03-Security Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C SecPath M9000 Configuration Guide(V7)(R9153P39 R9001P39)-6W40003-Security Configuration Guide
24-IP-MAC binding configuration
24-IP-MAC binding configuration 144.10 KB
Configuring IP-MAC binding
About IP-MAC binding
The device prevents user spoofing attacks by using an IP-MAC binding table to filter out illegitimate packets with forged source IP addresses or MAC addresses.
Operating mechanism
The IP-MAC binding table contains binding entries that bind IP addresses and MAC addresses. The device uses the binding entries to match an incoming packet.
As shown in Figure 1, all hosts communicate with the IP network through the device. When the device receives a packet, it compares the source IP address and source MAC address in the packet with the IP-MAC binding entries. Table 1 describes the way the device processes the packet based on the match result.
Figure 1 IP-MAC binding application scenario
Table 1 Processing of a packet based on the match result
Match result
Processing of the packet
The packet source IP address and source MAC address match the same IP-MAC binding entry.
Permits the packet.
Only the source IP address or source MAC address matches a binding entry.
Drops the packet.
The source IP address and source MAC address match two different binding entries.
Drops the packet.
Both the source IP address and the source MAC address of a packet match no IP-MAC binding entry.
Processes the packet based on the default action.
By default, the device permits all packets that do not match any binding entries. You can use the ip-mac binding no-match action deny command to set the default action to deny.
IP-MAC binding entry creation
An IP-MAC binding entry binds an IP address to a MAC address. You can manually create IP-MAC binding entries one by one or generate them in bulk. All binding entries are globally effective.
Manual creation of IP-MAC binding entries
This method is applicable only to networks that do not contain many hosts and in which the hosts are statically assigned IP addresses.
Bulk generation of IP-MAC binding entries
This method is applicable to networks that contain many hosts.
This method allows a device to generate IPv4-MAC binding entries based on ARP entries and create IPv6-MAC binding entries based on ND entries on an interface.
The device generates an IP-MAC binding entry based on an ARP or ND entry as follows:
·     If neither the IP address nor the MAC address in the ARP/ND entry exists in the binding table, the device generates a new binding entry. In this situation, the IP address and the MAC address are uniquely bound to each other.
·     If the MAC address in the ARP/ND entry exists in the binding table but the IP address does not, the device generates a new binding entry. In this situation, the MAC address is bound to multiple IP addresses.
·     If the IP address in the ARP/ND entry exists in the binding table, the device will not generate a new binding entry. This is because an IP address can be bound to only one MAC address.
IP-MAC binding entries generated based on ARP and ND entries are static. Therefore, the binding entries are not updated when the relevant ARP or ND entries change.
Restrictions and guidelines: IP-MAC binding configuration
IP-MAC binding entries are static. Therefore, the IP-MAC binding feature is applicable only to networks where all users are statically assigned IP addresses. Using this feature in a network where all users' IP addresses are dynamically assigned through DHCP might cause communication failure.
A MAC address can be bound to multiple IP addresses. To bind a MAC address in a binding entry to another IP address, use the MAC address and new IP address to create a new binding entry. You can choose to delete the existing binding entry or retain it. An IP address can be bound to only one MAC address. To bind an IP address in a binding entry to another MAC address, you must delete the existing binding entry and then create the new one.
IP-MAC binding tasks at a glance
To configure IP-MAC binding, perform the following tasks:
1.     Enabling the IP-MAC binding feature on an interface
2.     Configuring IP-MAC binding entries
Choose the options to configure as needed:
¡     Manually creating an IP-MAC binding entry
¡     Bulk generating IP-MAC binding entries
3.     Setting the default action for packets that do not match any IP-MAC binding entries
Enabling the IP-MAC binding feature globally
When this feature is globally enabled, the device compares the source IP address and source MAC address in incoming packets with existing IP-MAC binding entries. The packets that do not exactly match any IP-MAC binding entries are dropped.
2.     Enable the IP-MAC binding feature globally.
ip-mac binding enable
By default, the IP-MAC binding feature is disabled globally.
