04-WLAN mesh commands | 138.41 KB |
1 WLAN mesh commands
active-link keepalive-count
Use active-link keepalive-count to set the mesh link keepalive packet limit for the active link.
Use undo active-link keepalive-count to restore the default.
active-link keepalive-count number
The mesh link keepalive packet limit is 6.
Mesh policy view
number: Specifies the maximum number of keepalive packets in the range of 1 to 100.
Use this feature in subway applications to achieve fast link switchover.
With the keepalive packet limit set, an onboard MP sends probe requests to a trackside MP at intervals of 100 milliseconds. If the onboard MP fails to receive a reply when the limit is reached, it terminates the active link or switches to the standby link if a standby link is available.
Make sure the value of the limit multiplied by 0.1 is smaller than the value of the keepalive interval multiplied by 3.
This feature takes effect only when MLSP is enabled.
# Set the mesh link keepalive packet limit to 10 for mesh policy 1.
[Sysname] wlan mesh-policy abc
[Sysname-wlan-mesh-policy-abc] active-link keepalive-count 10
display wlan mesh-policy
link-keepalive
akm mode sae
Use akm mode sae to set the authentication and key management mode to simultaneous authentication of equals (SAE).
Use undo akm mode to restore the default.
akm mode sae
undo akm mode
The authentication and key management mode is not set.
Mesh profile view
Make sure the mesh profile is disabled before you configure or remove its authentication and key management mode setting.
# Set the authentication and key management mode to SAE in mesh profile 1.
[Sysname] wlan mesh-profile 1
[Sysname-wlan-mesh-profile-1] akm mode sae
display wlan mesh-profile
display wlan mesh-link
Use display wlan mesh-link to display mesh link information.
display wlan mesh-link [ mesh-profile mesh-profile-number | interface interface-type interface-number | peer-mac-address mac-address ]
mesh-profile mesh-profile-number: Specifies a mesh profile by its profile number. The value range is 1 to 32.
peer-mac-address mac-address: Specifies a peer MP by its MAC address in H-H-H format.
If you do not specify any parameters, this command displays information about all mesh links.
# Display information about all mesh links.
<Sysname> display wlan mesh-link
Peer MAC RSSI BSSID Interface Link state Online time
7b2d-23bb-e56f 22 4a1b-517d-23ff WLAN-MeshLink1 Active(an) 00h 08m 31s
6a3b-cc5a-e215 22 4a1b-517d-23ff WLAN-MeshLink2 Standby(an-W) 00h 40m 56s
Table1-1 Command output
Peer MAC |
MAC address of the peer MP. |
WLAN mesh link interface. |
Link state |
Link status: · Active—Active link. · Active(T)—Active temporary link. · Standby—Standby link. Radio mode: · a—802.11a. · ac—802.11ac. · an—802.11n (5GHz). · ax—802.11ax. · b—802.11b. · g—802.11g. · gac—802.11gac. · gax—802.11gax. · gn—802.11n (2.4GHz). By default, mesh signals are transmitted over the air. The W next to the radio mode indicates that the mesh signals are transmitted in waveguides or LCX cables. |
Online time |
The amount of time that the mesh link has been active. |
Use display wlan mesh-policy to display mesh policy information.
display wlan mesh-policy [ mesh-policy-name ]
mesh-policy-name: Specifies a mesh policy by its name, a case-insensitive string of 1 to 31 characters. If you do not specify a policy name, this command displays information about all mesh policies.
