- 20-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-SNMP configuration
- 04-RMON configuration
- 05-NETCONF configuration
- 06-EAA configuration
- 07-Process monitoring and maintenance configuration
- 08-Flow log configuration
- 09-Packet capture configuration
- 10-Mirroring configuration
- 11-Fast log output configuration
- 12-UCC configuration
- 13-SQA configuration
| 02-NQA configuration | 734.58 KB |
Configuring NQA operations on the NQA client
NQA operations tasks at a glance
Configuring the ICMP echo operation
Configuring the ICMP jitter operation
Configuring the DHCP operation
Configuring the HTTP operation
Configuring the UDP jitter operation
Configuring the SNMP operation
Configuring the UDP echo operation
Configuring the UDP tracert operation
Configuring the voice operation
Configuring the DLSw operation
Configuring the path jitter operation
Configuring optional parameters for the NQA operation
Configuring the collaboration feature
Configuring threshold monitoring
Configuring the NQA statistics collection feature
Configuring the saving of NQA history records
Scheduling the NQA operation on the NQA client
Configuring NQA templates on the NQA client
NQA template tasks at a glance
Configuring the TCP half open template
Configuring the HTTPS template
Configuring the RADIUS authentication template
Configuring the SNMP DCA template
Configuring optional parameters for the NQA template
Display and maintenance commands for NQA
Example: Configuring the ICMP echo operation
Example: Configuring the ICMP jitter operation
Example: Configuring the FTP operation
Example: Configuring the HTTP operation
Example: Configuring the UDP jitter operation
Example: Configuring the SNMP operation
Example: Configuring the TCP operation
Example: Configuring the UDP echo operation
Example: Configuring NQA collaboration
Example: Configuring the ARP template
Example: Configuring the ICMP template
Example: Configuring the IMAP template
Example: Configuring the POP3 template
Example: Configuring RTSP template
Example: Configuring SMTP template
Example: Configuring the TCP template
Example: Configuring the TCP half open template
Example: Configuring the UDP template
Example: Configuring the HTTP template
Example: Configuring the HTTPS template
Example: Configuring the FTP template
Example: Configuring the RADIUS authentication template
Example: Configuring the SNMP template
Example: Configuring SNMP DCA template
Example: Configuring the SSL template
Example: Configuring the WAP template
Configuring NQA
About NQA
Network quality analyzer (NQA) allows you to measure network performance, verify the service levels for IP services and applications, and troubleshoot network problems.
NQA operating mechanism
An NQA operation contains a set of parameters such as the operation type, destination IP address, and port number to define how the operation is performed. Each NQA operation is identified by the combination of the administrator name and the operation tag. You can configure the NQA client to run the operations at scheduled time periods.
As shown in Figure 1, the NQA source device (NQA client) sends data to the NQA destination device by simulating IP services and applications to measure network performance.
All types of NQA operations require the NQA client, but only the TCP, UDP echo, UDP jitter, and voice operations require the NQA server. The NQA operations for services that are already provided by the destination device such as FTP do not need the NQA server. You can configure the NQA server to listen and respond to specific IP addresses and ports to meet various test needs.
After starting an NQA operation, the NQA client periodically performs the operation at the interval specified by using the frequency command.
You can set the number of probes the NQA client performs in an operation by using the probe count command.
For the voice and path jitter operations, the NQA client performs only one probe per operation and the probe count command is not available.
Collaboration with Track
NQA can collaborate with the Track module to notify application modules of state or performance changes so that the application modules can take predefined actions.
The NQA + Track collaboration is available for the following application modules:
· Static routing.
· Traffic redirecting.
· WLAN uplink detection.
The following describes how a static route destined for 192.168.0.88 is monitored through collaboration:
1. NQA monitors the reachability to 192.168.0.88.
2. When 192.168.0.88 becomes unreachable, NQA notifies the Track module of the change.
3. The Track module notifies the static routing module of the state change.
4. The static routing module sets the static route to invalid according to a predefined action.
For more information about collaboration, see High Availability Configuration Guide.
Threshold monitoring
Threshold monitoring enables the NQA client to take a predefined action when the NQA operation performance metrics violate the specified thresholds.
Table 1 describes the relationships between performance metrics and NQA operation types.
Table 1 Performance metrics and NQA operation types
Performance metric |
NQA operation types that can gather the metric |
Probe duration |
All NQA operation types except UDP jitter, UDP tracert, path jitter, and voice |
Number of probe failures |
Round-trip time |
ICMP jitter, UDP jitter, and voice |
Number of discarded packets |
One-way jitter (source-to-destination or destination-to-source) |
One-way delay (source-to-destination or destination-to-source) |
Calculated Planning Impairment Factor (ICPIF) (see "Configuring the voice operation") |
Voice |
Mean Opinion Scores (MOS) (see "Configuring the voice operation") |
Voice |
NQA templates
An NQA template is a set of parameters (such as destination address and port number) that defines how an NQA operation is performed. Features such as load balancing and health monitoring can use the NQA template to collect statistics.
You can create multiple NQA templates on the NQA client. Each template must be identified by a unique template name.
NQA tasks at a glance
To configure NQA, perform the following tasks:
Perform this task on the destination device before you configure the TCP, UDP echo, UDP jitter, and voice operations.
3. Configuring NQA operations or NQA templates
¡ Configuring NQA operations on the NQA client
¡ Configuring NQA templates on the NQA client
After you configure an NQA operation, you can schedule the NQA client to run the NQA operation.
An NQA template does not run immediately after it is configured. The template creates and run the NQA operation only when it is required by the feature (such as load balancing) to which the template is applied.
Configuring the NQA server
To perform TCP, UDP echo, UDP jitter, and voice operations, you must configure the NQA server on the destination device.
The NQA server listens and responds to requests on the specified IP addresses and ports.
You can configure multiple TCP or UDP listening services on an NQA server, where each corresponds to a specific IP address and port number.
The IP address and port number for a listening service must be unique on the NQA server and match the configuration on the NQA client.
1. Enter system view.
2. Enable the NQA server.
nqa server enable
By default, the NQA server is disabled.
3. Configure a TCP listening service.
nqa server tcp-connect ipv4-address port-number [ tos tos ]
This task is required for only TCP operations.
4. Configure a TCP listening service.
nqa server udp-echo ipv4-address port-number [ tos tos ]
This task is required for only UDP echo, UDP jitter, and voice operations.
Enabling the NQA client
2. Enable the NQA client.
nqa agent enable
By default, the NQA client is enabled.
The NQA client configuration takes effect after you enable the NQA client.
To configure NQA operations, perform the following tasks:
1. Configuring an NQA operation
¡ Configuring the ICMP echo operation
¡ Configuring the ICMP jitter operation
¡ Configuring the DHCP operation
¡ Configuring the DNS operation
¡ Configuring the FTP operation
¡ Configuring the HTTP operation
¡ Configuring the UDP jitter operation
¡ Configuring the SNMP operation
¡ Configuring the TCP operation
¡ Configuring the UDP echo operation
¡ Configuring the UDP tracert operation
¡ Configuring the voice operation
¡ Configuring the DLSw operation
¡ Configuring the path jitter operation
2. (Optional.) Configuring optional parameters for the NQA operation
3. (Optional.) Configuring the collaboration feature
4. (Optional.) Configuring threshold monitoring
5. (Optional.) Configuring the NQA statistics collection feature
6. (Optional.) Configuring the saving of NQA history records
7. Scheduling the NQA operation on the NQA client
The ICMP echo operation measures the reachability of a destination device. It has the same function as the ping command, but provides more output information. In addition, if multiple paths exist between the source and destination devices, you can specify the next hop for the ICMP echo operation.
The ICMP echo operation sends an ICMP echo request to the destination device per probe.
2. Create an NQA operation and enter NQA operation view.
nqa entry admin-name operation-tag
3. Specify the ICMP echo type and enter its view.
type icmp-echo
4. Specify the destination IP address for ICMP echo requests.
IPv4:
destination ip ip-address
IPv6:
destination ipv6 ipv6-address
By default, no destination IP address is specified.
5. Specify the source address for ICMP echo requests. Choose one option as needed:
¡ Use the IP address of the specified interface as the source IP address.
source interface interface-type interface-number
By default, the source IP address of ICMP echo requests is the primary IP address of their output interface.
The specified source interface must be up.
¡ Specify the source IPv4 address.
source ip ip-address
By default, the source IPv4 address of ICMP echo requests is the primary IPv4 address of their output interface.
The specified source IPv4 address must be the IPv4 address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out.
¡ Specify the source IPv6 address.
source ipv6 ipv6-address
By default, the source IPv6 address of ICMP echo requests is the IPv6 address of their output interface.
The specified source IPv6 address must be the IPv6 address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out.
6. Specify the output interface or the next hop IP address for ICMP echo requests. Choose one option as needed:
¡ Specify the output interface.
out interface interface-type interface-number
By default, the output interface is not specified. The NQA client determines the output interface based on the routing table lookup.
¡ Specify the next hop IPv4 address.
next-hop ip ip-address
By default, no next hop IPv4 address is specified.
¡ Specify the next hop IPv6 address.
next-hop ipv6 ipv6-address
By default, no next hop IPv6 address is specified.
7. (Optional.) Set the payload size for each ICMP echo request.
data-size size
The default payload size is 100 bytes.
8. (Optional.) Specify the payload fill string for ICMP echo requests.
data-fill string
The default payload fill string is the hexadecimal string 00010203040506070809.
The ICMP jitter operation measures unidirectional and bidirectional jitters. The operation result helps you to determine whether the network can carry jitter-sensitive services such as real-time voice and video services.
The ICMP jitter operation works as follows:
1. The NQA client sends ICMP packets to the destination device.
2. The destination device time stamps each packet it receives, and then sends the packet back to the NQA client.
3. Upon receiving the responses, the NQA client calculates the jitter according to the timestamps.
The ICMP jitter operation sends a number of ICMP packets to the destination device per probe. The number of packets to send is determined by using the probe packet-number command.
The display nqa history command does not display the results or statistics of the ICMP jitter operation. To view the results or statistics of the operation, use the display nqa result or display nqa statistics command.
Before starting the operation, make sure the network devices are time synchronized by using NTP. For more information about NTP, see "Configuring NTP."
3. Specify the ICMP jitter type and enter its view.
type icmp-jitter
4. Specify the destination IP address for ICMP packets.
5. Set the number of ICMP packets sent per probe.
probe packet-number number
The default setting is 10.
6. Set the interval for sending ICMP packets.
probe packet-interval interval
The default setting is 20 milliseconds.
7. Specify how long the NQA client waits for a response from the server before it regards the response times out.
probe packet-timeout timeout
The default setting is 3000 milliseconds.
8. Specify the source IP address for ICMP packets.
By default, the source IP address of ICMP packets is the primary IP address of their output interface.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no ICMP packets can be sent out.
The DHCP operation measures whether or not the DHCP server can respond to client requests. DHCP also measures the amount of time it takes the NQA client to obtain an IP address from a DHCP server.
