H3C Network Adapter Datasheet-6W101
HomeSupportServersNetwork AdapterProduct LiteratureCard DatasheetsH3C Network Adapter Datasheet-6W101
04-mLOM network adapter specifications
04-mLOM network adapter specifications 884.90 KB
The figures in this section are for illustration only.
mLOM network adapter list
Table 1 mLOM network adapters
Model
Specifications
NIC-10GE-2P-560F-L2
2-port 10-GE optical interface mLOM network adapter (SFP+)
NIC-10GE-2P-560F-L2-M
NIC-GE-4P-360T-L3
4-port GE electrical interface mLOM network adapter
NIC-GE-4P-360T-L3-M
NIC-10GE-2P-560T-L2
2-port 10-GE electrical interface mLOM network adapter
NIC-10GE-2P-560T-L2-M
NIC-10GE-2P-560F-L2
Figure 1 NIC-10GE-2P-560F-L2
Ports and LEDs
Figure 2 NIC-10GE-2P-560F-L2 front panel
(1) SFP+ fiber port LINK LED
(2) SFP+ fiber port ACT LED
(3) 10-GE SFP+ fiber ports (2 in total)
For information about the fiber port LEDs, see Table 14.
Technical specifications
Table 2 NIC-10GE-2P-560F-L2 technical specifications
Item
Specifications
Basic properties
Chip model
MAC chip: Intel X722
PHY chip: Inphi WPCS4227C.A2
The X722 MAC chip is on the system board and is available only for G3 servers.
Maximum power consumption
7 W
Bus type
KR ×2
Form factor
mLOM
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3ab, 802.3ad, 802.1q, 802.3az
Available transceiver modules
See "About H3C Network Adapters."
Features
Table 3 NIC-10GE-2P-560F-L2 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Multiple Rx Queues (RSS)
TCP/IP Stateless Offloading
TCP/IP Offload Engine (TOE)
Wake-on-LAN
RDMA
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
·     One asterisk (*) indicates that the feature is not available for VMware ESXi.
·     Three asterisks (***) indicate that the feature is available only for Linux and BSD.
·     Only one port on the network adapter supports NCSI at a time.
Figure 3 NIC-10GE-2P-560F-L2-M
Ports and LEDs
Figure 4 NIC-10GE-2P-560F-L2-M front panel
(1) 10-GE SFP+ fiber ports (2 in total)
(2) SFP+ fiber port LINK LED
(3) SFP+ fiber port ACT LED
Table 4 NIC-10GE-2P-560F-L2-M technical specifications
Item
Specifications
Basic properties
Chip model
PHY chip: Inphi CS4227
15 W
Bus type
10G-KR ×2
Form factor
LP
By default, the network adapter comes with a full-height bracket installed.
Network properties
Connectors
2 × 10-GE SFP+
Data rate
10 Gbit/s
Transmission media
Optical fiber
Duplex mode
Full duplex
Standards
802.3, 802.3ab, 802.3u, 802.3x, 802.3ad, 802.1q, 802.3az
Features
Table 5 NIC-10GE-2P-560F-L2-M features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-GE-4P-360T-L3
Figure 5 NIC-GE-4P-360T-L3
Ports and LEDs
Figure 6 NIC-GE-4P-360T-L3 front panel
(1) RJ-45 copper port LINK LED
(2) RJ-45 copper port ACT LED
(3) 1000Base-T Ethernet ports 1 through 4 (from left to right)
For information about the copper port LEDs, see Table 15.
Table 6 NIC-GE-4P-360T-L3 technical specifications
Item
Specifications
Basic properties
Chip model
PHY chip: Marvell 88E1543-A1-LKJ2C000
3 W
Bus type
SGMII ×4
Form factor
mLOM
Network properties
Connectors
4 × RJ-45
Data rate
1000 Mbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
Features
Table 7 NIC-GE-4P-360T-L3 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-GE-4P-360T-L3-M
Figure 7 NIC-GE-4P-360T-L3-M
Ports and LEDs
Figure 8 NIC-GE-4P-360T-L3-M front panel
(1) 1000Base-T Ethernet ports 1 through 4 (from left to right)
(3) RJ-45 copper port LINK LED
Table 8 NIC-GE-4P-360T-L3-M technical specifications
Item
Specifications
Basic properties
Chip model
5 W
Bus type
1000BASE-X ×4
Form factor
LP
Network properties
Connectors
4 × RJ-45
Data rate
1000 Mbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
Features
Table 9 NIC-GE-4P-360T-L3-M features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
NIC-10GE-2P-560T-L2
Figure 9 NIC-10GE-2P-560T-L2
Ports and LEDs
Figure 10 NIC-10GE-2P-560T-L2 front panel
(3) 1/10Gbit/s autosensing Ethernet ports (2 in total)
For information about the copper port LEDs, see Table 16.
Table 10 NIC-10GE-2P-560T-L2 technical specifications
Item
Specifications
Basic properties
Chip model
PHY chip: Intel EZX557AT2
11 W
Bus type
KR ×2
Form factor
mLOM
Network properties
Connectors
2 × RJ-45
Data rate
1/10 Gbit/s
Transmission media
STP cable
Duplex
Full duplex
Standards
Features
Table 11 NIC-10GE-2P-560T-L2 features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
Figure 11 NIC-10GE-2P-560T-L2-M
Ports and LEDs
Figure 12 NIC-10GE-2P-560T-L2-M front panel
Table 12 NIC-10GE-2P-560T-L2-M technical specifications
Item
Specifications
Basic properties
Chip model
PHY chip: Intel X557-AT2
15 W
Bus type
10G-KR ×2
Form factor
LP
Network properties
Connectors
2 × RJ-45
Data rate
1/10 Gbit/s
Transmission media
STP cable
Duplex mode
Full duplex
Standards
Features
Table 13 NIC-10GE-2P-560T-L2-M features
Feature
Supported
Jumbo Frames
Load Balancing
802.1Q VLANs
Auto-Negotiation
FCoE
iSCSI
SRIOV
VMDq
Wake-on-LAN
RDMA
NPAR
NCSI
NIC bonding
DPDK
IPv6
LLDP
LLDP Pass-through
Remote boot
PXE Boot
FCoE Boot
iSCSI Boot
LEDs
Table 14 SFP+/SFP28 port status LED description
Status
LINK (amber)
ACT (green)
Steady on
Flashing
The port is sending or receiving data.
Steady on
Off
A link is present, but the port is not sending or receiving data.
Off
Off
No link is present.
Table 15 RJ-45 port status LED description
Status
LINK (green)
ACT (green)
Steady on
Flashing
Steady on
Off
Off
Off
No link is present.
Table 16 RJ-45 port status LED description for NIC-10GE-2P-560T-L2 and NIC-10GE-2P-560T-L2-M
Status
LINK
ACT
Steady amber
Flashing green
A 10-GE link is present, and the port is sending or receiving data.
Steady amber
Off
A 10-GE link is present, but no data is being sent or received.
Steady green
Flashing green
A GE link is present, and the port is sending or receiving data.
Steady green
Off
A GE link is present, but no data is being sent or received.
Off
Off
No link is present.