# Display information about all mesh policies.
<Sysname> display wlan mesh-policy
Mesh policy name : default_mesh_policy
Mesh link initiation : Enabled
MLSP : Disabled
MLSP optimize : Disabled
Waveguide switch : Disabled
MLSP mode : Normal
MLSP logging : Disabled
Max links : 2
Probe request interval : 1000 ms
Link hold RSSI : 15
Waveguide hold RSSI : 15
Link hold time : 4000 ms
Link switch threshold : 10
Link saturation RSSI : 150
Link establish threshold : 5
Link optimize threshold : 30
Active link keepalive count : 6
MLSP logging interval : 1000 ms
Table1-2 Command output
Mesh link initiation |
Status of the mesh link initiation feature: · Enabled. · Disabled. |
MLSP |
Status of the MLSP feature: · Enabled. · Disabled. |
MLSP optimize |
Status of MLSP link switchover optimization: · Enabled. · Disabled. |
Waveguide switch |
Fast waveguide link switchover: · Enabled. · Disabled. |
MLSP mode |
Mesh link establishment mode: · Normal. · Stable. |
MLSP logging |
Status of MLSP logging: · Enabled. · Disabled. |
Max links |
Maximum number of links. |
Link hold RSSI |
Mesh link hold RSSI. |
Waveguide hold RSSI |
Waveguide link hold RSSI. |
Link hold time |
Link hold time in milliseconds. |
Link switch threshold |
Link switch threshold. |
Link saturation RSSI |
Link saturation RSSI. |
Active link keepalive count |
Mesh link keepalive packet limit. |
Link optimize threshold |
Threshold for MLSP link switchover optimization. |
MLSP logging interval |
Interval at which MLSP logs are collected. |
Use display wlan mesh-profile to display mesh profile information.
display wlan mesh-profile [ mesh-profile-number ]
mesh-profile-number: Specifies a mesh profile by its number in the range of 1 to 32. If you do not specify a mesh profile, this command displays information about all mesh profiles.
# Display information about all mesh profiles.
<Sysname> display wlan mesh-profile
Mesh profile number : 1
Mesh ID : 11
Link keepalive interval : 2 s
Link backhaul rate : 18 Mbps
Mesh profile status : Enabled
Link metric type : Not Configured
AKM mode : None
PSK status : Disabled
Mesh profile number : 2
Mesh ID : 22
AKM mode : None
Table1-3 Command output
Mesh profile status |
Status of the mesh profile: · Enabled. · Disabled. |
AKM mode |
Authentication and key management mode: · None—No authentication and key management mode is specified. · SAE—SAE mode is specified. |
PSK status |
Preshared key configuration status: · Enabled—A preshared key is configured. · Disabled—No preshared key is configured. |
interface wlan-mesh
Use interface wlan-mesh to create a mesh interface and enter its view, or enter the view of an existing mesh interface.
Use undo interface wlan-mesh to remove a mesh interface.
interface wlan-mesh interface-number
undo interface wlan-mesh interface-number
No mesh interface exists.
interface-number: Specifies the number of the mesh interface in the range of 0 to 1023.
# Create mesh interface 3 and enter its view.
[Sysname] interface wlan-mesh 3
[Sysname-WLAN-Mesh3]
mesh-interface
link-establish-threshold
Use link-establish-threshold to set the mesh link establishment threshold.
Use undo link-establish-threshold to restore the default.
link-establish-threshold threshold-value
The mesh link establishment threshold is 5.
Mesh policy view
threshold-value: Specifies the mesh link establishment threshold in the range of 1 to 100.
An onboard MP establishes a mesh link with a trackside MP only when the link RSSI reaches or exceeds the sum of the link establishment threshold and link hold RSSI. This prevents link flapping caused by frequent mesh link establishment.
By fine adjustment of the link establishment threshold, you can control mesh link establishment without changing the link hold RSSI.
# Set the mesh link establishment threshold to 3 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-establish-threshold 3
link-hold-rssi
link-hold-rssi
Use link-hold-rssi to set the mesh link hold RSSI, the minimum signal strength for a mesh link to be retained.
Use undo link-hold-rssi to restore the default.
link-hold-rssi value
undo link-hold-rssi
The mesh link hold RSSI is 15.
Mesh policy view
value: Specifies the mesh link hold RSSI in the range of 5 to 100.
# Set the mesh link hold RSSI to 24 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-hold-rssi 24
link-hold-time
Use link-hold-time to set the link hold time, the minimum amount of time before a link switchover can occur.
Use undo link-hold-time to restore the default.
link-hold-time value
undo link-hold-time
The mesh link hold time is 4000 milliseconds.
Mesh policy view
value: Specifies a time value in the range of 1000 to 20000 milliseconds.