The NQA client simulates the DHCP relay agent to forward DHCP requests for IP address acquisition from the DHCP server. The interface that performs the DHCP operation does not change its IP address. When the DHCP operation completes, the NQA client sends a packet to release the obtained IP address.
The DHCP operation acquires an IP address from the DHCP server per probe.
3. Specify the DHCP type and enter its view.
type dhcp
4. Specify the IP address of the DHCP server as the destination IP address of DHCP packets.
5. Specify the output interface for DHCP request packets.
By default, the NQA client determines the output interface based on the routing table lookup.
6. Specify the source IP address of DHCP request packets.
By default, the source IP address of DHCP request packets is the primary IP address of their output interface.
The specified source IP address must be the IP address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out.
The DNS operation simulates domain name resolution, and it measures the time for the NQA client to resolve a domain name into an IP address through a DNS server. The obtained DNS entry is not saved.
The DNS operation resolves a domain name into an IP address per probe.
3. Specify the DNS type and enter its view.
type dns
4. Specify the IP address of the DNS server as the destination IP address of DNS packets.
5. Specify the domain name to be translated.
resolve-target domain-name
The FTP operation measures the time for the NQA client to transfer a file to or download a file from an FTP server.
The FTP operation uploads or downloads a file from an FTP server per probe.
To upload (put) a file to the FTP server, use the filename command to specify the name of the file you want to upload. The file must exist on the NQA client.
To download (get) a file from the FTP server, include the name of the file you want to download in the url command. The file must exist on the FTP server. The NQA client does not save the file obtained from the FTP server.
Use a small file for the FTP operation. A big file might result in transfer failure because of timeout, or might affect other services because of the amount of network bandwidth it occupies.
3. Specify the FTP type and enter its view.
type ftp
4. Specify an FTP login username.
username username
By default, no FTP login username is specified.
5. Specify an FTP login password.
By default, no FTP login password is specified.
6. Specify the source IP address for FTP request packets.
By default, the source IP address of FTP request packets is the primary IP address of their output interface.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no FTP requests can be sent out.
7. Set the data transmission mode.
mode { active | passive }
The default mode is active.
8. Specify the FTP operation type.
operation { get | put }
The default FTP operation type is get.
9. Specify the destination URL for the FTP operation.
url url
By default, no destination URL is specified for an FTP operation.
Enter the URL in one of the following formats:
¡ ftp://host/filename.
¡ ftp://host:port/filename.
The filename argument is required only for the get operation.
10. Specify the name of the file to be uploaded.
filename file-name
By default, no file is specified.
This step is required only for the put operation.
The configuration does not take effect for the get operation.
The HTTP operation measures the time for the NQA client to obtain responses from an HTTP server.
The HTTP operation supports the following operation types:
· Get—Retrieves data such as a Web page from the HTTP server.
· Post—Sends data to the HTTP server for processing.
· Raw—Sends a user-defined HTTP request to the HTTP server. You must manually configure the content of the HTTP request to be sent.
The HTTP operation completes the operation of the specified type per probe.
3. Specify the HTTP type and enter its view.
type http
4. Specify the destination URL for the HTTP operation.
url url
By default, no destination URL is specified for an HTTP operation.
¡ http://host/resource
¡ http://host:port/resource
5. Specify an HTTP login username.
username username
By default, no HTTP login username is specified.
6. Specify an HTTP login password.
By default, no HTTP login password is specified.
7. Specify the HTTP version.
version { v1.0 | v1.1 }
By default, HTTP 1.0 is used.
8. Specify the HTTP operation type.
operation { get | post | raw }
The default HTTP operation type is get.
If you set the operation type to raw, the client pads the content configured in raw request view to the HTTP request to send to the HTTP server.
9. Configure the HTTP raw request.
a. Enter raw request view.
raw-request
Every time you enter raw request view, the previously configured raw request content is cleared.
b. Enter or paste the request content.
By default, no request content is configured.
For successful HTTP operations, make sure the raw request content is valid and does not contain command aliases configured by using the alias command. For more information about the alias command, see CLI commands in Fundamentals Command Reference.
c. Save the input and return to HTTP operation view.
This step is required only when the operation type is set to raw.
10. Specify the source IP address for the HTTP packets.
By default, the source IP address of HTTP packets is the primary IP address of their output interface.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no HTTP packets can be sent out.
The UDP jitter operation measures unidirectional and bidirectional jitters. The operation result helps you determine whether the network can carry jitter-sensitive services such as real-time voice and video services.
The UDP jitter operation works as follows:
1. The NQA client sends UDP packets to the destination port.
The UDP jitter operation sends a number of UDP packets to the destination device per probe. The number of packets to send is determined by using the probe packet-number command.
The UDP jitter operation requires both the NQA server and the NQA client. Before you perform the UDP jitter operation, configure the UDP listening service on the NQA server. For more information about UDP listening service configuration, see "Configuring the NQA server."
To ensure successful UDP jitter operations and avoid affecting existing services, do not perform the operations on well-known ports from 1 to 1023.
The display nqa history command does not display the results or statistics of the UDP jitter operation. To view the results or statistics of the UDP jitter operation, use the display nqa result or display nqa statistics command.
3. Specify the UDP jitter type and enter its view.
type udp-jitter
4. Specify the destination IP address for UDP packets.
By default, no destination IPv4 address is specified.
The destination IPv4 address must be the same as the IP address of the UDP listening service configured on the NQA server.
5. Specify the destination port number for UDP packets.
destination port port-number
By default, no destination port number is specified.
The destination port number must be the same as the port number of the UDP listening service on the NQA server.
6. Specify the source IP address for UDP packets.
By default, the source IPv4 address of UDP packets is the primary IPv4 address of their output interface.
The source IPv4 address must be the IPv4 address of a local interface, and the interface must be up. Otherwise, no UDP packets can be sent out.
7. Specify the source port number for UDP packets.
source port port-number
By default, the NQA client randomly picks an unused port as the source port when the operation starts.
8. Specify an output interface for UDP packets.
9. Set the number of UDP packets sent per probe.
10. Set the interval for sending UDP packets.
11. Specify how long the NQA client waits for a response from the server before it regards the response times out.
12. (Optional.) Set the payload size for each UDP packet.
data-size size
13. (Optional.) Specify the payload fill string for UDP packets.
data-fill string
The SNMP operation tests whether the SNMP service is available on an SNMP agent.
The SNMP operation sends one SNMPv1 packet, one SNMPv2c packet, and one SNMPv3 packet to the SNMP agent per probe.
3. Specify the SNMP type and enter its view.
type snmp
4. Specify the destination IP address for SNMP packets.
5. Specify the destination port number for SNMP packets.
The default destination port number of SNMP packets is 161.
6. Specify the source IP address for SNMP packets.
By default, the source IP address of SNMP packets is the primary IP address of their output interface.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no SNMP packets can be sent out.
7. Specify the source port number for SNMP packets.
8. Specify the community name carried in the SNMPv1 and SNMPv2c packets.
community read { cipher | simple } community-name
By default, the SNMPv1 and SNMPv2c packets carry community name public.
Make sure the specified community name is the same as the community name configured on the SNMP agent.
The TCP operation measures the time for the NQA client to establish a TCP connection to a port on the NQA server.
The TCP operation requires both the NQA server and the NQA client. Before you perform a TCP operation, configure a TCP listening service on the NQA server. For more information about the TCP listening service configuration, see "Configuring the NQA server."
The TCP operation sets up a TCP connection per probe.
3. Specify the TCP type and enter its view.
type tcp
4. Specify the destination address for TCP packets.
The destination IPv4 address must be the same as the IPv4 address of the TCP listening service configured on the NQA server.
5. Specify the destination port number for TCP packets.
By default, no destination port number is configured.
The destination port number must be the same as the port number of the listening service on the NQA server.
6. Specify the source IP address for TCP packets.
By default, the source IPv4 address of TCP packets is the primary IPv4 address of their output interface.
The source IPv4 address must be the IPv4 address of a local interface, and the interface must be up. Otherwise, no TCP packets can be sent out.
The UDP echo operation measures the round-trip time between the client and a UDP port on the NQA server.
The UDP echo operation requires both the NQA server and the NQA client. Before you perform a UDP echo operation, configure a UDP listening service on the NQA server. For more information about the UDP listening service configuration, see "Configuring the NQA server."
The UDP echo operation sends a UDP packet to the destination device per probe.
3. Specify the UDP echo type and enter its view.
type udp-echo
4. Specify the destination address for UDP packets.
The destination IPv4 address must be the same as the IPv4 address of the UDP listening service configured on the NQA server.
8. (Optional.) Set the payload size for each UDP packet.
data-size size
The default setting is 100 bytes.
9. (Optional.) Specify the payload fill string for UDP packets.
data-fill string
The UDP tracert operation determines the routing path from the source device to the destination device.
The UDP tracert operation sends a UDP packet to a hop along the path per probe.
The UDP tracert operation is not supported on IPv6 networks. To determine the routing path that the IPv6 packets traverse from the source to the destination, use the tracert ipv6 command. For more information about the command, see Network Management and Monitoring Command Reference.
Before you configure the UDP tracert operation, you must perform the following tasks:
· Enable sending ICMP time exceeded messages on the intermediate devices between the source and destination devices. If the intermediate devices are H3C devices, use the ip ttl-expires enable command. For more information about the ip ttl-expires enable command, see Network Connectivity Command Reference.
· Enable sending ICMP destination unreachable messages on the destination device. If the destination device is an H3C device, use the ip unreachables enable command. For more information about the ip unreachables enable command, see Network Connectivity Command Reference.
3. Specify the UDP tracert operation type and enter its view.
type udp-tracert
4. Specify the destination IP address for the UDP packets.
5. Specify the destination port number for the UDP packets.
By default, the destination port number is 33434.
The specified port number must be an unused port number on the destination device, so the destination device can reply with an ICMP port unreachable message.
6. Specify an output interface for UDP packets.
7. Specify the source IP address for UDP packets.
¡ Specify the IP address of the specified interface as the source IP address.
By default, the source IP address of UDP packets is the primary IP address of their output interface.
¡ Specify the source IP address.
The specified source interface must be up. The source IP address must be the IP address of a local interface, and the local interface must be up. Otherwise, no probe packets can be sent out.
8. Specify the source port number for UDP packets.
9. Set the maximum number of consecutive probe failures.
max-failure times
The default setting is 5.
10. Set the initial TTL value for UDP packets.
init-ttl value
The default setting is 1.
11. (Optional.) Set the payload size for each UDP packet.
data-size size
12. (Optional.) Enable the no-fragmentation feature.
no-fragment enable
By default, the no-fragmentation feature is disabled.
The voice operation measures VoIP network performance.
The voice operation works as follows:
1. The NQA client sends voice packets at sending intervals to the destination device (NQA server).
The voice packets are of one of the following codec types:
¡ G.711 A-law.
¡ G.711 µ-law.
¡ G.729 A-law.
