server A.
·     Allow each IP address in network 10.0.1.16/28 to initiate a maximum of 10 connections.
·     Distribute packets carrying a specific cookie value to Server A without limiting the number of connections initiated from the associated client.
Figure 563 Network diagram
Analysis
To implement the connection limit feature, complete the following configuration on the LB device:
·     Configure a connection limit policy to allow a maximum of 10 connections from each IP address on a specific network.
·     Configure a sticky group based on cookie insertion and disable the override limits function.
·     Configure a virtual server, and specify a server farm, a sticky group, and a connection limit policy for it.
When you configure the connection limit feature, follow these restrictions and guidelines:
·     Disable the override limits function for the sticky group.
·     For cookie-based session stickiness, the cookie carried by the host must be consistent with that allocated to the real server. You can view the cookies on real servers through a command.
·     In the connection limit rule, select the Source IP address and Destination IP address options for Limit by.
Procedures
Details not shown.
2.     Click Create to create a template named t1, specify the type as HTTP, and set the expected status code to 200.
Figure 564 Creating a health monitoring template
3.     Click OK.
Configuring a server farm
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Round robin and probe method as t1.
Figure 565 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and create a real server. Specify the real server name as rs1, the IP address as 192.168.1.1, and the maximum number of connections as 200.
Figure 566 Adding a real server
Figure 567 Creating a real server
3.     Click OK.
4.     Create real servers rs2 and rs3 in the same way real server rs1 is created. Configure the IPv4 addresses as 192.168.1.2 and 192.168.1.3 for real servers rs2 and rs3, respectively. Do not set the maximum connection limit for rs2 and rs3.
Figure 568 Server farm information
2.     Click Create to create a sticky group named cookie. Set the type to HTTP-cookie, the cookie stickiness to Cookie insertion, and the cookie name to X-LB. Disable the override limits function.
Figure 569 Creating a sticky group cookie
3.     Click OK.
Configuring an advanced ACL
1.     Navigate to the Object > ACL > IPv4 ACL page, and click Create. Specify the type as Advanced ACL and the ACL number as 3001.
Figure 570 Creating an advanced ACL rule 3001
2.     Click OK. On the new IPv4 advanced ACL rule page that opens, add an ACL rule. Select Source IPv4 address/wildcard mask and Destination IPv4 address/wildcard mask for Match criteria. Specify the source IPv4 address/wildcard mask as 10.0.1.16/0.0.0.15, and the destination IPv4 address/wildcard mask as 61.159.4.100/0.0.0.0. Clear the Continue to add next rule option.
Figure 571 Creating a rule for advanced ACL 3001
3.     Click OK.
Configuring a connection limit policy
1.     Navigate to the LB > Application Load Balancing > Advanced Policies > Connection Limit Policy page.
2.     Click Create to add a connection limit policy named lp.
3.     Click Create to add a rule. Specify the type as IPv4 ACL and the ACL number as 3001, select  Source IP address and Destination IP address for Limit by, and enter 10 for the upper and lower limits.
Figure 572 Creating a connection limit policy
Figure 573 Creating a limit rule
Figure 574 Creating a connection limit policy rule
4.     Click OK.
2.     Create a virtual server named vs. Specify the type as HTTP, the IPv4 address as 61.159.4.100, and the port number as 80. Specify server farm sf, server farm sticky group cookie, and connection limit policy lp. Enable the virtual server feature, and then click OK.
Figure 575 Creating a virtual server
3.     Click OK.
Viewing the cookie value of server farm members on the device
Execute the following command to view the cookie value of server farm members on the device (not available on the Web interface).
<Sysname>display sticky virtual-server brief
Slot 1:
Sticky type  Sticky method   Sticky key        Virtual server Real-server/Link
HTTP cookie  Cookie Insert   2.0.74232acd.0    vs             192.168.1.1:0
HTTP cookie  Cookie Insert   2.1.d7ecc40e.0    vs             192.168.1.2:0
HTTP cookie  Cookie Insert   2.2.ac21e602.0    vs             192.168.1.3:0
Clearing virtual server and real server statistics
1.     Clear virtual server and real server statistics for accurate verification result, and then inject traffic for verification.
2.     Navigate to the Monitor > Application Load Balancing > Virtual Servers > Real-time Statistics page. Select virtual server vs, and click Clear to clear virtual server statistics.
Figure 576 Clearing virtual server statistics
3.     Navigate to the Monitor > Application Load Balancing > Real Servers > Real-time Statistics page. Click Clear to clear server farm member statistics.
Figure 577 Clearing server farm statistics
4.     View the detailed statistics of the virtual server and each server farm member by clicking the Details icon on the virtual server statistics page and the server farm member statistics page.
Figure 578 Viewing the detailed virtual server statistics
Figure 579 Viewing the detailed server farm member statistics
Limiting connections on Server A
Initiate 3000 connections to the virtual server from 100 source addresses not matching the connection limit policy.
