| 03-SRv6 TE policy commands | 286.45 KB |
display bgp routing-table ipv6 sr-policy
display segment-routing ipv6 te bfd
display segment-routing ipv6 te forwarding
display segment-routing ipv6 te policy
display segment-routing ipv6 te policy last-down-reason
display segment-routing ipv6 te policy statistics
display segment-routing ipv6 te policy status
display segment-routing ipv6 te policy-group
display segment-routing ipv6 te sbfd
display segment-routing ipv6 te segment-list
reset segment-routing ipv6 te forwarding statistics
srv6-policy backup hot-standby enable
srv6-policy forwarding statistics enable
srv6-policy forwarding statistics interval
srv6-policy switch-delay delete-delay
address-family ipv6 sr-policy
Use address-family ipv6 sr-policy to create the BGP IPv6 SR policy address family and enter its view, or enter the view of the existing BGP IPv6 SR policy address family.
Use undo address-family ipv6 sr-policy to delete the BGP IPv6 SR policy address family and all the configuration in the BGP IPv6 SR policy address family.
The BGP IPv6 SR policy address family does not exist.
BGP instance view
The configuration in BGP IPv6 SR policy address family view applies only to routes and peers in the BGP IPv6 SR policy address family.
# In BGP instance view, create the BGP IPv6 SR policy address family and enter its view.
[Sysname] bgp 100
[Sysname-bgp-default] address-family ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6]
advertise ebgp enable
Use advertise ebgp enable to enable advertising BGP IPv6 SR policy routes to EBGP peers.
Use undo advertise ebgp enable to restore the default.
BGP IPv6 SR policy routes are not advertised to EBGP peers.
By default, BGP IPv6 SR policy routes are advertised among IBGP peers. To advertise BGP IPv6 SR policy routes to EBGP peers, you must execute this command to enable the advertisement capability.
# Enable advertising SRv6 TE policy routes to EBGP peers.
[Sysname] bgp 100
[Sysname-bgp-default] address ipv6 sr-policy
[Sysname-bgp-default-srpolicy-ipv6] advertise ebgp enable
backup hot-standby
Use backup hot-standby to configure hot standby for an SRv6 TE policy.
Use undo backup hot-standby to restore the default.
backup hot-standby { disable | enable }
Hot standby is not configured for an SRv6 TE policy.
SRv6 TE policy view
disable: Disables hot standby for the SRv6 TE policy.
enable: Enables hot standby for the SRv6 TE policy.
The hot standby feature takes the candidate path with the greatest preference value in the SRv6 TE policy as the primary path and that with the second greatest preference value as the standby path. When the forwarding paths corresponding to all SID lists of the primary path fails, the standby path immediately takes over to minimize service interruption.
You can enable hot standby for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable hot standby for SRv6 TE policy 1.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] policy 1
[Sysname-srv6-te-policy-1] backup hot-standby enable
bestroute encap-type
Use bestroute encap-type to specify the packet encapsulation type preferred in optimal route selection.
Use undo bestroute encap-type to restore the default.
bestroute encap-type { mpls | srv6 }
The device does not select optimal routes according to the packet encapsulation type.
BGP-VPN instance view.
mpls: Prefers to use MPLS-encapsulated routes during optimal route selection.
srv6: Prefers to use SRv6-encapsulated routes during optimal route selection.
After this command is executed, BGP selects the optimal route in the VPN instance by using the following procedure:
1. Selects the route according to the NEXT_HOP, Preferred-value, and LOCAL_PREF attributes in turn.
2. Selects the route according to the encapsulation type specified by the bestroute encap-type command.
3. Proceeds the subsequent steps in the original BGP route select procedure.
For more information about BGP route selection, see BGP overview in Layer 3—IP Routing Configuration Guide.
# Configure BGP to prefer SRv6-encapsulated routes during optimal route selection.
[Sysname] bgp 100
[Sysname-bgp-default-vpn1] bestroute encap-type srv6
bfd echo
Use bfd echo to configure the echo packet mode BFD for an SRv6 TE policy.
Use undo bfd echo to restore the default.
bfd echo { disable | enable [ source-ipv6 ipv6-address ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] }
undo bfd echo
The echo packet mode BFD is not configured for an SRv6 TE policy. An SRv6 TE policy uses the echo BFD settings configured in SRv6 TE view.
SRv6 TE policy view
disable: Disables the echo packet mode BFD for the SRv6 TE policy.
enable: Enables the echo packet mode BFD for the SRv6 TE policy.
source-ipv6 ipv6-address: Specifies the source IPv6 address of the BFD session. If you do not specify this option, the configuration in SRv6 TE view applies.
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the template specified in SRv6 TE view applies.
backup-template backup-template-name e: Specifies a BFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the backup template specified in SRv6 TE view applies.
oam-sid sid: Adds an OAM SID to BFD packets to identify the destination node. The sid argument represents the SRv6 SID of the destination node. If you do not specify this option, no OAM SID will be added to BFD packets. At present, the OAM SID must be set to the End.OP SID of the destination node.
You can configure the echo packet mode BFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The device supports the echo packet mode BFD and the SBFD for an SRv6 TE policy. If both modes are configured for the same SRv6 TE policy, the SBFD takes effect.
# Enable the echo packet mode BFD for SRv6 TE policy 1, and specify the source IPv6 address of the BFD session as 11::11.
[Sysname-srv6-te-policy-1] bfd echo enable source-ipv6 11::11
srv6-policy bfd echo
binding-sid
Use binding-sid to configure a BSID for an SRv6 TE policy.
Use undo binding-sid to delete the BSID.
binding-sid ipv6 ipv6-address
undo binding-sid
No BSID is configured for an SRv6 TE policy.
SRv6 TE policy view
ipv6 ipv6-address: Specifies the BSID value, which is an IPv6 address.
You can use this command to manually configure a BSID for an SRv6 TE policy or leave the SRv6 TE policy to obtain a BSID automatically. If an SRv6 TE policy has only color and endpoint configuration, the SRv6 TE policy will automatically request a BSID.
The manually configured BSID has a higher priority over the automatically obtained BSID.
The BSID configured by this command must be on the locator specified for SRv6 TE policies in SRv6 TE view. Otherwise, the SRv6 TE policy cannot forward packets.
# Set the BSID of SRv6 TE policy srv6policy to 1000::1.
[Sysname-segment-routing-ipv6] traffic engineering
[Sysname-srv6-te] policy srv6policy
[Sysname-srv6-te-policy-srv6policy] binding-sid ipv6 1000::1
candidate-paths
Use candidate-paths to create and enter the candidate path view for an SRv6 TE policy, or enter the existing SRv6 TE policy candidate path view.
Use undo candidate-paths to delete the SRv6 TE policy candidate path view and all the configurations in the view.
candidate-paths
The candidate path view for an SRv6 TE policy does not exist.
SRv6 TE policy view
# Create the SRv6 TE policy candidate paths instance and enter its view.
[Sysname-srv6-te-policy-srv6policy] candidate-paths
[Sysname-srv6-te-policy-srv6policy-path]
color end-point
Use color end-point to configure the color and endpoint attributes of an SRv6 TE policy.
Use undo color to delete the color and endpoint settings of an SRv6 TE policy.
color color-value end-point ipv6 ipv6-address
undo color
The color and endpoint attributes of an SRv6 TE policy are not configured.
SRv6 TE policy view
color-value: Specifies the color attribute value, in the range of 0 to 4294967295.
Ipv6-address: Specifies the endpoint IPv6 address.
Different SRv6 TE policies cannot have the same color or endpoint IP address.