2. The destination device time stamps each voice packet it receives and sends it back to the source.
3. Upon receiving the packet, the source device calculates the jitter and one-way delay based on the timestamp.
The voice operation sends a number of voice packets to the destination device per probe. The number of packets to send per probe is determined by using the probe packet-number command.
The following parameters that reflect VoIP network performance can be calculated by using the metrics gathered by the voice operation:
· Calculated Planning Impairment Factor (ICPIF)—Measures impairment to voice quality on a VoIP network. It is decided by packet loss and delay. A higher value represents a lower service quality.
· Mean Opinion Scores (MOS)—A MOS value can be evaluated by using the ICPIF value, in the range of 1 to 5. A higher value represents a higher service quality.
The evaluation of voice quality depends on users' tolerance for voice quality. For users with higher tolerance for voice quality, use the advantage-factor command to set an advantage factor. When the system calculates the ICPIF value, it subtracts the advantage factor to modify ICPIF and MOS values for voice quality evaluation.
The voice operation requires both the NQA server and the NQA client. Before you perform a voice operation, configure a UDP listening service on the NQA server. For more information about UDP listening service configuration, see "Configuring the NQA server."
To ensure successful voice operations and avoid affecting existing services, do not perform the operations on well-known ports from 1 to 1023.
The display nqa history command does not display the results or statistics of the voice operation. To view the results or statistics of the voice operation, use the display nqa result or display nqa statistics command.
3. Specify the voice type and enter its view.
type voice
4. Specify the destination IP address for voice packets.
By default, no destination IP address is configured.
The destination IP address must be the same as the IP address of the UDP listening service on the NQA server.
5. Specify the destination port number for voice packets.
6. Specify the source IP address for voice packets.
By default, the source IP address of voice packets is the primary IP address of their output interface.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no voice packets can be sent out.
7. Specify the source port number for voice packets.
8. Configure the basic voice operation parameters.
¡ Specify the codec type.
codec-type { g711a | g711u | g729a }
By default, the codec type is G.711 A-law.
¡ Set the advantage factor for calculating MOS and ICPIF values.
advantage-factor factor
By default, the advantage factor is 0.
9. Configure the probe parameters for the voice operation.
¡ Set the number of voice packets to be sent per probe.
The default setting is 1000.
¡ Set the interval for sending voice packets.
¡ Specify how long the NQA client waits for a response from the server before it regards the response times out.
The default setting is 5000 milliseconds.
10. Configure the payload parameters.
a. Set the payload size.
data-size size
For the G.711A-law and G.711 µ-law codec types, the default payload size is 172 bytes.
For the G.729 A-law codec type, the default payload size is 32 bytes.
b. (Optional.) Specify the payload fill string for voice packets.
data-fill string
The DLSw operation measures the response time of a DLSw device.
It sets up a DLSw connection to the DLSw device per probe.
3. Specify the DLSw type and enter its view.
type dlsw
4. Specify the destination IP address for the probe packets.
5. Specify the source IP address for the probe packets.
By default, the source IP address of the probe packets is the primary IP address of their output interface.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out.
The path jitter operation measures the jitter, negative jitters, and positive jitters from the NQA client to each hop on the path to the destination.
The path jitter operation performs the following steps per probe:
1. Obtains the path from the NQA client to the destination through tracert. A maximum of 64 hops can be detected.
2. Sends a number of ICMP echo requests to each hop along the path. The number of ICMP echo requests to send is set by using the probe packet-number command.
Before you configure the path jitter operation, you must perform the following tasks:
For more information about the ip ttl-expires enable and ip unreachables enable commands, see Network Connectivity Command Reference.
3. Specify the path jitter type and enter its view.
type path-jitter
5. Specify the source IP address for ICMP echo requests.
The source IP address must be the IP address of a local interface, and the interface must be up. Otherwise, no ICMP echo requests can be sent out.
6. Configure the probe parameters for the path jitter operation.
a. Set the number of ICMP echo requests to be sent per probe.
b. Set the interval for sending ICMP echo requests.
c. Specify how long the NQA client waits for a response from the server before it regards the response times out.
7. (Optional.) Specify an LSR path.
lsr-path ip-address&<1-8>
By default, no LSR path is specified.
The path jitter operation uses tracert to detect the LSR path to the destination, and sends ICMP echo requests to each hop on the LSR path.
8. Configure the NQA client to perform the path jitter operation only on the destination address.
target-only
By default, the path jitter operation is performed on each hop on the path to the destination.
9. (Optional.) Set the payload size for each ICMP echo request.
data-size size
10. (Optional.) Specify the payload fill string for ICMP echo requests.
data-fill string
Unless otherwise specified, the following optional parameters apply to all types of NQA operations.
The parameter settings take effect only on the current operation.
2. Enter the view of an existing NQA operation.
3. Configure a description for the operation.
By default, no description is configured.
4. Set the interval at which the NQA operation repeats.
frequency interval
For a voice or path jitter operation, the default setting is 60000 milliseconds.
For other types of operations, the default setting is 0 milliseconds, and only one operation is performed.
When the interval expires, but the operation is not completed or is not timed out, the next operation does not start.
5. Specify the probe times.
probe count times
In an UDP tracert operation, the NQA client performs three probes to each hop to the destination by default.
In other types of operations, the NQA client performs one probe to the destination per operation by default.
This command is not available for the voice and path jitter operations. Each of these operations performs only one probe.
6. Set the probe timeout time.
probe timeout timeout
This command is not available for the ICMP jitter, UDP jitter, voice, or path jitter operations.
7. Set the maximum number of hops that the probe packets can traverse.
ttl value
The default setting is 30 for probe packets of the UDP tracert operation, and is 20 for probe packets of other types of operations.
This command is not available for the DHCP or path jitter operations.
8. Set the ToS value in the IP header of the probe packets.
tos value
The default setting is 0.
9. Enable the routing table bypass feature.
route-option bypass-route
By default, the routing table bypass feature is disabled.
This command does not take effect if the destination address of the NQA operation is an IPv6 address.
Collaboration is implemented by associating a reaction entry of an NQA operation with a track entry. The reaction entry monitors the NQA operation. If the number of operation failures reaches the specified threshold, the configured action is triggered.
The collaboration feature is not available for the following types of operations:
· ICMP jitter operation.
· UDP jitter operation.
· UDP tracert operation.
· Voice operation.
· Path jitter operation.
A reaction entry cannot be modified after it is created.
3. Configure a reaction entry.
reaction item-number checked-element probe-fail threshold-type consecutive consecutive-occurrences action-type trigger-only
You cannot modify the content of an existing reaction entry.
4. Return to system view.
5. Associate Track with NQA.
For information about the configuration, see High Availability Configuration Guide.
6. Associate Track with an application module.
This feature allows you to monitor the NQA operation running status.
An NQA operation supports the following threshold types:
· average—If the average value for the monitored performance metric either exceeds the upper threshold or goes below the lower threshold, a threshold violation occurs.
· accumulate—If the total number of times that the monitored performance metric is out of the specified value range reaches or exceeds the specified threshold, a threshold violation occurs.
· consecutive—If the number of consecutive times that the monitored performance metric is out of the specified value range reaches or exceeds the specified threshold, a threshold violation occurs.
Threshold violations for the average or accumulate threshold type are determined on a per NQA operation basis. The threshold violations for the consecutive type are determined from the time the NQA operation starts.
The following actions might be triggered:
· none—NQA displays results only on the terminal screen. It does not send traps to the NMS.
· trap-only—NQA displays results on the terminal screen, and meanwhile it sends traps to the NMS.
To send traps to the NMS, the NMS address must be specified by using the snmp-agent target-host command. For more information about the command, see Network Management and Monitoring Command Reference.
· trigger-only—NQA displays results on the terminal screen, and meanwhile triggers other modules for collaboration.
In a reaction entry, configure a monitored element, a threshold type, and an action to be triggered to implement threshold monitoring.
The state of a reaction entry can be invalid, over-threshold, or below-threshold.
· Before an NQA operation starts, the reaction entry is in invalid state.
· If the threshold is violated, the state of the entry is set to over-threshold. Otherwise, the state of the entry is set to below-threshold.
The threshold monitoring feature is not available for the path jitter operation.
3. Enable sending traps to the NMS when specific conditions are met.
reaction trap { path-change | probe-failure consecutive-probe-failures | test-complete | test-failure [ accumulate-probe-failures ] }
By default, no traps are sent to the NMS.
The ICMP jitter, UDP jitter, and voice operations support only the test-complete keyword.
The following parameters are not available for the UDP tracert operation:
¡ The probe-failure consecutive-probe-failures option.
¡ The accumulate-probe-failures argument.
4. Configure threshold monitoring. Choose the options to configure as needed:
¡ Monitor the operation duration.
reaction item-number checked-element probe-duration threshold-type { accumulate accumulate-occurrences | average | consecutive consecutive-occurrences } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
This reaction entry is not supported in the ICMP jitter, UDP jitter, UDP tracert, or voice operations
¡ Monitor failure times.
reaction item-number checked-element probe-fail threshold-type { accumulate accumulate-occurrences | consecutive consecutive-occurrences } [ action-type { none | trap-only } ]
This reaction entry is not supported in the ICMP jitter, UDP jitter, UDP tracert, or voice operations.
¡ Monitor the round-trip time.
reaction item-number checked-element rtt threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
Only the ICMP jitter, UDP jitter, and voice operations support this reaction entry.
¡ Monitor packet loss.
reaction item-number checked-element packet-loss threshold-type accumulate accumulate-occurrences [ action-type { none | trap-only } ]
¡ Monitor the one-way jitter.
reaction item-number checked-element { jitter-ds | jitter-sd } threshold-type { accumulate accumulate-occurrences | average } threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
¡ Monitor the one-way delay.
reaction item-number checked-element { owd-ds | owd-sd } threshold-value upper-threshold lower-threshold
¡ Monitor the ICPIF value.
reaction item-number checked-element icpif threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
Only the voice operation supports this reaction entry.
¡ Monitor the MOS value.
reaction item-number checked-element mos threshold-value upper-threshold lower-threshold [ action-type { none | trap-only } ]
The DNS operation does not support the action of sending trap messages. For the DNS operation, the action type can only be none.
NQA forms statistics within the same collection interval as a statistics group. To display information about the statistics groups, use the display nqa statistics command.
When the maximum number of statistics groups is reached, the NQA client deletes the oldest statistics group to save a new one.
A statistics group is automatically deleted when its hold time expires.
The NQA statistics collection feature is not available for the UDP tracert operation.
If you use the frequency command to set the interval to 0 milliseconds for an NQA operation, NQA does not generate any statistics group for the operation.
3. Set the statistics collection interval.
statistics interval interval
The default setting is 60 minutes.
4. Set the maximum number of statistics groups that can be saved.
statistics max-group number
By default, the NQA client can save a maximum of two statistics groups for an operation.
To disable the NQA statistics collection feature, set the number argument to 0.
5. Set the hold time of statistics groups.
statistics hold-time hold-time
The default setting is 120 minutes.
This task enables the NQA client to save NQA history records. You can use the display nqa history command to display the NQA history records.