The statistics shows that the numbers of connections assigned to Sever A, Server B, and Server C are 200, 1400, and 1400, respectively. All service connections are successfully established.
Figure 580 Statistics of real server rs1
Figure 581 Statistics of real server rs2
Figure 582 Statistics of real server rs3
Figure 583 Statistics of the virtual server
Limiting connections initiated from the specified network
Clear the virtual server and server farm member statistics. Then, initiate 3000 connections to the virtual server from 100 source addresses in the network specified in the connection limit policy.
The statistics shows that the numbers of connections assigned to Sever A, Server B, and Server C are 200, 1240, and 1240, respectively. A number of 320 packet are lost.
Figure 584 Statistics of real server rs1
Figure 585 Statistics of real server rs2
Figure 586 Statistics of real server rs3
Figure 587 Statistics of the virtual server
Cookie-based session persistence
Clear the virtual server and member statistics. Then, initiate 3000 connections to the virtual server from 100 source addresses in the network specified in the connection limit policy. The client request carries the cookie configured for Sever A.
The statistics shows that the all the 3000 connections are assigned to Sever A. No connections are assigned to Sever B or Sever C.
Figure 588 Statistics of real server rs1
Figure 589 Statistics of real server rs2
Figure 590 Statistics of real server rs3
Figure 591 Statistics of the virtual server
Configuration files
nqa template http t1
 expect status 200
acl advanced 3001
 rule 0 permit ip source 10.0.1.16 0.0.0.15 destination 61.159.4.100 0
sticky-group cookie type http-cookie
 override-limit enable
 cookie insert
 check all-packet
server-farm sf1
 probe t1
  connection-limit max 200
loadbalance limit-policy lp
 limit 1 acl 3001 per-destination per-source amount 10 10
real-server rs1
 ip address 192.168.1.1
real-server rs2
real-server rs3
virtual-server vs type http
 lb-limit-policy lp
 default server-farm sf1 sticky cookie
 service enable
IPS/AV/WAF-based deep packet inspection configuration example
As shown in Figure 592, the LAN user is connected to the LB device to access the Internet. Enable deep packet inspection for traffic passing through the LB device to identify network attacks and security risks and take relevant actions, protecting the LB device and internal servers.
If the host initiates an IPS/AV/WAF attack, the LB device can identify the attack, logs the event, and take relevant actions (such as drop attack packets) to protect the internal servers.
Figure 592 Network diagram
Analysis
To implement deep packet inspection for the service traffic that passes the LB device, complete the following configuration on the LB device:
·     Install an IPS/AV/WAF license.
·     Upgrade the IPS/AV/WAF signature library to the latest version.
·     Configure the IPS/AV/WAF profile.
·     Specify the IPS/AV/WAF profile for the virtual server.
When you configure IPS/AV/WAF-based deep packet inspection, follow these restrictions and guidelines:
·     Make sure the device is installed with an IPS/AV/WAF license and the signature library is upgraded to the latest version.
·     After modifying content security configuration (through addition, modification, or deletion), you must click Submit to make your modification take effect.
·     Enable system log output for IPS/AV.
·     WAF supports only fast log output. You need to enable fast log output to the log host at the CLI.
Procedures
Applying for a license
Details not shown.
Installing the license
1.     Navigate to the System > license Config page.
2.     Click Install to upload the license file for the specified module.
Figure 593 Installing a license
Figure 594 IPS/AV/WAF license information
Upgrading the signature library
1.     Navigate to the System > Upgrade Center > Signature Upgrade page.
2.     Upgrade the IPS/AV/WAF signature library in sequence. The device supports online upgrade, manual upgrade, and scheduled upgrade.
Figure 595 Upgrading a signature library
Figure 596 Signature library information
You can the upgrade the IPS/AV/WAF signature library through online upgrade or scheduled upgrade only when you can access the official website of the device..
You can download the IPS/AV/WAF signature library file from the official website, and use the downloaded file to perform manual upgrade.
Creating an IPS profile (optional)
1.     Navigate to the LB > App Security > IPS > Profiles page.
2.     Click Create. On the Create IPS Profile page, specify the name as ips, and click OK.
Figure 597 Creating an IPS profile
Creating an anti-virus profile (optional)
1.     Navigate to the LB > App Security > Anti-Virus > Profiles page.
2.     Click Create. On the Create Anti-Virus Profile page, specify the name as av, and click OK.
Figure 598 Creating an anti-virus profile
Creating a WAF profile (optional)
1.     Navigate to the LB > App Security > WAF > Profiles page.
2.     Click Create. On the WAF profile creation page, specify the name as waf, and click OK.
Figure 599 Creating a WAF profile
2.     Click Create to create a template named t1, specify the type as TCP, and set the destination port number to 80.
Figure 600 Creating a health monitoring template
3.     Click OK.
1.     Navigate to the LB > Application Load Balancing > Server Farms page.
2.     Click Create to create a server farm named sf1. Specify the scheduling algorithm as Hash source IP address and probe method as t1.
