10-High Availability Command Reference
HomeSupportReference GuidesCommand ReferencesH3C S6520X & S6520-SI & S5560X-HI & S5000-EI & MS4600 Command References-R6615Pxx-6W10110-High Availability Command Reference
09-BFD commands
09-BFD commands 230.90 KB
BFD commands
Basic BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
BFD template view
Static BFD session view
hmac-md5: Specifies the HMAC MD5 algorithm.
hmac-mmd5: Specifies the HMAC Meticulous MD5 algorithm.
hmac-msha1: Specifies the HMAC Meticulous SHA1 algorithm.
hmac-sha1: Specifies the HMAC SHA1 algorithm.
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enhance BFD session security.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure VLAN-interface 11 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname-Vlan-interface11] bfd authentication-mode simple 1 plain 123456
bfd dampening
Use bfd dampening to configure BFD session flapping suppression.
Use undo bfd dampening to disable BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
undo bfd dampening
BFD sessions are not suppressed.
maximum-interval: Specifies the maximum amount of time a BFD session is suppressed, in the range of 1 to 3600 seconds. The default is 20 seconds.
initial-interval: Specifies the amount of time a BFD session is suppressed for the first time. The value range for the initial-interval argument is 1 to 3600 seconds. The default is 6 seconds.
secondary-interval: Specifies the amount of time a BFD session is suppressed for the second time. The value range for the secondary-interval argument is 1 to 3600 seconds. The default is 10 seconds.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
This command allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·     A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·     After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·     After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·     After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡     If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡     If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
# Enable BFD session flapping suppression, and set the maximum-interval, initial-interval, and secondary-interval to 12 seconds, 4 seconds, and 8 seconds, respectively.
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd demand enable
bfd detect-interface first-fail-timer
Use bfd detect-interface first-fail-timer to configure the timer that delays reporting the first BFD session establishment failure to the data link layer.
Use undo bfd detect-interface first-fail-timer to restore the default.
bfd detect-interface first-fail-timer seconds
The first BFD session establishment failure is not reported to the data link layer.
Interface view
seconds: Specifies the timeout time that reports the first BFD session establishment failure to the data link layer. The value range for this argument is 1 to 10000 seconds.
If the BFD session fails to be established when the timer expires, BFD reports the failure to the data link layer and sets the data link layer state of the interface to DOWN(BFD). This behavior rapidly identifies the interfaces for which BFD sessions fail to be established. In this case, the BFD session state is displayed as Down in the display bfd session command output. The line protocol state of the interface is displayed as DOWN(BFD) in the display interface command output.
If the local end is configured with the bfd detect-interface command, the BFD session for detecting the local interface state fails to be established when the following conditions exist:
·     The remote end is not configured with the bfd detect-interface command.
·     The local and remote ends have mismatching BFD authentication settings.
# Configure the timer that delays reporting the first BFD session establishment failure as 10 seconds.
[Sysname-Vlan-interface11] bfd detect-interface first-fail-timer 10
display interface (Interface Command Reference)
bfd detect-interface source-ip
Use bfd detect-interface source-ip to associate the interface state with BFD.
Use undo bfd detect-interface to remove the association between the interface state and BFD.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ] [ template template-name ]
The interface state is not associated with BFD. BFD does not set the link layer protocol of the interface to DOWN(BFD) state when detecting a failure.
Interface view
ip-address: Specifies the source IP address for BFD control packets.
discriminator: Specifies BFD session discriminators. If you do not specify discriminators, the device obtains BFD session discriminators through autonegotiation.
local local-value: Specifies the local discriminator. The value range for the local-value argument is 97 to 128.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
template template-name: Specifies a template by its name, a case-sensitive string of 1 to 63 characters. If you do not specify a template, the BFD session uses the BFD parameters configured in interface view.
By creating a BFD session for single-hop detection through exchange of BFD control packets, this feature implements fast link detection. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence.
The source IP address of control packets is specified manually, and the destination IP address is fixed at 224.0.0.184. As a best practice, specify the IP address of the interface as the source IP address. If the interface does not have an IP address, specify a unicast IP address other than 0.0.0.0 as the source IP address.
You can associate the state of the following interfaces with BFD:
·     Layer 2 Ethernet interfaces.
·     Member ports in a Layer 2 aggregation group.
·     Layer 3 Ethernet interfaces.
·     Member ports in a Layer 3 aggregation group.
·     Layer 3 Ethernet subinterfaces.
·     VLAN interfaces.
·     Layer 2 aggregate interfaces.
·     Layer 3 aggregate interfaces.
·     Layer 3 aggregate subinterfaces.