The NQA history record saving feature is not available for the following types of operations:
· Voice operation.
3. Enable the saving of history records for the NQA operation.
history-record enable
By default, this feature is enabled only for the UDP tracert operation.
4. Set the lifetime of history records.
history-record keep-time keep-time
A record is deleted when its lifetime is reached.
5. Set the maximum number of history records that can be saved.
history-record number number
The default setting is 50.
When the maximum number of history records is reached, the system will delete the oldest record to save a new one.
The NQA operation runs between the specified start time and end time (the start time plus operation duration). If the specified start time is ahead of the system time, the operation starts immediately. If both the specified start and end time are ahead of the system time, the operation does not start. To display the current system time, use the display clock command.
You cannot enter the operation type view or the operation view of a scheduled NQA operation.
A system time adjustment does not affect started or completed NQA operations. It affects only the NQA operations that have not started.
2. Specify the scheduling parameters for an NQA operation.
nqa schedule admin-name operation-tag start-time { hh:mm:ss [ yyyy/mm/dd | mm/dd/yyyy ] | now } lifetime { lifetime | forever } [ recurring ]
Some operation parameters for an NQA template can be specified by the template configuration or the feature (such as load balancing) that uses the template. When both are specified, the parameters in the template configuration take effect.
To configure NQA templates, perform the following tasks:
1. Perform at least one of the following tasks:
¡ Configuring the ARP template
¡ Configuring the ICMP template
¡ Configuring the IMAP template
¡ Configuring the DNS template
¡ Configuring the POP3 template
¡ Configuring the SMTP template
¡ Configuring the TCP template
¡ Configuring the TCP half open template
¡ Configuring the UDP template
¡ Configuring the HTTP template
¡ Configuring the HTTPS template
¡ Configuring the FTP template
¡ Configuring the RADIUS authentication template
¡ Configuring the RTSP template
¡ Configuring the SIP template
¡ Configuring the SNMP template
¡ Configuring the SNMP DCA template
¡ Configuring the SSL template
¡ Configuring the WAP template
2. (Optional.) Configuring optional parameters for the NQA template
A feature that uses the ARP template performs the ARP operation to test whether the ARP service is available on the destination device.
In the ARP operation, the NQA client sends an ARP request to the destination device. If the client receives an ARP reply, it determines that the ARP service is available on the destination device.
2. Create an ARP template and enter its view.
nqa template arp name
3. (Optional.) Specify the destination IP address for the probe packets.
4. (Optional.) Specify the source IP address for the probe packets.
A feature that uses the ICMP template performs the ICMP operation to measure the reachability of a destination device. The ICMP template is supported on both IPv4 and IPv6 networks.
2. Create an ICMP template and enter its view.
nqa template icmp name
3. Specify the destination IP address for the operation.
IPv4:
IPv6:
4. Specify the source IP address for ICMP echo requests. Choose one option as needed:
By default, the primary IP address of the output interface is used as the source IP address of ICMP echo requests.
By default, the primary IPv4 address of the output interface is used as the source IPv4 address of ICMP echo requests.
By default, the IPv6 address of the output interface is used as the source IPv6 address of ICMP echo requests.
5. Specify the next hop IP address for ICMP echo requests.
IPv4:
IPv6:
By default, no IP address of the next hop is configured.
6. Configure the probe result sending on a per-probe basis.
reaction trigger per-probe
By default, the probe result is sent to the feature that uses the template after three consecutive failed or successful probes.
If you execute the reaction trigger per-probe and reaction trigger probe-pass commands multiple times, the most recent configuration takes effect.
If you execute the reaction trigger per-probe and reaction trigger probe-fail commands multiple times, the most recent configuration takes effect.
7. (Optional.) Set the payload size for each ICMP request.
data-size size
data-fill string
A feature that uses the IMAP template performs the IMAP operation to determine the availability of the IMAP service on the IMAP server.
Before you perform an IMAP operation, enable the IMAP Server service on the IMAP server and configure related settings, including the login username, password, and mailbox name.
2. Create an IMAP template and enter IMAP template view.
nqa template imap name
3. (Optional.) Specify the destination address for the probe packets.
IPv4:
IPv6:
By default, no destination address is specified.
4. (Optional.) Specify the destination port number for the probe packets.
The default destination port number is 143.
5. (Optional.) Specify the source address for the probe packets.
IPv4:
By default, the primary IPv4 address of the output interface is used as the source IPv4 address of the probe packets.
The source IPv4 address must be the IPv4 address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out.
IPv6:
By default, the source IPv6 address of the probe packets is the IPv6 address of their output interface.
The source IPv6 address must be the IPv6 address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out.
6. (Optional.) Specify the login username.
username username
By default, no login username is specified.
7. (Optional.) Specify the login password.
By default, no login password is specified.
8. (Optional.) Specify the mailbox name.
mailbox mailbox-name
By default, mailbox INBOX is used.
A feature that uses the DNS template performs the DNS operation to determine the status of the server. The DNS template is supported on both IPv4 and IPv6 networks.
In DNS template view, you can specify the address expected to be returned. If the returned IP addresses include the expected address, the DNS server is valid and the operation succeeds. Otherwise, the operation fails.
Create a mapping between the domain name and an address before you perform the DNS operation. For information about configuring the DNS server, see documents about the DNS server configuration.
2. Create a DNS template and enter DNS template view.
nqa template dns name
3. Specify the destination IP address for the probe packets.
IPv4:
IPv6:
4. Specify the destination port number for the probe packets.
By default, the destination port number is 53.
IPv4:
By default, the source IPv4 address of the probe packets is the primary IPv4 address of their output interface.
IPv6:
6. Specify the source port number for the probe packets.
By default, no source port number is specified.
7. Specify the domain name to be translated.
8. Specify the domain name resolution type.
resolve-type { A | AAAA }
By default, the type is type A.
A type A query resolves a domain name to a mapped IPv4 address, and a type AAAA query to a mapped IPv6 address.
9. (Optional.) Specify the IP address that is expected to be returned.
IPv4:
expect ip ip-address
IPv6:
expect ipv6 ipv6-address
By default, no expected IP address is specified.
10. Configure the probe result sending on a per-probe basis.
A feature that uses the POP3 template performs the POP3 operation to determine the availability of the POP3 service on the POP3 server.
Before you perform a POP3 operation, enable the POP3 Server service on the POP3 server and configure related settings, including the login username and password.
2. Create a POP3 template and enter POP3 template view.
nqa template pop3 name
IPv4:
IPv6:
The default destination port number is 110.
IPv4:
IPv6:
6. Specify the login username.
username username
7. Specify the login password.
About the SMTP template
A feature that uses the SMTP template performs the SMTP operation to determine the availability of the SMTP service on the SMTP server.
2. Create a SMTP template and enter SMTP template view.
nqa template smtp name
IPv4:
IPv6:
The default destination port number is 25.
IPv4:
IPv6:
A feature that uses the TCP template performs the TCP operation to test whether the NQA client can establish a TCP connection to a specific port on the server.
In TCP template view, you can specify the expected data to be returned. If you do not specify the expected data, the TCP operation tests only whether the client can establish a TCP connection to the server.
2. Create a TCP template and enter its view.
nqa template tcp name
IPv4:
IPv6:
The destination address must be the same as the IP address of the TCP listening service configured on the NQA server.
4. Specify the destination port number for the operation.
The destination port number must be the same as the port number of the TCP listening service on the NQA server.
IPv4:
The source IP address must be the IPv4 address of a local interface, and the interface must be up. Otherwise, no probe packets can be sent out.
IPv6:
By default, the IPv6 address of the output interface is used as the source IPv6 address of the probe packets.
6. (Optional.) Specify the payload fill string for the probe packets. Choose one option as needed:
¡ Specify the payload fill string.
data-fill string
¡ Specify the hexadecimal payload fill string.
hex-data-fill hex [ raw ]
7. (Optional.) Configure the expected response data.
¡ Configure the expected response data to determine a successful NQA operation:
expect { data | hex-data } string [ offset number ]
¡ Configure the expected response data to determine a failed NQA operation:
expect { failed-data | hex-failed-data } string [ offset number ]
By default, no expected response data is configured.
The expected response data check takes effect only if the data-fill or hex-data-fill command is also configured.
If you configure both commands, the expect { failed-data | hex-failed-data } command takes effect.
8. (Optional.) Enable the NQA client to send resource release notifications to the NQA server when the operation is complete.
resource-release { data-fill | hex-data-fill } string
By default, the NQA client does not send resource release notifications to the NQA server when an NQA operation is complete.
A feature that uses the TCP half open template performs the TCP half open operation to test whether the TCP service is available on the server. The TCP half open operation is used when the feature cannot get a response from the TCP server through an existing TCP connection.
The TCP half open operation works as follows:
· If port detection is disabled, the NQA client sends a TCP ACK packet to the server. If the client receives an RST packet, it considers that the TCP service is available on the server.
· If port detection is enabled, the NQA client sends a TCP SYN packet to the server. If the client receives a SYN-ACK packet, it considers that the destination TCP port is operating correctly on the server.
2. Create a TCP half open template and enter its view.
nqa template tcphalfopen name
3. (Optional.) Enable port detection.
port-detect enable
By default, port detection is disabled.
To use the port detection feature, you must specify a destination port number for the TCP half open template.
4. Specify the destination IP address of the operation.
IPv4:
IPv6:
The destination address must be the same as the IP address of the listening service configured on the NQA server.
5. Specify the destination port number.
For the port detection feature to take effect, the destination port number must be specified.
6. Specify the source IP address for the probe packets.
IPv4:
IPv6:
7. Specify the output interface for the probe packets.
8. Specify the next hop IP address for the probe packets.
IPv4:
IPv6:
By default, the IP address of the next hop is configured.
9. Configure the probe result sending on a per-probe basis.
A feature that uses the UDP template performs the UDP operation to test the following items:
· Reachability of a specific port on the NQA server.
· Availability of the requested service on the NQA server.
In UDP template view, you can specify the expected data to be returned. If you do not specify the expected data, the UDP operation tests only whether the client can receive the response packet from the server.
The UDP operation requires both the NQA server and the NQA client. Before you perform a UDP operation, configure a UDP listening service on the NQA server. For more information about the UDP listening service configuration, see "Configuring the NQA server."
2. Create a UDP template and enter its view.
nqa template udp name
3. Specify the destination IP address of the operation.
IPv4:
IPv6:
IPv4:
IPv6:
data-fill string
7. (Optional.) Set the payload size for the probe packets.
data-size size
8. (Optional.) Configure the expected response data.
9. (Optional.) Enable the NQA client to send resource release notifications to the NQA server when the operation is complete.
A feature that uses the HTTP template performs the HTTP operation to measure the time it takes the NQA client to obtain data from an HTTP server.
The expected data is checked only when the data is configured and the HTTP response contains the Content-Length field in the HTTP header.
The status code of the HTTP packet is a three-digit field in decimal notation, and it includes the status information for the HTTP server. The first digit defines the class of response.
Before you perform the HTTP operation, you must configure the HTTP server.
