04-Tunnel policy commands | 52.60 KB |
display mpls tunnel
Use display mpls tunnel to display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination { ipv4-address | ipv6-address } }
all: Displays all tunnels.
statistics: Displays tunnel statistics.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, this command displays tunnel information for the public network.
destination: Displays the tunnel destined for the specified address.
ipv4-address: Specifies the tunnel destination IPv4 address.
ipv6-address: Specifies the tunnel destination IPv6 address.
# Display information about all tunnels.
<Sysname> display mpls tunnel all
Destination Type Tunnel/NHLFE VPN Instance
2.2.2.2 LSP NHLFE1024 -
3.3.3.3 LSP NHLFE1026 -
Destination |
Tunnel destination address. |
Type |
Tunnel type. |
Tunnel/NHLFE |
Tunnel or NHLFE entry. NHLFEnumber represents the ingress LSP that matches the NHLFE entry with NID of number. |
VPN Instance |
VPN instance name. If the tunnel belongs to the public network, this field displays a hyphen (-). |
# Display tunnel statistics.
<Sysname> display mpls tunnel statistics
LSP : 1
GRE : 0
CRLSP: 0
LSP |
Number of LSP tunnels. |
GRE |
This field is not supported in the current software version. Number of GRE tunnels. |
CRLSP |
This field is not supported in the current software version. Number of CRLSP and SRLSP tunnels. |
display tunnel-policy
Use display tunnel-policy to display tunnel policy information.
display tunnel-policy [ tunnel-policy-name ]
tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, this command displays information about all tunnel policies.
# Display information about tunnel policy policy1.
<Sysname> display tunnel-policy policy1
Tunnel policy name : policy1
Preferred paths :
Interface : Not Configured
Tunnel type: Not Configured
Select-Seq : LSP
Load balance number : 5
Preferred paths |
This field is not supported in the current software version. Preferred tunnels information. |
This field is not supported in the current software version. Tunnel interface name of the preferred tunnel. |
Tunnel type |
This field is not supported in the current software version. Type of the preferred tunnel. |
Select-Seq |
Tunnel selection order. Only the LSP tunnel type is supported in this software version. |
Load balance number |
Number of tunnels for load balancing. |
select-seq load-balance-number
Use select-seq load-balance-number to set the number of LSP tunnels for load balancing.
Use undo select-seq to restore the default.
select-seq lsp load-balance-number number
undo select-seq
The device selects only one tunnel.
Tunnel policy view
load-balance-number number: Specifies the number of tunnels for load balancing. The value range for the number argument depends on the ECMP mode set by the ecmp mode command.
Table 4 Value ranges for the number argument in different ECMP modes
ECMP mode |
Value range for number |
Normal mode or enhanced mode |
1 to 128 |
Compressed mode |
1 to 32 |
Other modes |
1 to 64 |
# Configure tunnel policy policy1 to use two LSP tunnels for load balancing.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] select-seq lsp load-balance-number 2
tunnel-policy (system view)
Use tunnel-policy to create a tunnel policy and enter its view, or enter the view of an existing tunnel policy.
Use undo tunnel-policy to delete a tunnel policy.
tunnel-policy tunnel-policy-name
undo tunnel-policy tunnel-policy-name
No tunnel policies exist.
tunnel-policy-name: Specifies a name for the tunnel policy, a case-sensitive string of 1 to 19 characters.
# Create tunnel policy policy1 and enter its view.