# Configure the color as 20 and endpoint IPv6 address as 1000::1 for SRv6 TE policy srv6policy.
[Sysname-srv6-te-policy-srv6policy] color 20 end-point ipv6 1000::1
color match dscp
Use color match dscp to create color-to-DSCP mappings for an SRv6 TE policy group.
Use undo color match dscp to delete color-to-DSCP mappings for the SRv6 TE policy group.
color color-value match dscp { ipv4 | ipv6 } dscp-value-list
undo color color-value match dscp { ipv4 | ipv6 } dscp-value-list
color color-value match dscp { ipv4 | ipv6 } default
undo color color-value match dscp { ipv4 | ipv6 } [ default ]
No color-to-DSCP mappings are created for an SRv6 TE policy group.
SRv6 TE policy group view
color-value: Specifies the color attribute value of an SRv6 TE policy, in the range of 0 to 4294967295.
ipv4: Specifies DSCP values of IPv4 packets.
ipv6: Specifies DSCP values of IPv6 packets.
dscp-value-list: Specifies a space-separated list of up to 32 DSCP value items. Each item specifies a DSCP value in the range of 0 to 63 or a range of DSCP values in the form of dscp-value1 to dscp-value2. The value for the dscp-value2 argument must be greater than or equal to the value for the dscp-value1 argument.
default: Configures a default color-to-DSCP mapping. Packets that do not match any mappings are steered to the default SRv6 TE policy (the policy specified in the default mapping).
You can map the color values of only valid SRv6 TE policies to DSCP values.
You can configure color-to-DSCP mappings separately for the IPv4 address family and IPv6 address family. For a specific address family, a DSCP value can be mapped to only one color value.
Use the color match dscp default command to specify the default SRv6 TE policy for an address family. If no SRv6 TE policy in an SRv6 TE policy group matches a specific DSCP value, the default SRv6 TE policy is used to forward packets containing the DSCP value. Only one default SRv6 TE policy can be specified for an address family.
When the device receives an IPv4 or IPv6 packet that does not match any color-to-DSCP mapping, the device selects a valid SRv6 TE policy for the packet in the following order:
1. The default SRv6 TE policy specified for the same address family as the packet.
2. The default SRv6 TE policy specified for the other address family.
3. The SRv6 TE policy mapped to the smallest DSCP value in the same address family as the packet.
4. The SRv6 TE policy mapped to the smallest DSCP value in the other address family.
# In SRv6 TE policy group 10, map DSCP value 30 to color value 20 for IPv4 packets, so that IPv4 packets with a matching DSCP value are steered to the associated SRv6 TE policy.
[Sysname-srv6-te] policy-group 10
[Sysname-srv6-te-policy-group-10] color 20 match dscp ipv4 30
Use display bgp routing-table ipv6 sr-policy to display route information of a BGP SRv6 TE policy.
display bgp [ instance instance-name ] routing-table ipv6 sr-policy [ sr-policy-prefix [ advertise-info ] | { color color-value | end-point ipv6 ipv6-address } * | peer ipv6-address { advertised-routes | received-routes } [ statistics ] | statistics ]
instance instance-name: Specifies a BGP instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a BGP instance, this command displays information about the default instance.
sr-policy-prefix: Specifies a BGP IPv6 SR policy route prefix, which is a case-insensitive string of 1 to 512 characters in the format of BGP IPv6 SR policy route/prefix length.
color color-value: Specifies the color attribute value of a BGP IPv6 SR policy route, in the range of 1 to 4294967295.
end-point ipv6 ipv6-address: Specifies the end-point IPv6 address of a BGP IPv6 SR policy route.
advertise-info: Displays advertisement information about BGP IPv6 SR policy routes.
peer ipv6-address: Specifies a peer by its IPv6 address.
advertised-routes: Displays detailed information about the BGP IPv6 SR policy routes advertised to the specified peer.
received-routes: Displays detailed information about the BGP IPv6 SR policy routes received from the specified peer.
statistics: Displays route statistics.
If you do not specify any parameters, this command displays brief information about all BGP IPv6 SR policy routes.
# Display brief information about all BGP IPv6 SR policy routes.
<Sysname> display bgp routing-table ipv6 sr-policy
Total number of routes: 1
Status codes: * - valid, > - best, d - dampened, h - history
a – additional-path
>i Network : [46][46][8::8]/192
NextHop : 1::2 LocPrf : 100
PrefVal : 0 MED : 0
Path/Ogn: i
Status codes |
Status codes of the route. |
Origin |
Origin of the route: · i – IGP—Originated in the AS. · e – EGP—Learned through an EGP. · ? – incomplete—Unknown origin. |
Network |
BGP IPv6 SR policy route, comprised of the following elements: · SRv6 TE policy candidate path preference. · SRv6 TE policy color attribute value. · Endpoint IPv6 address. |
NextHop |
Next hop IP address. |
LocPrf |
Local preference value. |
PrefVal |
Preferred value of the route. |
MED |
Multi-Exit Discriminator attribute value. |
Path/Ogn |
AS_PATH and ORIGIN attributes of the route: · AS_PATH—Records the ASs the route has passed. · ORIGIN—Identifies the origin of the route. |
# Display detailed information about BGP IPv6 SR policy route [46][46][8::8]/192.
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192
BGP local router ID: 5.5.5.1
Local AS number: 100
Paths: 1 available, 1 best
BGP routing table information of [46][46][8::8]/192
Imported route.
Original nexthop: ::
Output interface: NULL0
Route age : 19h45m02s
OutLabel : NULL
RxPathID : 0x0
TxPathID : 0x0
AS-path : (null)
Origin : igp
Attribute value : MED 0, localpref 100, pref-val 32768
State : valid, local, best
IP precedence : N/A
QoS local ID : N/A
Traffic index : N/A
Tunnel encapsulation info:
Type: 15 (SR policy)
Policy name: p1
Binding SID: 2::6
Preference: 100
Path: 1
Weight: 1
SIDs: {2::2}
Paths |
Route information: · available—Number of valid routes. · best—Number of optimal routes. |
BGP routing table information of [46][46][8::8]/192 |
Information of the BGP IPv6 SR policy route [46][46][8::8]/192, where: · [46] is the SRv6 TE policy candidate path preference · [46] is the SRv6 TE policy color attribute value. · [8::8] is the endpoint IPv6 address. |
From |
IP address of the BGP peer that advertised the route. |
Rely Nexthop |
Recursive nexthop IP address. If no next hop is found by route recursion, this field displays not resolved. |
Original nexthop |
Original nexthop IP address. If the route was obtained from a BGP update message, the original next hop is the nexthop IP address in the message. |
Route age |
Time elapsed since the last update for the route. |
OutLabel |
Outgoing label of the route. |
RxPathID |
Received Add-Path ID of the route. |
TxPathID |
Advertised Add-Path ID of the route. |
AS-path |
AS_PATH attribute of the route. |
Origin |
Origin of the route: · igp—Originated in the AS. · egp—Learned through an EGP. · incomplete—Unknown origin. |
Attribute value |
BGP path attributes: · MED—MED value. · localpref—Local preference value. · pref-val—Preferred value. · pre—Protocol preference. |
State |
Current state of the route. Options include: · valid—Valid route. · internal—Internal route. · external—External route. · local—Locally generated route. · synchronize—Synchronized route. · best—Optimal route. · delay—Delayed route. The route will be delayed for optimal route selection. This value is available only in detailed information of the route. · not preferred for reason—Reason why the route is not selected as the optimal route. For more information, see Table 3. |
IP precedence |
IP precedence of the route, in the range of 0 to 7. N/A indicates that the route does not support this field. |
QoS local ID |
QoS local ID of the route, in the range of 1 to 4095. N/A indicates that the route does not support this field. |
Traffic index |
Traffic index in the range of 1 to 64. N/A indicates that the route does not support this field. |
Type: 15 (SR Policy) |
The tunnel encryption type is 15, which represents SR policy. |
Preference |
Candidate path preference. |
Binding SID |
BSID value of the SRv6 TE policy. |
Path |
Candidate path. |
Weight |
Weight of the SID list. |
SIDs |
List of SIDs. A G-SID is displayed in the format of {sid-value, coc32, prefix-length}, where sid-value is the SID value and prefix-length is the common prefix length. |
Table 3 Reason why the route is not selected as the optimal route
Reason |
preferred-value |
Routes with larger preferred values exist. |
local-preference |
Routes with larger local preference values exist. |
as-path |
Routes with smaller AS_PATH attribute values exist. |
origin |
There are routes whose origin has a higher priority. The route origins are IGP, EGP, and INCOMPLETE in descending order of priority. |
med |
Routes with smaller MED values exist. |
remote-route |
There are routes whose remote-route attribute has a higher priority. BGP selects the optimal route from remote routes in this order: · Route learned from an EBGP peer. · Route learned from a confederation EBGP peer. · Route learned from a confederation IBGP peer. · Route learned from an IBGP peer. |
igp-cost |
Routes with smaller IGP metrics exist. |
relydepth |
Routes with smaller recursion depth values exist. |
rfc5004 |
A route received from an EBGP peer is the current optimal route. BGP does not change the optimal route when it receives routes from other EBGP peers. |
router-id |
Routes with smaller router IDs exist. If one of the routes is advertised by a route reflector, BGP compares the ORIGINATOR_ID of the route with the router IDs of other routes. Then, BGP selects the route with the smallest ID as the optimal route. |
