| 04-WLAN high availability commands | 39.26 KB |
1 WLAN high availability commands
Dual-link backup commands
backup-ac
Use backup-ac to specify a backup AC.
Use undo backup-ac to remove the backup AC configuration.
backup-ac { ip ipv4-address | ipv6 ipv6-address }
undo backup-ac { ip | ipv6 }
In AP view, an AP uses the configuration in AP group view.
In AP group view, no backup AC is specified.
AP view
AP group view
ip ip-address: Specifies a backup AC by its IPv4 address.
ipv6 ipv6-address: Specifies a backup AC by its IPv6 address.
You can specify only one IPv4 address or one IPv6 address in either AP view or AP group view.
The configuration in AP view takes precedence over the configuration in AP group view. If you execute the undo command in AP view, the backup AC specified in AP group view will be used.
Executing the undo command also terminates the backup CAPWAP tunnel.
# Specify a backup AC for AP ap1.
[Sysname] wlan ap ap1 model WA6330
[Sysname-wlan-ap-ap1] backup-ac ip 192.168.1.1
# Specify a backup AC for AP group group1.
[Sysname] wlan ap-group 1
[Sysname-wlan-ap-group-1] backup-ac ip 192.168.1.1
wlan tunnel-preempt
Use wlan tunnel-preempt enable to enable master CAPWAP tunnel preemption.
Use wlan tunnel-preempt disable to disable master CAPWAP tunnel preemption.
Use undo wlan tunnel-preempt to restore the default.
wlan tunnel-preempt { disable | enable }
In AP view, an AP uses the configuration in AP group view. If no configuration exists in AP group view, the AP uses the configuration in global configuration view.
In AP group view, an AP uses the configuration in global configuration view.
In global configuration view, master CAPWAP tunnel preemption is disabled.
AP view
AP group view
Global configuration view
When this feature is enabled, the backup CAPWAP tunnel will become the master tunnel if the backup AC has higher AP connection priority than the master AC.
When this feature is disabled, the backup CAPWAP tunnel becomes the master tunnel only when the master AC fails.
# Enable master CAPWAP tunnel preemption for AP ap1.
[Sysname-ap-ap1] wlan tunnel-preempt enable
# Enable master CAPWAP tunnel preemption for APs in AP group group1.
[Sysname] wlan ap-group group1
[Sysname-wlan-ap-group-group1] wlan tunnel-preempt enable
# Enable master CAPWAP tunnel preemption globally.
[Sysname] wlan global-configuration
[Sysname-wlan-global-configuration] wlan tunnel-preempt enable