A link hold timer prevents frequent active link changes to ensure transmission stability in subway mesh networks.
An onboard MP switches to the optimal standby link as long as the link hold timer expires.
If the link hold timer does not expire, an onboard MP switches to the optimal standby link only when either of the following conditions is met:
· The active link's RSSI exceeds the link saturation RSSI.
· The active link's RSSI is lower than the link hold RSSI.
If no standby link is available, an MP keeps using the active link when the RSSI on the active link is lower than the link hold RSSI. The MP terminates the active link when the active link RSSI reaches or exceeds the link saturation RSSI.
# Set the link hold time to 5000 milliseconds for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-hold-time 5000
link-initiation enable
Use link-initiation enable to enable mesh link initiation.
Use undo link-initiation enable to disable mesh link initiation.
Mesh link initiation is enabled.
Mesh policy view
Mesh link initiation enables the MP to send Link Open requests to a peer without having received a Link Open request from that peer. If this feature is disabled, the MP must wait for a Link Open request from its peer before it can send one.
# Disable mesh link initiation.
[Sysname-wlan-mesh-policy-abc] undo link-initiation enable
mlsp enable
link-keepalive
Use link-keepalive to set the mesh link keepalive interval.
Use undo link-keepalive to restore the default.
link-keepalive keepalive-interval
undo link-keepalive
The mesh link keepalive interval is 2 seconds.
Mesh profile view
keepalive-interval: Specifies a keepalive interval in the range of 1 to 1800 seconds.
MPs on a mesh link use keepalive packets to detect mesh link status. The MP with a higher MAC address sends keepalive packets at the keepalive interval to the peer end. The sending MP disconnects the mesh link if it has not received a reply before three consecutive keepalive intervals expire. The receiving MP disconnects the mesh link if it has not received keepalive packets before three consecutive keepalive intervals expire. For correct link status detection, the keepalive interval at the sending end must be equal to or less than three times the keepalive interval at the receiving end.
# Set the mesh link keepalive interval to 6 seconds in mesh profile 1.
[Sysname-wlan-mesh-profile-1] link-keepalive 6
link-maximum-number
Use link-maximum-number to set the maximum number of mesh links on a radio.
Use undo link-maximum-number to restore the default.
link-maximum-number max-link-number
A maximum of two mesh links can be established on a radio.
Mesh policy view
max-link-number: Specifies a limit in the range of 1 to 8.
The MP will stop establishing new mesh links on a radio after the maximum number of mesh links is reached.
# Set the maximum number of mesh links to 5 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-maximum-number 5
link-optimize-threshold
Use link-optimize-threshold to set the threshold for MLSP link switchover optimization.
Use undo link-optimize-threshold to restore the default.
link-optimize-threshold threshold-value
The MLSP link optimization threshold is 30.
Mesh policy view
threshold-value: Specifies the MLSP link optimization threshold in the range of 15 to 80.
With MLSP link switchover optimization enabled, the system switches to the optimal mesh link if the RSSIs of secure standby links reach the threshold. A secure standby link is a link that has never been replaced by link switchover optimization.
Perform multiple on-site tests and set the threshold to a proper value based on the test results. If the threshold is too high, the device might fail to switch its mesh link in time, causing packet loss. If the threshold is two low, the mesh link in use might have a low RSSI, affecting traffic transmission.
# Set the threshold for MLSP link switchover to 45.
[Sysname-wlan-mesh-policy-abc] link-optimize-threshold 45
mlsp-optimize enable
link-saturation-rssi
Use link-saturation-rssi to set the link saturation RSSI.
Use undo link-saturation-rssi to restore the default.
link-saturation-rssi value
The link saturation RSSI is 150.
Mesh policy view
value: Specifies a link saturation RSSI value in the range of 30 to 150.
To prevent strong signal strength from affecting chip performance, an MP terminates the active link when the link's RSSI exceeds the link saturation RSSI. If MLSP is enabled, the onboard MP will try to establish an active mesh link with another mesh peer.
# Set the link saturation RSSI to 50 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-saturation-rssi 50
link-switch-threshold
Use link-switch-threshold to set the link switchover threshold.
