07-System
HomeSupportSecurityH3C SecCenter CSAP-NTAConfigure & DeployConfiguration GuidesH3C SecCenter CSAP-NTA Probe Appliance Series Comware 7 Web-Based Configure Guide-6W60007-System
15-Configuration log settings
15-Configuration log settings 12.86 KB
Introduction
This feature logs operations that administrators perform on the device.
The device can create a dedicated configuration log buffer and a separate log file to store configuration log messages. For the device to do so, click the System tab, select Log Settings > Basic Settings, and then select the Output to log buffer option on the Syslog page.
The device saves configuration log messages to the log file buffer before writing the messages to the log file in bulk. After writing the log messages in the log file buffer to the log file, the device clears the log file buffer.
The size of a log file is limited. After the limit is reached, the device replaces the oldest log messages with new log messages.