cluster-list |
Routes with smaller CLUSTER_LIST attribute values exist. |
peer-address |
Routes advertised by peers with lower IP addresses exist. |
received |
Earlier learned routes exist. |
# Displays advertisement information about the BGP IPv6 SR policy route [46][46][8::8]/192.
<Sysname> display bgp routing-table ipv6 sr-policy [46][46][8::8]/192 advertise-info
BGP local router ID: 2.2.2.2
Local AS number: 1
Paths: 1 best
BGP routing table information of [46][46][8::8]/192(TxPathID:0):
Advertised to peers (2 in total):
1::1
3::3
Paths |
Number of optimal paths to reach the destination network. |
BGP routing table information of [46][46][8::8]/192(TxPathID:0) |
Advertisement information about the BGP IPv6 SR policy route [46][46][8::8]/192. TxPathID represents the advertised Add-Path ID of the route. |
Advertised to peers (2 in total) |
Indicates the peers to which the route has been advertised. The number in the parentheses indicates the total number of the peers. |
# Display statistics about the BGP IPv6 SR policy routes advertised to peer 2::2.
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 advertised-routes statistics
Advertised routes total: 2
# Display statistics about the BGP IPv6 SR policy routes received from peer 2::2.
<Sysname> display bgp routing-table ipv6 sr-policy peer 2::2 received-routes statistics
Received routes total: 1
Table 5 Command output
Advertised routes total |
Total number of routes advertised to the specified peer. |
Received routes total |
Total number of routes received from the specified peer. |
# Display statistics about BGP IPv6 SR policy routes.
<Sysname> display bgp routing-table ipv6 sr-policy statistics
Total number of routes: 3
Use display segment-routing ipv6 te bfd to display BFD information for SRv6 TE policies.
display segment-routing ipv6 te bfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down: Displays BFD information for SRv6 TE policies in down state.
policy: Displays BFD information for the specified SRv6 TE policy.
color color-value: Specifies the color attribute value of an SRv6 TE policy, in the range of 0 to 4294967295.
end-point ipv6 ipv6-address: Specifies the IPv6 address of the endpoint of an SRv6 TE policy.
name policy-name: Specifies the name of an SRv6 TE policy, a case-sensitive string of 1 to 59 characters.
up: Displays BFD information for SRv6 TE policies in up state.
If you do not specify any parameters, this command displays BFD information for all SRv6 TE policies.
# Display BFD information for all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy bfd
Color: 10
Endpoint: 4::4
Policy name: p1
State: Up
Nid: 2149580801
BFD type: ECHO
Source IPv6: 1::1
State: Up
Timer: 37
VPN index: 1
Template name: abc
Table 6 Command output
Color |
Color attribute value of an SRv6 TE policy. |
Endpoint |
Endpoint IP address of the SRv6 TE policy. |
Policy name |
Name of the SRv6 TE policy. |
State |
SBFD session state: · Up · Down · Delete |
Nid |
Forwarding entry index for an SID list. |
BFD type |
The current software version supports only the BFD echo mode. |
Source IPv6 |
Source IPv6 address of the BFD session. |
Timer |
BFD session timer, in seconds. |
VPN index |
Index of the VPN instance. |
Template name |
Name of the echo mode BFD template. |
Use display segment-routing ipv6 te forwarding to display SRv6 TE forwarding information.
display segment-routing ipv6 te forwarding [ policy { name policy-name | { color color-value | end-point ipv6 ipv6-address } * } ] [ verbose ]
policy: Displays forwarding information of the specified SRv6 TE policy. If you do not specify an SRv6 TE policy, this command displays forwarding information of all SRv6 TE policies.
color color-value: Specifies the color of an SRv6 TE policy, in the range of 0 to 4294967295.
end-point ipv6 ip-address: Specifies the endpoint IPv6 address of an SRv6 TE policy.
verbose: Displays detailed SRv6 TE forwarding information. If you do not specify this keyword, the command displays brief SRv6 TE forwarding information.
# Display brief information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te forwarding
Total forwarding entries: 1
Policy name/ID: p1/0
Binding SID: 8000::1
Forwarding index: 2150629377
Main path:
Seglist ID: 1
Seglist forwarding index: 2149580801
Weight: 1
Outgoing forwarding index: 2148532225
Interface: GE1/0
Nexthop: FE80::6CCE:CBFF:FE91:206
Backup path:
Seglist ID: 2
Seglist forwarding index: 2149580802
Weight: 1
Outgoing forwarding index: 2148532226
Interface: GE2/0
Nexthop: FE80::6CCE:CBFF:FE91:207
# Display detailed information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te forwarding verbose
Inbound statistics:
Total octets: 525
Total packets: 1
Erroneous packets: 0
Dropped packets: 0
Input rate in last 300 seconds:
0 bits/sec, 0 pkts/sec
Input rate in last statistical period (20 sec):
Outbound statistics:
Total octets: 750
Total packets: 1
Dropped packets: 0
Output rate in last 300 seconds:
Output rate in last statistical period (20 sec):
Main path:
Seglist ID: 1
Weight: 1
Total octets: 750
Total packets: 1
Dropped packets: 0
Output service-class 4:
416 octets, 4 packets,
0 errors, 0 dropped packets
Interface: GE1/0
Path ID: 1
SID list: {44::44, 45::45}
Total octets: 750
Total packets: 1
Dropped packets: 0
Backup path:
Seglist ID: 2
Weight: 1
Interface: GE2/0
Path ID: 2
SID list: {44::44, 45::47}
Table 7 Command output
Total forwarding entries |
Total number of SRv6 TE forwarding entries. |
Policy name/ID |
Name/ID of an SRv6 TE policy. |
Binding SID |
SID value of the ingress node. |
Forwarding index |
Index of the SRv6 TE policy forwarding entry. |
Inbound statistics |
Statistics on inbound traffic (the traffic received by the BSID). |
Total octets |
Total number of octets forwarded. |
Total packets |
Total number of packets forwarded. |
Erroneous packets |
Number of erroneous packets. |
Dropped packets |
Number of dropped packets. |
Input rate in last 300 seconds: 0 bits/sec, 0 pkts/sec |
Inbound traffic rate (in bits/second and packets/second) in the most recent 300 seconds. |
Input rate in last statistical period (20 sec): 0 bits/sec, 0 pkts/sec |
Inbound traffic rate (in bits/second and packets/second) in the most recent statistical interval. To set the statistical interval, use the srv6-policy forwarding statistics interval command. |
Outbound statistics |
Statistics on outbound traffic. |
Output rate in last 300 seconds: 0 bits/sec, 0 pkts/sec |
Outbound traffic rate (in bits/second and packets/second) in the most recent 300 seconds. |
Output rate in last statistical period (20 sec): 0 bits/sec, 0 pkts/sec |
Outbound traffic rate (in bits/second and packets/second) in the most recent statistical interval. To set the statistical interval, use the srv6-policy forwarding statistics interval command. |
Output service-class |
Outbound traffic statistics for the specified service class. A value of 255 means no service class is configured for the SRv6 TE policy. The SRv6 TE policy has the lowest forwarding priority. |
Main path |
Main path for traffic forwarding. |
Backup path |
Backup path for traffic forwarding. |
Seglist ID |
ID of the SID list. |
Seglist forwarding index |
Forwarding entry index of the SID list. |
Weight |
Outgoing forwarding index |
The nexthop forwarding entry index of the first address in the SID list. |
Brief name of the outgoing interface. |
Nexthop |
Next hop IPv6 address. |
Path ID |
ID of the SRv6 TE policy candidate path. |
SID list |
List of SIDs. |
SID |
SID of the node, which is an IPv6 address. |
Common prefix length |
Common prefix length of the G-SID. |
G-SID length |
Length of the G-SID. |
Use display segment-routing ipv6 te policy to display SRv6 TE policy information.