Use undo link-switch-threshold to restore the default.
link-switch-threshold threshold-value
The link switchover threshold is 10.
Mesh policy view
threshold-value: Specifies a link switchover threshold in the range of 1 to 100.
In subway application, an onboard MP enabled with MLSP switches to a standby link when the following conditions are met:
· The link hold timer has expired.
· The RSSI on a standby link is higher than the active link RSSI and the gap reaches or exceeds the link switchover threshold.
# Set the link switchover threshold to 50 for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] link-switch-threshold 50
mesh-id
Use mesh-id to assign a mesh ID to a mesh profile.
Use undo mesh-id to restore the default.
mesh-id mesh-id
undo mesh-id
A mesh profile does not contain a mesh ID.
Mesh profile view
mesh-id: Specifies a mesh ID, a case-sensitive string of 1 to 32 characters.
The mesh ID in each mesh profile must be unique.
MPs on the same mesh network must use the same mesh ID.
# Assign mesh ID mesh to mesh profile 1.
[Sysname-wlan-mesh-profile-1] mesh-id mesh
mesh-interface
Use mesh-interface to bind a mesh interface to a radio interface.
Use undo mesh-interface to restore the default.
mesh-interface interface-number
undo mesh-interface
No mesh interface is bound to a radio interface.
Radio interface view
interface-number: Specifies the number of a mesh interface in the range of 0 to 1023.
You can bind only one mesh interface to a radio interface. If you execute this command multiple times, the most recent configuration takes effect.
# Bind mesh interface 3 to WLAN-Radio 1/0/1.
[Sysname] interface wlan-radio 1/0/1
[Sysname-WLAN-Radio1/0/1] mesh-interface 3
interface wlan-mesh
mesh peer-mac-address
Use mesh peer-mac-address to add an MP to the mesh peer blacklist or whitelist.
Use undo mesh peer-mac-address to remove MPs from the mesh peer blacklist or whitelist.
mesh peer-mac-address [ blacklist ] mac-address
undo mesh peer-mac-address [ blacklist ] [ mac-address ]
No mesh peer blacklist or whitelist exists.
blacklist: Adds the MAC address of an MP to the mesh peer blacklist. If you do not specify this keyword, the command adds the MAC address to the mesh peer whitelist.
mac-address: Specifies the MAC address of a radio interface on an MP in H-H-H format.
If you configure both the blacklist and whitelist, only the whitelist takes effect.
If you execute the command multiple times to add the same MAC address to the whitelist or blacklist, the most recent configuration takes effect.
# Add the MAC address of a radio interface on MP to the mesh peer blacklist.
[Sysname] interface wlan-radio 1/0/2
[Sysname-WLAN-Radio1/0/2] mesh peer-mac-address blacklist 4ab7-c78a-44ff
mesh-policy
Use mesh-policy to bind a mesh policy to a radio interface.
Use undo mesh-policy to restore the default.
mesh-policy name policy-name
undo mesh-policy
The default mesh policy default_mesh_policy is bound to a radio interface.
You can bind only one mesh policy to a radio interface. If you execute this command multiple times, the most recent configuration takes effect.
# Bind mesh policy policy3 to WLAN-Radio 1/0/2.
[Sysname-WLAN-Radio1/0/2] mesh-policy name policy3
wlan mesh-policy
mesh-profile
Use mesh-profile to bind a mesh profile to a radio interface.
Use undo mesh-profile to restore the default.
undo mesh-profile
No mesh profile is bound to a radio interface.
# Bind mesh profile 3 to WLAN-Radio 1/0/2.
[Sysname-WLAN-Radio1/0/2] mesh-profile 3
mesh-profile enable
wlan mesh-profile
mesh-profile enable
Use mesh-profile enable to enable a mesh profile.
Use undo mesh-profile enable to disable a mesh profile.
mesh-profile enable
A mesh profile is disabled.
Mesh profile view
Before you enable a mesh profile, you must assign it a mesh ID.
# Enable mesh profile 1.
[Sysname-wlan-mesh-profile-1] mesh-profile enable
mesh-id
mlsp enable
Use mlsp enable to enable MLSP.