2. Create an HTTP template and enter its view.
nqa template http name
3. Specify the destination URL for the HTTP template.
url url
By default, no destination URL is specified for an HTTP template.
4. Specify an HTTP login username.
username username
5. Specify an HTTP login password.
6. Specify the HTTP version.
7. Specify the HTTP operation type.
By default, the HTTP operation type is get.
8. Configure the content of the HTTP raw request.
raw-request
c. Return to HTTP template view.
The system automatically saves the configuration in raw request view before it returns to HTTP template view.
9. Specify the source IP address for the probe packets.
IPv4:
IPv6:
10. (Optional.) Configure the expected status codes.
expect status status-list
By default, no expected status code is configured.
11. (Optional.) Configure the expected data.
expect data expression [ offset number ]
By default, no expected data is configured.
A feature that uses the HTTPS template performs the HTTPS operation to measure the time it takes for the NQA client to obtain data from an HTTPS server.
The expected data is checked only when the expected data is configured and the HTTPS response contains the Content-Length field in the HTTPS header.
The status code of the HTTPS packet is a three-digit field in decimal notation, and it includes the status information for the HTTPS server. The first digit defines the class of response.
Before you perform the HTTPS operation, configure the HTTPS server and the SSL client policy for the SSL client. For information about configuring SSL client policies, see Security Configuration Guide.
2. Create an HTTPS template and enter its view.
nqa template https name
3. Specify the destination URL for the HTTPS template.
url url
By default, no destination URL is specified for an HTTPS template.
¡ https://host/resource
¡ https://host:port/resource
4. Specify an HTTPS login username.
username username
By default, no HTTPS login username is specified.
5. Specify an HTTPS login password.
By default, no HTTPS login password is specified.
6. Specify an SSL client policy.
ssl-client-policy policy-name
By default, no SSL client policy is specified.
7. Specify the HTTPS version.
By default, HTTPS 1.0 is used.
8. Specify the HTTPS operation type.
By default, the HTTPS operation type is get.
If you set the operation type to raw, the client pads the content configured in raw request view to the HTTPS request to send to the HTTPS server.
9. Configure the content of the HTTPS raw request.
raw-request
c. Return to HTTPS template view.
The system automatically saves the configuration in raw request view before it returns to HTTPS template view.
10. Specify the source IP address for the probe packets.
IPv4:
IPv6:
12. (Optional.) Configure the expected status codes.
A feature that uses the FTP template performs the FTP operation. The operation measures the time it takes the NQA client to transfer a file to or download a file from an FTP server.
Configure the username and password for the FTP client to log in to the FTP server before you perform an FTP operation. For information about configuring the FTP server, see Fundamentals Configuration Guide.
2. Create an FTP template and enter its view.
nqa template ftp name
3. Specify an FTP login username.
username username
4. Specify an FTP login password.
password { cipher | simple } sting
IPv4:
IPv6:
6. Set the data transmission mode.
7. Specify the FTP operation type.
By default, the FTP operation type is get, which means obtaining files from the FTP server.
8. Specify the destination URL for the FTP template.
url url
By default, no destination URL is specified for an FTP template.
When you perform the get operation, the file name is required.
When you perform the put operation, the filename argument does not take effect, even if it is specified. The file name for the put operation is determined by using the filename command.
9. Specify the name of a file to be transferred.
filename filename
This task is required only for the put operation.
A feature that uses the RADIUS authentication template performs the RADIUS authentication operation to check the availability of the authentication service on the RADIUS server.
The RADIUS authentication operation workflow is as follows:
1. The NQA client sends an authentication request (Access-Request) to the RADIUS server. The request includes the username and the password. The password is encrypted by using the MD5 algorithm and the shared key.
2. The RADIUS server authenticates the username and password.
¡ If the authentication succeeds, the server sends an Access-Accept packet to the NQA client.
¡ If the authentication fails, the server sends an Access-Reject packet to the NQA client.
3. The NQA client determines the availability of the authentication service on the RADIUS server based on the response packet it received:
¡ If an Access-Accept packet is received, the authentication service is available on the RADIUS server.
¡ If an Access-Reject packet is received, the authentication service is not available on the RADIUS server.
Before you configure the RADIUS authentication template, specify a username, password, and shared key on the RADIUS server. For more information about configuring the RADIUS server, see AAA in User Access and Authentication Configuration Guide.
2. Create a RADIUS authentication template and enter its view.
nqa template radius name
IPv4:
IPv6:
By default, the destination port number is 1812.
5. Specify a username.
username username
By default, no username is specified.
6. Specify a password.
By default, no password is specified.
7. Specify a shared key for secure RADIUS authentication.
key { cipher | simple } string
By default, no shared key is specified for RADIUS authentication.
8. Specify the source IP address for the probe packets.
IPv4:
IPv6:
The Real Time Streaming Protocol (RTSP) is a network control protocol designed for real-time control (such as play/pause and forward/playback) of media streaming on the Internet.
A feature that uses the RTSP template performs the RTSP operation to test the availability of the RTSP server.
2. Create an RTSP template and enter RTSP template view.
nqa template rtsp name
3. (Optional.) Specify the source address for the probe packets.
IPv4:
IPv6:
4. (Optional.) Specify the request method.
¡ Specify the OPTIONS method.
request-method options
¡ Specify the DESCRIBE method.
request-method describe
By default, the OPTIONS method is used.
5. (Optional.) Configure the expected status codes.
6. (Optional.) Specify the destination URL.
url url
By default, no destination URL is specified.
Valid formats for the destination URL are:
¡ rtsp://host/resource
¡ rtsp: //host:port/resource
The Session Initiation Protocol (SIP) is a communications protocol for signaling that controls multimedia communication sessions over IP networks. SIP messages can be transported over UDP or TCP.
A feature that uses the SIP template performs the SIP operation to test the availability of the SIP service on the SIP server.
2. Create a SIP template and enter SIP template view.
nqa template sip name
3. Specify the transport protocol.
transport-protocol { tcp | udp }
By default, the UDP transport protocol is used.
4. (Optional.) Specify the destination address for the probe packets.
IPv4:
IPv6:
5. (Optional.) Specify the destination port number for the probe packets.
The default destination port number is 5060.
6. (Optional.) Specify the source address for the probe packets.
IPv4:
IPv6:
7. (Optional.) Configure the expected status codes.
By default, no expected status codes are configured.
A feature that uses the SNMP template performs the SNMP operation to determine the availability of the SNMP service on an SNMP agent.
2. Create an SNMP template and enter SNMP template view.
nqa template snmp name
IPv4:
IPv6:
The default destination port number is 161.
IPv4:
IPv6:
6. (Optional.) Specify the community name for SNMPv1 or SNMPv2c probe packets.
By default, the SNMP template uses community name public.
A feature that uses the SNMP Data Collection Agent (DCA) template performs the SNMP DCA operation to measure the performance of a device running an SNMP agent. The SNMP DCA operation involves the following steps:
1. The NQA client sends queries to collect SNMP object values from the SNMP agent.
The query message contains the OID that identifies the object to collect on the SNMP agent. Typically, the CPU, memory, and disk usage objects are collected.
2. The NQA client determines the performance of the device based on the collected object values and the threshold and weight values configured for the objects. Then, the NQA client reports the information to the associated feature for the feature to act accordingly.
Before you start the SNMP DCA operation, you must configure the SNMP agent.
2. Create an SNMP DCA template and enter its view.
nqa template snmpdca name
IPv4:
IPv6:
IPv4:
IPv6:
6. (Optional.) Specify the SNMP community name.
The default SNMP community name is public.
7. (Optional.) Specify the SNMP agent type.
agent-type { net-snmp | user-defined | windows }
The default SNMP agent type is Net-SNMP.
8. (Optional.) Specify the SNMP version.
version { v1 | v2c }
By default, SNMPv1 is used.
9. (Optional.) Specify the threshold and weight for the CPU usage object.
cpu { threshold threshold-value | weight weight-value }
By default, the CPU usage threshold is 80 and the weight is 3.
10. (Optional.) Specify the threshold and weight for the memory usage object.
memory { threshold threshold-value | weight weight-value } *
By default, the memory usage threshold is 70 and the weight is 2.
11. (Optional.) Specify the threshold and weight for the disk usage object.
disk { threshold threshold-value | weight weight-value } *
By default, the disk usage threshold is 90 and the weight is 4.
12. (Optional.) Configure a custom SNMP object for the SNMP DCA to collect and set the threshold and weight for the object.
oid oid threshold threshold-value weight weight-value
By default, an SNMP DCA template does not contain custom SNMP objects.
This step is required if the user-defined SNMP agent type is used.
A feature that uses the SSL template performs the SSL operation to measure the time required to establish an SSL connection to an SSL server.
Before you configure the SSL template, you must configure the SSL client policy. For information about configuring SSL client policies, see Security Configuration Guide.
2. Create an SSL template and enter its view.
nqa template ssl name
IPv4:
IPv6:
By default, the destination port number is not specified.
5. Specify an SSL client policy.
IPv4:
IPv6:
Wireless Application Protocol (WAP) is a technical standard for accessing information over a mobile wireless network. It describes a protocol suite allowing the interoperability of WAP equipment, and software with different network technologies.
A feature that uses the WAP template performs the WAP operation to determine the availability of the WAP gateway.
Before you start the WAP operation, you must configure the WAP gateway.
2. Create an WAP template and enter its view.
nqa template wap name
IPv4:
IPv6:
IPv4:
IPv6:
url url
7. (Optional.) Configure the expected response data to determine a successful NQA operation.
By default, no expected response data is configured to determine a successful NQA operation.
This step is required if the url command is configured.
Unless otherwise specified, the following optional parameters apply to all types of NQA templates.
The parameter settings take effect only on the current NQA template.
1. Enter system view.
2. Enter the view of an existing NQA template.
nqa template { arp | dns | ftp | http | https | icmp | imap | pop3 | radius | rtsp | sip | smtp | snmp | snmpdca | ssl | tcp | tcphalfopen | udp | wap } name
3. Configure a description.
frequency interval
If the operation is not completed when the interval expires, the next operation does not start.
5. Set the probe timeout time.
6. Set the TTL for the probe packets.
ttl value
The default setting is 20.
This command is not available for the ARP template.
7. Set the ToS value in the IP header of the probe packets.
tos value
By default, the operation is performed on the public network.
8. Set the number of consecutive successful probes to determine a successful operation event.
reaction trigger probe-pass count
The default setting is 3.
If the number of consecutive successful probes for an NQA operation is reached, the NQA client notifies the feature that uses the template of the successful operation event.
9. Set the number of consecutive probe failures to determine an operation failure.
reaction trigger probe-fail count
If the number of consecutive probe failures for an NQA operation is reached, the NQA client notifies the feature that uses the NQA template of the operation failure.