display segment-routing ipv6 te policy [ name policy-name | down | up | { color color-value | end-point ipv6 ipv6-address } * ]
name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
down: Specifies the SRv6 TE policies in down state.
up: Specifies the SRv6 TE policies in up state.
end-point ipv6 ipv6-address: Specifies the endpoint IPv6 address of an SRv6 TE policy.
If you do not specify any parameters, this command displays information about all SRv6 TE policies.
# Display information about all SRv6 TE policies.
Name/ID: p1/0
Color: 10
Endpoint: 1000::1
Name from BGP:
BSID:
Mode: Dynamic Type: Type 2 Request state: Succeeded
Current BSID: 8000::1 Explicit BSID: - Dynamic BSID: 8000::1
Reference counts: 3
Flags: A/BS/NC
Status: Up
AdminStatus: Not configured
Up time: 2020-03-09 16:09:40
Down time: 2020-03-09 16:09:13
Hot backup: Enabled
Statistics: Enabled
SBFD: Enabled
Remote: 1000
SBFD template name: abc
SBFD backup-template name: -
OAM SID: -
BFD Echo: Not configured
Service-class: -
Candidate paths state: Configured
Candidate paths statistics:
CLI paths: 1 BGP paths: 0 PCEP paths: 0
Candidate paths:
Preference : 20
CpathName:
Instance ID: 0 ASN: 0 Node address: 0.0.0.0
Peer address: ::
Optimal: Y Flags: V/A
Explicit SID list:
ID: 1 Name: Sl1
Weight: 1 Forwarding index: 2149580801
State: Up State(Echo BFD): Down
Table 8 Command output
Name/ID |
SRv6 TE policy name/ID. |
Color |
Color attribute of the SRv6 TE policy. |
Endpoint |
Endpoint IPv6 address of the SRv6 TE policy. If the endpoint is not configured, this field displays None. |
Name from BGP |
Name of the SRv6 TE policy obtained from BGP. If no SRv6 TE policy was obtained from BGP, this field is empty. |
BSID |
Mode |
BSID configuration mode: · Explicit—Manually configured. · Dynamic—Dynamically requested. · None—Not configured. |
Type |
BSID type: · None—Not configured. · Type 2—IPv6 address. |
Request state |
BSID request state: · Conflicted—BSID conflict. · Failed. · Succeeded. |
Explicit BSID |
Manually configured BSID. |
Dynamic BSID |
Dynamically requested BSID. |
Reference counts |
Number of times that the SRv6 TE policy has been referenced. |
Flags |
SRv6 TE policy flags: · A—Active SRv6 TE policy. · C—Optimal SRv6 TE policy. · N—In optimal SRv6 TE policy selection progress. · BA—Requesting BSID. · BS—Optimal BSID. · D—Deleted SRv6 TE policy. · CF—Conflicted with an existing BSID. · NC—Manually configured SRv6 TE policy. · NB—SRv6 TE policy obtained from a BGP route. |
Status |
SRv6 TE policy state: · Up · Down |
AdminStatus |
Whether the shutdown command has been configured for the SRv6 TE policy: · Configured—The policy is administratively down. · Not configured—The policy is administratively up. |
Up time |
Date and time when the SRv6 TE policy became up. |
Down time |
Date and time when the SRv6 TE policy became down. |
Hot backup |
Hot standby status for the SRv6 TE policy: · Enabled. · Disabled. · Not configured. |
Statistics |
Traffic statistics status for the SRv6 TE policy: · Disabled. · Enabled. · Not configured. |
SBFD |
SBFD status for the SRv6 TE policy: · Enabled. · Disabled. · Not configured. |
Remote |
Remote discriminator of the SBFD session. |
SBFD template name |
Name of the SBFD template for the main path. |
SBFD backup-template name |
Name of the SBFD template for the backup SID list. |
OAM SID |
OAM SID added to SBFD packets or Echo BFD packets. |
BFD Echo |
Echo packet mode BFD status for the SRv6 TE policy: · Enabled. · Disabled. · Not configured. |
Source IPv6 address |
Source IPv6 address of the echo packet mode BFD session. |
Echo template name |
Name of the echo BFD template. |
Echo backup-template name |
Name of the echo BFD template for the backup SID list. |
Forwarding index |
Forwarding entry index of the SRv6 TE policy. |
Service-class |
Service class value of the SRv6 TE policy. If the default service class is used, this field displays a hyphen (-). |
Candidate paths state |
Whether candidate paths are configured: · Configured. · Not configured. |
Candidate paths statistics |
Candidate paths statistics by path origin. |
CLI paths |
Number of manually configured candidate paths. |
BGP paths |
Number of candidate paths obtained from BGP SRv6 Policy routes. |
PCEP paths |
This field is not supported in the current software version. Number of candidate paths obtained from PCEP. |
Candidate paths |
SRv6 TE policy candidate path information. |
Preference |
SRv6 TE policy candidate path preference. |
CPathName |
Name of the candidate path obtained from a BGP route. If no path name was obtained, this field is empty. |
Instance ID |
BGP instance ID. A value of 0 indicates that the device does not obtain SRv6 TE policy information from BGP peers. |
ASN |
AS number. A value of 0 indicates that the device does not obtain SRv6 TE policy information from BGP peers. |
Node address |
BGP node address. For an SRv6 TE policy obtained from a BGP peer, the node address is the Router ID of the BGP peer. For an SRv6 TE policy obtained in other methods, the node address is 0.0.0.0. |
Peer address |
BGP peer address. For a manually configured SRv6 TE policy, the peer address is ::. For an SRv6 TE policy obtained from a BGP peer, the peer address is the address of the BGP peer. |
Optimal |
Whether the path is the optimal path: · Y—Yes. · N—No. |
Flags |
Flags of the SRv6 TE policy candidate path: · V—Valid candidate path. · A—Active candidate path. · None—No candidate path. |
Explicit SID list |
Explicit SID list in the candidate path of the SRv6 TE policy. |
ID |
SID list ID. |
Name |
SID list name. |
Weight |
Weight of the SID list in the candidate path. |
Forwarding index |
State |
SID list state: · UP. · DOWN. |
State(type) |
SBFD or echo BFD session state for the SID list: · Up. · Down. · Path Inactive—The candidate path contains no available SID list. · Unknown—The SBFD or echo BFD result is unknown. If SBFD or echo BFD is not configured, this field displays a hyphen (-). |
Use display segment-routing ipv6 te policy last-down-reason to display information about the most recent down event for SRv6 TE policies.
display segment-routing ipv6 te policy last-down-reason [ binding-sid bsid | color color-value endpoint ipv6 ipv6-address | policy-name policy-name ]
binding-sid bsid: Specifies an SRv6 TE policy by its BSID, which is an IPv6 address.
color color-value endpoint ipv6 ipv6-address: Specifies an SRv6 TE policy by its color attribute value and endpoint IPv6 address. The value range for the color attribute value is 0 to 4294967295.
policy-name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters.