Use undo mlsp enable to disable MLSP.
mlsp enable
undo mlsp enable
MLSP is disabled.
Mesh policy view
Make sure mesh link initiation is enabled before you enable MLSP.
Disabling MLSP clears all MLSP proxy settings.
# Enable MLSP.
[Sysname-wlan-mesh-policy-abc] mlsp enable
mlsp-log enable
Use mlsp-log enable to enable MLSP logging.
Use undo mlsp-log enable to disable MLSP logging.
mlsp-log enable
MLSP logging is disabled.
Mesh policy view
This feature enables the system to collect RSSIs, CPU usage, channel usage, and packet transmit rates on both ends of a mesh link at the specified intervals and generate MLSP logs. The logs are saved on the onboard MP for administrators to debug network issues.
You can execute this command only when MLSP is enabled.
# Enable MLSP logging.
[Sysname-wlan-mesh-policy-abc] mlsp-log enable
mlsp-log interval
mlsp-log interval
Use mlsp-log interval to set the MLSP logging interval.
Use undo mlsp-log interval to restore the default.
mlsp-log interval interval
The MLSP logging interval is 1000 milliseconds.
Mesh policy view
interval: Specifies the interval in the range of 500 to 4000 milliseconds.
# Set the MLSP logging interval to 2000 milliseconds.
[Sysname-wlan-mesh-policy-abc] mlsp-log interval 2000
mlsp enable
mlsp-log enable
mlsp-mode
Use mlsp-mode to specify the mesh link establishment mode.
Use undo mlsp-mode to restore the default.
mlsp-mode { normal | stable }
undo mlsp-mode
The mesh link establishment mode is normal.
Mesh policy view
Parameters:
normal: Specifies the normal mode.
stable: Specifies the stable mode.
In stable link establishment mode, an onboard MP uses the first detected link as its first active link. When the maximum number of supported links is reached, an onboard MP does not replace an existing link with a newly detected link even if the new link has a higher RSSI.
# Specify the mesh link switchover mode as stable.
[Sysname-wlan-mesh-policy-abc] mlsp-mode stable
link-maximum-number
mlsp enable
Use mlsp-optimize enable to enable MLSP link switchover optimization.
Use undo mlsp-optimize enable to disable MLSP link switchover optimization.
MLSP link switchover optimization is disabled.
Mesh policy view
In subway applications, RSSIs on onboard MPs might be greatly larger than RSSIs on trackside MPs when the train passes the trackside MPs and the MPs' antennas point to the same direction. This might cause loss of packets from onboard MPs to trackside MPs. Mesh link switchover optimization enables onboard MPs to switch to the optimal standby links in advance to avoid packet loss.
With this feature enabled, an onboard MP switches to the optimal secure standby link whose RSSI exceeds the optimization threshold after the link hold time is reached. A secure standby link is a link that has never been replaced by MLSP link switchover optimization. If an active link is replaced by MLSP link switchover optimization, the link is marked as unsecure.
To use this feature, you must perform on-site tests. If packet loss does not occur during the tests, do not configure this feature as a best practice.
# Enable MLSP link switchover optimization.
[Sysname-wlan-mesh-policy-abc] mlsp-optimize enable
mlsp-proxy
Use mlsp-proxy to specify a proxied device for MLSP proxy.
Use undo mlsp-proxy to delete all proxied devices for MLSP proxy.
mlsp-proxy mac-address mac-address vlan vlan-id [ ip ip-address ]
undo mlsp-proxy { all | mac-address mac-address [ vlan vlan-id ] }
No proxied device is specified for MLSP proxy.
Mesh policy view
mac-address mac-address: Specifies the MAC address of the proxied device.
vlan vlan-id: Specifies the VLAN ID of the proxied device.
ip ip-address: Specifies the IP address of the proxied device.
all: Specifies all proxied devices.
This feature enables an onboard MP to use the MAC address of the proxied device to send gratuitous ARP packets for MAC address table update of trackside MPs. This ensures fast transmission of downlink packets over the new active link after a link switchover.
