- 07-System
- 01-Track
- 02-BFD
- 03-NQA
- 04-Basic log settings
- 05-Email server
- 06-Session log settings
- 07-Sandbox log settings
- 08-Threat log settings
- 09-Application audit log settings
- 10-NetShare log settings
- 11-URL filtering log settings
- 12-Attack defense log settings
- 13-Reputation log settings
- 14-Bandwidth alarm logs
- 15-Configuration log settings
- 16-Security policy log
- 17-Terminal identification logging
- 18-Heartbeat log settings
- 19-WAF log settings
- 20-Bandwidth management logs
- 21-Report settings
- 22-Session settings
- 23-Signature upgrade
- 24-Software upgrade
- 25-License management
- 26-Administrators
- 27-Date and time
- 28-SNMP
- 29-Configuration management
- 30-Reboot
- 31-About
- 32-Ping
- 33-Tracert
- 34-Packet capture
- 35-Webpage Diagnosis
- 36-Diagnostic Info
- 37-Packet trace
- 38-Fast Internet Access
| 29-Configuration management | 40.71 KB |
Introduction
A configuration file contains a set of software feature settings for the device. You can save software feature settings to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a server for future use. For example, import a configuration file to multiple devices that share the same configuration.
Configuration types
Factory defaults
Factory defaults are basic settings that came with the device. The device starts up with the factory defaults if no startup configuration files are available.
Startup configuration
The device uses the startup configuration to configure software features during startup. After the device starts up, you can specify the configuration file to be loaded at the next startup. If no startup configuration files are available, the device starts up with the factory defaults.
Running configuration
The running configuration takes effect while the device is operating. It includes unchanged startup settings and new settings. The running configuration is stored in memory and is cleared at a device reboot or power-off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
Configuration backup
Use this feature to back up the running configuration on the device to a local configuration file or to a configuration file on an FTP or TFTP server. The device supports immediate backup and periodic backup.
You can use the backup configuration files for configuration rollback.
Configuration rollback
Use this feature to replace the running configuration with the configuration in a configuration file. The configuration file can be saved on the local device or on an FTP or TFTP server. If you use a configuration file on an FTP or TFTP server for configuration rollback, you must specify the rollback time.
Restoring the factory defaults removes all configurations you have made from the device.
If server-based backup or rollback is used, make sure the device can reach the remote FTP or TFTP server.
Manage the running configuration
Back up the running configuration
1. Click the System tab.
2. In the navigation pane, select Maintenance > Configuration Management.
3. Click Back up current configuration.
4. Configure the configuration backup parameters.
Table 1 Configuration backup configuration items
Item |
Backup type |
Select a location to save the backup configuration files: · Back up to local. · Back up to server. |
Auto backup interval |
Enter the interval for periodic configuration backup. If you do not configure this parameter, the device does not periodically back up the running configuration. |
Max backup files |
Enter the maximum number of backup configuration files that can be saved on the device. After the maximum number is reached, the system deletes the oldest backup file for the new backup file. |
Local backup path |
Enter the directory where the backup configuration files will be saved on the device. The directory must already exist on the device. |
Prefix name |
Enter a file name prefix for backup configuration files. Backup configuration files are named in the format of prefix_serial number.cfg. |
Immediate backup |
To back up the running configuration immediately, select this item. |
Server type |
Select the file transfer protocol. Options include FTP and TFTP. |
Address |
Enter the IPv4 or IPv6 address of the file server. |
VRF |
Select the name of the VPN instance to which the file server belongs. |
Username |
Enter the username for logging in to the file server. |
Password |
Enter the password for logging in to the file server. |
Port |
Enter the port number of the file server. |
Backup path |
Enter the path where the backup configuration files will be saved on the server. |
5. Click OK.
Roll back the configuration
3. Click Configure rollback.
4. Select the rollback file location:
¡ To use a configuration file saved on the local storage device, select Local device.
¡ To use a configuration file saved on a remote file server, select Server.
5. Roll back the configuration or schedule a rollback:
¡ If you are using a local configuration file for rollback, specify a local directory in the Location field, click Access to the file to show configuration files in the directory, identify the configuration file you are using, and then click its Roll Back link to roll back the configuration.
¡ If you are using a configuration file on a remote server for rollback, configure the parameters as shown in Table 2 to schedule a rollback, and then click OK.
Table 2 Configuration items for server-based rollback
Item |
Server type |
Select the server type. Options include FTP and TFTP. |
Address |
Enter the IPv4 or IPv6 address of the server. |
VRF |
Select the name of the VPN instance to which the server belongs. |
Username |
Enter the username for logging in to the FTP or TFTP server. |
Password |
Enter the password for logging in to the FTP or TFTP server. |
Port |
Enter the port number of the FTP or TFTP server. |
Rollback file path |
Enter the path where the rollback configuration file is saved. |
Default rollback file |
Enter the name of the default rollback configuration file. If you do not specify a rollback configuration file, the default rollback configuration file will be used. |
Rollback file |
Enter the name of the rollback configuration file. |
Rollback date |
Set the date on which the configuration rollback will be performed. |
Rollback time |
Set the time when the configuration rollback will be performed. Setting a rollback time is required. |
Cancel scheduled rollback |
Select this option to cancel the rollback schedule. |