If you do not specify any parameters, this command displays information about the most recent down event for all SRv6 TE policies.
# Display information about the most recent down event for SRv6 TE policy abc.
<Sysname> display segment-routing ipv6 te policy last-down-reason policy-name abc
Name/ID: p1/1
Color: 10
Endpoint: 4::4
BSID: 5000::2
Up time: 2020-06-23 15:42:14
Down time: 2020-06-23 15:41:15
Down reason: Candidate path invalid segment list
Candidate paths:
Preference : 10
CPathName:
Explicit SID list:
ID: 1 Name: s1
Down reason: No SRv6 SID Out
Table 9 Command output
Name/ID |
Color |
Color attribute value of the SRv6 TE policy. If the color attribute is not configured, this field displays 0. |
Endpoint |
Endpoint address of the SRv6 TE policy. If the endpoint address is not configured, this field displays None. |
BSID |
Up time |
Time when the SRv6 TE policy came up. |
Down time |
Time when the SRv6 TE policy went down. |
Down reason |
Reason for the down event of the SRv6 TE policy: · Admin down—The SRv6 TE policy has been shut down by the shutdown command. · No Endpoint. · No candidate path. · No valid candidate path. · Candidate path invalid segment list—All SID lists in the candidate path are down. · Policy unconfigured—The SRv6 TE policy is being deleted. · Internal error. |
Candidate paths |
Candidate path information of the SRv6 TE policy. |
Preference |
Preference of the candidate path. |
CPathName |
Name of the candidate path. If no candidate path name is obtained from BGP, this field is empty. |
Explicit SID List |
ID |
SID list index. |
Name |
SID list name. |
Up time |
Time when the SID list came up. |
Down time |
Time when the SID list went down. |
Down reason |
Reason for the down event of the SID list: · No SID list—The SID list does not exist. · No SRv6 SID Out—The first SID in the SID list has no outgoing interface. · Internal error. |
Use display segment-routing ipv6 te policy statistics to display SRv6 TE policy statistics.
# Display SRv6 TE policy statistics.
<Sysname> display segment-routing ipv6 te policy statistics
IPv6 TE Policy Database Statistics
Total policies: 1 (1 up 0 down)
Configured: 1 (1 up 0 down)
From BGP: 0 (Added 0 deleted 0 0 up 0 down)
Total candidate paths: 1
Configured: 1
From BGP: 0 (Added 0 deleted 0)
Total SID lists: 1 (1 up 0 down)
From BGP: 0 (0 up 0 down)
Table 10 Command output
Total policies |
Total number of SRv6 TE policies: · up—Number of SRv6 TE policies in up state. · down—Number of SRv6 TE policies in down state. |
Configured |
Number of manually configured SR policies. · up—Number of SRv6 TE policies in up state. · down—Number of SRv6 TE policies in down state. |
From BGP |
Number of SR policies learned through BGP. · Added—Number of BGP-added SRv6 TE policies. · deleted—Number of BGP-deleted SRv6 TE policies. · up—Number of SRv6 TE policies in up state. · down—Number of SRv6 TE policies in down state. |
Use display segment-routing ipv6 te policy status to display status information about SRv6 TE policies.
display segment-routing ipv6 te policy status [ policy-name policy-name ]
policy-name policy-name: Specifies an SRv6 TE policy by its name, a case-sensitive string of 1 to 59 characters. If you do not specify this option, the command displays status information about all SRv6 TE policies.
The device executes the check items for an SRv6 TE policy one by one.
If the result for a check item is Passed, it means that the SRv6 TE policy passed the check for this item and the next item check starts.
If the result for a check item is Failed, the subsequent items will not be checked and the check result for those items is displayed as a hyphen (-).
# Display status information about all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy status
Name/ID: p1/0
Status: Up
Check admin status : Passed
Check for endpoint & color : Passed
Check for segment list : Passed
Check valid candidate paths : Passed
Check for BSIDs : Passed
Table 11 Command output
Name/ID |
Status |
State of the SRv6 TE policy: · Up. · Down. |
Check admin status |
Check the administrative status of the SRv6 TE policy: · Passed—The SRv6 TE policy is administratively up. · Failed—The SRv6 TE policy is administratively shut down by using the shutdown command. |
Check for endpoint & color |
Check for the endpoint and color configuration for the SRv6 TE policy: · Passed—The endpoint address and color are configured. · Failed—The endpoint address or color is not configured. |
Check for segment lists |
Check for valid SID lists in the candidate paths of the SRv6 TE policy: · Passed—A valid SID list exists. · Failed—No valid SID list exists. |
Check valid candidate paths |
Check for an up candidate path in the SRv6 TE policy: · Passed—An up candidate path exists. · Failed—No up candidate path exists. |
Check for BSIDs |
Check for the binding SID configuration for the SRv6 TE policy: · Passed—A BSID is specified for the SRv6 TE policy. · Failed—No BSID is specified for the SRv6 TE policy. |
Use display segment-routing ipv6 te policy-group to display information about SRv6 TE policy groups.
display segment-routing ipv6 te policy-group [ group-id ] [ verbose ]
group-id: Specifies an SRv6 TE policy group by its ID in the range of 1 to 4294967295. If you do not specify this argument, the command displays information about all SRv6 TE policy groups.
verbose: Displays detailed SRv6 TE policy information. If you do not specify this keyword, the command displays brief SRv6 TE policy information.
# Display brief information about all SRv6 TE policy groups.
<Sysname> display segment-routing ipv6 te policy-group
Total number of policy groups: 1
GroupID GroupState UPMappings TotalMappings
10 Up 26 26
# Display detailed information about all SRv6 TE policy groups.
<Sysname> display segment-routing ipv6 te policy-group verbose
GroupID: 10 GroupState: Up
GroupNID: 2151677953 Referenced: 1
Flags: A
Endpoint: 4::4
UP/Total Mappings: 26/26
Color Type DSCP
10 IPv4 10, 12, 14, 16, 18, 20
Table 12 Command output
UPMappings |
Number of up (valid) color-to-DSCP mappings in the SRv6 TE policy group. |
TotalMappings |
Total number of color-to-DSCP mappings in the SRv6 TE policy group. |
GroupNID |
Index of the forwarding entry for the SRv6 TE policy group. |
Referenced |
Number of times that the SRv6 TE policy group has been used. |
Flags |
Flags of the SRv6 TE policy group: · A—Assign the forwarding entry index of the SRv6 TE policy group. · F—Issue the forwarding entry of the SRv6 TE policy group. · W—Waiting for assigning the forwarding entry index of the SRv6 TE policy group. · D—Delete the SRv6 TE policy group. · None—The SRv6 TE policy group is in initialized or stable state. |
Endpoint |
Destination node IP address of the SRv6 TE policy group. None indicates that the endpoint is not configured. |
UP/Total Mappings |
Number of valid color-to-DSCP mappings/total number of configured color-to-DSCP mappings in the SRv6 TE policy group. |
Color |
Color value |
Type |
Packet type: IPv4 or IPv6. |
DSCP |
DSCP value. |
Use display segment-routing ipv6 te sbfd to display SBFD information for SRv6 TE policies.
display segment-routing ipv6 te sbfd [ down | policy { { color color-value | end-point ipv6 ipv6-address } * | name policy-name } | up ]
down: Displays SBFD information for SRv6 TE policies in down state.
policy: Displays SBFD information for the specified SRv6 TE policy.
up: Displays SBFD information for SRv6 TE policies in up state.
