- 11-NMM Command Reference
- 02-NQA commands
- 03-iNQA commands
- 04-NTP commands
- 05-PTP commands
- 06-Network synchronization commands
- 07-PoE commands
- 08-SNMP commands
- 09-RMON commands
- 10-Event MIB commands
- 11-NETCONF commands
- 12-SmartMC commands
- 13-EPA commands
- 14-ONVIF commands
- 15-CWMP commands
- 16-EAA commands
- 17-Process monitoring and maintenance commands
- 18-Mirroring commands
- 19-sFlow commands
- 20-Information center commands
- 21-Packet capture commands
- 22-VCF fabric commands
- 23-Cloud connection commands
- 24-EPS agent commands
- 25-eMDI commands
- 26-SQA commands
| 00-Preface | 100.53 KB |
Preface
This command reference describes the configuration commands for network management and monitoring features. It covers the commands for viewing system information, collecting traffic statistics, assessing the network performance, synchronizing time for all devices with clocks in your network, and checking and debugging the current network connectivity with the ping, tracert, and debug commands.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
