00-Preface | 100.66 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for ACL and QoS features, including traffic classification, traffic policing, traffic shaping, QoS policy, congestion management, congestion avoidance, priority mapping, and MPLS QoS.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