Display and maintenance commands for NQA
Task |
Command |
Display history records of NQA operations. |
display nqa history [ admin-name operation-tag ] |
Display the current monitoring results of reaction entries. |
display nqa reaction counters [ admin-name operation-tag [ item-number ] ] |
Display the most recent result of the NQA operation. |
display nqa result [ admin-name operation-tag ] |
Display NQA server status. |
display nqa server status |
Display NQA statistics. |
display nqa statistics [ admin-name operation-tag ] |
NQA configuration examples
Example: Configuring the ICMP echo operation
As shown in Figure 2, configure an ICMP echo operation on the NQA client (the AC) to test the round-trip time to Device A. The next hop of the AC is Device B.
1. Assign IP addresses to interfaces, as shown in Figure 2. (Details not shown.)
2. Configure static routes or a routing protocol to make sure the devices can reach each other. (Details not shown.)
3. Configure the AC:
# Create an ICMP echo operation.
<AC> system-view
[AC] nqa entry admin test1
[AC-nqa-admin-test1] type icmp-echo
# Specify 10.2.2.2 as the destination IP address of ICMP echo requests.
[AC-nqa-admin-test1-icmp-echo] destination ip 10.2.2.2
# Specify 10.1.1.2 as the next hop so the ICMP echo requests are sent through Device B to Device A.
[AC-nqa-admin-test1-icmp-echo] next-hop ip 10.1.1.2
# Configure the ICMP echo operation to perform 10 probes.
[AC-nqa-admin-test1-icmp-echo] probe count 10
# Set the probe timeout time to 500 milliseconds for the ICMP echo operation.
[AC-nqa-admin-test1-icmp-echo] probe timeout 500
# Configure the ICMP echo operation to repeat every 5000 milliseconds.
[AC-nqa-admin-test1-icmp-echo] frequency 5000
# Enable saving history records.
[AC-nqa-admin-test1-icmp-echo] history-record enable
# Set the maximum number of history records to 10.
[AC-nqa-admin-test1-icmp-echo] history-record number 10
[AC-nqa-admin-test1-icmp-echo] quit
# Start the ICMP echo operation.
[AC] nqa schedule admin test1 start-time now lifetime forever
# After the ICMP echo operation runs for a period of time, stop the operation.
[AC] undo nqa schedule admin test1
# Display the most recent result of the ICMP echo operation.
[AC] display nqa result admin test1
NQA entry (admin admin, tag test1) test results:
Send operation times: 10 Receive response times: 10
Min/Max/Average round trip time: 2/5/3
Square-Sum of round trip time: 96
Last succeeded probe time: 2011-08-23 15:00:01.2
Extended results:
Packet loss ratio: 0%
Failures due to timeout: 0
Failures due to internal error: 0
Failures due to other errors: 0
# Display the history records of the ICMP echo operation.
[AC] display nqa history admin test1
NQA entry (admin admin, tag test1) history records:
Index Response Status Time
370 3 Succeeded 2011-08-23 15:00:01.2
369 3 Succeeded 2011-08-23 15:00:01.2
368 3 Succeeded 2011-08-23 15:00:01.2
367 5 Succeeded 2011-08-23 15:00:01.2
366 3 Succeeded 2011-08-23 15:00:01.2
365 3 Succeeded 2011-08-23 15:00:01.2
364 3 Succeeded 2011-08-23 15:00:01.1
363 2 Succeeded 2011-08-23 15:00:01.1
362 3 Succeeded 2011-08-23 15:00:01.1
361 2 Succeeded 2011-08-23 15:00:01.1
The output shows that the packets sent by the AC can reach Device A through Device B. No packet loss occurs during the operation. The minimum, maximum, and average round-trip times are 2, 5, and 3 milliseconds, respectively.
Example: Configuring the ICMP jitter operation
As shown in Figure 3, configure an ICMP jitter operation to test the jitter between the AC and the device.
1. Assign IP addresses to interfaces, as shown in Figure 3. (Details not shown.)
# Create an ICMP jitter operation.
<AC> system-view
[AC-nqa-admin-test1] type icmp-jitter
# Specify 10.2.2.2 as the destination address for the operation.
[AC-nqa-admin-test1-icmp-jitter] destination ip 10.2.2.2
# Configure the operation to repeat every 1000 milliseconds.
[AC-nqa-admin-test1-icmp-jitter] frequency 1000
[AC-nqa-admin-test1-icmp-jitter] quit
# Start the ICMP jitter operation.
# After the ICMP jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the ICMP jitter operation.
Min/Max/Average round trip time: 15/32/17
Square-Sum of round trip time: 3235
Last packet received time: 2011-05-29 13:56:17.6
Extended results:
Packets out of sequence: 0
Packets arrived late: 0
ICMP-jitter results:
RTT number: 10
Min positive SD: 4 Min positive DS: 1
Max positive SD: 21 Max positive DS: 28
Positive SD number: 5 Positive DS number: 4
Positive SD sum: 52 Positive DS sum: 38
Positive SD average: 10 Positive DS average: 10
Positive SD square-sum: 754 Positive DS square-sum: 460
Min negative SD: 1 Min negative DS: 6
Max negative SD: 13 Max negative DS: 22
Negative SD number: 4 Negative DS number: 5
Negative SD sum: 38 Negative DS sum: 52
Negative SD average: 10 Negative DS average: 10
Negative SD square-sum: 460 Negative DS square-sum: 754
One way results:
Max SD delay: 15 Max DS delay: 16
Min SD delay: 7 Min DS delay: 7
Number of SD delay: 10 Number of DS delay: 10
Sum of SD delay: 78 Sum of DS delay: 85
Square-Sum of SD delay: 666 Square-Sum of DS delay: 787
Lost packets for unknown reason: 0
# Display the statistics of the ICMP jitter operation.
[AC] display nqa statistics admin test1
NQA entry (admin admin, tag test1) test statistics:
NO. : 1
Start time: 2015-07-10 13:56:14.0
Life time: 47 seconds
Send operation times: 410 Receive response times: 410
Min/Max/Average round trip time: 1/93/19
Square-Sum of round trip time: 206176
Extended results:
RTT number: 410
Min positive SD: 3 Min positive DS: 1
Max positive SD: 30 Max positive DS: 79
Positive SD number: 186 Positive DS number: 158
Positive SD sum: 2602 Positive DS sum: 1928
Positive SD average: 13 Positive DS average: 12
Positive SD square-sum: 45304 Positive DS square-sum: 31682
Min negative SD: 1 Min negative DS: 1
Max negative SD: 30 Max negative DS: 78
Negative SD number: 181 Negative DS number: 209
Negative SD sum: 181 Negative DS sum: 209
Negative SD average: 13 Negative DS average: 14
Negative SD square-sum: 46994 Negative DS square-sum: 3030
One way results:
Max SD delay: 46 Max DS delay: 46
Number of SD delay: 410 Number of DS delay: 410
Sum of SD delay: 3705 Sum of DS delay: 3891
Square-Sum of SD delay: 45987 Square-Sum of DS delay: 49393
Example: Configuring the FTP operation
As shown in Figure 4, configure an FTP operation to test the time required for the AC to upload a file to the FTP server. The login username and password are admin and systemtest, respectively. The file to be transferred to the FTP server is config.txt.
1. Assign IP addresses to interfaces, as shown in Figure 4. (Details not shown.)
# Create an FTP operation.
<AC> system-view
[AC-nqa-admin-test1] type ftp
# Specify the URL of the FTP server.
[AC-nqa-admin-test1-ftp] url ftp://10.2.2.2
# Specify 10.1.1.1 as the source IP address.
[AC-nqa-admin-test1-ftp] source ip 10.1.1.1
# Configure the device to upload file config.txt to the FTP server.
[AC-nqa-admin-test1-ftp] operation put
[AC-nqa-admin-test1-ftp] filename config.txt
# Set the username to admin for the FTP operation.
[AC-nqa-admin-test1-ftp] username admin
# Set the password to systemtest for the FTP operation.
[AC-nqa-admin-test1-ftp] password simple systemtest
# Enable the saving of history records.
[AC-nqa-admin-test1-ftp] history-record enable
[AC-nqa-admin-test1-ftp] quit
# Start the FTP operation.
# After the FTP operation runs for a period of time, stop the operation.
# Display the most recent result of the FTP operation.
Send operation times: 1 Receive response times: 1
Min/Max/Average round trip time: 173/173/173
Square-Sum of round trip time: 29929
Last succeeded probe time: 2011-11-22 10:07:28.6
Extended results:
Failures due to disconnect: 0
Failures due to no connection: 0
# Display the history records of the FTP operation.
1 173 Succeeded 2011-11-22 10:07:28.6
The output shows that it took the AC 173 milliseconds to upload a file to the FTP server.
Example: Configuring the HTTP operation
As shown in Figure 5, configure an HTTP operation on the NQA client to test the time required to obtain data from the HTTP server.
1. Assign IP addresses to interfaces, as shown in Figure 5. (Details not shown.)
# Create an HTTP operation.
<AC> system-view
[AC-nqa-admin-test1] type http
# Specify the URL of the HTTP server.
[AC-nqa-admin-test1-http] url http://10.2.2.2/index.htm
# Set the HTTP operation type to get (the default HTTP operation type).
[AC-nqa-admin-test1-http] operation get
# Configure the operation to use HTTP version 1.0 (the default HTTP version).
[AC-nqa-admin-test1-http] version v1.0
[AC-nqa-admin-test1-http] history-record enable
[AC-nqa-admin-test1-http] quit
# Start the HTTP operation.
# After the HTTP operation runs for a period of time, stop the operation.
# Display the most recent result of the HTTP operation.
Min/Max/Average round trip time: 64/64/64
Square-Sum of round trip time: 4096
Last succeeded probe time: 2011-11-22 10:12:47.9
Extended results:
# Display the history records of the HTTP operation.
1 64 Succeeded 2011-11-22 10:12:47.9
The output shows that it took the AC 64 milliseconds to obtain data from the HTTP server.
Example: Configuring the UDP jitter operation
As shown in Figure 6, configure a UDP jitter operation to test the jitter, delay, and round-trip time between the AC and the device.
1. Assign IP addresses to interfaces, as shown in Figure 6. (Details not shown.)
3. Configure the NTP protocol to make sure the devices are time synchronized.
4. Configure the device:
# Enable the NQA server.
[Device] nqa server enable
# Configure a listening service to listen to UDP port 9000 on IP address 10.2.2.2.
[Device] nqa server udp-echo 10.2.2.2 9000
5. Configure the AC:
# Create a UDP jitter operation.
<AC> system-view
[AC-nqa-admin-test1] type udp-jitter
# Specify 10.2.2.2 as the destination address of the operation.
[AC-nqa-admin-test1-udp-jitter] destination ip 10.2.2.2
# Set the destination port number to 9000.
[AC-nqa-admin-test1-udp-jitter] destination port 9000
[AC-nqa-admin-test1-udp-jitter] frequency 1000
[AC-nqa-admin-test1-udp-jitter] quit
# Start the UDP jitter operation.
# After the UDP jitter operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP jitter operation.
Extended results:
UDP-jitter results:
RTT number: 10
One way results:
SD lost packets: 0 DS lost packets: 0
# Display the statistics of the UDP jitter operation.
NO. : 1
Start time: 2011-05-29 13:56:14.0
Extended results:
UDP-jitter results:
RTT number: 410
One way results:
Example: Configuring the SNMP operation
As shown in Figure 7, configure an SNMP operation to test the time the AC uses to get a response from the SNMP agent.