If you do not specify any parameters, this command displays SBFD information for all SRv6 TE policies.
# Display SBFD information for all SRv6 TE policies.
<Sysname> display segment-routing ipv6 te policy sbfd
Color: 10
Endpoint: 4::4
Policy name: p1
State: Down
Nid: 2149580801
BFD type: SBFD
Remote Discr: 100
State: Down
Timer: 30
VPN index: 0
Template name: abc
Table 13 Command output
Color |
Endpoint |
Policy name |
State |
SBFD session state: · Up. · Down. · Delete. |
Nid |
BFD type |
The current software version supports only the SBFD type. |
Remote Discr |
Remote discriminator. |
Timer |
SBFD session timer, in seconds. |
Use display segment-routing ipv6 te segment-list to display SRv6 TE SID list information.
display segment-routing ipv6 te segment-list [ name seglist-name | id id-value ]
name segment-list-name: Specifies a SID list by its name, a case-sensitive string of 1 to 128 characters.
id id-value: Specifies a SID list by its ID. The value range for the SID list ID is 1 to 4294967295.
If you do not specify a SID list name or ID, this command displays information about all SRv6 TE SID lists.
To view SID list ID information, execute the display segment-routing ipv6 te policy command.
# Display information about all SRv6 TE SID lists.
<Sysname> display segment-routing ipv6 te segment-list
Total Segment lists: 1
Name/ID: A/1
Origin: CLI
Status: Up
Nodes: 1
Index : 1 SID: 1::2
Type : Type 2 Flags: None
Coc Type : - Common prefix length: 0
Table 14 Command output
Total Segment lists |
Number of SID lists. |
Name/ID |
SID list name/ID. |
Origin |
Origin of the SID list. Options include: · CLI—Locally configured in the CLI. · BGP—Issued by BGP. · PCE—Issued by a PCE. (This option is not supported in the current software version.) If the SID list does not have a valid origin, this field displays a hyphen (-). |
Status |
SID list status, Down or Up. |
Nodes |
Number of nodes in the SID list. |
Index |
Node index. |
SID |
SID value (IPv6 address) of the node. |
Type |
SID type of the node: · None—Not configured. · Type 2—IPv6 address. |
Flags |
Node flags, which are not defined and displayed as None. |
COC type |
Compression type of the SID, which is COC32, representing the 32-bit compression. If the SID is not compressed, this field displays a hyphen (-). |
end-point
Use end-point to configure the endpoint IP address for the SRv6 TE policy group.
Use undo end-point to restore the default.
undo end-point ipv6
No endpoint address is configured for the SRv6 TE policy group.
ipv6 ipv6-address: Specifies the endpoint IPv6 address for the SRv6 TE policy group.
The SRv6 TE policies added to the SRv6 TE policy group must use the same endpoint IPv6 address as the SRv6 TE policy group.
# Configure the endpoint address as 100::2 for SRv6 TE policy group 10.
[Sysname-srv6-te-policy-group-10] end-point ipv6 100::2
explicit segment-list
Use explicit segment-list to specify a SID list for a candidate path.
Use undo explicit segment-list to delete a SID list of a candidate path or restore the default weight of a SID list.
explicit segment-list segment-list-name [ weight weight-value ]
undo explicit segment-list segment-list-name [ weight ]
No SID lists are specified for an SRv6 TE policy candidate path.
SRv6 TE policy path preference view
segment-list-name: Specifies an SID list name, a case-sensitive string of 1 to 128 characters.
weight weight-value: Specifies a weight for the SID list, in the range of 1 to 4294967295. The default weight is 1.
An SRv6 TE policy uses the SID list specified for the highest-preference candidate path as a traffic forwarding subpath.
An SRv6 TE policy candidate path can have multiple SID lists. All the SID lists can be used to forward traffic for load sharing based on their weights. Assume SID lists a, b, and c are assigned weights x, y, z, respectively. The load of SID list a is x/(x+y+z) of the total traffic.
If you assign weight values for the same SID list multiple times, the most recent configuration takes effect.
# Configure SID list abc for the SRv6 TE policy candidate path with preference 20, and the set the SID list weight to 20.
[Sysname-srv6-te] policy a1
[Sysname-srv6-te-policy-a1] candidate-paths
[Sysname-srv6-te-policy-a1-path] preference 20
[Sysname-srv6-te-policy-a1-path-pref-20] explicit segment-list abc weight 20
segment-list
Use forwarding statistics to configure traffic forwarding statistics for an SRv6 TE policy.
Use undo forwarding statistics to restore the default.
forwarding statistics { disable | [ service-class ] enable }
An SRv6 TE policy uses the traffic forwarding statistics configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables the SRv6 TE policy forwarding statistics.
enable: Enables the SRv6 TE policy forwarding statistics.
service-class: Enables the SRv6 TE policy forwarding statistics based on service class. If you specify this keyword, in addition to statistics of total traffic forwarded through the SRv6 TE policy tunnel, the command collects traffic statistics for each service class. If you specify do not specify this keyword, the command collects only the statistics of total traffic forwarded through the SRv6 TE policy.
You can configure traffic forwarding statistics for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
# Enable traffic forwarding statistics for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] forwarding statistics enable
srv6-policy forwarding statistic enable
srv6-policy forwarding statistic interval
import-route sr-policy
Use import-route sr-policy to enable BGP to redistribute BGP IPv6 SR policy routes.
Use undo import-route sr-policy to restore the default.
BGP does not redistribute BGP IPv6 SR policy routes.
After you execute this command, the system will redistribute the local BGP IPv6 SR policy routes to the BGP routing table and advertise the routes to IBGP peers. Then, the peers can forward traffic based on the BGP IPv6 SR policy.
# In BGP IPv6 SR policy address family view, enable BGP to redistribute BGP IPv6 SR policy routes.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv6] import-route sr-policy
index
Use index to add a node to a SID list.
Use undo index to delete a node from a SID list.
index index-number ipv6 ipv6-address
undo index index-number
No nodes exist in a SID list.
SID list view
index-number: Specifies the node index, in the range of 1 to 65535.
ipv6 ipv6-address: Specifies the IPv6 address of the node.
When you add a G-SID to the SID list, the common prefix length configured by this command must be the same as that of the locator where the next node belongs.
# Add a node to SID list abc, and set the node index to 1 and IPv6 address to 1000::1.
[Sysname-srv6-te] segment-list abc
[Sysname-srv6-te-sl-abc] index 1 ipv6 1000::1
locator
policy
Use policy to create an SRv6 TE policy and enter its view, or enter the view of an existing SRv6 TE policy.
Use undo policy to delete an SRv6 TE policy and all the configuration in the SRv6 TE policy.
policy policy-name
undo policy policy-name
No SRv6 TE policies exist.
SRv6 TE view
policy-name: Specifies an SRv6 TE policy name, a case-sensitive string of 1 to 59 characters.
