20-Network Management and Monitoring Configuration Guide
HomeSupportConfigure & DeployConfiguration GuidesH3C Access Controllers Configuration Guides(R5447P04)-6W10020-Network Management and Monitoring Configuration Guide
11-Fast log output configuration
11-Fast log output configuration 65.46 KB
Configuring fast log output
About fast log output
The fast log output feature enables fast output of logs to log hosts.
Typically, logs generated by a service module are first sent to the information center, which then outputs the logs to the specified destination (such as to log hosts). When fast log output is configured, logs of service modules are sent directly to log hosts instead of to the information center. Compared to outputting logs to the information center, fast log output saves system resources. For more information about the information center, see System Management Configuration Guide.
Logs are classified into eight severity levels from 0 through 7 in descending order.
Table 1 Log levels
Severity value
Level
0
Emergency
The system is unusable. For example, the system authorization has expired.
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
3
Error
Error condition. For example, the link state changes.
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
6
Informational
Informational message. For example, a command or a ping operation is executed.
7
Debugging
Debug message.
Restrictions: Hardware compatibility with fast log output
Hardware series
Model
Product code
Fast log output compatibility
WX1800H series
WX1804H-PWR
EWP-WX1804H-PWR-CN
Yes
WX2500H series
WX2508H-PWR-LTE
WX2510H-PWR
WX2510H-F-PWR
WX2540H
WX2540H-F
WX2560H
EWP-WX2508H-PWR-LTE
EWP-WX2510H-PWR
EWP-WX2510H-F-PWR
EWP-WX2540H
EWP-WX2540H-F
EWP-WX2560H
Yes
MAK series
MAK204
MAK206
EWP-MAK204
EWP-MAK206
Yes
WX3000H series
WX3010H
WX3010H-X-PWR
WX3010H-L-PWR
WX3024H
WX3024H-L-PWR
WX3024H-F
EWP-WX3010H
EWP-WX3010H-X-PWR
EWP-WX3010H-L-PWR
EWP-WX3024H
EWP-WX3024H-L-PWR
EWP-WX3024H-F
Yes:
·     WX3010H-X-PWR
·     WX3010H-L-PWR
·     WX3024H-L-PWR
No:
·     WX3010H
·     WX3024H
·     WX3024H-F
WX3500H series
WX3508H
WX3508H
WX3510H
WX3510H
WX3520H
WX3520H-F
WX3540H
WX3540H
EWP-WX3508H
EWP-WX3508H-F
EWP-WX3510H
EWP-WX3510H-F
EWP-WX3520H
EWP-WX3520H-F
EWP-WX3540H
EWP-WX3540H-F
Yes
WX5500E series
WX5510E
WX5540E
EWP-WX5510E
EWP-WX5540E
Yes
WX5500H series
WX5540H
WX5560H
WX5580H
EWP-WX5540H
EWP-WX5560H
EWP-WX5580H
Yes
Access controller modules
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
LSUM1WCME0
EWPXM1WCME0
LSQM1WCMX20
LSUM1WCMX20RT
LSQM1WCMX40
LSUM1WCMX40RT
EWPXM2WCMD0F
EWPXM1MAC0F
Yes
Hardware series
Model
Product code
WX1800H series
WX1804H-PWR
WX1810H-PWR
WX1820H
WX1840H
EWP-WX1804H-PWR
EWP-WX1810H-PWR
EWP-WX1820H
EWP-WX1840H-GL
No
WX3800H series
WX3820H
WX3840H
EWP-WX3820H-GL
EWP-WX3840H-GL
Yes
WX5800H series
WX5860H
EWP-WX5860H-GL
Yes
Restrictions and guidelines: fast log output configuration
The device supports outputting logs from service modules to log hosts by using the following methods in descending order of priority:
1.     Fast log output.
2.     Flow log. For more information about flow log and the service modules supported by flow log, see "Configuring flow log."
3.     Information center.
If you configure multiple log output methods for a service module, the service module outputs its logs in the method that has the highest priority.
To output NAT logs to a log host, you must specify the log format required by the log host in the customlog format and customlog host commands.
2.     Enable fast log output.
customlog format { attack-defense | dpi | nat { cmcc | telecom | unicom } | packet-filter | session }
By default, fast log output is disabled.
3.     Configure fast log output parameters.
customlog host { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] export { attack-defense | cmcc-sessionlog | cmcc-userlog | dpi | packet-filter | session | telecom-sessionlog | telecom-userlog | unicom-sessionlog | unicom-userlog } *
By default, no fast log output parameters are configured.
The value for the port-number argument must be the same as the port number configured on the log host. Otherwise, the log host cannot receive logs.
4.     (Optional.) Configure the timestamp of fast output logs to show the system time.
customlog timestamp localtime
By default, the timestamp of fast output logs shows the Greenwich Mean Time (GMT).
Fast log output configuration examples
Example: Configuring fast log output to a log host
As shown in Figure 1, configure fast log output on the AC to send NAT444 user logs to the log host in CMCC format.
Figure 1 Network diagram
1.     Make sure the AC and the log host can reach each other. (Details not shown.)
2.     Configure the AC:
# Enable fast log output in CMCC format for the NAT module.
<AC> system-view
[AC] customlog format nat cmcc
# Output NAT444 user logs in CMCC format to the log host at 1.2.0.1/16.
[AC] customlog host 1.2.0.1 port 1000 export cmcc-userlog
# Enable NAT444 user log.
[AC] nat log enable
[AC] nat log port-block-assign
[AC] nat log port-block-withdraw
3.     Configure the log host:
The log host configuration varies by log host. For more information, see related document of the log host.
On the host, verify that logs are received from the AC successfully.
