- 04-Layer 2—LAN Switching Configuration Guide
- 01-MAC address table configuration
- 02-Ethernet link aggregation configuration
- 03-Port isolation configuration
- 04-VLAN configuration
- 05-QinQ configuration
- 06-Loop detection configuration
- 07-Spanning tree configuration
- 08-LLDP configuration
- 09-Layer 2 forwarding configuration
- 10-VLAN termination configuration
09-Layer 2 forwarding configuration | 55.10 KB |
Configuring normal Layer 2 forwarding
About normal Layer 2 forwarding
Restrictions: Hardware compatibility with Layer 2 forwarding
Display and maintenance commands for Layer 2 forwarding
Configuring fast Layer 2 forwarding
Restrictions: Hardware compatibility with fast Layer 2 forwarding
Display and maintenance commands for fast Layer 2 forwarding
When an incoming frame's destination MAC address does not match any Layer 3 interface's MAC address, normal Layer 2 forwarding forwards the frame through a Layer 2 interface.
The device uses the destination MAC address of the frame to look for a match in the MAC address table.
· The device forwards the frame out of the outgoing interface in the matching entry if a match is found.
· The device floods the frame to all interfaces in the VLAN of the frame if no match is found.
Normal Layer 2 forwarding is enabled by default.
This feature is supported only on Layer 2 Ethernet ports on Ethernet switching modules or the SPU-300-G module.
On Layer 2 Ethernet switching modules of MSR devices that are operating in IRF mode, Layer 2 forwarding across member devices is not supported. On SIC Layer 2 Ethernet switching modules, Layer 2 forwarding across member devices and slots is not supported.
Layer 2 forwarding across slots that reside on the same device is supported if multiple HMIM-24GSW, HMIM-24GSWP, HMIM-8GSW, or HMIM-8GSWF Layer 2 Ethernet switching modules are installed on the following devices:
· MSR5660.
· MSR5680.
Layer 2 forwarding across slots that reside on the same device is not supported on MSR5620 devices that are installed with multiple HMIM-8GSW or HMIM-8GSWF Layer 2 Ethernet switching modules.
On MSR56 devices:
· Layer 2 forwarding across slots is supported if multiple HMIM Layer 2 Ethernet switching modules are installed on the same SPE-S1 module.
· Layer 2 forwarding across slots is not supported if multiple HMIM Layer 2 Ethernet switching modules are installed on the same SPE-S3 module.
Task |
Command |
Display Layer 2 forwarding statistics. |
display mac-forwarding statistics [ interface interface-type interface-number ] |
Clear Layer 2 forwarding statistics. |
reset mac-forwarding statistics |
About fast Layer 2 forwarding
Fast Layer 2 forwarding improves packet forwarding efficiency by using a high-speed cache and flow-based technology. It identifies a flow by using the following items:
· Source IP address.
· Source port number.
· Destination IP address.
· Destination port number.
· Protocol number.
· Input interface.
· Output interface.
· VLAN ID.
Fast Layer 2 forwarding creates an entry in a high-speed cache by obtaining the forwarding information of a flow's first packet. Subsequent packets of the flow are forwarded based on the entry.
Fast Layer 2 forwarding is enabled by default.
· MSR5660.
· MSR5680.
On MSR56 devices:
IMPORTANT: The MSR 56-60 and MSR 56-80 routers installed with the MPU-100-G modules do not support parameters or commands that are available only in IRF mode. |
Task |
Command |
Display IPv4 fast forwarding entries. |
In standalone mode: display mac-forwarding cache ip [ ip-address ] [ slot slot-number ] In IRF mode: display mac-forwarding cache ip [ ip-address ] [ chassis chassis-number slot slot-number ] |
Display IPv4 fast forwarding entries for fragments. |
In standalone mode: display mac-forwarding cache ip fragment [ ip-address ] [ slot slot-number ] In IRF mode: display mac-forwarding cache ip fragment [ ip-address ] [ chassis chassis-number slot slot-number ] |
Display IPv6 fast forwarding entries. |
In standalone mode: display mac-forwarding cache ipv6 [ ipv6-address ] [ slot slot-number ] In IRF mode: display mac-forwarding cache ipv6 [ ipv6-address ] [ chassis chassis-number slot slot-number ] |