When this feature is enabled on an interface, the device compares the source IP address and source MAC address in incoming packets of the interface with existing IP-MAC binding entries. The packets that do not exactly match any IP-MAC binding entries are dropped.
2.     Enter interface view.
3.     Enable the IP-MAC binding feature on the interface.
By default, the IP-MAC binding feature is disabled on an interface.
Creating an IP-MAC binding entry
2.     Create an IP-MAC binding entry.
IPv4:
ip-mac binding ipv4 ipv4-address mac-address mac-address [ vlan vlan-id | vpn-instance vpn-instance-name ]
IPv6:
ip-mac binding ipv6 ipv6-address mac-address mac-address [ vlan vlan-id | vpn-instance vpn-instance-name ]
By default, no IP-MAC binding entry is configured.
This task allows the device to generate IP-MAC binding entries in bulk based on existing ARP and ND entries on an interface.
2.     Bulk generate IP-MAC binding entries.
ip-mac binding interface interface-type interface-number
By default, the device permits packets that do not match any IP-MAC binding entries to pass through. This task allows you to set the default action to deny for these packets.
2.     Set the default action to deny for packets that do not match any IP-MAC binding entries.
By default, the action for packets that do not match any IP-MAC binding entries is permit.
Display and maintenance commands for IP-MAC binding
Display IPv4-MAC binding entries.
display ip-mac binding ipv4 [ ipv4-address ] [ mac-address mac-address ] [ vlan vlan-id | vpn-instance vpn-instance-name ]
Display IPv6-MAC binding entries.
display ip-mac binding ipv6 [ ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id | vpn-instance vpn-instance-name ]
Display statistics about packets dropped by the IP-MAC binding feature.
In standalone mode:
display ip-mac binding statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display ip-mac binding statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Display the status of the IP-MAC binding feature.
display ip-mac binding status
Clear statistics about packets dropped by the IP-MAC binding feature.
In standalone mode:
reset ip-mac binding statistics [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
reset ip-mac binding statistics [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
IP-MAC binding configuration examples
Example: Configuring IPv4-MAC binding
As shown in Figure 2, Host A, Host B, and the server are statically assigned IPv4 addresses. Host A and Host B communicate with the server through the gateway (the device).
Create the following IPv4-MAC binding entries on the device to permit packets only from Host A, Host B, and the server:
·     Bind IPv4 address 192.168.0.1 to MAC address 0001-0203-0404 for Host A.
·     Bind IPv4 address 192.168.0.2 to MAC address 0001-0203-0405 for Host B.
·     Bind IPv4 address 192.168.1.3 to MAC address 0001-0203-0407 for the server.
Figure 2 Network diagram
1.     Assign IP addresses to interfaces:
Assign an IP address to interface GigabitEthernet 1/0/1.