This command must be executed on both ends of the link for a BFD session to be established.
If you execute both the bfd detect-interface and bfd echo enable commands for an interface, only the bfd detect-interface command takes effect.
For BFD detection to take effect, do not execute this command on both a Layer 3 Ethernet interface and its subinterface.
For BFD detection to take effect, do not execute this command on both a Layer 2 Ethernet interface and the VLAN interface created for the VLAN to which the Layer 2 Ethernet interface is assigned.
To configure this command on the following interfaces at the same time, you must manually specify the local and remote discriminators on each of the interfaces:
·     A Layer 3 aggregate interface.
·     A subinterface of the Layer 3 aggregate interface.
·     A member port of the Layer 3 aggregate interface.
As a best practice, do not configure this command on these interfaces at the same time.
For BFD detection to take effect, do not execute this command on the following interfaces at the same time:
·     A Layer 2 aggregate interface.
·     A member port of the Layer 2 aggregate interface.
·     The VLAN interface to which the Layer 2 aggregate interface belongs.
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd detect-interface source-ip 20.1.1.1 discriminator local 513 remote 514 on the local device, you must configure bfd detect-interface source-ip 20.1.1.2 discriminator local 514 remote 513 on the peer device.
The local discriminators of BFD sessions for interfaces on the same device must be different.
The echo function does not take effect on BFD sessions associated with interface states.
# Create a BFD session to detect the state of VLAN-interface 10, and specify the source IP address as 20.1.1.1.
[Sysname-Vlan-interface10] bfd detect-interface source-ip 20.1.1.1
bfd detect-interface special-processing
Use bfd detect-interface special-processing to enable special processing for BFD sessions.
Use undo bfd detect-interface special-processing to disable special processing for BFD sessions.
bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
undo bfd detect-interface special-processing [ admin-down | authentication-change | session-up ] *
All types of special processing for BFD sessions are disabled.
Interface view
admin-down: Notifies a session down event to the data link layer upon receipt of a BFD packet with the State field as AdminDown. This keyword helps rapidly discover interfaces that BFD sessions are manually shut down. If you do not specify this keyword, the device sets the BFD session state to Down, but does not notify the session down event to the data link layer.
authentication-change: Immediately sets the session to down state upon a local authentication information change. This keyword helps rapidly discover interfaces with authentication information changes. If you do not specify this keyword, the device sets the session to down state if authentication information inconsistency still persists after a period of time.
session-up: Ignores authentication information inconsistency when the local session is up. If there is a large number of BFD sessions, examining authentication information consistency affects device performance. If you do not specify this keyword, the device examines authentication information in incoming BFD packets when the local session state is up. If the authentication information does not match on the two ends, the BFD session is declared down.
If you do not specify any parameters, this command enables or disables all types of special processing.
# Enable all types of special processing for BFD sessions on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd detect-interface special-processing admin-down authentication-change session-up
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode are both 5.
Interface view
BFD template view
value: Specifies a detection time multiplier. The value range for this argument is 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Actual detection interval calculation method
Mode
Actual detection interval of the sender
Echo packet mode
Detection time multiplier of the sender × actual packet sending interval of the sender
Control packet mode BFD session in asynchronous mode
Detection time multiplier of the receiver × MAX (minimum receiving interval supported by the sender, minimum sending interval supported by the receiver)
Control packet mode BFD session in demand mode
Detection time multiplier of the sender × MAX (minimum sending interval supported by the sender, minimum receiving interval supported by the receiver)
# Set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode to 6 on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo function.
Use undo bfd echo enable to disable the echo function.
undo bfd echo [ receive | send ] enable
The echo function is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo function for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
·     Periodically sends echo packets to detect link connectivity.
·     Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
The echo function does not take effect on control-mode BFD sessions established with IPv6 link-local addresses.
# Enable the echo function on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets. The source IP address must be a valid unicast IPv4 address in dotted decimal notation.
The source IP address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
The source IPv6 address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd init-fail-timer
Use bfd init-fail-timer to set the delay timer for BFD to notify upper-layer protocols of session establishment failures.
Use undo bfd init-fail-timer to restore the default.
bfd init-fail-timer seconds
BFD does not notify upper-layer protocols of session establishment failures.
seconds: Specifies the delay time in the range of 5 to 600 seconds. After the delay time, BFD notifies the upper-layer protocol of session establishment failures.
CAUTION
CAUTION:
For session establishment failures caused by configuration mismatches at the two ends, this command can cause the upper-layer protocol to act incorrectly. Therefore, use this command with caution. BFD status mismatch and BFD authentication configuration mismatch are examples of configuration mismatches.
