- 14-WLAN Configuration Guide (AC)
- 01-Compatibility of hardware and AC functionality
- 02-AP management configuration
- 03-Radio management configuration
- 04-WLAN access configuration
- 05-WLAN security configuration
- 06-WLAN authentication configuration
- 07-WIPS configuration
- 08-WLAN QoS configuration
- 09-WLAN roaming configuration
- 10-WLAN load balancing configuration
- 11-WLAN radio resource measurement configuration
- 12-Channel scanning configuration
- 13-Band navigation configuration
- 14-WLAN multicast optimization configuration
- 15-WLAN RRM configuration
- 16-WLAN IP snooping configuration
- 17-WLAN probe configuration
- 18-Spectrum management configuration
| 01-Compatibility of hardware and AC functionality | 38.15 KB |
This document describes MSR routers that can function as ACs and compatible APs.
MSR routers |
Compatible APs |
MSR810-W MSR810-W-DB MSR810-LM MSR810-LM-HK MSR810-LM-CNDE-SJK MSR810-W-LM MSR810-W-LM-HK MSR810-LME MSR2600-6-X1 MSR2600-10-X1 MSR2600-15-X1 MSR26-30 MSR3600-28 MSR3600-28-X1 MSR3600-28-X1-DP MSR3600-51 MSR3600-51-X1 MSR3600-51-X1-DP MSR36-10 MSR3610-X1-DP MSR3610-X1-DC MSR3610-X1-DP-DC MSR36-20 MSR36-40 MSR36-60 MSR3620-X1 MSR3640-X1 MSR3640-X1-HI |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA4320H WA4320H-EI WA5320 WA5320H WA5320E WA5320i WA5320-SI WA5530 WA5530-SI WA5620 WA5620i-CAN SIC-AP320 (supported only on the MSR2600-6-X1, MSR3610-X1-DP, MSR3610-X1-DC, MSR3610-X1-DP-DC, MSR3620-X1, and MSR3640-X1) WA6320-FIT WA6320H-FIT WA6322-FIT WA6322H-FIT WA6330-FIT WA6338-FIT WA6528-FIT WA6620-FIT WA6622-FIT WA6628-FIT WA6638-FIT |
MSR1004S-5G |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-SI WA4320-ACN-B WA5320E-WiNet WA5320-WiNet WA2620-WiNet WA2620E-WiNet WA4320H-ACN-HI WA4320H WA4320H-EI WA5320H WA5320 WA5320E WA5530 WA5620i-ACN WA5620 WA560-WW WA536-WW WA538-WW WA530-WW WA530X-WW WA510H-WW WA5320i WA5530-SI WA5320-SI WA560-WW-FIT WA538-WW-FIT WA536-WW-FIT WA530-WW-FIT WA530X-WW-FIT WA510H-WW-FIT WA5320H-WiNet |
MSR810-W-WiNet MSR810-LM-WiNet MSR830-4LM-WiNet MSR830-5BEI-WiNet MSR830-6EI-WiNet MSR830-10BEI-WiNet MSR830-10PBEI-WiNet MSR830-6BHI-WiNet MSR830-10BHI-WiNet MSR2600-10-X1-WiNet MSR2630-WiNet MSR3600-28-WiNet MSR3610-WiNet MSR3610-X1-WiNet MSR3620-WiNet MSR3620-DP-WiNet MSR3660-WiNet |
WA4320i-ACN WA4320H-ACN WA4320-ACN WA4320X WA4330-ACN WA4320-ACN-B WA4320H-ACN-HI WA4320-ACN-SI WA2620-WiNet WA2620E-WiNet WA4320H WA4320H-EI WA5320H WA5320 WA5320E WA5320-WiNet WA5320E-WiNet WA5530 WA5620i-ACN WA5620 |
MSR2630-XS MSR3600-28-XS MSR3610-XS MSR3610-I-XS MSR3610-IE-XS MSR3620-XS MSR860-6EI-XS MSR860-6HI-XS MSR3620-X1-XS MSR3640-XS MSR3660-XS |
WA2610H WA2610H-LI WA4320H-SI WA4320-ACN-E WA4320-ACN-D WA4320-ACN-C WA4320i-X WA4320H WA5320H-LI WA5320-D WA5320-C WA5320-C-IOT WA5320 WA5320i-LI WA5320H WA5320-C-EI WA5320X-E WA5320X-SI WA5320X WA5320X-LI WA5530S WA5530-LI WA5530 SIC-AP320 (supported only on the MSR2630-XS, MSR3610-XS, MSR3610-I-XS, MSR3610-IE-XS, MSR3620-X1-XS, and MSR3640-XS) WA6320-C-FIT WA6320-D-FIT WA6330-LI-FIT WA6320H-LI-FIT |
MSR810-LM-GL MSR810-W-LM-GL MSR830-6EI-GL MSR830-10EI-GL MSR830-6HI-GL MSR830-10HI-GL MSR2600-6-X1-GL |
WA510H-WW WA530-WW WA530X-WW WA536-WW WA538-WW WA560-WW |
MSR1004S-5G-GL |
