- 17-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-EAA configuration
- 05-Process monitoring and maintenance configuration
- 06-NETCONF configuration
- 07-Information center configuration
- 08-SNMP configuration
- 09-NetStream configuration
- 10-RMON configuration
- 11-Flow log configuration
- 12-Event MIB configuration
- 13-Packet capture configuration
- 14-Fast log output configuration
- 15-Mirroring configuration
- 16-GOLD configuration
- 17-BFD configuration
- 18-Track configuration
- 19-Interface collaboration configuration
- 20-Process placement configuration
| 15-Mirroring configuration | 65.38 KB |
Restrictions and guidelines: Flow mirroring configuration
Flow mirroring tasks at a glance
Configuring a traffic behavior
Applying a QoS policy to an interface
Applying a QoS policy globally
Configuring flow mirroring
About flow mirroring
Flow mirroring copies packets matching a class to a designated port for packet analyzing and monitoring. It is implemented through QoS.
To implement flow mirroring through QoS, perform the following tasks:
· Define traffic classes and configure match criteria to classify packets to be mirrored. Flow mirroring allows you to flexibly classify packets to be analyzed by defining match criteria.
· Configure traffic behaviors to mirror the matching packets to the specified destination.
For more information about QoS policies, traffic classes, and traffic behaviors, see ACL and QoS Configuration Guide.
For information about the configuration commands except the mirror-to command, see QoS policy commands in ACL and QoS Command Reference.
To configure flow mirroring, perform the following tasks:
1. Configuring a traffic class
A traffic class defines the criteria that filters the traffic to be mirrored.
2. Configuring a traffic behavior
A traffic behavior specifies mirroring destinations.
Choose either of the following tasks:
¡ Applying a QoS policy to an interface
¡ Applying a QoS policy globally
1. Enter system view.
2. Create a class and enter class view.
3. Configure match criteria.
if-match [ not ] match-criteria
By default, no match criterion is configured in a traffic class.
4. (Optional.) Display traffic class information.
display traffic classifier
This command is available in any view.
2. Create a traffic behavior and enter traffic behavior view.
3. Mirror traffic to an interface.
mirror-to interface interface-type interface-number
By default, no mirroring actions exist to mirror traffic to interfaces.
4. (Optional.) Display traffic behavior configuration.
display traffic behavior
Configuring a QoS policy
2. Create a QoS policy and enter QoS policy view.
qos policy policy-name
3. Associate a class with a traffic behavior in the QoS policy.
classifier classifier-name behavior behavior-name
By default, no traffic behavior is associated with a class.
4. (Optional.) Display QoS policy configuration.
display qos policy
You can apply a QoS policy to an interface to mirror the traffic of the interface.
A policy can be applied to multiple interfaces.
In one traffic direction of an interface, only one QoS policy can be applied.
2. Enter interface view.
3. Apply a policy to the interface.
4. (Optional.) Display the QoS policy applied to the interface.
display qos policy interface
You can apply a QoS policy globally to mirror the traffic on all ports.
2. Apply a QoS policy globally.
3. (Optional.) Display global QoS policies.
display qos policy global