1. Assign IP addresses to interfaces, as shown in Figure 7. (Details not shown.)
3. Configure the SNMP agent on the device:
# Set the SNMP version to all.
[Device] snmp-agent sys-info version all
# Set the read community to public.
[Device] snmp-agent community read public
# Set the write community to private.
[Device] snmp-agent community write private
4. Configure the AC:
# Create an SNMP operation.
<AC> system-view
[AC-nqa-admin-test1] type snmp
# Specify 10.2.2.2 as the destination IP address of the SNMP operation.
[AC-nqa-admin-test1-snmp] destination ip 10.2.2.2
[AC-nqa-admin-test1-snmp] history-record enable
[AC-nqa-admin-test1-snmp] quit
# Start the SNMP operation.
# After the SNMP operation runs for a period of time, stop the operation.
# Display the most recent result of the SNMP operation.
Min/Max/Average round trip time: 50/50/50
Square-Sum of round trip time: 2500
Last succeeded probe time: 2011-11-22 10:24:41.1
Extended results:
# Display the history records of the SNMP operation.
1 50 Succeeded 2011-11-22 10:24:41.1
The output shows that it took the AC 50 milliseconds to receive a response from the SNMP agent.
Example: Configuring the TCP operation
As shown in Figure 8, configure a TCP operation to test the time required for the AC to establish a TCP connection with the device.
1. Assign IP addresses to interfaces, as shown in Figure 8. (Details not shown.)
3. Configure the device:
# Configure a listening service to listen to TCP port 9000 on IP address 10.2.2.2.
[Device] nqa server tcp-connect 10.2.2.2 9000
# Create a TCP operation.
<AC> system-view
[AC-nqa-admin-test1] type tcp
# Specify 10.2.2.2 as the destination IP address.
[AC-nqa-admin-test1-tcp] destination ip 10.2.2.2
[AC-nqa-admin-test1-tcp] destination port 9000
[AC-nqa-admin-test1-tcp] history-record enable
[AC-nqa-admin-test1-tcp] quit
# Start the TCP operation.
# After the TCP operation runs for a period of time, stop the operation.
# Display the most recent result of the TCP operation.
Min/Max/Average round trip time: 13/13/13
Square-Sum of round trip time: 169
Last succeeded probe time: 2011-11-22 10:27:25.1
Extended results:
# Display the history records of the TCP operation.
1 13 Succeeded 2011-11-22 10:27:25.1
The output shows that it took the AC 13 milliseconds to establish a TCP connection to port 9000 on the NQA server.
Example: Configuring the UDP echo operation
As shown in Figure 9, configure a UDP echo operation on the NQA client to test the round-trip time to the device. The destination port number is 8000.
1. Assign IP addresses to interfaces, as shown in Figure 9. (Details not shown.)
# Configure a listening service to listen to UDP port 8000 on IP address 10.2.2.2.
[Device] nqa server udp-echo 10.2.2.2 8000
# Create a UDP echo operation.
<AC> system-view
[AC-nqa-admin-test1] type udp-echo
[AC-nqa-admin-test1-udp-echo] destination ip 10.2.2.2
# Set the destination port number to 8000.
[AC-nqa-admin-test1-udp-echo] destination port 8000
[AC-nqa-admin-test1-udp-echo] history-record enable
[AC-nqa-admin-test1-udp-echo] quit
# Start the UDP echo operation.
# After the UDP echo operation runs for a period of time, stop the operation.
# Display the most recent result of the UDP echo operation.
Min/Max/Average round trip time: 25/25/25
Square-Sum of round trip time: 625
Last succeeded probe time: 2011-11-22 10:36:17.9
Extended results:
# Display the history records of the UDP echo operation.
1 25 Succeeded 2011-11-22 10:36:17.9
The output shows that the round-trip time between the AC and port 8000 on the device is 25 milliseconds.
Example: Configuring NQA collaboration
As shown in Figure 10, configure a static route to Switch B on the AC with Switch A as the next hop. Associate the static route with a track entry and an ICMP echo operation to monitor the state of the static route.
1. Assign IP addresses to interfaces, as shown in Figure 10. (Details not shown.)
2. On the AC, configure a static route, and associate the static route with track entry 1.
<AC> system-view
[AC] ip route-static 10.1.1.2 24 10.2.1.1 track 1
3. Configure an ICMP echo operation:
# Create an NQA operation with administrator name admin and operation tag test1.
# Set the NQA operation type to ICMP echo.
[AC -nqa-admin-test1] type icmp-echo
# Specify 10.2.1.1 as the destination IP address.
[AC -nqa-admin-test1-icmp-echo] destination ip 10.2.1.1
# Configure the operation to repeat every 100 milliseconds.
[AC-nqa-admin-test1-icmp-echo] frequency 100
# Create reaction entry 1. If the number of consecutive probe failures reaches 5, collaboration is triggered.
[AC-nqa-admin-test1-icmp-echo] reaction 1 checked-element probe-fail threshold-type consecutive 5 action-type trigger-only
4. Create track entry 1, and associate it with reaction entry 1 of the NQA operation.
[AC] track 1 nqa entry admin test1 reaction 1
# Display information about all the track entries on the AC.
[AC] display track all
Track ID: 1
State: Positive
Duration: 0 days 0 hours 0 minutes 0 seconds
Notification delay: Positive 0, Negative 0 (in seconds)
Tracked object:
NQA entry: admin test1
Reaction: 1
# Display brief information about active routes in the routing table on the AC.
[AC] display ip routing-table
Destinations : 13 Routes : 13
0.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
10.1.1.0/24 Static 60 0 10.2.1.1 Vlan3
10.2.1.0/24 Direct 0 0 10.2.1.2 Vlan3
10.2.1.0/32 Direct 0 0 10.2.1.2 Vlan3
10.2.1.2/32 Direct 0 0 127.0.0.1 InLoop0
10.2.1.255/32 Direct 0 0 10.2.1.2 Vlan3
127.0.0.0/32 Direct 0 0 127.0.0.1 InLoop0
127.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
224.0.0.0/4 Direct 0 0 0.0.0.0 NULL0
224.0.0.0/24 Direct 0 0 0.0.0.0 NULL0
255.255.255.255/32 Direct 0 0 127.0.0.1 InLoop0
The output shows that the static route with the next hop 10.2.1.1 is active, and the status of the track entry is positive.
# Remove the IP address of VLAN-interface 3 on Switch A.
[SwitchA-Vlan-interface3] undo ip address
Track ID: 1
State: Negative
Tracked object:
Reaction: 1
Destinations : 12 Routes : 12
The output shows that the static route does not exist, and the status of the track entry is negative.
Example: Configuring the ARP template
As shown in Figure 11, configure an ARP template on the AC for a feature to perform the ARP operation to determine the availability of the ARP service on the device.
1. Assign IP addresses to interfaces, as shown in Figure 11. (Details not shown.)
2. Configure the AC:
# Create an ARP template named arp.
<AC> system-view
[AC] nqa template arp arp
# Specify 10.1.1.2 as the destination IP address for the probe packets.
[AC-nqatplt-arp-arp] destination ip 10.1.1.2
# Configure the NQA client to notify the feature of the successful operation event if the number of consecutive successful probes reaches 2.
[AC-nqatplt-arp-arp] reaction trigger probe-pass 2
# Configure the NQA client to notify the feature of the operation failure if the number of consecutive failed probes reaches 2.
[AC-nqatplt-arp-arp] reaction trigger probe-fail 2
Example: Configuring the ICMP template
As shown in Figure 12, configure an ICMP template for a feature to perform the ICMP echo operation from the AC to Device A.
1. Assign IP addresses to interfaces, as shown in Figure 12. (Details not shown.)
# Create ICMP template icmp.
<AC> system-view
[AC] nqa template icmp icmp
[AC-nqatplt-icmp-icmp] destination ip 10.2.2.2
[AC-nqatplt-icmp-icmp] probe timeout 500
# Configure the ICMP echo operation to repeat every 3000 milliseconds.
[AC-nqatplt-icmp-icmp] frequency 3000
[AC-nqatplt-icmp-icmp] reaction trigger probe-pass 2
[AC-nqatplt-icmp-icmp] reaction trigger probe-fail 2
Example: Configuring the IMAP template
As shown in Figure 13, configure an IMAP template for a feature to perform the IMAP operation to determine the availability of the IMAP service on the device.
In the IMAP operation, the NQA client will try to log in to mailbox test on the IMAP server by using username admin and password 123456.
1. Assign IP addresses to interfaces, as shown in Figure 13. (Details not shown.)
# Create an IMAP template named imap.
<AC> system-view
[AC] nqa template imap imap
[AC-nqatplt-imap-imap] destination ip 10.2.2.2
# Specify the login username and password.
[AC-nqatplt-imap-imap] username admin
[AC-nqatplt-imap-imap] password simple 123456
# Specify test as the mailbox name used for the IMAP operation.
[AC-nqatplt-imap-imap] mailbox test
[AC-nqatplt-imap-imap] reaction trigger probe-pass 2
[AC-nqatplt-imap-imap] reaction trigger probe-fail 2
Example: Configuring the POP3 template
As shown in Figure 14, configure a POP3 template for a feature to perform the POP3 operation to determine the availability of the POP3 service on the device.
In the POP3 operation, the NQA client will try to log in to the POP3 server by using username admin and password 123456.
1. Assign IP addresses to interfaces, as shown in Figure 14. (Details not shown.)
# Create a POP3 template named pop3.
<AC> system-view
[AC] nqa template pop3 pop3
[AC-nqatplt-pop3-pop3] destination ip 10.2.2.2
[AC-nqatplt-pop3-pop3] username admin
[AC-nqatplt-pop3-pop3] password simple 123456
[AC-nqatplt-pop3-pop3] reaction trigger probe-pass 2
[AC-nqatplt-pop3-pop3] reaction trigger probe-fail 2
Example: Configuring RTSP template
As shown in Figure 15, configure an RTSP template for a feature to perform the RTSP operation to test the availability of the RTSP server.
1. Assign IP addresses to interfaces, as shown in Figure 15. (Details not shown.)
3. Configure the RTSP server on the device. (Details not shown.)
# Create an RTSP template named rstp.
<AC> system-view
[AC] nqa template rtsp rtsp
# Specify rtsp://10.2.2.2/index.htm as the destination URL.
[AC-nqatplt-RTSP-RTSP] url RTSP://10.2.2.2/index.htm
# Set the RTSP request method to options.
[AC-nqatplt-rtsp-rtsp] request-method options
# Configure the expected status codes.
[AC-nqatplt-rtsp-rtsp] expect status 200 to 400
[AC-nqatplt-rtsp-rtsp] reaction trigger probe-pass 2
[AC-nqatplt-rtsp-rtsp] reaction trigger probe-fail 2
Example: Configuring SMTP template
As shown in Figure 16, configure an SMTP template for a feature to perform the SMTP operation to test whether the NQA client can log in to the mailbox on the SMTP server.
