- 07-System
- 01-Track
- 02-BFD
- 03-NQA
- 04-Basic log settings
- 05-Email server
- 06-Session log settings
- 07-Sandbox log settings
- 08-Threat log settings
- 09-Application audit log settings
- 10-NetShare log settings
- 11-URL filtering log settings
- 12-Attack defense log settings
- 13-Reputation log settings
- 14-Bandwidth alarm logs
- 15-Configuration log settings
- 16-Security policy log
- 17-Terminal identification logging
- 18-Heartbeat log settings
- 19-WAF log settings
- 20-Bandwidth management logs
- 21-Report settings
- 22-Session settings
- 23-Signature upgrade
- 24-Software upgrade
- 25-License management
- 26-Administrators
- 27-Date and time
- 28-SNMP
- 29-Configuration management
- 30-Reboot
- 31-About
- 32-Ping
- 33-Tracert
- 34-Packet capture
- 35-Webpage Diagnosis
- 36-Diagnostic Info
- 37-Packet trace
- 38-Fast Internet Access
| 35-Webpage Diagnosis | 27.19 KB |
Webpage Diagnosis
This help contains the following topics:
Introduction
This feature outputs easy-to-read diagnosis results to help you quickly troubleshoot webpage access failures of internal users. With this feature, you do not need to manually ping servers or display log messages.
· This feature supports only IPv4.
· This feature supports only HTTP webpages.
· Before starting a webpage diagnosis, you must configure security policies to ensure connectivity between the following security zones:
¡ Security zone where the user resides.
¡ Security zone where the Web server resides.
¡ Security zone Local.
Perform a webpage diagnosis
1. Select System > Diagnosis Center > Webpage Diagnosis.
2. Configure webpage diagnosis parameters.
Table 1 Webpage diagnosis configuration items
Item |
User IP |
IP address of the user. |
User VRF |
VPN instance to which the user belongs. |
Webpage URL |
URL that the user accessed, for example, http://www.example.com. |
Webpage VRF |
VPN instance to which the webpage belongs. |
3. Click Diagnose.
4. View the webpage diagnosis result to analyze the failure and resolve the issue.
5. (Optional.) Click Export to export the webpage diagnosis result to a .xml file.
