17-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Configuration Guide(V7)(R9153P39 R9001P39)-6W40017-Network Management and Monitoring Configuration Guide
09-NetStream configuration
09-NetStream configuration 58.03 KB
Configuring session-based NetStream
About session-based NetStream
Session-based NetStream provides statistics for session-based services and exports the statistics in NetStream v9 format to NetStream servers.
For information about sessions, see session management in Security Configuration Guide.
Session-based NetStream aggregation modes
Session-based NetStream aggregates session statistics according to the aggregation criteria of an aggregation mode and exports the statistics to NetStream servers.
Table 1 lists the available aggregation modes. In each mode, the system merges statistics for multiple sessions if each aggregation criterion is of the same value.
Table 1 Session-based NetStream aggregation modes
Aggregation mode
Aggregation criteria
App aggregation
Application layer protocol ID.
App-profile aggregation
·     Application layer protocol ID.
·     Traffic rule ID.
App-user aggregation
·     User IP address.
Session-based NetStream data export
Session-based NetStream uses an aging mechanism to export flow entry statistics to NetStream servers.
When the aging timer for a session-based NetStream entry expires, statistics about the entry is cleared from the cache and exported to the NetStream servers.
When the session-based NetStream cache is full, the device stops generating new flow entries. Statistics collection for existing flow entries is not affected.
A session-based NetStream entry is also exported in the following situations:
·     The session itself ages out.
·     The session is manually deleted by the administrator.
Restrictions: Hardware compatibility with session-based NetStream
Hardware platform
Module type
NetStream compatibility
M9006
M9010
M9014
Blade IV firewall module
Yes
Blade V firewall module
Yes
NAT module
Yes
Application delivery engine (ADE) module
Yes
Anomaly flow cleaner (AFC) module
No
M9010-GM
Encryption module
Yes
M9016-V
Yes
M9008-S
M9012-S
Yes
Yes
Intrusion prevention service (IPS) module
Yes
Video network gateway module
Yes
No
M9008-S-6GW
IPv6 module
Yes
M9008-S-V
Yes
M9000-AI-E8
Yes
Yes
M9000-AI-E16
Yes
Restrictions and guidelines: Session-based NetStream configuration
For session-based NetStream to work, DPI must be enabled on the device. For more information about DPI, see DPI Configuration Guide.
2.     Enable session-based NetStream.
session-based netstream enable
By default, session-based NetStream is disabled.
3.     Enable session-based NetStream aggregation modes.
session-based netstream aggregation { app | app-profile | app-user } *
By default, all session-based NetStream aggregation modes are disabled.
4.     Specify a destination host for session-based NetStream data export.
session-based netstream export host ip-address udp-port [ vpn-instance vpn-instance-name ]
By default, no destination host is specified for session-based NetStream data export.
5.     (Optional.) Specify a source IP address for session-based NetStream packets.
session-based netstream export source ip ip-address
By default, the source IP address of session-based NetStream packets is the primary IP address of the output interface.
6.     (Optional.) Set the aging timer for cached session-based NetStream entries.
session-based netstream timeout minutes
By default, a session-based NetStream entry is can be cached for 5 minutes before being aged out.
Display and maintenance commands session-based NetStream
Display session-based NetStream statistics in the cache.
display session-based netstream aggregation-cache { app | app-profile | app-user } *