This command takes effect only for control packet mode.
In some cases, for an upper-layer protocol to act correctly, BFD must notify the upper-layer protocol of session establishment failures. For example, with this command configured, the link aggregation module can promptly set the state of a member port from Selected to Unselected in the case of a link failure.
# Set the delay timer to 10 seconds for BFD to notify upper-layer protocols of session establishment failures.
[Sysname] bfd init-fail-timer 10
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
The minimum interval for receiving BFD echo packets is 400 milliseconds.
Interface view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value takes 0 or is in the range of 100 to 1000.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
·     The echo packet mode is enabled on the local end.
·     The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-echo-receive-interval 500
bfd min-receive-interval
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
The minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
·     Minimum interval for transmitting BFD control packets on the peer end.
·     Minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-receive-interval 500
bfd min-transmit-interval
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
The minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
Interface view
BFD template view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000.
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
The actual single-hop BFD control packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting single-hop BFD control packets on the local end.
·     Minimum interval for receiving single-hop BFD control packets on the peer end.
The values that can actually take effect for this command are 3, 10, 100, 400, and 1000. If the negotiated interval is none of these values, the smallest one closest to the negotiated interval applies. For example, the actual single-hop BFD control packet transmitting interval on the local end is 400 milliseconds if the following conditions exist:
·     The minimum interval for transmitting single-hop BFD control packets on the local end is 500 milliseconds.
·     The minimum interval for receiving single-hop BFD control packets on the peer end is 3 milliseconds.
·     The negotiated interval is 500 milliseconds.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-transmit-interval 500
bfd multi-hop authentication-mode
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { hmac-md5 | hmac-mmd5 | hmac-msha1 | hmac-sha1 | m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd static
bfd multi-hop destination-port
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier for control packet mode is 5.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Actual detection interval calculation method
Mode
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
bfd static
bfd multi-hop min-receive-interval
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
The minimum interval for receiving multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for receiving multihop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
bfd static
bfd multi-hop min-transmit-interval
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
The minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds. The value range for this argument is 3 to 1000.
The actual multihop BFD control packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting multihop BFD control packets on the local end.
·     Minimum interval for receiving multihop BFD control packets on the peer end.
The values that can actually take effect for this command are 3, 10, 100, 400, and 1000. If the negotiated interval is none of these values, the smallest one closest to the negotiated interval applies. For example, the actual multihop BFD control packet transmitting interval on the local end is 400 milliseconds if the following conditions exist:
·     The minimum interval for transmitting multihop BFD control packets on the local end is 500 milliseconds.
·     The minimum interval for receiving multihop BFD control packets on the peer end is 3 milliseconds.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd static
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
bfd static
Use bfd static to create a static BFD session and enter its view, or enter the view of an existing static BFD session.
Use undo bfd static to delete a static BFD session and all its settings.
For IPv4 single-hop detection:
bfd static session-name [ peer-ip ipv4-address interface interface-type interface-number source-ip ipv4-address [ discriminator local local-value remote remote-value ] ]
For IPv6 single-hop detection:
bfd static session-name [ peer-ipv6 ipv6-address interface interface-type interface-number source-ipv6 ipv6-address[ discriminator local local-value remote remote-value ] ]
For IPv4 multihop detection:
bfd static session-name [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] source-ip ipv4-address [ discriminator local local-value remote remote-value ] [ track-interface interface-type interface-number ] ]
For IPv6 multihop detection:
bfd static session-name [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] source-ipv6 ipv6-address [ discriminator local local-value remote remote-value ] [ track-interface interface-type interface-number ] ]
undo bfd static session-name
No static BFD sessions exist.
session-name: Specifies a static BFD session name, a case-sensitive string of 1 to 64 characters.
peer-ip ipv4-address: Specifies the peer IPv4 address in dotted decimal notation. It must be a valid unicast IPv4 address. The peer IPv4 address and the source IPv4 address determine the path to be detected.
peer-ipv6 ipv6-address: Specifies the peer IPv6 address. The peer IPv6 address and the source IPv6 address determine the path to be detected.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the static BFD session belongs to the public network.
interface interface-type interface-number: Specifies an interface by its type and number. BFD uses the specified interface as the outgoing interface for outgoing packets.
source-ip ipv4-address: Specifies the source IPv4 address for control packets, in dotted decimal notation. It must be a valid unicast IPv4 address.
peer-ipv6 ipv6-address: Specifies the source IPv6 address for control packets.
local local-value: Specifies the local discriminator in the range of 1 to 32768.
track-interface interface-type interface-number: Specifies an interface monitored by the static BFD session. When the monitored interface fails, the static BFD session changes to the down state. If you do not specify an interface, the static BFD session does not monitor any interfaces.
