| 00-Preface | 100.47 KB |
Preface
This document describes the installation procedure for the H3C SecPath F5000-AI160[F5000-E] firewalls.It covers preparing for installation, installing the firewall, accessing the firewall, hardware replacement, hardware management and maintenance, and troubleshooting.
· Audience
Audience
· Network planners
· Field technical support and servicing engineers
· Network administrators working with H3C SecPath F10X0 firewalls
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE |
Network topology icons
Represents an access point. |
Documentation feedback
We appreciate your comments.