# Create an SRv6 TE policy named srv6policy and enter its view.
[Sysname-srv6-te] policy p1
[Sysname-srv6-te-policy-p1]
policy-group
Use policy-group to create an SRv6 TE policy group and enter its view, or enter the view of an existing SRv6 TE policy group.
Use undo policy-group to delete an SRv6 TE policy group and all the configuration in the SRv6 TE policy group.
policy-group group-id
undo policy-group group-id
No SRv6 TE policy groups exist.
SRv6 TE view
group-name: Specifies an SRv6 TE policy group by its ID in the range of 1 to 4294967295.
You can add SRv6 TE policies to an SRv6 TE policy group to implement SRv6 TE policy based forwarding according to DSCP values of packets.
# Create SRv6 TE policy group 1 and enter its view.
[Sysname-srv6-te-policy-group-1]
preference
Use preference to set the preference for an SRv6 TE policy candidate path and enter SRv6 TE policy path preference view, or enter an existing SRv6 TE policy path preference view.
Use undo preference to delete an SRv6 TE policy candidate path preference and all the configuration in the SRv6 TE policy path preference view.
preference preference-value
undo preference preference-value
preference-value: Specifies a candidate path preference in the range of 1 to 65535. A bigger value represents a higher preference.
A preference represents a candidate path of an SRv6 TE policy.
# Set the preference of an SRv6 TE policy candidate path to 20, and enter SRv6 TE policy path preference view.
Use reset segment-routing ipv6 te forwarding statistics to clear forwarding statistics for all SRv6 TE policies.
# Clear SRv6 TE policy forwarding statistics.
<Sysname> reset segment-routing ipv6 te forwarding statistics
router-id filter
Use router-id filter to enable Router ID filtering.
Use undo router-id filter to disable Router ID filtering.
router-id filter
Router ID filtering is disabled.
For the device to process only part of the received BGP IPv6 SR policy routes, you can execute this command to enable filtering the routes by Router ID.
This command enables the device to check the Route Target attribute of a received BGP IPv6 SR policy route. The device accepts the route only if the Route Target attribute contains the Router ID of the local device.
To use Router ID filtering, make sure you add Route Target attributes to BGP IPv6 SR policy routes properly by using routing policy or other methods. Otherwise, Router ID filtering might learn or drop BGP IPv6 SR policy routes incorrectly.
# Enable Router ID filtering.
[Sysname] bgp 100
[Sysname-bgp-default-srpolicy-ipv6] router-id filter
sbfd
Use sbfd to configure SBFD for an SRv6 TE policy.
Use undo sbfd to restore the default.
sbfd { disable | enable [ remote remote-id ] [ template template-name ] [ backup-template backup-template-name ] [ oam-sid sid ] }
undo sbfd
SBFD is disabled for an SRv6 TE policy. An SRv6 TE policy uses the SBFD configuration in SRv6 TE view.
SRv6 TE policy view
disable: Disables SBFD for the SRv6 TE policy.
enable: Enables SBFD for the SRv6 TE policy.
remote remote-id: Specifies the remote discriminator of the SBFD session, in the range of 1 to 4294967295. If you do not specify this option, the configuration in SRv6 TE view applies.
template template-name: Specifies an SBFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the template specified in SRv6 TE view applies.
backup-template backup-template-name: Specifies as SBFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the backup template specified in SRv6 TE view applies.
oam-sid sid: Adds an OAM SID to SBFD packets to identify the destination node. The sid argument represents the SRv6 SID of the endpoint destination node. If you do not specify this option, no OAM SID will be added to BFD packets. At present, the OAM SID must be set to the End.OP SID of the destination node.
You can configure SBFD for all SRv6 TE policies globally in SRv6 TE view or for a specific SRv6 TE policy in SRv6 TE policy view. The policy-specific configuration takes precedence over the global configuration. An SRv6 TE policy uses the global configuration only when it has no policy-specific configuration.
The remote discriminator specified in this command must be the same as that specified in the sbfd local-discriminator command on the reflector. Otherwise, the reflector will not send responses to the initiator.
# Enable SBFD for SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] sbfd enable
sbfd local-discriminator (High Availability Command Reference)
srv6-policy sbfd
segment-list
Use segment-list to create a SID list and enter its view, or enter the view of an existing SID list.
Use undo segment-list to delete a SID list and all the configuration in the SID list.
undo segment-list segment-list-name
No SID lists exist.
SRv6 TE view
segment-list-name: Specifies the SID list name, a case-sensitive string of 1 to 128 characters.
# Create a SID list named abc and enter its view.
service-class
Use service-class to set a service class value for an SRv6 TE policy.
Use undo service-class to restore the default.
service-class service-class-value
undo service-class
No service class value is set for an SRv6 TE policy.
SRv6 TE policy view
service-class-value: Specifies a service class value in the range of 0 to 15. The smaller the service class value, the lower the SRv6-TE policy priority. An SRv6-TE policy that is not assigned a service class value has the lowest priority.
The device compares the service class value of the traffic with the service class values of SRv6 TE policies and forwards the traffic to a matching tunnel. The device uses the following rules to select an SRv6 TE policy to forward the traffic:
· If the traffic matches only one SRv6 TE policy, the device uses this SRv6 TE policy.
· If the traffic matches multiple SRv6 TE policies, the device selects an SRv6 TE policy based on the flow forwarding mode:
¡ If there is only one flow and flow-based forwarding is used, the device randomly selects a matching SRv6 TE policy for packets of the flow.
¡ If there are multiple flows or if there is one flow but packet-based forwarding is used, the device uses all matching SRv6 TE policies to load share the packets.
For more information about the flow identification and load sharing mode, see the ip load-sharing mode command.
· If the traffic does not match any SRv6 TE policy, the device randomly selects an SRv6 TE policy from all SRv6 TE policies with the smallest service class value.
To set a service class value for traffic, use the remark service-class command in traffic behavior view.
# Set the service class value to 5 for SRv6 TE policy.
[Sysname-srv6-te-policy-1] service-class 5
ip load-sharing mode (Layer 3—IP Services Command Reference)
remark service-class (ACL and QoS Command Reference)
shutdown
Use shutdown to shut down an SRv6 TE policy.
Use undo shutdown to bring up an SRv6 TE policy.
shutdown
An SRv6 TE policy is not administratively shut down.
SRv6 TE policy view
If multiple SRv6 TE policies exist on the device, you can shut down unnecessary SRv6 TE policies to prevent them from affecting traffic forwarding.
# Shut down SRv6 TE policy 1.
[Sysname-srv6-te-policy-1] shutdown
sr-policy steering
Use sr-policy steering to configure the traffic steering mode for SRv6 TE policies.
Use undo sr-policy steering to restore the default.
sr-policy steering { disable | policy-based }
The device steering data packets to SRv6 TE policies based on colors of the packets.
BGP instance view
disable: Disables color-based traffic steering to an SRv6 TE policy.
policy-based: Steers traffic to an SRv6 TE policy based on the bound policy, color, and load sharing tunnel policy in a descending order of priority.
The following traffic steering modes are available for SRv6 TE policies:
· Based on color—The device searches for an SRv6 TE policy that has the same color and endpoint address as the color and nexthop address of a BGP route. If a matching SRv6 TE policy exists, the device recurse the BGP route to that SRv6 TE policy. Then, when the device receives packets that match the BGP route, it forwards the packets through the SRv6 TE policy.
· Based on tunnel policy—On an IPv6 L3VPN over SRv6 network or EVPN L3VPN over SRv6 network, deploy a tunnel policy that uses an SRv6 TE policy. In this way, the SRv6 TE policy will be used as the public tunnel to carry the packets of a VPN instance. For more information about the tunnel policy configuration, see MPLS Configuration Guide.