A static BFD session can be used for single-hop detection and multihop detection. By working with Track, a static BFD session can provide fast failure detection. For more information about Track association with BFD, see Track in High Availability Configuration Guide.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd static abc peer-ip 20.1.1.1 vpn-instance vpn1 source-ip 20.1.1.2 discriminator local 513 remote 514 on the local device, you must configure bfd static bcd peer-ip 20.1.1.2 vpn-instance vpn1 source-ip 20.1.1.1 discriminator local 514 remote 513 on the peer device.
When creating a static BFD session, you must specify a peer IP address. The system checks only the format of the IP address but not its correctness. If the peer IPv4 or IPv6 address is incorrect, the static BFD session cannot be established.
If you do not specify the local discriminator or remote discriminator when creating a static BFD session, you must perform either of the following tasks for the BFD session to take effect:
·     Use the discriminator command to specify the local discriminator and remote discriminator for the static BFD session.
·     Execute the undo bfd static command and then execute the bfd static command to re-create the static BFD session with the local and remote discriminators specified.
The bfd static session-name command without any parameters specified can only be used to enter the view of an existing static BFD session.
If you use a static BFD session in control packet mode to perform single-hop detection, make sure the following requirements are met for the BFD session to be successfully established:
·     The IP address of the peer interface where the static BFD session resides is used as the peer IP address.
·     The IP address of the local interface where the static BFD session resides is used as the source IP address.
To modify a static BFD session, delete the static BFD session and then configure a new static BFD session.
Different static BFD sessions cannot have the same local discriminator.
A static BFD session can monitor the following interfaces:
·     Layer 3 Ethernet interfaces and their subinterfaces.
·     Layer 2 aggregate interfaces and their member ports.
·     Layer 3 aggregate interfaces and their subinterfaces and member ports.
# Create a static BFD session and enter its view. The static BFD session detects the link with the outgoing interface VLAN-interface 10 and the next hop 1.1.1.2. The source IP address for the session is 1.1.1.1, the local discriminator is 1537, and the remote discriminator is 2048.
[Sysname] bfd static abc peer-ip 1.1.1.2 interface vlan-interface 10 source-ip 1.1.1.1 discriminator local 1537 remote 2048
[Sysname-bfd-static-session-abc]
discriminator
track bfd
bfd template
Use bfd template to create a BFD template and enter its view, or enter the view of an existing BFD template.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD templates exist.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
discriminator
Use discriminator to specify the local and remote discriminators for a static BFD session.
Use undo discriminator to remove the local and remote discriminator for the static BFD session.
discriminator { local local-value | remote remote-value }
undo discriminator { local local-value | remote remote-value }
No local and remote discriminators are specified for a static BFD session.
Use this command only if you do not specify the local or remote discriminator when creating a static BFD session.
To modify the local or remote discriminator of a static BFD session, execute the undo discriminator and then the discriminator command to specify a new local or remote discriminator.
# Create local discriminator 1537 and remote discriminator 2048 for static BFD session abc.
[Sysname-bfd-static-session-abc] discriminator local 1537
[Sysname-bfd-static-session-abc] discriminator remote 2048
bfd static
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator local local-value | static session-name | verbose ]
display bfd session [ [ dynamic ] [ control | echo ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ] ]
display bfd session [ [ dynamic ] [ control | echo ] [ lsp | te | pw ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] | [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] ] [ verbose ] ]
display bfd session [ [ static ] [ ip ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ip ipv4-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
display bfd session [ [ static ] [ ipv6 ] [ state { down | admin-down | init | up } ] [ discriminator remote remote-value ] [ peer-ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ] [ verbose ]
discriminator local local-value: Specifies a BFD session by its local discriminator in the range of 1 to 4294967295.
static session-name: Specifies a static BFD session by its name, a case-sensitive string of 1 to 64 characters.
dynamic: Specifies dynamic BFD sessions.
static: Specifies static BFD sessions.
control: Specifies BFD sessions in control packet mode.
echo: Specifies BFD sessions in echo mode.
ip: Specifies BFD sessions used to detect IPv4 links.
ipv6: Specifies BFD sessions used to detect IPv6 links.
lsp: Specifies BFD sessions used to detect MPLS LSPs.
te: Specifies BFD sessions used to detect MPLS TE tunnels.
pw: Specifies BFD sessions used to detect PWs.
state: Displays BFD sessions by session state.
down: Specifies BFD sessions in Down state.
admin-down: Specifies BFD sessions in AdminDown state.
init: Specifies BFD sessions in Init state.
up: Specifies BFD sessions in Up state.
discriminator remote remote-value: Specifies a BFD session by its remote discriminator in the range of 1 to 4294967295.
peer-ip ipv4-address: Specifies a BFD session by the peer IPv4 address in dotted decimal notation.
peer-ipv6 ipv6-address: Specifies a BFD session by the peer IPv6 address.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays the BFD sessions of the public network.
verbose: Displays detailed BFD session information.
If you do not specify the dynamic or static keyword, this command displays all dynamic and static BFD sessions.
# Display brief information about all BFD sessions.
<Sysname> display bfd session
 Total sessions: 8        Up sessions: 8        Init mode: Active
 LD/RD            SourceAddr      DestAddr        State  Holdtime    Interface
 513/513          1.1.1.1         1.1.1.2         Up     2297ms      Vlan100
 IPv6 session working in control packet mode:
       Local discr: 513                  Remote discr: 513
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session state: Up                      Interface: Vlan100
         Hold time: 2142ms
 MPLS LSP session working in control packet mode:
 32773/32770     1.1.1.9         3.3.3.9         Up      0ms         N/A
 IPv4 static session working in control packet mode:
 1600/1600        1.1.1.1         1.1.1.2         Up     2290ms      Vlan100
 IPv6 static session working in control packet mode:
       Local discr: 1700                  Remote discr: 1700
         Hold time: 2142ms
 MPLS TE session working in control packet mode:
 2050/2050      1.1.1.1         127.0.0.1       Up       2458ms      N/A
 MPLS TE session working in echo mode:
 LD             SourceAddr      DestAddr        State    Holdtime    Interface
 2051           1.1.1.1         3.3.3.3         Up       4851ms      Tun2
 MPLS PW session working in control packet mode:
 20481/20481    2.2.2.2         127.0.0.1       Up       2489ms      N/A
Total Session Num
Total number of BFD sessions.
Up Session Num
Total number of active BFD sessions.
Init Mode
BFD operating mode: Active or passive.
BFD session type and operating mode:
·     IPv4 session working in control packet mode.
·     IPv4 session working in echo mode.
·     IPv6 session working in control packet mode.
·     IPv6 session working in echo mode.
·     MPLS LSP session working in control packet mode—BFD session in control packet mode used to detect failures in an LSP.
·     MPLS LSP session working in echo mode—BFD session in echo packet mode used to detect failures in an LSP.
·     IPv4 static session working in control packet mode.
·     IPv6 static session working in control packet mode.
·     MPLS TE session working in control packet mode—BFD session in control packet mode used to detect failures of an MPLS TE tunnel.
·     MPLS TE session working in echo mode—BFD session in echo mode used to detect failures of an MPLS TE tunnel.
·     MPLS PW session working in control packet mode—BFD session in control packet mode used to detect failures of an LDP PW or static PW.
·     MPLS PW session working in echo mode—BFD session in echo mode used to detect failures of an LDP PW or static PW.
·     MPLS TE static session working in control packet mode—Static BFD session in control packet mode used to detect failures of an MPLS TE tunnel.
·     MPLS TE static session working in echo mode—Static BFD session in echo mode used to detect failures of an MPLS TE tunnel.
·     MPLS PW static session working in control packet mode—Static BFD session in control packet mode used to detect failures of an LDP PW or static PW.
LD/RD
Local discriminator/Remote discriminator of the session.
SourceAddr
Source IP address of the session.
DestAddr
Destination IP address of the session.
Session State/State
Session state: Down, Init, or Up.
Name of the interface of the session.
Hold Time/Holdtime
Length of time before the session detection timer expires, in milliseconds.
For a BFD session in Down state, this field displays 0ms.
Local discr
Local discriminator of the session.
Remote discr
Source IP
Source IPv6 address of the session.
Destination IP
Destination IPv6 address of the session.