1. Assign IP addresses to interfaces, as shown in Figure 16. (Details not shown.)
3. Configur the AC:
# Create an SMTP template named smtp.
<AC>system-view
[AC] nqa template smtp smtp
[AC-nqatplt-smtp-smtp] destination ip 10.2.2.2
[AC-nqatplt-smtp-smtp] reaction trigger probe-pass 2
[AC-nqatplt-smtp-smtp] reaction trigger probe-fail 2
Example: Configuring the TCP template
As shown in Figure 17, configure a TCP template for a feature to perform the TCP operation. The operation tests whether the AC can establish a TCP connection to the device.
1. Assign IP addresses to interfaces, as shown in Figure 17. (Details not shown.)
# Create a TCP template named tcp.
<AC> system-view
[AC] nqa template tcp tcp
[AC-nqatplt-tcp-tcp] destination ip 10.2.2.2
[AC-nqatplt-tcp-tcp] destination port 9000
[AC-nqatplt-tcp-tcp] reaction trigger probe-pass 2
[AC-nqatplt-tcp-tcp] reaction trigger probe-fail 2
Example: Configuring the TCP half open template
As shown in Figure 18, configure a TCP half open template for a feature to test whether the device can provide the TCP service for the AC.
1. Assign IP addresses to interfaces, as shown in Figure 18. (Details not shown.)
# Create a TCP half open template named test.
<AC> system-view
[AC] nqa template tcphalfopen test
[AC-nqatplt-tcphalfopen-test] destination ip 10.2.2.2
[AC-nqatplt-tcphalfopen-test] reaction trigger probe-pass 2
[AC-nqatplt-tcphalfopen-test] reaction trigger probe-fail 2
Example: Configuring the UDP template
As shown in Figure 19, configure a UDP template for a feature to perform the UDP operation. The operation tests whether the AC can receive a response from device.
1. Assign IP addresses to interfaces, as shown in Figure 19. (Details not shown.)
# Create a UDP template named udp.
<AC> system-view
[AC] nqa template udp udp
[AC-nqatplt-udp-udp] destination ip 10.2.2.2
[AC-nqatplt-udp-udp] destination port 9000
[AC-nqatplt-udp-udp] reaction trigger probe-pass 2
[AC-nqatplt-udp-udp] reaction trigger probe-fail 2
Example: Configuring the HTTP template
As shown in Figure 20, configure an HTTP template for a feature to perform the HTTP operation. The operation tests whether the NQA client can get data from the HTTP server.
1. Assign IP addresses to interfaces, as shown in Figure 20. (Details not shown.)
# Create an HTTP template named http.
<AC> system-view
[AC] nqa template http http
# Specify http://10.2.2.2/index.htm as the URL of the HTTP server.
[AC-nqatplt-http-http] url http://10.2.2.2/index.htm
# Set the HTTP operation type to get (the default HTTPS operation type).
[AC-nqatplt-http-http] operation get
[AC-nqatplt-http-http] reaction trigger probe-pass 2
[AC-nqatplt-http-http] reaction trigger probe-fail 2
Example: Configuring the HTTPS template
As shown in Figure 21, configure an HTTPS template for a feature to test whether the NQA client can get data from the HTTPS server (the device).
1. Assign IP addresses to interfaces, as shown in Figure 21. (Details not shown.)
# Configure an SSL client policy named abc, and make sure the AC can use the policy to connect to the HTTPS server. (Details not shown.)
# Create an HTTPS template named test.
<AC> system-view
[AC] nqa template https https
# Specify http://10.2.2.2/index.htm as the URL of the HTTPS server.
[AC-nqatplt-https-https] url https://10.2.2.2/index.htm
# Specify SSL client policy abc for the HTTPS template.
[AC-nqatplt-https-https] ssl-client-policy abc
# Set the HTTPS operation type to get (the default HTTPS operation type).
[AC-nqatplt-https-https] operation get
# Set the HTTPS version to 1.0 (the default HTTPS version).
[AC-nqatplt-https-https] version v1.0
[AC-nqatplt-https-https] reaction trigger probe-pass 2
[AC-nqatplt-https-https] reaction trigger probe-fail 2
Example: Configuring the FTP template
As shown in Figure 22, configure an FTP template for a feature to perform the FTP operation. The operation tests whether the AC can upload a file to the FTP server. The login username and password are admin and systemtest, respectively. The file to be uploaded to the FTP server is config.txt.
1. Assign IP addresses to interfaces, as shown in Figure 22. (Details not shown.)
# Create an FTP template named ftp.
<AC> system-view
[AC] nqa template ftp ftp
[AC-nqatplt-ftp-ftp] url ftp://10.2.2.2
[AC-nqatplt-ftp-ftp] source ip 10.1.1.1
[AC-nqatplt-ftp-ftp] operation put
[AC-nqatplt-ftp-ftp] filename config.txt
# Set the username to admin for the FTP server login.
[AC-nqatplt-ftp-ftp] username admin
# Set the password to systemtest for the FTP server login.
[AC-nqatplt-ftp-ftp] password simple systemtest
[AC-nqatplt-ftp-ftp] reaction trigger probe-pass 2
[AC-nqatplt-ftp-ftp] reaction trigger probe-fail 2
Example: Configuring the RADIUS authentication template
As shown in Figure 23, configure a RADIUS authentication template for a feature to test whether the RADIUS server (the device) can provide authentication service for the AC. The username and password are admin and systemtest, respectively. The shared key is 123456 for secure RADIUS authentication.
1. Assign IP addresses to interfaces, as shown in Figure 23. (Details not shown.)
3. Configure the RADIUS server on the device. (Details not shown.)
# Create a RADIUS authentication template named radius.
<AC> system-view
[AC] nqa template radius radius
# Specify 10.2.2.2 as the destination IP address of the operation.
[AC-nqatplt-radius-radius] destination ip 10.2.2.2
# Set the username to admin.
[AC-nqatplt-radius-radius] username admin
# Set the password to systemtest.
[AC-nqatplt-radius-radius] password simple systemtest
# Set the shared key to 123456 in plain text for secure RADIUS authentication.
[AC-nqatplt-radius-radius] key simple 123456
[AC-nqatplt-radius-radius] reaction trigger probe-pass 2
[AC-nqatplt-radius-radius] reaction trigger probe-fail
Example: Configuring the SNMP template
As shown in Figure 24, configure an SNMP template for a feature to perform the SNMP operation. The SNMP operation tests whether the NQA client can communicate with the SNMP agent on the device.
1. Assign IP addresses to interfaces, as shown in Figure 24. (Details not shown.)
# Create an SNMP template named snmp.
<AC> system-view
[AC] nqa template snmp snmp
# Specify the destination IP address and port number for the SNMP operation.
[AC-nqatplt-snmp-snmp] destination ip 10.2.2.2
[AC-nqatplt-snmp-snmp] destination port 161
# Specify public as the read community.
[AC-nqatplt-snmp-snmp] community read simple public
[AC-nqatplt-snmp-snmp] reaction trigger probe-pass 2
[AC-nqatplt-snmp-snmp] reaction trigger probe-fail 2
Example: Configuring SNMP DCA template
As shown in Figure 25, configure an SNMP DCA template to perform the SNMP DCA operation. In the SNMP DCA operation, the NQA client collects resource usage object values (including CPU, memory, and disk usage values) from the SNMP agent on the device. Based on the collected values and their associated thresholds and weights, the NQA client determines the performance of the device and reports the information to the associated feature.
1. Assign IP addresses to interfaces, as shown in Figure 25. (Details not shown.)
3. Configure the SNMP agent on the device. (Details not shown.)
# Create an SNMP DCA template named snmpdca.
<AC> system-view
[AC] nqa template snmpdca snmpdca
# Specify the destination IP address and port number for the SNMP DCA operation.
[AC-nqatplt-snmpdca-snmpdca] destination ip 10.2.2.2
[AC-nqatplt-snmpdca-snmpdca] destination port 161
[AC-nqatplt-snmpdca-snmpdca] community read simple public
# Specify the SNMP agent type.
[AC-nqatplt-snmpdca-snmpdca] agent-type windows
# Specify the SNMP version.
[AC-nqatplt-snmpdca-snmpdca] version v1
# Specify the threshold and weight values for the CPU, memory, and disk usage object.
[AC-nqatplt-snmpdca-snmpdca] cpu threshold 12 weight 12
[AC-nqatplt-snmpdca-snmpdca] memory threshold 15 weight 15
[AC-nqatplt-snmpdca-snmpdca] disk threshold 19 weight 19
# Configure a custom SNMP object and set its threshold and weight values.
[AC-nqatplt-snmpdca-snmpdca] oid 1.3.6.1.2.1.25.3.3.1.2 threshold 19 weight 19
[AC-nqatplt-snmpdca-snmpdca] reaction trigger probe-pass 2
[AC-nqatplt-snmpdca-snmpdca] reaction trigger probe-fail 2
Example: Configuring the SSL template
As shown in Figure 26, configure an SSL template for a feature to test whether the AC can establish an SSL connection to the SSL server on the device.
1. Assign IP addresses to interfaces, as shown in Figure 26. (Details not shown.)
Configure an SSL client policy named abc, and make sure the AC can use the policy to connect to the SSL server on the device. (Details not shown.)
# Create an SSL template named ssl.
<AC> system-view
[AC] nqa template ssl ssl
# Set the destination IP address and port number to 10.2.2.2 and 9000, respectively.
[AC-nqatplt-ssl-ssl] destination ip 10.2.2.2
[AC-nqatplt-ssl-ssl] destination port 9000
# Specify SSL client policy abc for the SSL template.
[AC-nqatplt-ssl-ssl] ssl-client-policy abc
[AC-nqatplt-ssl-ssl] reaction trigger probe-pass 2
[AC-nqatplt-ssl-ssl] reaction trigger probe-fail 2
Example: Configuring the WAP template
As shown in Figure 27, configure an WAP template for a feature to perform the WAP operation. The WAP operation tests whether the NQA client can connect to the WAP gateway and access a particular URL through the gateway.
1. Assign IP addresses to interfaces, as shown in Figure 27. (Details not shown.)
3. Configure the WAP gateway on the device. (Details not shown.)
# Create a WAP template named wap.
<AC> system-view
[AC] nqa template wap wap
# Specify the destination IP address and port number for the WAP operation
[AC-nqatplt-wap-wap] destination ip 10.2.2.2
[AC-nqatplt-wap-wap] destination port 9201
# Specify the data expected in the response packet to determine a successful NQA operation.
[AC-nqatplt-wap-wap] expect hex-data a11a offset 10
# Specify the destination URL.
[AC-nqatplt-wap-wap] url http://wap.test.com
[AC-nqatplt-wap-wap] reaction trigger probe-pass 2
[AC-nqatplt-wap-wap] reaction trigger probe-fail 2
