- 12-Layer 3—IP Routing Command Reference
- 01-Basic IP routing commands
- 02-Static routing commands
- 03-RIP commands
- 04-OSPF commands
- 05-IS-IS commands
- 06-BGP commands
- 07-Policy-based routing commands
- 08-IPv6 static routing commands
- 09-IPv6 policy-based routing commands
- 10-RIPng commands
- 11-OSPFv3 commands
- 12-Routing policy commands
- 13-Guard route commands
- 14-RIR commands
00-Preface | 100.62 KB |
Preface
This command reference describes commands that help you get started with the device. It includes the following feature modules: Basic IP routing, Static routing, RIP, OSPF, IS-IS, BGP, Policy-based routing, IPv6 static routing, IPv6 policy-based routing, RIPng, OSPFv3, Routing policy, Guard route and RIR.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
