| 01-About the configuration examples | 21.33 KB |
About the H3C SecPath LB Products Comware 7 Configuration Examples
The following matrix shows the hardware and software versions to which this configuration example set is applicable:
Model |
Software version |
L5000-E/L5030/L5060/L5080 |
R8560 |
L1030/L1050/L1070/L1090 |
R1160 |
CAUTION: Support for the features in the configuration examples depends on the device model. For feature support information of your device, see the configuration guide and command reference for the device. |
This document set includes the following documents:
· Application Load Balancing Configuration Examples
· Multi-Service Egress Gateway Configuration Examples
· Link Load Balancing Configuration Examples