Figure 601 Creating a server farm
3.     Click OK.
2.     Edit server farm sf1, and create a real server. Specify the real server name as rs1 and the IP address as 192.168.1.1.
Figure 602 Adding a real server
Figure 603 Creating a real server
3.     Click OK.
Figure 604 Server farm information
2.     Click Create to add the virtual server named vs. Specify the type as TCP, set the IPv4 address to 61.159.4.100/32, enable the virtual server feature, and enable the content security function. Specify the WAF profile waf, IPS profile ips, and anti-virus profile av.
Figure 605 Creating a virtual server
3.     Click OK.
4.     After modifying content security configuration, click Submit to make the modification take effect, and complete the virtual server configuration.
Figure 606 Completing virtual server configuration
Enabling IPS/AV/WAF logging
1.     Navigate to the System > Log Settings > Attack Defense Log Settings page, enable System log for both IPS logs and anti-virus logs, and then click Apply.
Figure 607 Enabling system log for IPS logs and anti-virus logs
2.     Navigate to the System > Log Settings > Basic Settings > Fast Log Output page. Create a log host, specify the log host IP address, and enable WAF logs.
Figure 608 Creating a log host
Figure 609 Enabling WAF logs
3.     Navigate to the System > Log Settings > Basic Settings > Storage Space Settings page to enable the dpi | threat service.
Figure 610 Enabling the dpi | threat service
4.     Execute the following command to enable fast log output to the log host for WAF (not available on the Web interface).
[Sysname]customlog format dpi waf
Handling IPS attacks
The host sends a request with the following URL through a browser:
http://61.159.4.100/mytest1/export/show2.php?id=2%20%20AND%203206=CONVERT(INT,(CHAR(58)+CHAR(103)+CHAR(115)+CHAR(99)+CHAR(58)+(SELECT%20SUBSTRING((ISNULL(CAST(*%20form%20pangolin_test_table;--%20AS%20NVARCHAR(4000)),CHAR(32))),1,100))+CHAR(58)+CHAR(112)+CHAR(120)+CHAR(117)+CHAR(58)))
The device can detect the attack traffic, intercept the attack, and generate a threat log.
To view the threat log, navigate to the Monitor > Device Logs > Traffic Logs page. Click the Details icon to view the detailed information about the log.
Figure 611 Viewing the threat log
Figure 612 IPS threat log details
Handling AV attacks
Attack the host, transfer the virus test sample through HTTP to the LB device, and observe the detection result.
Figure 613 Viewing the threat log
Figure 614 AV threat log details
Handling WAF attacks
http://61.159.4.100/x.php?id%20=123456%27%3Cscript%3Ealert(%27xss%27)%3C/script%3E
You can view the threat log on the log server.
Sep 29 17:48:41 2021 Sysname %%10 VsysId:1 WAF/4/WAF_IPV4_INTERZONE: Protocol(1001)=TCP; Application(1002)=http; SrcIPAddr(1003)=10.0.0.2; SrcPort(1004)=51300; DstIPAddr(1007)=61.159.4.100; DstPort(1008)=80; RcvVPNInstance(1042)=; SrcZoneName(1025)=--; DstZoneName(1035)=--; UserName(1113)=10.0.0.2; PolicyName(1079)=waf; AttackName(1088)=Generic_Cross_Site_Scripting_Attempt_Base_On_Message_Dialogs(HttpURI); AttackID(1089)=24485; Category(1090)=Vulnerability; Protection(1091)=WebApplication; SubProtection(1092)=Any; Severity(1087)=MEDIUM; Action(1053)=Reset & Logging; CVE(1075)=--; BID(1076)=--; MSB(1077)=--; HitDirection(1115)=original; RealSrcIP(1100)=; SubCategory(1124)=XSS; CapturePktName(1116)=; SrcMacAddr(1021)=000c-294d-297a; DstMacAddr(1022)=0c3a-fa8c-cce8; HttpHost(1117)= 61.159.4.100; HttpUserAgent(1210)= Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; WOW64; Trident/4.0; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR; URL(1093)= 61.159.4.100/x.php?id%20=123456%27%3Cscript%3Ealert(%2
Configuration files
nqa template tcp t1
 destination port 80
 customlog host 188.100.0.112 export dpi waf
app-profile vs1632905761_vs
 ips apply policy ips mode protect
 anti-virus apply policy av mode protect
 waf apply policy waf mode protect
inspect logging parameter-profile av_logging_default_parameter
inspect logging parameter-profile ips_logging_default_parameter
server-farm sf1
 probe t1
real-server rs1
real-server rs2
real-server rs3
 dpi-app-profile vs1632905761_vs
 service enable
waf policy waf
dac log-collect service dpi threat enable
ips policy ips
 status enabled
ips logging parameter-profile ips_logging_default_parameter
anti-virus policy av
anti-virus logging parameter-profile av_logging_default_parameter
