- 10-MPLS Configuration Guide
 - 01-Basic MPLS configuration
 - 02-Static LSP configuration
 - 03-LDP configuration
 - 04-MPLS TE configuration
 - 05-Static CRLSP configuration
 - 06-RSVP configuration
 - 07-Tunnel policy configuration
 - 08-MPLS L3VPN configuration
 - 09-MPLS L2VPN configuration
 - 10-VPLS configuration
 - 11-L2VPN access to L3VPN or IP backbone configuration
 - 12-MPLS OAM configuration
 - 13-MPLS protection switching configuration
 - 14-MCE configuration
| 00-Preface | 100.17 KB |
Preface
This configuration guide describes the basic and extended MPLS features, including basic MPLS, MPLS TE, and MPLS L2VPN and L3VPN.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
    Convention  |
    Description  |
   Boldface  |
   Bold text represents commands and keywords that you enter literally as shown.  |
   Italic  |
   Italic text represents arguments that you replace with actual values.  |
   Square brackets enclose syntax choices (keywords or arguments) that are optional.  |
   { x | y | ... }  |
   Braces enclose a set of required syntax choices separated by vertical bars, from which you select one.  |
   [ x | y | ... ]  |
   Square brackets enclose a set of optional syntax choices separated by vertical bars, from which you select one or none.  |
   { x | y | ... } *  |
   Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select a minimum of one.  |
   [ x | y | ... ] *  |
   Asterisk marked square brackets enclose optional syntax choices separated by vertical bars, from which you select one choice, multiple choices, or none.  |
   &<1-n>  |
   The argument or keyword and argument combination before the ampersand (&) sign can be entered 1 to n times.  |
   A line that starts with a pound (#) sign is comments.  |
GUI conventions
    Convention  |
    Description  |
   Boldface  |
   Window names, button names, field names, and menu items are in Boldface. For example, the New User window opens; click OK.  |
   Multi-level menus are separated by angle brackets. For example, File > Create > Folder.  |
Symbols
    Convention  |
    Description  |
   An alert that calls attention to important information that if not understood or followed can result in personal injury.  |
   An alert that calls attention to important information that if not understood or followed can result in data loss, data corruption, or damage to hardware or software.  |
   An alert that calls attention to essential information.  |
   NOTE:  |
   An alert that contains additional or supplementary information.  |
   An alert that provides helpful information.  |
Network topology icons
    Convention  |
    Description  |
   Represents a generic network device, such as a router, switch, or firewall.  |
   Represents a routing-capable device, such as a router or Layer 3 switch.  |
   Represents a generic switch, such as a Layer 2 or Layer 3 switch, or a router that supports Layer 2 forwarding and other Layer 2 features.  |
   Represents an access controller, a unified wired-WLAN module, or the access controller engine on a unified wired-WLAN switch.  |
   Represents an access point.  |
   Represents a wireless terminator unit.  |
   Represents a wireless terminator.  |
   Represents a mesh access point.  |
   Represents omnidirectional signals.  |
   Represents directional signals.  |
   Represents a security product, such as a firewall, UTM, multiservice security gateway, or load balancing device.  |
   Represents a security module, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG module.  |
Documentation feedback
We appreciate your comments.