To specify multiple proxied devices, repeat this command.
This command is unavailable when MLSP is disabled.
# Configure onboard MPs to proxy the device with MAC address 000f-e201-0101.
[Sysname-wlan-mesh-policy-abc] mlsp-proxy mac-address 000f-e201-0101 vlan 1
mlsp enable
preshared-key
Use preshared-key to add a preshared key to a mesh profile.
Use undo preshared-key to restore the default.
preshared-key { pass-phrase | raw-key } { cipher | simple } string
undo preshared-key
A mesh profile does not contain a preshared key.
Mesh profile view
pass-phrase: Sets the key in character string form.
raw-key: Sets the key in hexadecimal form.
cipher: Specifies the key in encrypted form.
simple: Specifies the key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies a case-sensitive key string. The following are the key length ranges:
· pass-phrase plaintext—8 to 63 characters.
· pass-phrase ciphertext—41 to 117 characters.
· raw-key plaintext—64 hexadecimal digits.
· raw-key ciphertext—117 characters.
Make sure the mesh profile is disabled before you use this command.
You can configure only one preshared key in a mesh profile. If you execute this command multiple times, the most recent configuration takes effect.
# Add preshared key abcdefghig in plain text to mesh profile 1.
[Sysname-wlan-mesh-profile-1] preshared-key pass-phrase simple abcdefghig
probe-request-interval
Use probe-request-interval to set the probe request interval.
Use undo probe-request-interval to restore the default.
probe-request-interval interval-value
The probe request interval is 1000 milliseconds.
Mesh policy view
interval-value: Specifies an interval in the range of 100 to 8191 milliseconds. As a best practice, set the value to a multiple of 100.
# Set the probe request interval to 500 milliseconds for mesh policy abc.
[Sysname-wlan-mesh-policy-abc] probe-request-interval 500
waveguide fast-switch
Use waveguide fast-switch to enable fast waveguide switchover.
Use undo waveguide fast-switch to disable fast waveguide switchover.
waveguide fast-switch enable
undo waveguide fast-switch enable
Fast waveguide switchover is disabled.
Mesh policy view
To avoid mesh connection failures caused by waveguide link switchover, enable fast waveguide link switchover for the mesh policies bound to both onboard and trackside MPs.
With this feature enabled, an onboard MP switches to a waveguide link once the MP detects the link.
# Enable fast waveguide link switchover.
[Sysname-wlan-mesh-policy-abc] waveguide fast-switch enable
link-hold-time
waveguide-hold-rssi
waveguide-hold-rssi
Use waveguide-hold-rssi to set the waveguide link hold RSSI.
Use undo waveguide-hold-rssi to restore the default.
waveguide-hold-rssi value
The waveguide link hold RSSI is 15.
Mesh policy view
value: Specifies the waveguide link hold RSSI in the range of 5 to 100.
If the RSSI of the waveguide active link drops below the waveguide link hold RSSI, the MP switches to the optimal waveguide link or terminates the active link.
# Set the waveguide link hold RSSI to 24.
[Sysname-wlan-mesh-policy-abc] waveguide-hold-rssi 24
wlan mesh-policy
Use wlan mesh-policy to create a mesh policy and enter its view, or enter the view of an existing mesh policy.
Use undo wlan mesh-policy to delete a mesh policy.
wlan mesh-policy policy-name
undo wlan mesh-policy policy-name
A system-defined mesh policy exists. The policy name is default_mesh_policy.
Before you can modify or delete attribute settings in the mesh policy that is used on a radio, you must disable the mesh profile that is bound to that radio.
You cannot delete or modify the system-defined mesh policy.
# Create mesh policy abc and enter mesh policy view.
wlan mesh-profile
Use wlan mesh-profile to create a mesh profile and enter its view, or enter the view of an existing mesh profile.
Use undo wlan mesh-profile to delete a mesh profile.
wlan mesh-profile mesh-profile-number
undo wlan mesh-profile mesh-profile-number
No mesh profiles exist.
To modify attribute settings in a mesh profile, you must first disable the mesh profile.
# Create mesh profile 1 and enter its view.
mesh-profile enable
