- 01-Fundamentals Configuration Guide
- 01-CLI configuration
- 02-RBAC configuration
- 03-Login management configuration
- 04-FTP and TFTP configuration
- 05-File system management configuration
- 06-Configuration file management configuration
- 07-Software upgrade configuration
- 08-ISSU configuration
- 09-Automatic configuration
- 10-Preprovisioning feature configuration
- 11-Device management configuration
- 12-Tcl configuration
- 13-Python configuration
- 14-License management
- 15-GIR configuration
00-Preface | 101.01 KB |
Preface
This configuration guide describes features and tasks that help you get started with the device, including:
· CLI.
· RBAC, device login, and device access control.
· Management of the device, file systems, configuration files, and licenses.
· FTP and TFTP.
· Tcl and Python.
· ISSU and common software upgrade.
· Automatic configuration and preprovisioning.
· GIR.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the S9820-64H switch.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