# Display detailed BFD session information.
<Sysname> display bfd session verbose
            Source IP: 1.1.1.1                  Destination IP: 1.1.1.2
     Destination port: 3784                      Session state: Up
            Interface: Vlan-interface100
      Min Tx interval: 500ms                Actual Tx interval: 500ms
      Min Rx interval: 500ms                    Detection time: 2500ms
             Rx count: 42                             Tx count: 43
      Connection type: Direct                      Up duration: 00:00:20
            Hold time: 2078ms                        Auth mode: None
          Detect mode: Async                              Slot: 0
             Protocol: OSPF
              Version:1
            Diag info: No Diagnostic
    Tracked interface: Vlan-interface100
             Rx count: 38                             Tx count: 38
      Connection type: Direct                      Up duration: 00:00:15
            Hold time: 2211ms                        Auth mode: None
       Detection mode: Async                              Slot: 0
             Protocol: OSPFv3
              Version: 1
          Local discr: 32774                      Remote discr: 32770
            Source IP: 1.1.1.9                  Destination IP: 3.3.3.9
     Destination port: 4784                      Session state: Up
            Interface: N/A
      Min Tx interval: 1000ms               Actual Tx interval: 3000ms
      Min Rx interval: 1000ms                   Detection time: 150000ms
             Rx count: 1                              Tx count: 13
      Connection type: Indirect                    Up duration: 00:00:36
            Hold time: 0ms                           Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
      Session name: aaaa
          Local discr: 1600                       Remote discr: 1600
             Protocol: STATIC_IPv4
              Version: 1
      Session name: bbbb
             Protocol: STATIC_IPv6
              Version: 1
          Local discr: 2050                       Remote discr: 2050
            Source IP: 1.1.1.1                  Destination IP: 127.0.0.1
            Interface: N/A
             Rx count: 72                             Tx count: 73
      Connection type: Indirect                    Up duration: 00:00:30
            Hold time: 2458ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
          Local discr: 2051
            Source IP: 1.1.1.1                  Destination IP: 3.3.3.3
     Destination port: 3785                      Session state: Up
            Interface: Tunnel2
            Hold time: 4851ms               Actual Tx interval: 1000ms
      Min Rx interval: 1000ms                   Detection time: 5000ms
             Rx count: 9083                           Tx count: 9637
      Connection type: Indirect                    Up duration: 02:20:42
             Protocol: MPLS_LSPV
              Version: 1
          Local discr: 20481                      Remote discr: 20481
            Source IP: 2.2.2.2                  Destination IP: 127.0.0.1
            Interface: N/A
            Hold time: 2489ms                        Auth mode: None
             Protocol: MPLS_LSPV
              Version: 1
Total sessions
Up sessions
Init mode
·     MPLS LSP session working in echo mode—BFD session in echo mode used to detect failures in an LSP.
·     MPLS TE session working in control packet mode.
·     MPLS TE session working in echo mode.
·     MPLS PW session working in control packet mode.
·     MPLS PW session working in echo mode.
·     MPLS TE static session working in control packet mode.
·     MPLS TE static session working in echo mode.
·     MPLS PW static session working in control packet mode.
Local discr
Remote discr
Source IP
Destination IP
Destination port
Destination port number in BFD packets defined in Comware:
·     The destination port number in single-hop BFD control packets is 3784.
·     The destination port number in single-hop or multihop BFD echo packets is 3785.
·     The destination port number in multihop BFD control packets is 4784.
·     The destination port number in BFD control packets for association between link aggregation and BFD is 6784.
The device uses the destination port number in incoming packets that are not defined in Comware as the destination port number in outgoing BFD packets.
Session state
Session state: Down, AdmDown, Init, or Up.
Min Tx interval
Minimum transmit interval.
Min Rx interval
Minimum receive interval.
Actual Tx interval
Actual transmit interval.
Detection time
Actual session detection timer.
Rx count
Number of packets received.
Tx count
Number of packets sent.
Hold time
Length of time before session detection timer expires.
For a BFD session in down state, this field displays 0ms.
Auth mode
Session authentication mode.
Connection type
Connection type of the interface: Direct or Indirect.
Up duration
Time period for which the session has been up.
Detect mode
Detection mode:
·     Async—Asynchronous mode.
·     Demand—Demand mode.
·     Async/Echo—Asynchronous mode with echo detection enabled.
·     Demand/Echo—Demand mode with echo detection enabled.
Slot
Slot number of the card where the BFD session resides.
Protocol
Protocol associated with BFD:
·     OSPF.
·     ISIS_BR_L1—IS-IS with the network type as broadcast and the router type as Level 1.
·     ISIS_BR_L2—IS-IS with the network type as broadcast and the router type as Level 2.
·     ISIS_P2P—IS-IS with the network type as P2P.
·     ISIS6_BR_L1—IPv6 IS-IS with the network type as broadcast and the router type as Level 1.
·     ISIS6_BR_L2—IPv6 IS-IS with the network type as broadcast and the router type as Level 2.
·     ISIS6_P2P—IPv6 IS-IS with the network type as P2P.
·     BGP.
·     MPLS_RSVP.
·     STATIC4—IPv4 static routing.
·     TRACK—Track.
·     RIP.
·     IPFRR—FIB IP FRR.
