- 03-Security Configuration Guide
- 01-Security zone configuration
- 02-Security policy configuration
- 03-Object group configuration
- 04-Object policy configuration
- 05-AAA configuration
- 06-IPoE configuration
- 07-Portal configuration
- 08-MAC authentication configuration
- 09-User identification configuration
- 10-Password control configuration
- 11-Public key management
- 12-PKI configuration
- 13-SSH configuration
- 14-SSL configuration
- 15-ASPF configuration
- 16-APR configuration
- 17-Session management
- 18-Connection limit configuration
- 19-Attack detection and prevention configuration
- 20-DDoS protection configuration
- 21-uRPF configuration
- 22-ARP attack protection configuration
- 23-ND attack defense configuration
- 24-IP-MAC binding configuration
- 25-IP reputation configuration
- 26-Keychain configuration
- 27-Crypto engine configuration
| 27-Crypto engine configuration | 46.91 KB |
Configuring crypto engines
About crypto engines
Crypto engines encrypt and decrypt data for service modules.
Crypto engine types
Crypto engines include the following types:
· Hardware crypto engines—A hardware crypto engine is a coprocessor integrated on a CPU or hardware crypto card. Hardware crypto engines can accelerate encryption/decryption speed, which improves device processing efficiency. You can enable or disable hardware crypto engines globally as needed. By default, hardware crypto engines are enabled.
· Software crypto engines—A software crypto engine is a set of software encryption algorithms. The device uses software crypto engines to encrypt and decrypt data for service modules. They are always enabled. You cannot enable or disable software crypto engines.
Crypto engine processing mechanism
If you disable hardware crypto engines, the device uses only software crypto engines for data encryption/decryption. If you enable hardware crypto engines, the device preferentially uses hardware crypto engines. If the device does not support hardware crypto engines, or if the hardware crypto engines do not support the required encryption algorithm, the device uses software crypto engines for data encryption/decryption.
Crypto engines provide encryption/decryption services for service modules, for example, the IPsec module. When a service module requires data encryption/decryption, it sends the desired data to a crypto engine. After the crypto engine completes data encryption/decryption, it sends the data back to the service module.
Display and maintenance commands for crypto engines
Task |
Command |
Display crypto engine information. |
display crypto-engine |
Display crypto engine statistics. |
In standalone mode: display crypto-engine statistics [ engine-id engine-id slot slot-number [ cpu cpu-number ] ] In IRF mode: display crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
Clear crypto engine statistics. |
In standalone mode: reset crypto-engine statistics [ engine-id engine-id slot slot-number [ cpu cpu-number ] ] In IRF mode: reset crypto-engine statistics [ engine-id engine-id chassis chassis-number slot slot-number [ cpu cpu-number ] ] |
