03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Configuration Guide(V7)(R9153P39 R9001P39)-6W40003-Security Configuration Guide
03-Object group configuration
03-Object group configuration 60.05 KB
Configuring object groups
About object groups
An object group is a group of objects that can be used by an ACL, object policy, or object group to identify packets. Object groups are divided into the following types:
·     MAC address object group—A group of MAC address objects used to match the MAC address in a packet.
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet or match the user from whom a packet comes.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet or match the user from whom a packet comes.
·     Service object group—A group of service objects used to match the upper-layer service in a packet.
Configuring a MAC address object group
2.     Create a MAC address object group and enter its view.
object-group mac-address object-group-name
The system has one default IPv4 address object group named any.
3.     (Optional.) Configure a description for the MAC address object group.
By default, an object group does not have a description.
4.     Configure a MAC address object.
[ object-id ] mac { mac-address | group-object group-object-name }
Configuring an IPv4 address object group
2.     Create an IPv4 address object group and enter its view.
object-group ip address object-group-name
3.     (Optional.) Configure a description for the IPv4 address object group.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ip-address { mask-length | mask | wildcard wildcard } | range ip-address1 ip-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
5.     Exclude an IPv4 address from the IPv4 address object.
object-id network exclude ip-address
By default, no IPv4 address in an IPv4 address object is excluded.
6.     (Optional.) Specify a security zone for the IPv4 address object group.
security-zone security-zone-name
By default, no security zone is specified for an IPv4 address object group.
Configuring an IPv6 address object group
2.     Create an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group named any.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name [ vpn-instance vpn-instance-name ] } | subnet ipv6-address prefix-length | range ipv6-address1 ipv6-address2 | group-object object-group-name | user user-name [ domain domain-name ] | user-group user-group-name [ domain domain-name ] }
5.     Exclude an IPv6 address from the IPv6 address object.
By default, no IPv6 address in an IPv6 address object is excluded.
6.     (Optional.) Specify a security zone for the IPv6 address object group.
By default, no security zone is specified for an IPv6 address object group.
Configuring a service object group
2.     Create a service object group and enter its view.
object-group service object-group-name
The system has multiple default service object groups.
3.     (Optional.) Configure a description for the service object group.
4.     Configure a service object.
[ object-id ] service { protocol [ { source { { eq | lt | gt } port | range port1 port2 } | destination { { eq | lt | gt } port | range port1 port2 } } * | icmp-type icmp-code | icmpv6-type icmpv6-code ] | group-object object-group-name }
Renaming an object group
2.     Rename an object group.
object-group rename old-object-group-name new-object-group-name
You can only rename non-default object groups.
Display and maintenance commands for object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | mac-address | service } [ default ] [ name object-group-name ] | name object-group-name ]