·     MAD.
·     MPLS_LSPV.
·     OSPFv3.
·     BGP4+.
·     PIM.
·     PIM6—IPv6 PIM.
·     STATIC6—IPv6 static routing.
·     RIPNG—RIPng.
·     Interface—Interface state.
·     TUNNEL.
·     VTEP.
·     LAGG—Link aggregation.
·     STATIC_IPv4—IPv4 static BFD session.
·     STATIC_IPv6—IPv6 static BFD session.
Diag info
Diagnostic information about the session:
·     No Diagnostic.
·     Control Detection Time Expired—A control-mode BFD session goes down because local detection times out.
·     Echo Function Failed—An echo-mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted.
·     Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down.
·     Administratively Down—The local system prevents a BFD session from being established.
Tracked interface
Interface monitored by the static BFD session.
bfd static
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
SBFD commands
Use bfd detect-multiplier to set the detection time multiplier in BFD template view.
The detection time multiplier is 5.
BFD template view
value: Specifies a detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of SBFD control packets that an initiator can discard continuously.
The detection time is the detection time multiplier of the initiator multiplied by the minimum SBFD packet sending interval of the initiator.
# In BFD template abc, set the detection time multiplier to 6.
[Sysname] bfd template abc
[Sysname-bfd-template-abc] bfd detect-multiplier 6
Use bfd min-transmit-interval to set the minimum interval for transmitting SBFD control packets in BFD template view.
The minimum interval for transmitting SBFD control packets is 400 milliseconds.
BFD template view
interval: Specifies the minimum interval for transmitting SBFD control packets, in milliseconds. The value range is 3 to 1000.
Use this command to prevent the SBFD control packet sending rate from exceeding the device capability.
The actual SBFD control packet transmitting interval is the set minimum interval.
# In BFD template abc, set the minimum interval for transmitting SBFD control packets to 500 milliseconds.
[Sysname-bfd-template-abc] bfd min-transmit-interval 500
Use bfd multi-hop detect-multiplier to set the detection time multiplier in system view.
# Set the detection time multiplier to 6.
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting SBFD control packets in system view.
# Set the minimum interval for transmitting SBFD control packets to 500 milliseconds.
bfd template
display sbfd session
Use display sbfd session to display SBFD session information.
display sbfd session { initiator | reflector } [ discriminator value | verbose ]
initiator: Displays SBFD session information for the initiator.
reflector: Displays SBFD session information for the reflector.
discriminator value: Specifies a local discriminator in the range of 1 to 4294967295.
verbose: Displays detailed information about all SBFD sessions.
If you do not specify the discriminator or verbose keyword, this command displays brief information about all SBFD sessions.
# Display brief information about all SBFD sessions for the initiator.
<Sysname> display sbfd session initiator
 Total Session Num: 1     Up Session Num: 1
 SBFD Session (MPLS LSP):
        Local Discr: 1                        Remote Discr: 1000001
          Source IP: 1.1.1.1
      Session State: Up
          Hold Time: 2184ms
Table 5 Command output
Total Session Num
Total number of SBFD sessions.
Up Session Num
Number of active SBFD sessions.
SBFD sessions created by MPLS.
Local Discr
Remote Discr
Source IP
Destination IP
Session State
Session state: Down or Up.
Hold Time
For an SBFD session in Down state, this field displays 0ms.
# Display detailed information about the SBFD session with local discriminator 2 for the initiator.
<Sysname> display sbfd session initiator discriminator 2
       Local Discr: 2                    Remote Discr: 1000002
         Source IP: 1.1.1.2            Destination IP: 127.0.0.2
     Session State: Up                      Hold Time: 4130ms
      Min Tx Inter: 500ms                Act Tx Inter: 1000ms
      Detect Inter: 5000ms             Running Up for: 00:01:30
          Rx Count: 100                      Tx Count: 100
              Slot: 0
          Protocol: MPLS_LSPV
         Diag Info: No Diagnostic
     Template Name: abc
Table 6 Command output
Local Discr
Remote Discr
Source IP
Destination IP
Session State
Hold Time
Min Tx Inter
Minimum SBFD packet transmission interval in milliseconds.
Act Tx Inter
Actual SBFD packet transmission interval in milliseconds.
Detect Inter
Actual session detection timer in milliseconds.
Running up for
Rx Count
Tx Count
Diag Info
·     No Diagnostic.
·     Control Detection Time Expired—The SBFD session goes down because local detection times out.
·     Neighbor Signaled Session Down—The remote end notifies the local end of SBFD session down.
Template Name
Template associated with the session. If no template is associated, this field is not displayed.