This command does not take effect on L2VPN networks.
# Configure the SRv6 TE traffic steering mode as tunnel policy.
[Sysname] bgp 100
[Sysname-bgp-default] sr-policy steering policy-based
Use srv6-policy backup hot-standby enable to enable hot standby for all SRv6 TE policies.
Use undo srv6-policy backup hot-standby enable to disable hot standby for all SRv6 TE policies.
Hot standby is disabled for all SRv6 TE policies.
SRv6 TE view
# Enable hot standby for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy backup hot-standby enable
backup hot-standby
Use srv6-policy bfd echo to enable the echo packet mode BFD for all SRv6 TE policies.
Use undo srv6-policy bfd echo to disable the echo packet mode BFD for all SRv6 TE policies.
srv6-policy bfd echo source-ipv6 ipv6-address [ template template-name ] [ backup-template backup-template-name ]
The echo packet mode BFD is disabled for all SRv6 TE policies.
SRv6 TE view
template template-name: Specifies a BFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the BFD session uses multihop BFD session settings configured in system view.
backup-template backup-template-name e: Specifies a BFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the BFD session uses multihop BFD session settings configured in system view.
# Enable the echo packet mode BFD for all SRv6 TE policies, and specify the source IPv6 address of the BFD session as 11::11.
[Sysname-srv6-te] srv6-policy bfd echo source-ipv6 11::11
bfd echo
srv6-policy forwarding statistics enable
Use srv6-policy forwarding statistics enable to enable traffic forwarding statistics for all SRv6 TE policies.
Use undo srv6-policy forwarding statistics enable to disable traffic forwarding statistics for all SRv6 TE policies.
srv6-policy forwarding statistics [ service-class ] enable
Traffic forwarding statistics is disabled for all SRv6 TE policies.
SRv6 TE view
# Enable traffic forwarding statistics for all SRv6 TE policies.
[Sysname-srv6-te] srv6-policy forwarding statistics enable
Use srv6-policy forwarding statistics interval to configure the traffic forwarding statistics interval for all SRv6 TE policies.
Use undo srv6-policy forwarding statistics interval to restore the default.
srv6-policy forwarding statistics interval interval
The SRv6 TE policies forwarding statistics interval is 30 seconds.
SRv6 TE view
interval: Specifies the SRv6 TE policy traffic forwarding statistics interval in the range of 5 to 65535, in seconds.
This command takes effect only all SRv6 TE policies.
# Set the SRv6 TE policy traffic forwarding statistics interval to 90 seconds.
[Sysname-srv6-te] srv6-policy forwarding statistics interval 90
srv6-policy locator
Use srv6-policy locator to specify a locator for SRv6 TE.
Use undo srv6-policy locator to cancel the locator configuration.
srv6-policy locator locator-name
No locator is specified for SRv6 TE.
SRv6 TE view
locator-name: Specifies a locator by its name, a case-sensitive string of 1 to 31 characters.
The locator specified in SRv6 TE view restricts the BSID range. Only BSIDs within the range of the locator can take effect.
You cannot change the locator for SRv6 TE by repeatedly executing this command. To change the locator, first execute the undo srv6-policy locator command to remove the specified locator and then execute the srv6-policy locator command to specify a new locator.
# Specify locator test1 in SRv6 TE view.
[Sysname] segment-routing ipv6
[Sysname-segment-routing-ipv6] traffic-engineering
[Sysname-srv6-te] srv6-policy locator test1
srv6-policy sbfd
Use srv6-policy sbfd to enable SBFD for all SRv6 TE policies and configure the SBFD session parameters.
Use undo srv6-policy sbfd to disable SBFD for all SRv6 TE policies.
srv6-policy sbfd remote remote-id [ template template-name ] [ backup-template backup-template-name ]
SBFD for all SRv6 TE policies is disabled.
SRv6 TE view
template template-name: Specifies an SBFD session parameter template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the SBFD uses the multihop SBFD session settings configured in system view.
backup-template backup-template-name: Specifies an SBFD session parameter template for the backup SID list. The backup-template-name argument indicates the template name, a case-sensitive string of 1 to 63 characters. If you do not specify this option, the SBFD uses the multihop SBFD session settings configured in system view.
# Enable SBFD for all SRv6 TE policies, and specify the SBFD session remote discriminator as 1000001.
[Sysname-srv6-te] srv6-policy sbfd remote 1000001
sbfd
srv6-policy switch-delay delete-delay
Use srv6-policy switch-delay delete-delay to configure the switchover delay time and deletion delay time for the SRv6 TE policy forwarding path.
Use undo srv6-policy switch-delay to restore the default.
srv6-policy switch-delay switch-delay-time delete-delay delete-delay-time
The switchover delay time and deletion delay time for the SRv6 TE policy forwarding path is 5000 milliseconds and 20000 milliseconds, respectively.
SRv6 TE view
switch-delay-time: Sets the forwarding path switchover delay time in the range of 0 to 600000 milliseconds.
delete-delay-time: Sets the forwarding path deletion delay time in the range of 0 to 600000 milliseconds.
The switchover delay and deletion delay mechanism is used to avoid traffic forwarding interruption during a forwarding path switchover.
When updating an SRv6 TE policy forwarding path, the device first establishes the new forwarding path before it deletes the old one. During the new path setup process, the device uses the old path to forward traffic until the switchover delay timer expires. When the switchover delay timer expires, the device switches traffic to the new path. The old path is deleted when the deletion delay timer expires.
# Set the SRv6 TE policy forwarding path switchover delay time to 8000 milliseconds and the deletion delay time to 15000 milliseconds.
[Sysname-srv6-te] srv6-policy switch-delay 8000 delete-delay 15000
traffic-engineering
Use traffic-engineering to create and enter the SRv6 TE view, or enter the existing SR TE view.
Use undo traffic-engineering to delete the SRv6 TE view and all the configuration in the view.
traffic-engineering
The SRv6 TE view does not exist.
SRv6 view
# Create and enter the SRv6 TE view.
[Sysname-srv6-te]
ttl-mode
Use ttl-mode to configure the TTL processing mode of SRv6 TE policies.
Use undo ttl-mode to restore the default.
ttl-mode { pipe | uniform }
undo ttl-mode
The TTL processing mode of SRv6 TE policies is pipe.
SRv6 view
pipe: Specifies the pipe TTL processing mode.
uniform: Specifies the uniform TTL processing mode.
An SRv6 TE policy used as a public tunnel supports the following TTL processing modes:
· Uniform—When the ingress node adds a new IPv6 header to an IP packet, it copies the TTL value of the original IP packet to the Hop Limit field of the new IPv6 header. Each node on the SRv6 TE policy forwarding path decreases the Hop Limit value in the new IPv6 header by 1. The node that de-encapsulates the packet copies the remaining Hop Limit value back to the original IP packet when it removes the new IPv6 header. The TTL value can reflect how many hops the packet has traversed in the public network. The tracert facility can show the real path along which the packet has traveled.
· Pipe—When the ingress node adds a new IPv6 header to an IP packet, it does not copy the TTL value of the original IP packet to the Hop Limit field of the new IPv6 header. It sets the Hop Limit value in the new IPv6 header to 255. Each node on the SRv6 TE policy forwarding path decreases the Hop Limit value in the new IPv6 header by 1. The node that de-encapsulates the packet does not copy the remaining Hop Limit value back to the original IP packet when it removes the new IPv6 header. Therefore, the public network nodes are invisible to user networks, and the tracert facility cannot show the real path in the public network.
# Configure the TTL processing mode of SRv6 TE policies to uniform.
[Sysname-segment-routing-ipv6] ttl-mode uniform
