11-Network Management and Monitoring Configuration Guide
HomeSupportResource CenterSwitchesS12500X-AF SeriesS12500X-AF SeriesTechnical DocumentsConfigure & DeployConfiguration GuidesH3C S12500X-AF Switch Series Configuration Guides(R28xx)-6W10011-Network Management and Monitoring Configuration Guide
14-Sampler configuration
14-Sampler configuration 55.66 KB
Configuring samplers
About sampler
A sampler selects a packet from sequential packets and sends the packet to other service modules for processing. Sampling is useful when you want to limit the volume of traffic to be analyzed. The sampled data is statistically accurate and sampling decreases the impact on the forwarding capacity of the device.
The device supports random sampling mode.
A sampler can sample packets for NetStream. Then, only the sampled packets are sent to and processed by the NetStream module. For more information about NetStream, see "Configuring NetStream."
Creating a sampler
2.     Create a sampler.
sampler sampler-name mode random packet-interval n-power rate
By default, no samplers exist.
Display and maintenance commands for a sampler
Display configuration information about the sampler.
In standalone mode:
display sampler [ sampler-name ] [ slot slot-number ]
In IRF mode:
display sampler [ sampler-name ] [ chassis chassis-number slot slot-number ]
Samplers and IPv4 NetStream configuration examples
Example: Configuring samplers and IPv4 NetStream
As shown in Figure 1, configure samplers and NetStream as follows:
·     Configure IPv4 NetStream on the device to collect statistics on outgoing traffic.
·     Send the NetStream data to port 5000 on the NetStream server.
·     Configure random sampling in the outbound direction to select one packet randomly from 256 packets on FortyGigE 1/0/2.
Figure 1 Network diagram
Configuration procedure
IMPORTANT
IMPORTANT:
By default, interfaces on the device are disabled (in ADM or Administratively Down state). To have an interface operate, you must use the undo shutdown command to enable that interface.
# Create sampler 256 in random sampling mode, and set the sampling rate to 8. One packet from 256 packets is selected.
[Device] sampler 256 mode random packet-interval n-power 8
# Enable IPv4 NetStream to use sampler 256 to collect statistics about outgoing traffic on FortyGigE 1/0/2.
[Device] interface fortygige 1/0/2
[Device-FortyGigE1/0/2] ip netstream outbound
[Device-FortyGigE1/0/2] ip netstream outbound sampler 256
[Device-FortyGigE1/0/2] quit
# Configure the address and port number of the NetStream server as the destination for the NetStream data export. Use the default source interface for the NetStream data export.
[Device] ip netstream export host 12.110.2.2 5000
# Display configuration information for sampler 256.
[Device] display sampler 256
 Sampler name: 256
  Mode: Random;  Packet-interval: 8; IsNpower: Y
  • Become a Partner
  • Partner Resources