# Display detailed information about all SBFD sessions for the initiator.
<Sysname> display sbfd session initiator verbose
              Slot: 0
          Protocol: MPLS_LSPV
     Template Name: abc
Table 7 Command output
Total Session Num
Up Session Num
Local Discr
Remote Discr
Source IP
Destination IP
Session State
Hold Time
Min Tx Inter
Minimum SBFD packet transmission interval.
Act Tx Inter
Actual SBFD packet transmission interval.
Detect Inter
Running up for
Rx Count
Tx Count
Diag Info
·     No Diagnostic.
Template Name
# Display brief information about all SBFD sessions for the reflector.
<Sysname> display sbfd session reflector
 Local discriminator 1000001 on slot 0
 Configured mode: Explicit value
        Local Discr: 1000001                  Remote Discr: 1
          Source IP: 2.2.2.1
     Destination IP: 1.1.1.1
          Hold Time: 2200ms
           VRF Name: vpn1
Table 8 Command output
Configured mode
Discriminator type:
·     IP Address—IPv4 address.
·     Explicit Value—Integer.
Total Session Num
Local Discr
Remote Discr
Source IP
Destination IP
Hold Time
VRF Name
VPN instance bound to the interface where the packets of the SBFD session are received.
If no VPN instance is bound to the interface, this field displays a hyphen (-).
# Display detailed information about the SBFD session with local discriminator 1000001 for the reflector.
<Sysname> display sbfd session reflector discriminator 1000001
 Configured mode: IP Address
 Total Session Num: 2
         Source IP: 2.2.2.1            Destination IP: 1.1.1.1
      Min Tx Inter: 500ms                Min Rx Inter: 10ms
      Detect Multi: 5                  Running Up for: 00:02:30
     Max Rx Period: 498ms               Max Tx Period: 1280us
         Hold Time: 2200ms
          VRF Name: vpn1
      Local Discr: 1000001              Remote Discr: 2
         Source IP: 2.2.2.2            Destination IP: 1.1.1.2
      Min Tx Inter: 1000ms               Min Rx Inter: 3790ms
      Detect Multi: 5                  Running Up for: 00:10:59
          Rx Count: 123                      Tx Count: 122
     Max Rx Period: 980ms               Max Tx Period: 580us
         Hold Time: 2500ms
          VRF Name: vpn2
Table 9 Command output
Configured mode
Discriminator type:
Total Session Num
Local Discr
Remote Discr
Source IP
Destination IP
Hold Time
Min Tx Inter
Minimum transmission interval of incoming SBFD packets.
Min Rx Inter
Minimum SBFD packet receiving interval.
Detect Multi
Session detection time multiplier carried in incoming SBFD packets.
Running up for
Rx Count
Tx Count
Max Rx Period
Maximum SBFD packet receiving interval in milliseconds.
Max Tx Period
Maximum response packet transmission interval, in microseconds.
Hold Time
VRF Name
sbfd local-discriminator
Use sbfd local-discriminator to set the local discriminator for the reflector.
Use undo sbfd local-discriminator to remove the local discriminator setting for the reflector.
sbfd local-discriminator { ipv4-address | integer-value }
undo sbfd local-discriminator { ipv4-address | integer-value }
No local discriminator is set for the reflector.
ipv4-address: Specifies a valid unicast IPv4 address as the local discriminator.
integer-value: Specifies an integer as the local discriminator, in the range of 1000001 to 16777215.
In a BFD session, both ends periodically send BFD packets to detect bidirectional forwarding path failures. SBFD is a unidirectional failure detection mechanism that provides shorter detection time than BFD. SBFD is used in scenarios where only one end of a link requires failure detection, such as MPLS TE tunnel establishment through static SRLSP.
An SBFD session involves the following roles:
·     Initiator—Periodically sends SBFD control packets to detect connectivity to remote entities. An initiator initiates SBFD sessions and maintains SBFD session state.
·     Reflector—Listens for incoming SBFD control packets on local entities and replies with response SBFD control packets.
The remote discriminator in SBFD control packets sent by the initiator must be specified in the sbfd local-discriminator command. Otherwise, the reflector does not reply with response SBFD control packets.
You can execute this command multiple times to configure multiple local discriminators.
A node can act as the initiator of one session and the reflector of another session at the same time.
# Specify 1.1.1.1 as the local discriminator for the reflector.
[Sysname] sbfd local-discriminator 1.1.1.1
# Specify 1000001 as the local discriminator for the reflector.
[Sysname] sbfd local-discriminator 1000001
mpls bfd (MPLS Command Reference)
