07-System
HomeSupportSecurityH3C SecCenter CSAP-NTAConfigure & DeployConfiguration GuidesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Web-Based Configure Guide-6W60007-System
21-Report settings
21-Report settings 31.15 KB
Report settings
This help contains the following topics:
·     Introduction
¡     Report subscription
¡     Email server
·     Configure report settings
¡     Configure report subscription
¡     Configure the email server
Introduction
Report subscription
After you add a subscriber for a report, the report will be sent to the subscriber through email.
For the subscribers to receive the report, you must configure the email server.
The device sends the daily report during the least busy hours (1 a.m. to 5 a.m.). The monthly report of the previous month is sent on the first day of each month.
The report subscription feature supports the following types of reports:
·     Summary report—Displays summarized service statistics collected over a time range.
·     Comparison report—Provides comparison of service statistics collected over two time ranges that contain the same number of days.
·     Intelligent report—Provides intelligent analysis of users' work efficiency, data leakage, and turnover risks based on their network access behaviors.
·     Comprehensive report—Illustrates the overall device operational and network security status based on analysis of critical service statistics.
Email server
To configure the device to send reports to the specified email address or enable the report subscription feature, you must configure the email server.
1.     Click the System tab.
2.     In the navigation pane, select Report Settings > Report Subscription.
3.     Click Add for a report.
4.     Enter the email address of the report subscriber and select a language for the reports.
2.     In the navigation pane, select Report Settings > Email Server.
3.     Configure the email server.
Table 1 Email server configuration items
Item
Email server address
Enter the IP address or host name of the email server.
Sender address
Enter the email sender address.
DNS server IP
Enter the IP address of the DNS server.
Identity authentication
Select Enable to enable email client authentication.
Enable email client authentication as required by the email server.
Secure user credential transmission
Select Enable to enable secure transmission of user authentication credentials.
Username
Enter the username for connecting to the email server.
Password
Enter the password for connecting to the email server.
4.     Click Apply.
