00-Preface | 75.74 KB |
Preface
The H3C vAC1000 virtual access controller documentation set describes the software features for the vAC1000 virtual access controller and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
This configuration guide includes the following feature modules:
· Device management.
· NTP.
· Information center.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators working with the vAC1000 virtual access controller.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