[Device-GigabitEthernet1/0/1] ip address 192.168.0.254 255.255.255.0
2.     Add interfaces to security zones.
[Device] security-zone name trust
[Device-security-zone-Trust] import interface gigabitethernet 1/0/1
[Device] security-zone name dmz
[Device-security-zone-DMZ] import interface gigabitethernet 1/0/2
[Device-security-zone-DMZ] quit
3.     Configure a security policy:
# Configure a rule named trust-dmz to allow hosts in security zone trust to access the server.
[Device] security-policy ip
[Device-security-policy-ip] rule name trust-dmz
[Device-security-policy-ip-1-trust-dmz] source-zone trust
[Device-security-policy-ip-1-trust-dmz] destination-zone dmz
[Device-security-policy-ip-1-trust-dmz] source-ip-subnet 192.168.0.0 24
[Device-security-policy-ip-1-trust-dmz] destination-ip-subnet 192.168.1.0 24
[Device-security-policy-ip-1-trust-dmz] action pass
[Device-security-policy-ip-1-trust-dmz] quit
# Configure a rule named dmz-trust to allow the hosts to access the internal servers.
[Device-security-policy-ip] rule name untrust-dmz
[Device-security-policy-ip-2-untrust-dmz] source-zone untrust
[Device-security-policy-ip-2-untrust-dmz] destination-zone dmz
[Device-security-policy-ip-2-untrust-dmz] destination-ip-host 10.1.1.2
[Device-security-policy-ip-2-untrust-dmz] action pass
[Device-security-policy-ip-2-untrust-dmz] quit
[Device-security-policy-ip] quit
4.     Configure the IP-MAC binding feature:
# Enable the IP-MAC binding feature on GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2.
[Device-GigabitEthernet1/0/1] ip-mac binding enable
[Device-GigabitEthernet1/0/2] ip-mac binding enable
# Create IPv4-MAC binding entries to permit packets only from Host A, Host B, and the server.
[Device] ip-mac binding ip 192.168.0.1 mac-address 0001-0203-0404
[Device] ip-mac binding ip 192.168.0.2 mac-address 0001-0203-0405
[Device] ip-mac binding ip 192.168.1.3 mac-address 0001-0203-0407
# Set the default action to deny for packets that do not match any IP-MAC binding entries.
[Device] ip-mac binding no-match action deny
# Display IPv4-MAC binding entries.
<Device> display ip-mac binding ipv4
Total entries: 1
IP address      MAC address         VPN instance         VLAN ID
192.168.0.1     0001-0203-0404      public               N/A
192.168.0.2     0001-0203-0405      public               N/A
192.168.1.3     0001-0203-0407      public               N/A
# Ping the server from Host C.
C:\> ping 192.168.1.3
Pinging 192.168.1.3 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 192.168.1.3:
   Packets: Sent = 4, Received = 0, Lost = 4 (100% loss),
The ping requests timed out, which indicates that the requests are blocked by the device.
Example: Configuring IPv6-MAC binding
As shown in Figure 3, Host A, Host B, and the server are statically assigned IPv6 addresses. Host A and Host B communicate with the server through the gateway (the device).
Create the following IPv6-MAC binding entries on the device to permit packets only from Host A, Host B, and the server:
·     Bind IPv6 address 2000::1/64 to MAC address 0001-0203-0404 for Host A.
·     Bind IPv6 address 2000::2/64 to MAC address 0001-0203-0405 for Host B.
·     Bind IPv6 address 2001::3/64 to MAC address 0001-0203-0407 for the server.
Figure 3 Network diagram
[Device-GigabitEthernet1/0/1] ipv6 address 2000::4 64
[Device] security-policy ipv6
[Device-security-policy-ipv6] rule name trust-dmz
[Device-security-policy-ipv6-1-trust-dmz] source-zone trust
[Device-security-policy-ipv6-1-trust-dmz] destination-zone dmz
[Device-security-policy-ipv6-1-trust-dmz] source-ip-subnet 2000::1 64
[Device-security-policy-ipv6-1-trust-dmz] destination-ip-subnet 2001::1 64
[Device-security-policy-ipv6-1-trust-dmz] action pass
[Device-security-policy-ipv6-1-trust-dmz] quit
[Device-security-policy-ipv6] rule name dmz-trust
[Device-security-policy-ipv6-2-dmz-trust] source-zone dmz
[Device-security-policy-ipv6-2-dmz-trust] destination-zone trust
[Device-security-policy-ipv6-2-dmz-trust] source-ip-subnet 2001::1 64
[Device-security-policy-ipv6-2-dmz-trust] destination-ip-subnet 2000::1 64
[Device-security-policy-ipv6-2-dmz-trust] action pass
[Device-security-policy-ipv6-2-dmz-trust] quit
[Device-security-policy-ipv6] quit
# Create IPv6-MAC binding entries to permit packets only from Host A, Host B, and the server.
[Device] ip-mac binding ipv6 2000::1 mac-address 0001-0203-0404
[Device] ip-mac binding ipv6 2000::2 mac-address 0001-0203-0405
[Device] ip-mac binding ipv6 2001::3 mac-address 0001-0203-0407
# Display IPv6-MAC binding entries.
<Device> display ip-mac binding ipv6
Total entries: 1
2000::1         0001-0203-0404      public               N/A
2000::2         0001-0203-0405      public               N/A
2001::3         0001-0203-0407      public               N/A
C:\> ping 2001::3
Pinging 2001::3 with 32 bytes of data:
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Ping statistics for 2001::3:
